View Full Version : 4.6L V8 Specific General Discussion
  1. LT headers and o/r x mid pipe
  2. Which mid-pipe?
  3. A/C Slowing down upon long drive? '08 GT
  4. Flowmaster "classic" axlebacks
  5. Datalogging - what does the "Linear Knock Sensor 1 Diagnostic Parameter" PID mean?
  6. BBK Throttle Body
  7. Quick Hot Rod Cam / SC question
  8. Well...It's more then a Paper Weight...!!!
  9. Ram Air Hood vs CAI?
  10. hey im back!!!!
  11. SCT/JLT 91 octane tune = ping. AmericanMuscle wants me to replace stock plugs?
  12. where to look up engine codes ?
  13. Mustang Newb with Newb Questions.
  14. Wide band sensor location?
  15. A "Stage" and a Boss Mustang question...
  16. Intake Spacers??
  17. So, I let my mom and dad borrow the Cherry Bomb this weekend
  18. Underdrive Pulleys
  19. Streetfighter installed!
  20. Fixed my water leak! BUT I have a SJB issue...
  21. strange problem need input
  22. rev limiter goes flat
  23. The Chevy Killer Rises Again!!
  24. 400 hp whipple questions
  25. Don't like your dyno numners? - "Just find another dyno"
  26. Transmission Problems
  27. Gear question for cams
  28. 4.6L tune question
  29. Comparison, Hurst vs MGW shifters
  30. Is BamaChips still in business?
  31. New Mustang owner
  32. cams from hell!!
  33. 2005 black GT,
  34. Stock 09 GT Help a Noob please
  35. mechanical boost gauge w/ SOS pillar
  36. is my fuel pump going bad?
  37. Flowmasters YES or NO for $175.00
  38. DRs and new wheels
  39. What pistons did you use on built motor?
  40. questions!!
  41. K-Member
  42. HALLEULJAH! ITS FIXED!
  43. BBR stage 2 cams
  44. whipple noise
  45. I JUST GOT SMOKED!!!
  46. Look @ your car & tell me where this connects
  47. My New Roush, Have Questions!?!?!
  48. OEM wheel studs with 1/4" spacers
  49. Bye Bye straight 6
  50. 4.6L longevity under forced induction
  51. major head issue,what to do,need help!!
  52. HT0 spark plug help
  53. Whipple HO Aluminum Intercooler Coolant Tank
  54. Anyone installed high flow feul rails on a KB?
  55. Manual Trans. oil change??
  56. need some help
  57. First time to the track... 11.6's at 117 mph w/ Edel E-force
  58. Satisfied for now
  59. rattling
  60. 2005 GT Sudden problem with WOT acceleration. HELP!!
  61. Meziere Electric Water Pump Group Buy
  62. need direction for swapping a tr6060
  63. First Oil Change for my baby
  64. fitment?
  65. "clunk" from drive shaft or pumpkin?
  66. Help Weird Problem with Electrical.
  67. Break-in suggestions
  68. Granatelli GM-410040 CAI
  69. Bolt on performance
  70. Anyone ever found top end on their stock GT?
  71. Blown Fuse to Main PCM
  72. What to get from Brenspeed?
  73. Cams or Longtubes?
  74. take a look
  75. Is this a problem
  76. TPS question
  77. McLeod RST installed
  78. Finally! Time to order... Edelbrock/Saleen?
  79. Ideas for a year from now
  80. 2 problems with my GT
  81. cams and idle
  82. Roush underdrive pullies opinions wanted
  83. Roushcharger info
  84. How much did stripes cost on an 05 GT?
  85. So my Paxton Novi 2200...
  86. New parts ordered!
  87. which S/C...
  88. Drag Radials
  89. Spark Plug Change was a .....
  90. Newbie mod questions
  91. Shane's E-Force Install Thread
  92. FRPP 62MM TB
  93. O2 Sensor 11% Higher...Why ?
  94. Pypes X pipe
  95. SCT live wire
  96. Gas and Octane Fail?
  97. Manual v. Auto
  98. back again...(new pics)
  99. horse power
  100. Faulty fuel and temp gauges
  101. SCT
  102. Bypass valve
  103. Problems with the car I'm buying
  104. Installed a Pacesetter o/r H-pipe on Roush 427R
  105. Coil On Plugs & Whipple HO
  106. Best Engine Oil Choice While Supercharged?
  107. Racing Myself
  108. 2006 GT offroad x-pipe
  109. Whipple Install Progess
  110. Air/Fuel ratio gauge
  111. What do i do?
  112. thumper cams
  113. Raising Compression Ratio?
  114. E-force ordered
  115. Performance Chip
  116. Shaker or Hood scoop
  117. RWHP Estimate
  118. Please Help!!! Supercharger choice
  119. Rally Gauges
  120. 2009 Alternator and Saleen S/C ????
  121. Long Tube Header Install???
  122. FRPP Hotrod cam owners, I need help......
  123. Boost-A-Pump vs. GT500 fuel pump??
  124. A Friend just got a GT500... how fast?? compare to Blown GT??
  125. Is my mustang missing something?
  126. quick nitrous question?
