View Full Version : 4.6L V8 Technical Discussions
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13
  1. Hesitation when accelerating...
  2. New gear company to consider?
  3. How does an exhaust leak sound like?
  4. Supercharger Problems
  5. Paxton / Vortech Owners - Have you seen/used this?
  6. Bama Tune Observations
  7. 4.6L 3v engine ?
  8. BMR = Headache.
  9. Tune & Exhaust note?
  10. Procharger Power Claims
  11. My Automatic Stalled
  12. Ford Plugs for the new 4.6 are Horrible!
  13. Who has the best tunes?
  14. seat problem
  15. MGW installed!!
  16. Help! Broken Spark Plug!
  17. 2008 GT - Spark Plugs a problem?
  18. Reuse the Passenger Airbag Cover??
  19. 05 GT w/no mufflers
  20. Exhaust I Acting/Sounding Peculiarly
  21. CAI + Tune = Wow
  22. HELP!
  23. 93Octane with a S/C 91 Tune?
  24. Steeda UDPs - Install
  25. Paxton Nova 1200 vs Vortech V2 Si
  26. Check Engine Light But No Codes!?
  27. resonators w/stock mufflers?
  28. Best Friends: Gears and Gas Mileage
  29. Catted X or H
  30. Why are my plugs fouled after JLT & Brenspeed tune?
  31. OK, WHAT'S THE NEXT MOD????
  32. New '08 Owner - Please Don't Kill Me
  33. X/H-pipe question...
  34. Turbocharger question
  35. P1000 then P0430 then P1000
  36. ticking sound at idle...
  37. Bucks in 1st gear when cold?
  38. Supercharger With The Most PSI?
  39. Kenne Bell Canned tune, can I modify the tune?
  40. O2 Sensor Eliminator for offroad X-Pipe
  41. Steeda UDPs - Yea or Nay?
  42. Starting out
  43. On tire mark
  44. Paxton 2200 H.O. Kit
  45. DTC P0451
  46. SCT adjustment for JLT CAI
  47. Threw Codes P0607 & P1000
  48. C&L CAI Qusetion? Street Tune or Racer Tune
  49. brake size
  50. is this normal??
  51. battery cable
  52. p2104 and p2111 codes...?!?!?!?!
  53. EXHAUST emitting moisture in the A.M.
  54. C&L Manifold
  55. Loud Ticking under Acceleration
  56. DTC code help !!!!
  57. Is raising the Rev Limiter/shift points a bad ID!
  58. 2005 Mustnag GT Trouble Starting
  59. Odometer main drive gear installation
  60. Does the Whipple 550HP w/ Intercooler work in an auto?
  61. 06 gt egr valve?
  62. Stroker Kit for the 4.6L 3V
  63. Headgaskets - Copper or Cometic
  64. 4.10's Article Oponion for 06 GT Automatic
  65. 3.31-automatics, 3.55 standards. why?
  66. My first dyno run
  67. 5R55S TCI Converter help
  68. 3.30-auto,,,3.55-standard. Why?
  69. Superchips Programmer
  70. Please Help. Cars Running Weird....
  71. Just ordered a Level 10 Stall
  72. NOS
  73. NEED HELP AND ADVICE ABOUT TRANNY AND ENGINE!!
  74. Is this MOD worth it?
  75. MY PONY NEEDS SOME HEADERS!!!!!!!
  76. 4.10 O/D off top speed? (135mph)
  77. Normal Brake Pedal Travel - 06 GT
  78. 2010 Mustang 4.6 N/A or Supercharged???
  79. Fuel filter quick connect help
  80. CA legal exhaust
  81. Still another 4.10 question
  82. Engine Bay rebuild
  83. HELP with Exhaust ??????
  84. Brenspeed does it again
  85. Buying an 05 Mustang, Problems?
  86. NEED SOME ADVISE MUSTANG TECHS, PLEASE!!!!
  87. More Performance: What The Hell Do I Do Next?
  88. Pypes X Pipe With Hi Flow Cats Install Feedback
  89. Buying 4.10 Ford Racing Gears
  90. Saleen Passenger Mirror
  91. SuperCharger Hell, please help!!!!
  92. Kooks Catted X-Pipe Possible Problem
  93. Launching with a DR
  94. Problem please help..
  95. wanted: walkthrough for pulling motor
  96. I hear...
  97. Sold my 05 v6 for a 10 v8
  98. 4.10/spider gears/warranty
  99. CAI options for 09 GT premium auto
  100. 05 GT RPM's Dropping while coming to a stop
  101. Ford Racing T/B
  102. Doing brakes tomorrow...
  103. Supercharger Issue
  104. TPS or Fuel Pump?
  105. Stock Mufflers with Non-catted Pypes X
  106. So is 91 octane really that good for an automatic v8?
  107. Dtc p0300 p0302 misfire codes help/advice
  108. RPM problems....
  109. bad bama tune??
