PDA
View Full Version : 4.6L (1996-2004 Modular) Mustang
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 [290] 291 292 293 294 295 296 297 298 299 300 301 302
  1. What should I be running???
  2. DIABLO TUNER?
  3. intake question
  4. 2nd thought on vortech aftercoolers
  5. [Deleted]
  6. [Deleted]
  7. [Deleted]
  8. [Deleted]
  9. [Deleted]
  10. Gear Oil
  11. Rim size???
  12. Price Watch- Cobra parts for your GT
  13. Thinking about geting a mustang i got some questions
  14. NEED HELP
  15. Perfect PI setup, or NOT?
  16. a crazy question
  17. [Deleted]
  18. PI SYSTEM
  19. Pi heads
  20. Okay....so I got a few questions
  21. MOVED: 1st time at the Track -- help w/my time slip
  22. Cold Air Intake
  23. What is done to 96-98 cobra for more power?
  24. hpipe differencer B/t 96-98 & 99-04
  25. 4.6 vs 4.6 ? Thunderbird vs Mustang Question
  26. Long Tubes & Catted X!
  27. 98 GT thoughts and opinions
  28. Headers on a 96Gt add 30 hp??!! WTF
  29. which one is better
  30. Headers
  31. T/B Spacers
  32. C.A.I. mixed with Maf System....BAD?
  33. Steeda Timing Adjuster
  34. Weight reduction
  35. UBR OR BASSANI
  36. Teh X-pipe is on!
  37. springs
  38. Tires, these Nittos gotta be good
  39. Car Away for winter
  40. Heater Core
  41. Comp Cams
  42. funky idle - stalls
  43. 351
  44. 4.6L SOHC Engine Improvements -General Help
  45. anybody?
  46. Mods to make my 96GT faster
  47. Lowering springs
  48. GOVERNED ????????
  49. Accufab TB & Plenum
  50. Power windows
  51. EMISSIONS!!!
  52. MAF for '96 GT
  53. SPEEDO OFF
  54. question on exhaust
  55. i need stock pulleys
  56. Should I buy a 01 SVT Cobra for $20K?
  57. MIL Eliminators ???
  58. speedo recalibration
  59. Throttle body, Upper plenum, MAM, CAI
  60. pi heads
  61. pi heads
  62. 99 Trans am
  63. Can a 2003 GT reach 500+hp
  64. Tach installation
  65. What should I do next???
  66. Best mods to make my stock 96 faster 0-30?
  67. 98 gt cams
  68. Tranny problems HELP!
  69. Tach driver wire locations
  70. Temp. Sender Location??
  71. [Deleted]
  72. [Deleted]
  73. performance parts
  74. Whats it cost to get a 3.73 gear installed?
  75. Stoopid head gasket.......
  76. Steeda Shifter came today!! Help ASAP!!
  77. from new to old
  78. Densecharger now TunableInduction.com
  79. 03 GT help please
  80. 98gt vs 91 5.0
  81. Cams?
  82. 3" exhaust question?
  83. 03 cobra rims on 98gt tires
  84. Throw-out bearing ...
  85. [Deleted]
  86. 70mm or 75mm T/B?
  87. Question about Dyno-tuning
  88. [Deleted]
  89. [Deleted]
  90. What do I need for 3.73 Gears
  91. MUST READ!!!! HELP!!!
  92. Check out what I made!
  93. diffrence in hp between 96-97-98
  94. knowledge needed... AKA Help
  95. 2000 gt with cobra heads, is it possible?
  96. could i hit 13's????
  97. Auto Tranny Question..
  98. Will I feel any difference?
  99. [Deleted]
  100. tail light lenses!!
  101. [Deleted]
  102. 98' GT 1/4 mile times...
  103. Tires
  104. Gear question
  105. Mach1, Cobra, or new GT?
  106. K&N (FIPK)
  107. mods to follow up exhaust?
  108. whistle sound from CAI
  109. Programmer
  110. Warning light
  111. How do you do a stand still burnout?
  112. Killer deal on (a) HOOKER!
  113. take a stab at this one???
  114. Steeda?
  115. thinking about seliing the stang
  116. [Deleted]
  117. STEEDA TRI-AX
  118. 94 Cobra VS 98 GT
  119. maganpacks vs. flowmasters?
  120. need gear help quick!