  127. question about KB boost a pump
  128. Tune question....
  129. Build is just about done
  130. supercharger help!!
  131. Started slave cylinder shim install
  132. p0053-p0054
  133. MMR stage two heads
  134. P1237 Fuel Pump Secondary Circuit Malfunction?
  135. Oil in my intake manifold?
  136. Battle of the quiet axlebacks
  137. Is this right?
  138. 4.6 3V heads
  139. SOS Pillar or Shelby Dash Gauges
  140. exhaust problems
  141. Does my side exit exhaust affect me for a turbo setup
  142. Cams / Power Level
  143. T3/T4 universal turbo kits
  144. Need some opinions on exhaust
  145. New From AZ
  146. Vortech V3 non-intercooled times...
  147. Shim or Slave Cylinder?
  148. What performs better in Texas?
  149. HELP!! 2005 mustang gt noise
  150. Running lean
  151. Traction Control ON or OFF
  152. Is the MPG onboard Computer Accurate?
  153. what IS that doohikey for???
  154. Tuner options
  155. I need help Please
  156. TCS off by default
  157. How often do you change/clean your CAI filter?
  158. 93 Octane - No Tune
  159. Wiring an AEM gauge for datalogging with the Xcal3?
  160. Big Boost Phase 2: GT500 Fuel Pump Install
  161. Anyone actually switch from 3.31's to 3.73's? Opinions!
  162. Best Price on a Whipple HO
  163. Smell gas under the hood after Roush Supercharger Installation
  164. Pickin it up tomorrow
  165. How mush PSI?
  166. redline?
  167. Bassani Race vs Bassani Street
  168. Heard a scary noise
  169. How will this sound?
  170. CMDP - no economy version?
  171. Need some advice
  172. 91 octane with 93 tune?
  173. Supercharger time ... help pick
  174. S & B Cold Air Intake
  175. email tune for diablosport predator question
  176. Can't get a dyno test.
  177. Kenne Bell Pulley size vs Boost, who's running what?
  178. Did I just mess up?
  179. Roush Stripe Catastrophe
  180. Looking for clutch opinions.
  181. Did my Steeda UDP's work?
  182. lookin for 300-325whp..... what do i need in mods!
  183. $1500 to spend, what combos will help my ET's the most
  184. My 06 Roush For Sale
  185. Spark plug temp ranges
  186. Will I have any issues with these tires?
  187. 8/29-Tampa-Poker Run-S&R Performance!!!
  188. Started Intercooler install
  189. Looking at a 2005 GT..issues??
  190. HELP!! Car stuck in Limp-Mode... codes 2112 & 2104 keep coming back!!!
  191. Line Locks
  192. Panhard adjustment before or after alignment?
  193. SOS Gauge pods
  194. Adjusting the Timing
  195. To upgrade, or TO UPGRADE? ($10k)
  196. What to Get and Where to Get It...?
  197. exhaust popping/backfire
  198. 2005 GT Backpressure?
  199. Appreciate feedback from Spec 3+ Clutch users
  200. have questions...need answers!
  201. Help!
  202. 3.90 or 4.10 for an 06 GT Auto!!!!!
  203. searching for boost
  204. If your getting in the 12s help me
  205. $2k to spend...what should I do next?
  206. +12v switched source that maintains power during cranking?
  207. Lowering of car causing exhaust vibration?
  208. Whipple & Steeda UDPs / GT500 pumps
  209. quality of gears
  210. Alternator & P0340 code
  211. Buying a Mustang, need advice
  212. Next Mod?
  213. strut tower brace with shaker
  214. 3V Cam Comparison
  215. Where to go now?
  216. Rebuilt Engine Pics
  217. Breathers......
  218. 3:73 or 3:90 gears
  219. Timing chain noise
  220. TO WELD OR NOT TO WELD?
  221. "squeaking" noise with turning
  222. Rebuilding my rear end i need help!!!
  223. What size belt to run with whipple 3.25" pulley?
  224. Mid mufflers
  225. Dyno Tuning in Colorado?
  226. Hypothetical Question about Cats and Emissions...
  227. Need advice on purchase
  228. Burnout Discussion
  229. GT Tuned - Need to Change Plugs?
  230. Moroso Axle Backs
  231. Cam Questions
  232. 20" Wheels 20x8.5 Non-Staggered (will I be happy w/ Non-Staggered?)
  233. Overjealous motion sensors?
  234. LT headers vs Shorty headers........
  235. Kooks LT & Mickey Thompson DR Group Buy
  236. Stiff clutch
  237. Surprisingly good dyno run Whipple H.O.
  238. What are Charge motion Delete plates?
  239. Nitto 555r launch rpms???
  240. bleeding slave on a 2006 mustang/??
  241. Another exhaust dilemma
  242. That old mustang sound
  243. next mod??
  244. Question's and AM vs Brenspeed tuning
  245. Biggest rear tire for stock gt
  246. Mods for my 07 GT
  247. 4.6L 3v bottom end strength with supercharger?
  248. Alternative to a V2 Intercooler?
  249. Opinions on catted X-pipes...
  250. 2005 Mustang GT Tuner Issue
