- How can you visually check if a Holley has vac secondaries?
- muffler recommendation - 1970 Mach 1
- disc brake conversion
- Anyone to paint and do body work Northern Cal
- Sheet Metal: OEM style vs Repro
- H.I.D lights?
- crate motor with a C4 trans?
- 66 clearance for headers?
- Mysterious tranny leak
- WTK: How hard is it to install a convertible top?
- lost a gear?
- How would it look?
- which engine would you use?
- I'm beginning to think my '65 that I just bought has a late model 302 in it.
- Dont shop at mustangs plus...
- C4 Tranny Filter changed, and this spring fell out?
- Autolite 2100 Connections
- New 67' mustang suggestions
- horrible SQUEAK
- 65/66 Headlight Bucket + Door FOR SALE
- Power Steering Upgrade
- Power Disc Brake upgrade
- 289 2V Choke
- some pics of my money pit
- RESTOMOD RULES!!!!!!
- Frame rails
- Almost ready for blasting
- Roller rockers on stock heads/valves?
- Leaky Power Steering Cylinder
- Distributor???
- Mustangs for sale in Austin
- Lights DImming
- room in the garage...
- Front Sway Bar Insulator Installation?
- ignition problems
- brake/tail lights stay on
- restomodding
- for the bench seat lovers
- '67 Mustang A/C, Heat, Defrost woes
- power steering hose bracket location
- Problems
- Psiclone - Autolite 1100
- 4 speed
- holley carb on craigslist
- need help headers
- Shelby GT350-H color?
- How much power am i making
- Dizzy Question
- Strud Rods
- TOO HOT!
- yes, I am now a born again texas..for now
- People with bench seats...
- 73 mach 1
- Phenolic spacer question...
- rebuild a classic
- Here is Some "65-66 GT" History.
- replacing exhaust manifold
- Might Buy A Salvage Yard T-5 Tranny $450
- Review: Scarebird Co. 6cyl Disc Conversation Kit
- I Think The Shop Screwed the Pooch: Frontend Rebuild
- How do I post Pics?
- stretch mustang
- Transmission and rear end question????
- Primal Scream
- New Project
- blue smoke,, blue smoke!!
- rear end assembly
- 1965 Mustang value
- plenty of go but no whoa
- better intake?
- Break My Rear
- Whats your Stang worth???
- Help Me!
- HELP!! What size electric fan for 66 mustang?
- Engine stalls - intermittent
- CENTER CONSOLE
- C4 tranny ?'s
- Steering clearance trouble
- C6 Pan Torque
- Distributor static timing.
- 67 power steering bracket
- body/paint shops
- CArb linkage questions photo please
- Checkoff list for engine swap, yes I've done resaearch . .
- 66 auto to T5 conv. ?brake pedal?
- shock install question
- GT 40P's?/ What headers?
- seats for 68 coupe.
- No Spark
- HELP!! Emergency Brake Install
- Found some front discs
- Help what rear gears do I have?
- 66 front fender nuts in rocker panel
- new transmission adjustments
- Alternator ?'s.
- I hate brakework.
- Tach
- just how fast is a...
- Orange peel in paint
- 351C 2V to 4V question
- Distributors OUT... I own that thing...YES!
- OEM grille, worth how much?
- Classic car with modern drive train??
- lots of play in my steering???
- electric fan vs. other one
- New owner of a 1966 289 Coupe
- I'm Sorry But It Happens To Mustangs Too
- granada spindle replacement
- '67 Convertible Glass Membrane
- where can I get
- Bracket/Bucket
- 65 in-dash "Type D" speaker
- Intake Sugguestions
- Staples on the Hood Seal??
- WHERE IN THE CAR
- New Carb-Great
- high back 65 mustang seat interchangeable
- exactly what will happen to a 6cyl stang with v8 replacement if no underchassis work is done?
- P/S question: pump alignment
- Help!!!need parts for a 1 bbl motor craft carb
- Is an anti-stall dashpot important in an auto?
