- Keeping the "startup" rev behavior
- O2 sensor
- Check engine strategy code after custom tune?
- Stock sounding cams...
- supercharger install
- Help Pls codes p0351 & p0352
- TR-3650 Gear Ratios
- wrecked 98 cobra questions
- GT500 blower on a 4.6?
- Tuning ?
- 600 hp
- Gear gurus: Gear noise help needed
- X pipe or new cats
- Is the motive bearing kit good?
- Questions about NOS kit and Tuners......
- Rearend Noises
- clutch noise
- Need some throttlebody help
- Low Idle after battery swap?
- Gear Questions, need some opinions
- Problems @ WOT
- AC/Heater fan not working...
- Supercharger for DD
- New supercharger choice - Edelbrock
- ? for SCT tune guru's.........
- CAI and Tuner
- Blinker light trouble???Please help
- Auto with 3.73 gears
- throttle body for whipple
- Double Clutch - Hurst Shifter - Rough??
- 4.10's installed
- Headers,sparkplugs, and WTF was ford thinking
- P0135
- 4.10 with AOD
- Comp Thumpr - Cam Phasers?
- OBDII Will not complete
- How much power could I get out of my car N/A
- engine noice please help
- Short tube headers for 07 Shelby GT
- TC or 3.73 gears? need advice please
- want to get some engine work done
- abaco digital maf
- 3rd Gear Issue.....
- Automatic transmission leak...
- Help taillights on a 2005 GT
- lost a # of boost after long tube install
- Ignition hesitates in snow
- Delayed throttle response.
- Troube Code: P0172 SYS BANK 1 RICH
- N0S Questions
- axle ratio
- Supercharger Question: A real head scratcher
- RAM AIR
- Naturally Aspired Build - Looking For Help
- BBK longtubes and SSS catback
- Supershaker Install Questions
- 1st MODS
- Shorty Header Install How-To?
- Requesting Advice on a 'possible' shifting problem
- Need your opinion!
- I NEED HELP WITH GEARS DECISIONS S197
- oil sending unit
- Billet fuel rails w/ Y-block
- Question about FI hp on stock block
- Upgrading the MAF on BBk CAI
- FI Guys....Especially Vortech.....Question..
- pulling the trigger today,vortech or paxton?
- New product from Trick Flow
- automatic transimssion question
- For those with the JLT intake...
- a little help please
- Shift Points HyperTech III 4.6 2005 ????
- manual transmission question
- HELP.....P0900 CODE 05 GT MANUAL
- Won't Start after new Tune
- Need help with inop gauges.
- what kind of fuel you use?
- KR Exhaust on a 4.6
- lean or rich?
- Mass Air Flow Sensor
- engine/tranny build up?
- Paint problem?
- Question on amount of differential oil needed, and whine noise.
- CAI and tune question
- thumper cams
- All 3 FRPP packs on a GT? Anyone know the end result?
- 07 GT Parking Brake SNAFU
- need help please ((o2 censor))
- New Valve Covers
- Tune Review: Brenspeed 93 Octane vs. BamaChips 93 Race
- Changing Tunes
- Won't Start!!! Please HELP!!!
- Is Paxton Novi the best of the best???
- opinions please..
- Violent screetch coming from pulleys. Help!
- PRO 5.0 Shifter Question
- POWER sHIFTING THE S197 NEAR IMPOSSIBLE!
- Has anybody messed around with their tuner options
- Regearing question
- P0135 Code
- FRPP hot rod vs Comp Cam Thumpr
- Supercharger Set up
- A.E.M. Brute Force
- Exhaust question
- Suspension
- CAI Cleaning
- 4.10/tune thread..
- Blowoff or thru, is either one better?
- new eldobrock blower for 4.6 3v
- Should I push it and upgrade to Saleen Stage 3 package from Breenspeed?
- 08 Spark Plugs
- stock H VS. aftermarket H
- Problem with Charging System
- 03 Cobra Supercharger on S197 4.6L?
- Supercharger with Cams
- Am I crazy? Too much gear?
- saleen supercharger
- Hellion single modded to Blow Thru
- Check engine light with new exhaust
- cams and vortech non-intercooled...
- Throttle Body Spacer
- New Throttle Body
- Head light diagram
- missing a gear
- Vortech supercharger 01
- SCT X3 Question
- Install Cost
- 2007 4.6 needs more power!!!
