PDA
View Full Version : Classic Mustangs (Tech)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 [106] 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172
  1. 1965 Mustang Smoking!!! ALot!!
  2. Bizarre door allignment/latching
  3. RSTMOD INTERIOR PAINT QUESTION
  4. fuel cells
  5. My New-to-Me 64 1/2 Mustang
  6. If you ever needed a reminder to maintain antifreeze
  7. C4 to AOD
  8. Battery draing questions
  9. Gas Mileage for a 1966 289 V8?
  10. need to find a spring compressor
  11. Car Stereo
  12. Honest/good mechanics in Las Vegas to work on 1968 mustang
  13. Passenger Side Squeak
  14. Carb dilemma...
  15. front end springs
  16. 351 cleveland rebuild??
  17. In need of some new/used rims badly :(
  18. MOCA Just a Month Away
  19. New Problem
  20. Phenolic spacer (with PICS)
  21. Wire Terminal Block - '67 Coupe
  22. Is this to be expected? "Slow start when hot" question...
  23. 69 AC Blower Problem
  24. Metal stripping help
  25. 69 mach1 Air filter fit Question
  26. Happy Independance Day
  27. Why did you choose mustang?
  28. Got the girls out today.
  29. minilites!!!
  30. 1966 Marti report?
  31. 65 stang bogging
  32. iPhone and Classic Mustangs
  33. Door Jammed
  34. Finally a Day off
  35. fuse block
  36. VIN on car
  37. update as of 5am
  38. Primed
  39. START COIL GETTEN HOT!!
  40. Air conditioner compatibility
  41. 2 part header question
  42. How to attach 68 Grille Ornaments
  43. 69 mustang
  44. WTH!?! Summit 1 wire alternator troubles
  45. anyone know?
  46. Trans fluid change at a quick change oil place?
  47. Worth picking up?
  48. wheel size question
  49. 5.0 out of a lincoln?
  50. EGR?
  51. exhaust cut outs
  52. turn signal harness
  53. Backfiring??
  54. Hard Starting When Hot
  55. 8 ' rear end ?????
  56. what color/kind or paint!!!!
  57. Radiator Support
  58. battery keeps dying
  59. Gas Gauge Problem....
  60. 351 Engine Wear????
  61. REAR END
  62. 289/C4 to rear end match?
  63. How To Handle This Mess?
  64. Test Drive video
  65. Sandblast or Sand?
  66. Starting a rebuilt 1966 289 with 2-bbl carburetor
  67. oil pan removal
  68. Ram air hood vs. Cowl hood?
  69. Need some advice
  70. Please Help Me!
  71. Power rack
  72. I did it !
  73. temp sensor loacation
  74. sheet metal
  75. Duplicate
  76. Worth the Time?
  77. t5 question
  78. 67 Fatory A/C Water Valve motor?
  79. 67 vs 88 clutch
  80. New guy here, journeyman Mustang freak
  81. Jeopardy
  82. Which Mufflers?
  83. Newbie...wanted to say hi
  84. Currie vs Quick
  85. finally blasted
  86. Questions on a 68
  87. Speedometer Problem
  88. Trying to track down an 65.
  89. Hey man, is that numbers matching?!
  90. 289 heads on a 302?
  91. 2 Core Aluminum vs. 3 Core Copper
  92. electrical problems
  93. Correct Refinishing Steps?
  94. 68' Coupe
  95. slip yoke leak
  96. tranny questions
  97. Overheating '66 Shelby Clone
  98. Motor Mount question '67 289
  99. What trans do I have?
  100. Noise with new front end
  101. What size carb jets are you running?
  102. engine porn
  103. Oil Leak question..
  104. Fluids colors
  105. Advice on Whether or Not Car is Worth the Price
  106. Performance parts in California
  107. 1966/67 Mustang Station Wagon?
  108. HELP! How to adjust valves on a 289....plus more
  109. kickdown lever leaking?
  110. well i just bought my new shocks
  111. 72 mach 1
  112. Muffler
  113. Salt air protection
  114. rocker stud size.
  115. '68 with PS and long tube headers
  116. Doctors?....Mechanics!!!
  117. c4 trans ?
  118. Large purchase
  119. Starter keeps spinning...
  120. brakes and floors ?
