- Small surge during cruise
- 300RWHP- Mission Accomplished, Much Learned
- Gear changes?
- Help! Engine troubles
- Saleen S/C coolant conversion kit
- Please help diagnose manual transmission squeal…
- 07 GT Fuel pump.
- Just picked up my '09 GT!! A couple of questions....
- 2 3/4 catted x too big?
- Clutch burning
- SCT X3: Setting idle rpm's
- Help - Mid Pipe Feedback - Pypes Off road X or H??
- Can a Shelby 5.4 supercharger work on a 4.6?
- 07 Running Rough - Whistle Hum
- Email Tunes...I Don't Get It
- 05 GT ticking/tapping noise
- Butt dyno happy
- Very novice question...
- Installed Kenne Bell and now have DTC codes and a funny noise.
- Wet nitrous Kit- how high can you go??
- random gear question...
- Delete plates or Gears????
- share your best way reach 0-60 here with manual trans.
- 2005gt
- Clutch Upgrade
- 40 mph surge - auto
- Can you all motor 500 WHP?
- How many degrees of advance....
- 06 STALLING AT IDLE !
- Lowered, what rear bump stops you using?
- first time burn out.!!!:) and some questions..
- Newbie needs advice on a mod plan!
- ordering my gears !!
- how much if i want to change an auto GT to manual?
- long tube headers with full exhaust system
- 5spd and Nitrous, pics, comments?
- PAXTON 2200 NOVI
- Saleen Extreme gets TECHCOIZED!!!!
- 06 GT Clunk Sounds from Rear End
- 2007GT/CS
- Brenspeed or JDM...Your opinion?
- 2007GT/CS
- TPMS??
- newbie question about SC
- Fuel pressure drops
- No power to fuel pump/injectors
- FI Q's & A's, Set-up, tune and others.
- please help put car to stock and check engine?
- BoomTube owners!
- Random misfires CMP sensor?
- Stang seems to backfire/pop a lot after start up
- gt500 Supercharger transplant in 2007 gt?
- ford racing gear
- gears update question!!!!!expert help...
- Steeda HD engine mounts..
- What does my rim/tire weigh?
- supercharger after 3.73 gear? or before?
- Manually Advancing Timing
- 2.5" vs 3" magnaflow
- New clutch?
- Tuning Software
- Crazy Idle Problems
- Good shop to install shorties
- SCT tune/JLT intake issues
- 2005 cobalt supercharger......
- Help:how to replace valve seals???
- Hot rod cams/full race delete plates?
- Injen CAI
- 305 /40/18s on a 2006 gt
- EXPERTS WANTED!!!
- GT/CS Question
- stupid grille removal question..plz help?
- which tire+wheel size are the best?
- torque converter now?
- Just Order Comp Cams NSR Stage 2
- TR-3650 gear ratios?
- reset computer today and...
- MY CAR DIED!
- 10 SEC MUSTANG
- Gas Tank/Gauge Trouble
- where can i buy this kind of hoops?
- Steeda tri-ax
- Quick question
- SCTx3 tuner help!
- Hot Rod Cams - Summer Fun
- PRO 5.0 3.90'S ???
- Rear end swap questions
- 2007 GT 4.6 ticking noise????
- Uneven burnout
- Warranty is up... Time for more power
- need advice on 3.55 or 3.73 on 2010
- I need info on ATC and RAM clutches
- Question about Optima Red Top Battery
- question
- cruise control goes off
- Burning oil?
- 2010 rear end
- The dreaded check engine light....
- 2005 GT - Stall and Shaky engine..
- gt 500 CAI anyone?
- Questions about X pipe & Tuner CEL?
- Hurst Shifter Question??
- MOSER DRIVESHAFTS
- Headers
- ANOTHER 3.73s or 4.10s thread
- Supercharger Pulley Change
- Quick Question On Gears
- What performance mods are available/recommend for the 2010 GT?
- Stage II Turbo Cams
- Driveshaft loop over Spydershaft.
- thud / knock in clutch
- Engine hiccup opinions needed
- what to keep?
- Start-up Issue...Any ideas?
- Jacking Up the Engine
- pulling the trigger on lt headers, curious about this set up
- Watkins Glen Track day
- CAI ?
- o5 GT track day
- 4.10 auto!
- ? about control arms ?
- Four Post Lift
- CAI w/ 93 tune- Octane Booster?
