View Full Version : 4.6 (Modular) Mustang
  1. cracked intake manifold
  2. Help with choosing gears and what you think my problem is, lol.
  3. procharger safety
  4. throwing codes p0506 help
  5. brownsh radiator coolant, do i have a blown head/intake on my '96 mustang gt?
  6. evap control code
  7. Lifter noise
  8. need stock front springs for a 96
  9. supercharger
  10. Electrical problems
  11. lincoln 32v?
  12. Header Question
  13. May have botched up my fuel lines today...whoops
  14. pulling to the left
  15. motor knocking
  16. udp?
  17. Intercooler Setup Help
  18. my new motor problems!!
  19. Sluggish....need help.
  20. should i swap my springs?
  21. help with dtc check engine codes
  22. rpm / gear question
  23. What the heck kind of alarm system do I have?
  24. Turning the wheel, scraping pads
  25. ?????WHAT SIZE?????
  26. brand new 02's still thows codes
  27. Spark plugs??
  28. The Official Suspension Guide
  29. Help, I lost a ton of acceleration when i put my CAI on!
  30. Changing brake pads for the first time.
  31. cooliant in spark plug well
  32. Nitrous plugs
  33. engine
  34. 5.4 Lightning Swap Begins
  35. How can I tell if I have the premium sound system
  36. PLEASE HELP!!!
  37. TwEECer, Quarterhorse, or Megasquirt?
  38. Power Mod(s)
  39. Flowmaster and X pipe
  40. cam ?
  41. 5w-20 vs. 5w-30??
  42. A/C Problems? Afraid of stalling
  43. transmission
  44. A/C question on 96 GT
  45. EVAP & Fuel Pressure Problem
  46. Production numbers for 1998 Gt
  47. Clutch Cable Problem
  48. (2) DTC Codes, PCM Fuse Blown, Help Needed (03 gt) 50k mi
  49. Rebuild specs
  50. Noise from rear suspension
  51. Tremec tko 500 What clutch?
  52. is a 117k too much??
  53. 1996 cobra killswitch
  54. Horrible vibration
  55. 2002 Mustang GT rear wheel squeaking
  56. 2000 GT engine missing
  57. Turning off CEL
  58. brakes
  59. car wont go into gear
  60. Any tricks???
  61. New Gears?
  62. O/R h with macs
  63. kjgh
  64. Brakes making noise!!!
  65. Manual Trans Temp gauge
  66. supercharger question
  67. Brake rotors and pads
  68. winding down noise
  69. AEM Bruteforce CAI
  70. 98 GT Cylinder 7 misfire help
  71. PI-heads+blower on stock bottome end??
  72. abs light, battery light and failed gauges after Intercooler!~ help
  73. BBK SPRINGS
  74. 99 gt ignition sequence Help asap
  75. Whining gears
  76. Bullitt Intake Swap High Idle
  77. Auto tranny problems
  78. Removing Oil Pan.
  79. HOOD PIN HELP 99-04
  80. boost limits??
  81. Need Electrical Guru, Gauge Cluster Problem...
  82. Top starter bolt? Where?
  83. which would be More reliable?
  84. uh oh...
  85. 2001 Clutch install Guide
  86. welp its not the egr valve?????
  87. How to check 02 Sensors?
  88. Mod suggestions???
  89. Spark plugs backing out
  90. Anyone running J&M LCA's?
  91. NEW BUILD-not impressed so far.
  92. Strut bar metal
  93. Silver Mustang w/ 03 Cobras
  94. Welding torque boxes
  95. What to get?
  96. tinted lights
  97. 2000 GT, 77k miles,5 speed, feels sluggish lately, bucking at low speed.
  98. Going to install 4.10's myself.. need help
  99. 4.6l engine how to lift it out?
  100. Burnt Oil Smell
  101. Is the new clutch cable supposed to be so springy?
  102. need help?
  103. VACUUM HOSE QUESTION
  104. Car is leaking anti-freeze on backside of the engine - need input
  105. annoying window rattle?
  106. Replacing bearing, what needs to be done?
  107. Oil Pressure Sensor - 2000 GT
  108. Please HELP!! SERIOUS problem!!!
  109. Need Clutch Advice
  110. Spring Install
  111. bbk shorty header install
  112. Staggerd no understeer?
  113. HID help please?
  114. What is this?
  115. 315 rear tire
  116. Convertible motor removal and fill
  117. CENTER CONSOLE
  118. Centerforce clutch + "gear crush"?
  119. slight rattle from engine when cold?
  120. egr valve and random cylinder missfire HELP!!!
  121. trans filter?
