- Is it something I did
- how much power can the 3650 handle?
- Head/intake gains
- long tube install
- Electric water pump
- Anyone running no mufflers?
- wierd coolant (oil?) leak PICS
- What I can do to make my 2000 GT lighter
- Color?? Strange?
- Spark Plugs
- thinking about side exit exaust..
- Headlights
- tko 600!!!!!!!!
- whats the better base?
- Long tube header help!
- New to Mustangs
- clutch going?
- headlights or bulbs
- Possible bad wheel bearing?
- bypassing O2 senors??
- battery light flashing when in high rpms
- Which plenum should I go with?
- trap speed of 114!?
- Newbie with impressions of my 2003 GT............
- Engine Choice
- g oil?
- stupid keyless entry
- Any good tuner Florida?
- Strut Tower Brace
- EGR
- Cobra Fog Light Install - Help!
- factory alarm keeps on going off
- Why is my gas mileage so ****ty
- COP's
- '00 GT
- NJ Shops
- 96 GT +50hp
- cam and tune question...
- problems when turning!!! UPDATED!!
- pi short block vs. npi short block
- Valve Spring Compressor
- MOTOR question
- Subframe connectors
- Timing problems
- About to order manifold.. any suggestions?
- Rear speaker grille removal (convertible)
- Squealing sound
- TPS wiring
- intake manifold help
- SCT VMP furl economy tune??
- cant get the crank out!
- My shifter shakes violently in 3rd gear
- HELP about to order new mufflers
- help identify: squeek from rear end
- First time at track, 1/8th mile
- Supercharger vs. 65k!!!
- dpfe
- Getting Ready to Order..
- Suspension Mods.
- lucus oil
- SVT Focus Fuel Pump
- WHY!!?? (CLUTCH)
- want to paint rims
- Rear shock question
- Nitto Drag Radial Tire life?
- Exhaust Leak
- Hesitation/stumbling (whatever you want to call it)
- Best price for an H pipe?
- 99 Mustang Exhaust Question
- Aftermarket spring ?'s
- Few questions..
- Aftermarket Guages
- injectors?!?!
- TOP SPEED
- Rear Shock question
- pistons hittin plugs????
- bbk plenum
- 26.5 mpg
- Exhaust worth the money?
- Wearing front tire
- 3650 rebuild information, (insights, experiences, outcomes)
- idle surge
- clutch problem?
- Automatic Stalling ?
- 2000 gt
- OBD2 and A/F
- 3.73 GEARS
- Quick Q
- Suspension Question?
- How much does a stock driveshaft weigh?
- Another clutch issue!!
- Why does my clutch pedal squeak?
- NEW! Mustang Noise... Damnit..
- where can i get one??
- What is the current thought on Patriot Heads?
- Any previous 5.0 fox owners...
- trans slipping?
- Best place to buy?
- Tire Size for 15" rim
- milling/shaving 01 2v heads
- Will this work..
- tuner hp?
- aftermarket k-member, where, why, how much?
- Coolant In Spark Plug Well = ?
- Cobra Bumper
- Hard time justifying modding
- Rear End Rebuild
- diablo tuner quicky?
- Camshaft Specs for PI Swap
- What stall torque converter to use????
- electrical problem
- SVT Fuel Pump
- recommended spark plugs
- Steering rack bolts on tubular k member too long
- Weird Wideband Problem
- Diablo Predator Octane??
- Shaker question
- H&R Spring, Bilstein Question.
- Antenna removal
- Loud bang --> black grease, wtf?
- anyone try the toyo t1r?
- Throw out Bearing Retainer!!!!!!
- New engine! Rides PERFECT!
- Drop'd Plus rims ??
- Best mods for my '97 Cobra
- SS lines
- T45R?
- 05+ engine in a new edge?
- car is shaking
- Redline MT-90 in a T-45=ok???
- coolant leak passenger side engine
- Honeycomb hood scoop
- quick question
- Flashing Tune??
- How to get Oil Dipstick out of block?
- JLT CAI
- GT spoiler delete......
- sputtering problem
- Need some opinions on decals
- injector size?
- How fast will it go
- Steeda Clutch Adjuster??
- check gas cap light on
- K&N Generation2 CAI kit Question
- about to order 31 spline setup, check my order
- Procharger Help
- V2sq should I?
- Snapped a header stud! ****
- driver side window wont work
- spun bearing....
- Stock Manifolds vs. Shorty Headers w/ Kenne Bell
- 3V SWAP
- specifications
- Throw Out Bearing?
- Bassani
- Intermittent misfire
- What about these?
- will it pass inspection
- Need help with a S/C!!!!
- Installed my wideband. Question about tunning
- Cobra Heads
- power window adjustment
- 01' GT automatic transmission question
- engine removal
- Removing outside trim above windows.
- Question bout radiator?
- Ported Eaton...
- Found a new motor....what now?
- SLM1 Dumps.
- P0602 Control module programming error
- 4.10's with an automatic??????
- new h pipe problem
- Gear Install
- CEL---MIL'S gone bad??
- please help manual rack..... anyone?
- manual rack and pinion
- Rear end going?
- body question..
- Sputtering problems.......
- what tranny do i have?
- x-pipe with SLP loudmouth cat back
- 2V or 4V
- MIL Eliminators
- Motor Mounts keep breakin
- Motor
- Getting The 3:90s
- why did my belt break?
- Quarter Window Covers
- 97 GT no s. belt...o ****! HELP!!!
- question about 96 GT
- Procharger install
- beeping
- CA Legal Mustang
- 98 gt missfire
- Windsor and Romeos!!!
- Strange Bolt-in 9 in or built 8.8?
- CAN SOMEONE PLEASE ANSWER THIS QUESTION??
- Bullitt Intake
- Need a favor...
- NEed help Sct Xcal 3 tuning
- Timing Question URGENT!
- Replacing a Intake manifold
- Most Bang for the least Buck!
- HEADERS
- more power!
- Install
- whistling?hissing?
- Headers Demystified! HP Gains or Not..
- Drivers Seat
- Any ideas what would cause this? Vid included
- picked up a dohc 4.6 for free today
- diablo or sct?
- 2003 SVT Cobra Exhaust
- PI Engine Swap
- Replacing Bearings only???
- Service engine light came on and off?
- Block and internal compnents
- Help with new tranny
- Stock mass air meter?
- What gear to select for my setup
- Tuner Question
- washing engine
- 99 GT wheel question
- 5309 and 53 QA codes what are they?
- Anyone know the cause of this?
- What is this?
- AC condensor removal tools
- t-45 has failed...
- Car stalls on cold start...
- 500hp on stock motor? & Boost gauge question...
- Ever Ordered from R1 Concepts?
- clutch cable
- Where can you buy domed pistons?
- Hood pin laynard anchor point
- Drag Slicks!?
- Recline?
- Just bought a 03 GT.
- Center Console Removal
- New to this ... Any Advise?? 95 GT
- How much drop
- New Member
- Odd viberation...
- MidPipe
- Gauges Sweep
- Stock rod question?
- PI Swap on Older Engine
- auto tranny
- Supercharger question?????
- 2000 rear seats in a 96 convertible?
- P0455 Emmision Control System Leak?