  121. New Intake Question
  122. Brake Booster extension for 65/66
  123. MOVED: Have any of you guys raced a supercar?
  124. c4 to t5
  125. alternators
  126. Clutch Pedal Compatibility
  127. Power booster & MC II
  128. radiator transfer
  129. Ignition problems?
  130. where can
  131. Project Fastback
  132. converting to power brakes
  133. over heating question
  134. Engine died after 15min drive...
  135. Spring saddles/perches?
  136. 65 Mustang 289 Severe Engine Knocking
  137. T10 or toploader?
  138. project advise
  139. timing mark confirmation help
  140. New carb instillation
  141. timing fence? question for 6 popper
  142. Power brake conversion
  143. How long is a 1962 T-Bird in overall length
  144. Block Number Help ?
  145. wheels and tires
  146. May be driving from San Francisco to central Oregon
  147. Greetings from Baghdad
  148. flexplate or flywheel
  149. Smaller combustion/ flat top pistons
  150. Tomorrow we dance!
  151. Gauge the Gage, Your thoughts please
  152. A couple of questions
  153. 69 mustang dimmer switch connector
  154. its not mustang but its a ford
  155. 1967 GT-350 Clone
  156. California Pony Cars Anyone?
  157. Fuel Tank Fuel Line Question...
  158. COIL SPRING QUESTION
  159. Mustang Project Advice Please!!
  160. Body Work
  161. New engine/trans time Advise?
  162. '67 coupe project
  163. Got my car back from the bodyshop
  164. Starter Run on
  165. Roller Rocker Arm Question
  166. Rally Pac
  167. 66 steering box
  168. Power steering pump picture needed
  169. Heater hose routing
  170. Motor / headers question
  171. I'll need lot of help
  172. Side scoopes
  173. need help!! on a starter motor
  174. 65 Mustang 1/4 times ...
  175. Hood To Cowl Seal
  176. Gone in 60 seconds
  177. 67 frame question
  178. '69 Fuses
  179. Pulled my engine!
  180. Rookie question about tranny?
  181. license plate light
  182. bumper question
  183. sticking loud pedal
  184. MIG Welders
  185. gt40p heads for $200
  186. photogallery of resto 66 fastback
  187. 67 A/C
  188. new brake lines
  189. what the crap!?
  190. im getting a new DD
  191. brake conversion questions
  192. valve rubbers
  193. 9 inch rear in 65 stang ?
  194. stock C4 vs 351W 420hp
  195. Its not a mustang but is is a ford
  196. adjusting vacuum advance?
  197. Blinkers...!!
  198. Turn Signal Flashes Too Fast?
  199. Transmission gasket leak, again
  200. What shocks will give me a more forgiving ride?
  201. any got 66 layout
  202. 302 serpentine conversion
  203. a carb?
  204. interesting finds in your mustang!
  205. Radiator advice: Angel or Devils?
  206. Engine dies at idle and won't resart
  207. Help Me Decide.
  208. hiccups at low revs - good at high
  209. Pics & extra original equipment?
  210. Radiator fluid level question
  211. 351
  212. Best Insurance for a 1966 Mustang?
  213. engine pull
  214. anyone need extra advice restoring old cars try this site
  215. Shelby Drop reconsideration....
  216. the adventure of the disappearing turn signal
  217. Need to know a good supplier of sheet metal
  218. what does the brake light mean? '67
  219. Safety upgrades
  220. 67 interior questions help please
  221. Speedo Cable Too Short?
  222. Motorcraft 4300 D Carb
  223. heater blower motor....
  224. Four Reasons Not to Restore a Vintage Car
  225. 72 Mach I 351 Q-Code....what do the codes mean?
  226. roller rocker valve cover clearance
  227. seatbelts?
  228. The tear down
  229. 1966 A-Code casting numbers
  230. Drip rails
  231. flowtech didn't work for me!
  232. Which carb is this ?
  233. '71 sportsroof seat platform?
  234. rust and stuff
  235. Battery Chaged: Car still not starting
  236. Over heating problem
  237. Breather hose mystery
  238. My donor car is in better shape than my restoration project car!
  239. Engine Question
  240. Engine Question
  241. My new 1966 Mustang Coupe (New pictures 7/08/07)
  242. Car Sale - Transportation???
  243. Universal Wiring Harness
  244. D-day! little engine removal advice please
  245. How Much Is This Engine Worth??? Picture Included!!!!
  246. brakes question
  247. Buying a 65 Stang, guy says it's an A code. PICs
  248. Help question. How do you 'prime' 66 289?
  249. '67 strt 6 Engine not starting
  250. *help with a 67 coupe*