  121. Exhaust w/o ltbs?
  122. Newbie needs advice on 2001 Bullitt GT
  123. [Deleted]
  124. Racing Question
  125. quick question
  126. Anderson Ford M/S Power Pipes
  127. stalling problem-need help
  128. 4.6 vs.5.0
  129. Is This B.S.???
  130. Tires and wheels
  131. gt hi-flow intake package?opinons
  132. spring poll!
  133. Pin Hole in the Head??
  134. Went to track last night, first time with the car
  135. short throws???
  136. !HELP ASAP - Rear Differential on 97 GT
  137. !HELP ASAP - Rear Differential on 97 GT
  138. Jet chip and Steeda timing adjuster
  139. Premium pedels
  140. hand brake wiring
  141. **help! burning oil**
  142. Cobra vs Mark VIII block
  143. [Deleted]
  144. [Deleted]
  145. Blown Oil Pump
  146. gettin my desecharger
  147. 97 GT VS. 86 GT WHO WOULD WIN
  148. intake spacer
  149. Help! What size alan wrench...
  150. what would you gaing off of this?
  151. accufab t/b with plenum for 200 bucks?
  152. Cheap Power?
  153. Trans-Am VS. Mustang GT
  154. Got a Bullit and want to change gears
  155. Notchy shifting T56
  156. Used gears?
  157. loud click noise
  158. Missing Part?
  159. [Deleted]
  160. [Deleted]
  161. me = dummy
  162. Check Engine Light
  163. how do you check pfe sensor?
  164. not a very good morning
  165. msd ignition help for cobra????
  166. Need ideas on this problem!
  167. PFE SENSOR!!!
  168. New mods on the way
  169. [Deleted]
  170. free shorties worth the trouble of install
  171. Mach1 clutch sucks
  172. 96 4.6l stang vs 1.8t GTI
  173. [Deleted]
  174. [Deleted]
  175. Romeo Heads, good question
  176. Drag Radial ?
  177. Added long tube headers-results?
  178. Headers and x-pipe or TB/Plenum
  179. 98 GT w/ some tranny questions.......
  180. Check engine light on?
  181. Head and cams??
  182. Exhaust
  183. FIPK
  184. differential rebuild
  185. Big step...
  186. Uploading picture for avatar???
  187. gears in, brakes acting funny
  188. Air Flow Increase... HELP ME!!!!
  189. Is this AI stock?
  190. Thermostat Question???
  191. Silver4.6 signing off....
  192. 04 Cobra 2.8 pulley upgrade question
  193. Need suspension advice
  194. How to install a New Hood ???
  195. Launching with 4.10s
  196. Air Silencer
  197. [Deleted]
  198. Supercharger Q
  199. [Deleted]
  200. Cant find aftermarket pinion snubber 99GT
  201. insurance for 16 or 17
  202. Rubber ring in fuel filter
  203. Intake manifolds with aluminum crossover.
  204. 350$ to much for gears??
  205. Damn OBD Code
  206. Where can i find 2 chambers flows???
  207. need help car stalling
  208. thrower for ricers
  209. Densecharger
  210. Anyone here have 4.30's?
  211. Adjustable clutch cable
  212. anyone heard of this sensor?
  213. Pinion Snubbers for 99 and up GT
  214. 1998 mustang gt startup squeal
  215. will my rear be ok?
  216. A new found faith!
  217. Well, I've got it.
  218. How much to pay for 04' GT?
  219. Why taller tires?
  220. [Deleted]
  221. 99 Block
  222. B&m shift kit
  223. How difficult to change tranny and gear fluid?
  224. How much tire will fit on a 17x8 rim?
  225. plaster yo *ss to the seat
  226. Went to track last nite, kinda happy
  227. How wide of wheel and tire will fit?
  228. hey guys i got a quick question...
  229. MustangTuning x-pipe
  230. best spark plug wires for 96 cobra?
  231. Newbie here - Need some help/advice with mods!
  232. ? about tune-ups
  233. 60' Times
  234. I need a transmission
  235. ford reimbursing me
  236. PIC OF MY 2001 GT
  237. what do you think it will add?
  238. Could I drop this into my 96gt with no problem?
  239. I need some Mod Help
  240. Pics of my car
  241. Should I trade my 98 GT for a 93 GT ?
  242. Clutch Problems
  243. good deal for Mustang drivers
  244. Synthetic???
  245. ideas
  246. UPDATE ON MY TRANS PROBLEM
  247. Swap a 5.0 into a 96 gt
  248. I think that I've found my stang.
  249. What do you run in the 1/4 mile?
  250. **Traction Control on/off** help
