View Full Version : Classic Mustangs
  1. REPLACEMENT WHEELS
  2. Best Small Blk Performance Book
  3. interior color problems
  4. My 1976 Mustang Cobra II
  5. Opinions on Canfield heads?
  6. Painting a car
  7. Parking Brake for Versailles rear end?
  8. 1964 170CI Auto, Which Carburetor?
  9. Front drum vibration
  10. engine work needed?
  11. Help Identifying Engine
  12. Clutch adjustment issue??
  13. Rear Springs
  14. No start issues
  15. engine knock sound
  16. Do You Really Need The Shorter T5 Yoke?
  17. CID vs Pertronix II (feedback)
  18. vinyl stripes?
  19. Motor mounts on '65 289
  20. what driveshaft to use?
  21. Shifter rattling noise?
  22. Temp Sending & Oil Pressure Sending Units
  23. Question about installing fuel pump.
  24. Tremec TKO-500 into '71 Mach 1
  25. What is this A/C part?
  26. What the Hell happened here???
  27. EZ Wiring 21 CIRCUIT HARNESS
  28. Which Rear Valence
  29. Relocate Fuse Box
  30. Need a Favor
  31. Overheated Engine = Cut Off
  32. will i have to roll my fenders?
  33. timing chain cover
  34. tko help
  35. Video Tour of GT140T (66 Mustang/svo 2.3 Turbo car)
  36. 9in rear end
  37. 71 sportsroof (fastback) package tray
  38. New Member with Questions about a 351W in my 66 Coupe :)
  39. T5 part# torque list.
  40. Leaking Coolant
  41. seat side shields
  42. disabled mustang owner needing info about transmission
  43. will these brakes fit a versailles rear end?
  44. First Mustang Build, 1968 Coupe Lots of ?'s
  45. New Mustang Steering Product
  46. Is it a good assumption?
  47. Headers for a mild 289?
  48. 351w engine swap
  49. when fixing the cowl
  50. Turn signal help - - 1966 Mustang
  51. Stroker Kit available locally for sale... offer price?
  52. Fuel Level Sending Unit
  53. holley fuel pump good sucker?
  54. Battery charging Q
  55. Parking brake, pass side
  56. Easy 351C modifications
  57. Ford 9" Rear pics
  58. Started suspension
  59. 289 Block Questions
  60. installing ignition key
  61. New mustang
  62. 1965 Mustang correct engine bay pictures?
  63. electric fan question
  64. Which wheel/size
  65. Oil in the exhaust?
  66. New motor for 66.
  67. Big O tire don't use them
  68. Headers
  69. Not for everyone.. but relocated fuel door
  70. Damn My Smart A**! MOTOR MOUNTS!
  71. Auto shifter gear indicator needle
  72. weird issue starting
  73. flush mounted windows progress
  74. Where to mount MSD ignition module?
  75. what belt would I need
  76. lost the wheel lock key
  77. What would cause cassette player to buzz?
  78. Just because it's "official" does not mean it is correct
  79. Could timing affect the oil flow?
  80. put the mallory distributor in today
  81. Master cylinder selection
  82. 67 68 Grill question
  83. anyone want my engine setup
  84. new paint job/ chrome molding
  85. Does it matter what paint is used during bodywork stages?
  86. My HEI is huge! Air cleaner wont fit
  87. 1973 mach 1 books and schematics. Where do I find them?
  88. another floor board question
  89. What do you guys think? Zinc additive for engine oil
  90. YES!!! We Have Ignition!!!
  91. Fixed the speedometer instead of replaced
  92. Igintion Problem Maybe?
  93. Restomod/Pro Touring Ideas
  94. You have to be kidding me!
  95. Talk me out of this... exhaust dilemma
  96. rust on ss wheel
  97. a good total timing
  98. Mystery wire under the hood
  99. my recaros and back seat done in leather
  100. 302 pully set up help needed
  101. tried to find axle gear by tire driveshaft method and have problem
  102. More battery hook up Q's
  103. Rebuilding my C4-Parts Advice Please
  104. Pitted Windshield
  105. Ignition coil
  106. A-arm VS Tire
  107. 69 with a 5.0 Backfire Problem
  108. On the road after 2 years
  109. Highest capacity radiator
  110. 1967 Mustang
  111. Upgraded Rally Pac gauges
  112. Tips for attaching fenders?
  113. joe67 has left the building
  114. Sizing up my exhaust
  115. Auto Trans Cooling Question
  116. Two questions in one thread...interior lighting and radios
  117. seat belt install
  118. Removing power steering
  119. Insurance
  120. T5 adapter
  121. 93 Coupe >> 289 Swap??