- Failed Emissions check
- Nitrous Camshaft Profile
- what kind of air intake does 2010 mustang GT have?
- Best Upgrade Options
- X pipe w/highflo's
- Concrete RPM/Tire Size/Gear Ratios
- Tell what's the difference please
- Fuel Filter
- Options for rear diffs?
- Re-tune for 4.10?
- Some Assistance Please
- Wheel Hop and Spin
- Will these springs fit my car?
- Intake upgrades
- Driver door issues
- NO POWER AND RUNNING RICH..
- Piston slap when cold??
- How to increase exhaust sound
- Best way to go for gears?
- pypes c/b fitment issues?
- Axle splines
- Clutch question.
- Clutch pedal travel adjustment on '07?
- JPC INTAKE: Basically Stock Engine : Results
- Stock 2005 GT - What performance mods for a 2000$ budget?
- What tune and CAI for 87 octane?
- CAI Confusion..
- Prochamber vs off road x-pipe
- 4.10's and twin screw
- gear install info..
- "Loading the suspension" question
- $1K to spend....need help
- Best one peice driveshaft
- Shifting After Transmission Work
- LT headers...
- MGW Shifter
- Lentech 4r70 going in
- DANGERS OF NOS???
- WHAT TYPE OF SYNTHETIC SHOULD I USE
- fuego programmer
- POWER ADDER VS N/A??
- Help me decide
- Vortech air to air
- Changing rear differential gear oil
- 4.6l 3v Cam swap
- mustang not idaling right
- help me with my o2 voltage data
- Wheel Torque?
- Anti-squat/relocation brackets
- Any opinions on the ROUSH Hypertech Performance Chip
- WHAT TO SPEND $600 ON???
- Brake sizes
- What is involved in a tune package?
- Can I use 93 octane fuel in my 08 Mustang GT
- HMMM, wierd noise between shifts
- 3.73 Gears Noise? Wrong Differential Fluid?
- Head Light Replacement
- E Brake
- 1995 Thunderbird OBD-II ECU...
- Installing MAC LT headers
- How do i turn up supercharger???
- Brenspeed Tune issue?
- My prognosis of my weird oil leak was on...Read More
- Fog Lamp removal
- Stalling out 06
- 17X9 with a nitto 315/35/17 DR will it fit...?
- Please help!!! Surging and sputtering
- battery randomly dead
- What are your FI IAT temps?
- Help...steady turn singal= no fuel pressure
- HID Kit for 2008 Mustang GT
- Tune a Ram Air without CAI?
- American Racing Header Combo
- o2 sensor
- Can Ford flash for 4.10 gears?
- PI 3-disc convertor
- new gears have brushing noise (not a whine)
- Crap-broke a darn plug
- SC readiness?
- PA alternators
- Lifetime of 3V 4.6L engines?
- Plug question
- Oil Debate ?
- Wondering..
- Brisk Plugs Heat Range?
- Shorty Headers and Tune Question
- Throttle Body Swap
- Need HELP on finding rearend gear ratio
- So has anyone tried it?
- Speedometer isn't accurate
- Amsoil feedback requested
- proplem with automatic transmission !!
- ?'s on Increasing tire height
- xcal 2 9415 question
- 2008 GT 2nd and 3rd Gear Question
- CAI...85mm or 95mm
- clunk coming from rear of car
- check engine light?
- Why a CV joint instead of U-joint?
- 2005 mustang 4.6L 3V question
- Car squeals when slowing (without applying brakes)???
- newbie to site
- Accel Coil Pack Issues
- Choosing Cop's
- CAI...JLT or C&L
- 2005 mustang
- underdrive pulleys steeda vs bbk/and roush
- CAI,THROTTLE BODY AND PLUGS QUESTIONS...
- MAF volts help needed: Educate me.
- Oil Change - Got me Nervous
- 06 4.6L Engine Vibration
- Tires
- New CAI and don't know what to do!!!!!!
- TCS Switch
- 'check charge system'.
- Fuel Gauge Off - HELP
- 2008 GT Third Gear Grind Syncro Replaced
- Will they work on '05+ GT's????
- Mutha Thumpr cam review
- 05-06 Vortech V-2 supercharger fuel pump help!!!!
- anyone seen this shift kit??
- 08 Spark Plugs
- MAF pin out needed
- Looking for switched 12v underhood
- Questions installing gauges
- Gear experts - question for ya
- Throttle lag at 3000rpm