- power steering pressure line
- Surface prep for new primer and filler
- Deck lid springs......BOING!!!!!!!!
- Know a restorer in DC area?
- Pinholes in Floor, Treating the pans
- Sand Blasting Small Parts?
- shorty headers for a 351C
- Best Donor
- Ignition Coils
- Distributor won round two...
- blinkers
- Carb rebuild
- Anyone in SOCAL want to get together for mustang Play Dates?
- 289 POWER
- HOOD COWLS
- i6Lowering springs?
- replacing gas cap
- TORQUE / ENGINE SPECS
- #1 cylinder?
- Young Owning The Old
- Toploader - how to evaluate the condition?
- 69 GT Coupe Side Scoops
- a little help with weatherstripping
- Cooling system- what is that replacement for radiator fans?
- Restoring a 65...interior rust????
- larger radiator for a 65-66
- Eleanor Engine??
- Anybody ever install the larger 15" styled steel wheels on a 65-66?
- my turn for a help question
- Archeological Resotrat
- Gauges broken?
- holley carb
- The Great Race (its not a race, its a rally!)
- What is this?
- How to tune your vintage Mustang for improved performance.
- Mustang Club of Houston Car Show Pics
- 67-68 FB Interior Vent Grills
- Clutch pedal question
- Valve lash question
- Trunk weatherstrip
- horn again .. what am I missing (pics)
- Eating crow because of bad advice.
- brake hose bracket location on a disc brake upgrade
- My engine, oil pan troubles
- Steering creaking sound
- 289 Oil Pressure Sender Orientation?
- 1968 mustang...engine vin?
- Carb Installation
- 67 Mustang Gas tank
- Floorpans?
- Is it just me . . . .
- where to buy carb parts for a motorcraft
- 427 medium riser
- Motor for my 69
- what a car ...
- Lincoln Brakes on a Classic??
- Glass Refinishing - does it work??
- Diffrential code
- Starting
- Pictures from Mustang Unlimited car show today
- Distributor stuck
- front tires squealing - alignment? something broke?
- Top loader & Bell housing
- Engine swap: 200ci I-6 to 429 CJ
- What to expect - want to buy a classic Mustang
- 79 truck help?
- 65 steering gear box
- Oil Pan/Dipstick
- New front tires,, and rear air shocks
- engine tick
- Ignition Issue
- the need to feel the power
- install time vs mechanic install
- Disc brake pressure control valve
- body shop price
- clutch fork-u
- 2004 seats in a '69
- Starting the Car Soon
- power stering
- MOVED: 347 longblock STROKER
- Can,t locate my Flasher Assy.
- Car stalls when put in gear.
- 500 error message
- Mods for a I6
- Mods?
- Dim Headlights?
- Gas Line & Gas Filter
- Top loader progress
- How fast?
- pulling a travel trailer with a 68 mustang?
- For Soaring
- wheel offset question
- wipers go too far
- Engine Ground Location?
- New engine?
- 69 mach/428cj/4spd Header fit???
- PCV tube
- Ignition / startup??
- 64 - 70 Spindle Info:
- Insurance?
- How much is enough?
- oilpump info
- Mustang Steve Disc Brakes?
- what parts can i use?
- Thread sealant and my thermostat housing
- which way to sell engine
- Converting a coupe to a fastback ???
- 68 Restoration
- Can you help me with this out of order trim tag?
- traction issues
- i want to modify, not restore, but cant find fitting stuff
- frame brackets and 9" rear ends
- A little slow the last few days.
- Need 65-66 seats
- Switching from L6 to V8 questions.
- Tranny ??
- good news sorta
- 1966 Ford Mustang Limousine
- Spotted a 289 Vert in the wild today =)
- Master Cylinder
- Mustang Steve brakes
- Body Alignment
- 4 speed tranny.. how much?
- oil pan for a 347 stroker
- C6/C4
- HELP! I'm installing Versailles 9" rear
- Oil Pan Removal