  122. What's it worth?
  123. 289 cooling system coversion
  124. 289 hooker 6901hkr headers fitment trouble
  125. Tri-Y header fitment issues
  126. brand new flo-fit seats in the box
  127. procar elite seats
  128. Any chance its a real deal
  129. classic mustang help
  130. suspension & steering ?'s
  131. selling the 67
  132. Electrical problem
  133. $1000 for a 302??
  134. vehicle history
  135. Steel cowl hood?
  136. Quarter window stuck on '65
  137. Looking For The Right Header
  138. Insulation under back seat
  139. who sells upper control arm seals?
  140. Rust coversion or encapsulation?
  141. Spark plugs
  142. new and need help
  143. The Real Man's Cowl Leak Test
  144. which master cylinder?
  145. Orange Autolite Sparkplug Wires
  146. Trying to diagnose overheating
  147. Best Place to get New Chrome Drip rails??
  148. Which vendor to buy from?
  149. Car Starts, Dies When I take off gas
  150. '68-69 Fastback
  151. Power Brakes
  152. Headers on a big block
  153. Alignment and on the road but problem
  154. 66 mustang drum to disc brake conversion
  155. Broke 68 Front Bleeder Valve
  156. LM-1 quite easy to use :-)
  157. Engine Cuts Off
  158. 66 coupe project
  159. Fine metal shavings in my dizzy!
  160. Spark plug wires
  161. Tranny Trouble
  162. 67 coupe to fastback project
  163. Ride of the month!
  164. 5.0 or 4.6?
  165. anyone need a polished billet alternator pully
  166. Mallory 85 Series HEI Distributors for 289?
  167. shift knob size for a 68 coupe
  168. I6 EFI setups?
  169. 1966 Mustang Coupe Color Choice?
  170. What would you guys do?
  171. ford 302 motor
  172. OPINIONS??
  173. Secondary Exhaust/ Crankcase Ventilation?
  174. General Coolant Question
  175. Another Pertronix/Coil Question
  176. Rear Quarter Windows
  177. Radiator Cap
  178. Help with hubcaps!
  179. Help me decide...
  180. V8 conversion in my 68 coupe
  181. Shelby dash emblems
  182. Boss 351 mods...
  183. Toploader Neutral Safety Switch
  184. Grande?
  185. Input on white spoilers?
  186. help: z-spec
  187. Car Trouble, Help?
  188. ididit steering column
  189. alternator test
  190. installation costs
  191. '66 C4 Transmission Oil Cooler Lines
  192. Properly Tuning a Holley Street Avenger (P/N 80670-1) HELP!!!!
  193. Guide to painting engine compartment walls?
  194. 1969 grande --Pics-whats worth??
  195. Light Whitish Smoke After a Long Drive
  196. 1967 power steering hoes
  197. 1973 MUSTANG MACH 1... OR AM I LOOKING AT SOMETHING ELSE? SPECIFICATIONS PLEASE.
  198. New Gauge cluster
  199. Is it hot
  200. Call me stupid or BLIND!!
  201. 5.0 to carburetor conversion
  202. 66 Dash Pad
  203. 65 66 center console lighting questions,...
  204. Replacing starter solenoid with battery out of car - anything to worry about?
  205. i am looking for some new seats
  206. Type A transmission fluid
  207. Power steering... Maybe at one point?
  208. What type of distributor?
  209. Motor Mount questions
  210. 65 headliner 65 install
  211. Reservoir
  212. Rear leaf spring help 68 Coupe
  213. Door Lock Issue
  214. Hard starting and electrical issues
  215. Took the plunge
  216. Progress
  217. Newbie w/ Barn Find 73 Mach 1
  218. Parking brake
  219. front turnsignal removal help!!
  220. Question about coils
  221. how to seal off rust inside engine block
  222. Proper way to install battery/terminal cables.
  223. more progess pics
  224. Drum Brake ques
  225. tach with HEI distributor
  226. 302 water pump pully direction
  227. Electrical Help
  228. transmission fluid leak
  229. cost for new a/c
  230. steering gear box 68 mustang
  231. What goes around comes around,...great story
  232. granada brake conversion questions
  233. best brake pads?
  234. A/C not working
  235. Rim Size
  236. Electrical. Year or Engine
  237. 1968 driver side door issues
  238. What is considered being "Hard" on a T-5?
  239. Want To Buy Another Classic Mustang
  240. Spintech mufflers?
  241. Can you simulate my engine?
  242. Ignition Diagnosis, pa-leeeze!
  243. upgrading the T5
  244. Help with a clutch pedal
  245. Street Master Intake?
  246. Mini tub pics (groho)
  247. 65 Mustang Shop Manual?
  248. beginner Restoration question
  249. Looking for help with my 1965 200ci.
  250. Firewall Question
