View Full Version : 4.6 (Modular) Mustang
  1. Missing at high rpm's
  2. Problem starting the car
  3. 390ci Swap (will it work?)
  4. Rear axle seal and pinion seal leaking
  5. Power steering problems need some advice
  6. Codes P0443 and p1451
  7. ABS Issue
  8. Not your normal brake question...
  9. Stretched Clutch Cable?
  10. 2001 GT ECU Location?
  11. Anybody have Fore fuel rails on thier 4.6?!
  12. safest way to up HP?
  13. Smoothest shifting
  14. What should I know about windshield replacement?
  15. Tubular K-Member questions
  16. Replacing headlamp assembly?
  17. Plugs look a little ashy/white. Pics..
  18. Hard Start
  19. Hood Scoop Decals
  20. 04 mustang gt weird sound
  21. Squeaking when powering down
  22. New Edge suspension questions
  23. sick of 4.6.. is there a 5.4 engin swap?
  24. need some info on supercharging
  25. Please help! 3.8 to 4.6sohc swap,no spark
  26. Help with engine code....
  27. 1997 GT suspension and another question
  28. Active Hood Scoop
  29. Yet More Brakes
  30. Exterior Door Pillar Trim Removal
  31. sct issues
  32. billstein bts struts and MM cc plates, what bushing if any?
  33. quick question
  34. how to better my 60 footer
  35. HELP! Cannot Attach Heater Core Hoses...
  36. Squeaky rear end?
  37. Is it a myth?
  38. 01 running rough and knocking need help
  39. OPINIONS??
  40. Opinions on gears
  41. Steeda adjustable cable & Quadrant owners...
  42. desperate for advice
  43. please help guys
  44. parked 3 wks-> washed engine-> miss fire
  45. Cold air intake questions.
  46. Getting Rear end done told me i needed clutches?? do i need these?
  47. How much power???
  48. DEEP DISH RIMS....WILL THEY FIT UP FRONT?
  49. TACH TROUBLE
  50. Low fuel pressure at rail
  51. front slitter
  52. setting up an autometer wideband
  53. Rattle or ping at WOT
  54. 01' SUPERCHARGED GT FOR SALE!!
  55. new intake manifold
  56. 78mm too much?
  57. Oil leaking under the procharger?
  58. Rising and Falling RPM's
  59. bad noise!
  60. COP fuel pump what?
  61. clutch question?
  62. What cams would be good for my set-up?
  63. procharger help
  64. po171--174 vacum leak?
  65. idler pulley
  66. A/C compressor cycles on and off
  67. car broken into...now problems.
  68. what is p0606
  69. spark plug help ASAP
  70. bottoming out under hard cornering...help
  71. Replacing wheel studs
  72. a/f ratio gauge...?
  73. 96 Cobra / GT Fog Light Switch
  74. 96 Cobra starting issue after gauge install??
  75. KYB GR2 Shocks/Struts
  76. charging system
  77. VIDEO of Rattle..
  78. blown out spark plug, what size helicoil?
  79. where's the best place to order a Tri-Ax from?
  80. 99-04 gt auto hellion single turbo help?
  81. Need help!!! 3 DTC Codes
  82. p0511 code thrown... help diagnostics!!
  83. Coilovers Vs Fox 4cyls
  84. Tapping pin? 03 GT
  85. Squeeky noise coming from the AC compressor
  86. help melted a wire!!
  87. Bleeding the Master?
  88. catalytic converter question
  89. Exhaust problems with offroad pipe
  90. header question
  91. Got a supercharger? I need a favor!
  92. need help asap!
  93. starter killing battery?!
  94. REPLACING SERPENTINE BELT
  95. 99 GT 4.6 Head removal help
  96. Please help with Alternator Prob
  97. Engine Squeels during hard shift.
  98. Transmission leaking out the back!
  99. boost and plug gap
  100. 96 front bumper cover removal
  101. Exhuast Clatter? Annoying Noise
  102. will it run??
  103. replacing lifters / lash adjusters.
  104. Dual Stage Rev Limiter
  105. s197 rear end in a new edge?
  106. REAR BLACKOUT DECAL ON SALE
  107. Hypothetical Question
  108. stang runs like crap
  109. 2001 Saleen WONT START - Please HELP
  110. Weird Problems, no crank sometimes...
  111. What is the best way to get 400+hp?
  112. Is this compatible?
  113. 04 mach1 miss with ac on
  114. Coilover struts and shocks
  115. Anyone using a standalone EMS?
  116. ac blows.. but its hot air.. out of freon maybe?