- Volant CAI?
- those with vortechs
- Headers+what else
- JDM Engineering or Evolution Performance
- 3.73s installed and have a ? for those with 4.10s
- Idle?
- Need help connecting the dots!
- Parking brake
- Need Help regarding Saleen Racecraft S/C Mustang
- 2007 mustang gt recalls ?
- oddball auto gear question..
- manual to auto tranny???
- Transmission noise... need help
- Help! Car died 3 times today!
- Drag radials and Short Throw Shifters
- Is there any way to lower just the rear of my 07GT
- the infamous 3rd gear grind
- iPod interface
- Pop/backfire out of right rear exhaust
- anyone running this kit...
- Sequential FI
- speedo problem 2007 Gt
- NEED HELP,2009 GT cruise control not working
- Whipple charged! What spark plugs should I run?
- Which tune to order?
- 2008 Tire Pressure Sensor
- spring mod list...
- superchagers
- Comp Stage 2 vs FRPP Hot Rod Cams
- My car has a new trick
- Emission test failed
- tpms
- I need some advice
- Fuel Pressure Gauge ???
- 2005 GT Spark Plug Install 48 K on Car
- Most efficient power adders?
- Stage 2 cams without springs
- traction control
- Charge Plates?
- question with hid xenon
- Have not a clue
- What are the advantages and disadvantages to installing 4.10 gears?
- Windows and In-Dash Dvd Stopped Working
- consistant vibration at 1100 and 3100 RPM pissing me off
- Clutch replacement question
- Oil pan drain plug diameter? '07 4.6
- Electric Problems
- SC belt question
- 2006 Mustang - No AC/Heater Fan & Fusebox Diagram
- FR500S specfic mufflers for sale?
- Upgrading trans, where should I go?
- shift into reverse?
- Driveline Vibes
- exhaust question from a fabricator.
- 06 Mustang GT Front 12V Aux not working
- Feed me NSR cam info (performance, dyno, pricing)
- Having a "pop" sound when i start my car
- MSD's Blaster 2 Coil On Plug High Output Ignition Coils
- No Springs Required Cam install difficulty
- sensor issues and wiring problems...any guesses?
- Bama 87 Performance - way less power
- Need some advise on guages
- Gasket Problems 2007 4.6
- 295/45's out back.....
- going FI, what gauges are needed
- NEW SUSPENSION MODS
- Ford Racing AXLE GIRDLE
- going FI what plugs??
- Newbee CAI/ tune install question
- Need Help!!! Bad knock
- 12s possible?
- Predator tuning questions
- high flow cats- worth it?
- Livernois Stage 2/3 Heads
- Saleen blower with 550 HP for 08 GT
- Brenspeed Tune and Emissions
- Saleen stage 3 + thumper cams ????
- wider tires?
- 2008 GT Exhaust System
- Low tire pressure light came on..
- Stock camshaft specifications
- SCT 3 vs. Diablo Predator Tuner
- General Brenspeed Programmer Questions
- Reflashed software - car runs like crap!
- questions about forging
- Long tubes on the way!
- Ford racing Drag Pak ...
- Leaking Whipple
- Necessary Gauges and Brands / Supercharged
- Gears Question! Quick Response Needed!
- 4:10 Gears
- tranny woes , maybe it is 6 speed time???
- Is there an RPM "governor" for 1st gear
- gear installation question.
- I make the right choice?
- Dead Spot @ ~2750 RPMs
- Anyone conquered the dreaded "Gear Rollover" noise?
- LTs design problem?
- long tubes add good sound?
- Shorties?
- LT install
- After CAI and Tune, whats next?
- New Supercharger edelbrock at sema show 08
- ACC Torque converters ?
- What cam to use
- Steeda UPD
- What Tuner?
- My Car Is Broke!!(transmission)
- New Gears
- looking for 350+whp on 91 pump... N/A.. ?
- Transmission HELP
- Need Help in AZ
- motive gears...
- Whipple Gen I vs Gen II
- 4.10 gears questions
- BBK CAI and TB installed, Idleing high?
- traction control
- B&M shift Kit E4OD
- rear end clunky
- Getting blown, gear questions
- 1997-99 svt cobra 4.6/t-5 into 1967 mustang?
- Where'd you get your gears put in at? (TX/LA shops)