  110. Does it hurt your car..........
  111. protorque
  112. JBA shorty header.. gaskets needed?
  113. Zex Traction Control Window Switch Problem
  114. intake manifold for 2000 gt stang
  115. C&L Performance 3 Valve Intake Manifold (2005+ GT)
  116. Am away at the track - P0453 code
  117. WOAH Champion 7989.. NOT one piece plugs after all?
  118. Pypes Violators Axel-back
  119. Changed fuel filter
  120. S197 Front strut install
  121. Aluminum or Steel Flywheel
  122. Strange upshifting
  123. 3.55,3.73,4.10 gears
  124. Shocks/Struts?
  125. Gear difference.
  126. Brake light problems
  127. Ford Racing Power Pack & Drag Pack
  128. will i need a tuner?
  129. CAI/tuner from Brenspeed or American Muscle ?
  130. Just bought an 05 gt and have some questions!!
  131. TIE ROD HELP!
  132. RPM's with gear change
  133. Has anyone installed a Vortech S/C along with Steeda UDP's?
  134. limited slip problem, i think...
  135. Drag Radial Question
  136. For those with centri's
  137. Alternator dying (bad diode) causing P0340
  138. Tune help!
  139. 2009 GT 4.6 L 3v OHC
  140. Two new weird noises
  141. Muffler Delete Exhaust- part throttle/cruise noise level
  142. Which Axle back
  143. Newbie with SCT tuning question
  144. Power steering pump noise
  145. Haynes manual for an 08?
  146. 2009 Mustang performance chip
  147. Emissions question..
  148. CDC Shaker with CAI
  149. SCT X3 Tuner question
  150. Overflow Temperature
  151. Anyone using Z-Max???
  152. kenne bell /adding meth/water inj
  153. Folks with Brenspeed tune
  154. quick question about transmission fluid change
  155. about intakes
  156. NGK Plugs
  157. BBK installed
  158. Stock Exhaust Issue
  159. silenced out exhaust system??
  160. STOCK CATS
  161. Supercharging a 2008 GT
  162. P0345 Codes
  163. C4 Transmission Speedometer & Reverse Light Sending Unit?
  164. CAI not for automatics?
  165. Best Prices for Superchargers or Turbo Kits
  166. Im new to all this
  167. Rev Limiter issues
  168. Possible TB/CAI/COMP PROB HELP !!!
  169. Edelbrock E-Force with CAI?
  170. Help! fuel rail pressure sensor error?
  171. O2 Sensor Extensions Different?
  172. did some datalogging...
  173. few questions
  174. Suggestions?
  175. increasing top speed?
  176. Problems with Kenne Bell.....Help?
  177. WHAT REAR END GEARS DO I HAVE????
  178. power band
  179. running lean
  180. Anyone Nitrous Injected???
  181. Upgrades......thoughts?
  182. Electrical Problem
  183. high flow cats worth it?
  184. Enging Choke
  185. Tri-Ax
  186. Diablo predator tuner
  187. auto trans won't shift
  188. Shift Points
  189. GT500 fuel pump upgrade purchase question
  190. Transmission swap?
  191. Sneak Time...
  192. RPM Redline 06 GT With 4.10 Gears
  193. Remote Oil Filter Kit
  194. 2006 Mustang GT Pinging bad above 3k rpm
  195. any 96 cobra guys in here
  196. running hoy
  197. 400hp 281ci 3v Naturally Aspirated POSSIBLE?
  198. Gear Install - How Much?
  199. Stalling issue
  200. Gears and Retune
  201. shorty header feedback...
  202. fuel upgrade
  203. cheep mods for HP?
  204. Do California emissions effect performance?
  205. CAMS after PAXTON
  206. pinion seal
  207. Engine Compartment Relay/Fuse box
  208. Engine mods for more boost?
  209. Fiat buys ford
  210. Idle Issues
  211. No Power Under 3k RPM
  212. kenne belle?
  213. ac question
  214. Automatic to Manual Conversion
  215. P0340 and hesitation at low throttle
  216. shorty headers?
  217. fuel guage or tank issue? 09 GT
  218. 06 GT Driveshaft Replacement
  219. spark plugs
  220. Found A New Tuner Option
  221. 4.6 irratic rod knock?
  222. 4.6 modular block question
  223. Tuning ? Need answers
  224. Tuning ?
  225. KB Supercharger, sputtering when cold
  226. Thinkin bout buying some Draglites..HELP PLEASE
  227. SCT Flash Tuner with Steeda CAI and tune?
  228. Stefs Oil Seperator Installed.
  229. Gunk in my coolant reservior
  230. Where do I start with the 05 GT??
  231. Overdrive Button
  232. 99-04 GT suspension info!
  233. Changing Gears ... Help Needed Please
  234. Bang 4 the buck
  235. Clunking 5 Speed
  236. rear main oil leak
  237. What More Can I Get?
  238. Tires
  239. Catback With The Best Sound And Most Power
  240. Catback With he Best Sound And Most Power
  241. '08 GT where to go from here?
  242. Steeda CMCV Installed
  243. Erratic Idle - What causes it?
  244. Slight stutter at launch
  245. How To: Change Differential Fluid
  246. Just bought a 2008 GT/CS
  247. Help! Automactic Transmission Fluid Change
  248. Edelbrock SC installed now I have Codes!
  249. newb question, how much power before the engine, tranny, and diff get angry?
  250. lc-1 windeband question