  122. Clutch help needed
  123. 1996 Lincoln MK8 EEC Pin Out
  124. P0340
  125. A newbie here, with bad problem
  126. Am I missing something here? Thoughts?
  127. rear end leak
  128. 96-98 HyperTech Power Programmer
  129. backfireing
  130. Nobody has installed this before?
  131. rebuilding sohc?
  132. SLP loudmouth question
  133. Weird sucking sound
  134. car shuts off
  135. new mustang owner wit electrical problem
  136. Summit shifter
  137. Cigarette adaptor plug not working after shifter install
  138. 32v DOHC licoln continental motor
  139. Oil in charge pipe?
  140. Sway Bar Sizes? Cobra Roush Stock?
  141. Exhauast clamps vs. Welding
  142. speed cal gears
  143. I have toilet noises under the hood!!
  144. runs funny with the hvac on?
  145. Cheap turbo
  146. Help with a little problem
  147. Help! The threads came out with my oil filter!!?!
  148. Orange fan/radiator indicator light??
  149. LOUD backfire, now it wont idle
  150. used headers
  151. Where does this go???????
  152. Bad Piston?
  153. Trouble with low revs
  154. help
  155. So if it isn't the PCV valve, what is it?
  156. 4.6 Thunderbird, Mustang Performance?
  157. Automatic trans help
  158. minor body panel help!
  159. RPMs jump when car in park (video inside)
  160. camber bolts or camber plates?
  161. Pink injectors?
  162. Engine Swap: 1985 GT HO engine into a 98 GT frame.
  163. speedometer calibration
  164. stock c/c plate adjustment with bolts
  165. $1200 for cams, how much gain can i expect?
  166. v6 and Cobra Sway Bars?
  167. Looking at a brake upgrade
  168. Plug change and running worse w/code????
  169. Timing cover issue with teksid
  170. whats my next mod?
  171. Will this work for installing X2 balljoints?
  172. Which One???!!
  173. Couple Questions
  174. Remove serpentine belt?
  175. a/c question
  176. MSD Ignition
  177. Main odometer drive gear replacement
  178. Trying to find a a driver window
  179. 2 codes what do they mean?
  180. running issues with my GT
  181. 99-04 auto to 5 speed swap wiring questions
  182. bad idle and bucking
  183. Wierd Problem
  184. ported npi heads?
  185. Brake Caliper Won't come off!!! ASAP!!!
  186. front springs with iron block?
  187. MSD or Ford Racing plugs.. or another brand?
  188. coil help
  189. Stiff clutch
  190. Arrgh, Suspension Data Overload
  191. Help!!!
  192. hid info needed
  193. arc in plug wire
  194. 02 gt has Idle problems.........
  195. fog lights as running lights
  196. 99-04 4.6 Engine Swap
  197. Modular Engine Swaps for Classic Mustangs
  198. N/A build 4.6s
  199. help P0230 code
  200. IAC Hose Canister - what does it do?
  201. HVAC only blows out threw defroster?
  202. shifter questions
  203. Need some knowledgable UCA/LCA help
  204. How do I wire my fog light?
  205. 99-04 GT Convert springs?
  206. no brake lights.
  207. need help from the pros
  208. 4R70W overdrive problem
  209. A/C Line question?
  210. Squeaky rear of car solved
  211. sway bar end link
  212. MACH 1 Dead Pedal
  213. exhaust question
  214. tubular k member 96 gt
  215. 8.8 housing question
  216. 2000 saleen s281 ball joint
  217. Drivers window out of adjustment
  218. 2000 saleen s281 guage cluster not lit
  219. Is this supposed to be bent?
  220. Fuel Injector Problem
  221. Help! Need Help on a Dead Car!
  222. Help please, Air Intake
  223. Help with COP's
  224. newb with questions on ram intake
  225. Engine running crappy.
  226. cylinder head swap
  227. Strange idle issue
  228. Car falls on its face...
  229. help throwing code 0320
  230. Vacuum leak question?
  231. Cragar SS wheels and tires to fit on a 04 Gt?
  232. Bad lucky with car ;[
  233. need new maf
  234. mach 1
  235. when stopping, rpms drop/motor shuts off
  236. Pulleys and Cams
  237. Some problems with my 96 GT???????
  238. Help with interior lights
  239. Tach Help
  240. pi head swap help
  241. Need part for car, but don't know what it is.
  242. Rpm dropping when stopping
  243. o2 sensor HELP ME PLEASE
  244. GOOD SPRINGS?
  245. cobra calipers?
  246. tail lights question
  247. what to do next?
  248. whats the deal?
  249. Bank 1 lean
  250. A/C vent rattle