  117. 1994-1998 Ford Mustang Post Fox Body Pre New Edge SN95 History article
  118. which midpipe for pypes LTs
  119. Thread size for oil outlet (96 Cobra) *Pics inside*
  120. Question on Grill Delete kit for 04 GT
  121. HELP! Dome light wiring
  122. Car not shifting into any gear...
  123. How to change Auto trans to manual? 98 mustang GT
  124. window wont roll up
  125. !@#$% Rear Brakes
  126. transmission porblems on a 2000 gt
  127. freshen up transmission
  128. Suspension for handling
  129. Sticking gas pedal problem
  130. Thermostat Housing Cracked
  131. Odometer broke. Options?
  132. Pilot Bearing going bad?
  133. Springs
  134. HELP! Suspension install issues.
  135. dead Battery???? or wiring problem???
  136. Tuner Q's
  137. Is there a Torque Converter for a 2004 Gt???
  138. 2003 mustang gt
  139. Can a bad engine computer burn up an alternator?
  140. anyone use federal mogul products?
  141. Tremec 3650
  142. Tranny problems... any help ?
  143. Tunning Advice/question.
  144. Wouldn't a 4prong spark plug be better than 2
  145. About to upgrade the fuel pump?
  146. Antenna problem revisited (with pictures)
  147. Supercharger kit help
  148. Eh.. Need Brakes.. Help
  149. gear whine
  150. Cowl panel ?
  151. Marh Pulley
  152. first start of the morning?
  153. Bottom line for correct fluid for TR-3650?
  154. 98 Cobra '01 engine swap?? HELP!
  155. spec clutch come with pilot bearing?
  156. I got nitrous , and want opinions
  157. restore oxidised paint?
  158. PI Intake swap kit?
  159. Will these wheels fit? are they a good deal
  160. Fed up with my gauges
  161. Another problem... I think?
  162. Stock Valve Train Support 480-500 rwhp?
  163. two quick questions...help!
  164. Trans removal with lts
  165. Squealing?
  166. previous LT header install post pics of engine suspended
  167. 255lph from Americanmuscle
  168. brake preference?
  169. Help with heads and cams
  170. Grinding noise
  171. NEED SOME SERIOUS HELP! Rear Mounted Cobra
  172. overhaulllll
  173. Auto to Manual Swap
  174. Please Help
  175. Odd starting issue
  176. Mach 460
  177. Building up for Kenne Bell
  178. iat sensor problems and p1400 code
  179. really quick question about oil in 02 gt
  180. 3650 3rd gear shot help!!!!
  181. Car Is Throwing Codes
  182. supercharger oil
  183. what would it require to put an 03 blower on a 96 2v 4.6
  184. Do edge bumpers and hood fit SN95's
  185. More Vacuum and Hesitation
  186. CMS Stage 1 or 2
  187. How to tell which motor is in car?
  188. mac exhaust
  189. 97 GT - Power Brake Booster
  190. blown engine
  191. Hesitating and Cutting Out
  192. cobra r wing
  193. SCT X3 powerflash problems..PLEASE HELP
  194. Where to get matte black stripes?
  195. cutting springs
  196. A/F gauges?
  197. Sniper Special Forces & Commando ?
  198. Mishimoto Radiator Fit problem
  199. spring suggestion
  200. Nitrous Window Switch
  201. 1965-2004 Ford Mustang Cobra History article
  202. no fire to injectors
  203. what kind of suspension is my cobra stock?
  204. maintenance
  205. The build has started, few more things
  206. Will 275/40-R17 fit on a 17X8 Rim??
  207. Needs some advice on purchasing a 1996 gt
  208. windshield wipers
  209. Automatic to Manual Swap
  210. 255/45/17 tire pressure
  211. speed cal
  212. Cooling System Emergency...Please Help!
  213. Just installed Accufab 75mm TB....2 things
  214. QUESTION ABOUT A CONVERTIBLE !!
  215. Upgrades/replacements...
  216. should i bump timing?
  217. pressure test?
  218. 99 Gt with V3 Si Dynoed today..
  219. Headlight Bulb Retainer Ring
  220. Cheapo AutoZone rotors
  221. Anyone know where i can find this?
  222. Rear End Gears
  223. 5.0 to mach 4.6
  224. opinions on engine swaps in price range
  225. tubular k member problems
  226. Brake swap
  227. Steeda Clutch Cable install
  228. Annoying squeek from rear
  229. 400 hp n/a
  230. cobra brake question
  231. plenum or not (noob)
  232. Just got my 02 gt want more low end power
  233. Headers
  234. Still got a misfire...
  235. Odyssey drycell battery
  236. 4.6L 2v PCV
  237. slight misfire?
  238. 04 cobra supercharger on a 98 cobra
  239. cracked intake manifold
  240. Help with choosing gears and what you think my problem is, lol.
  241. procharger safety
  242. throwing codes p0506 help
  243. brownsh radiator coolant, do i have a blown head/intake on my '96 mustang gt?
  244. evap control code
  245. Lifter noise
  246. need stock front springs for a 96
  247. supercharger
  248. Electrical problems
  249. lincoln 32v?
  250. Header Question
