- HEI style distributor
- Instrument gauge lights
- brake stuff
- h pipe doesnt fit
- finaly started the engine up
- Shelby settup
- Electric Fans
- Window rollers
- well i gotta ask... 8" vs. 8.8"
- No rear seatbelts....
- Cowl leak repair
- 1965 Mustang 351 Modified
- What stock '66 style motor mount (2 to chose from)
- theres oil comming out of my dipstick
- Cleveland problems
- 351W engine problem
- Some pictures from paint shop
- 65 351w c-6???
- shifter or tranny at fault?
- Driving like I Stole it
- general questions
- Temp switches
- the value of ford parts
- Emblem Adhesive
- 8" axles in a 9"?
- addition to plainsman's post on weather stripping
- Carb isnt getting fuel (Holley 4160)
- Ram air Mach1 ..
- 68 Backup Lights not working
- Stupid Cali Emissions
- Patriot tri-y fitment problem (rubs on shock tower)
- Performance Automatic C4 Super Streeter transmission
- when i drive to school...
- She's not starting! HELP! (could be timing issue?)
- Can someone post a '65 coupe antenna install stepbystep?
- Fuel Boiling?
- Finally off the jack stands
- 1968 Cougar XR7
- Windshield
- Is this going to be a problem?
- Just Bought a 68 GT with a 302
- 67 cowl hood
- driveshaft help quick!
- Really nice how-to for weatherstriping
- Go vote
- valve cover torque value
- starting trouble
- Por-15 second coat application question
- NEED TRANSMISSION HELP!!!
- ROTM voting for May is open
- Heater Core Leak
- Ignition switch removal
- Few 1965 coupe questions.
- Need a windsheild removal tool...
- 2 + 2?
- baer brakes
- thermostat question
- 68 Mustang Carb problem???
- Rust inhibition
- Video
- 67 Floorboards
- distributor 180 out
- edelbrock carbs
- Brake light issues?
- Clutch help
- Mustang Forums Project Mustang Name Poll
- front ujoint help
- Im gonna paint my car myself.
- help!!!where to get rear molding 73mach1
- Tune-Up
- need some advice
- do thermostats go bad
- Lemans Stripes 1970 Fastback
- clutch springs again
- water pump replacement
- rack and pinion convershion
- MY CAR IS RUINED
- Tighten up steering?
- Frame bent
- Wiring diagram for 65 mustang.
- oil everywere
- car show in fla
- Posi Install
- cable clutch
- 65 mustang 351w c-6
- Will it effect the value?
- edelbrock preformance rpm package
- Small Frame rust!
- 3 engine removal questions, well kinda 4 or 5...LOL
- eBay finding...
- 1973 351Q Code
- AOD trannie on 67?
- Steel Cowl Hood for a 1966?
- Decklid..steelie or fiberglass?
- stock 65' 289
- flywheel balance and number of teeth
- how to put a distributor back
- need some help desperately!
- starter or short???
- Project car wont start not getting spark?
- TCI and B&M Torque converters compared
- driveshaft removal
- throttle return
- Stock Speaker Location?
- Driveshaft too long?
- Knock when hot
- headers for a 69
- Need POWER for cd player!??
- Speaker wiring ?
- longtube headers for 66 with 302 and AOD
- question about 9"
- wondering about my 67 fastback S code
- brake line troubles
- Outside Mirrors for a 67
- Stuffing a 91 into a 66 - what can I use??
- MCA Anniversary Show in Birmingham
- throtle return spring
- need tips and tricks to removing leaf springs
- 3.55's or 3.73's??
- sway bar stock?
- Linkage?
- window problems again.
- 9" centre into an 8" housing ?
- Help with greasing upper control arm ?
- Which is more valuable
- where are the #'s?
- 66 Mustang Electrical
- Customizing old exhaust to fit new tri-ys
- Brake line help
- 1969 351W fan options
- Insurance Company Caved
- Where to get one
- My project today.
- decoding my car
- New Parts!
- FE aftermarket
- is it a big deal to replace the floor pans?
- How do you check the cowl vents for rust?
- Edelbrock carb & Vacum line ?'s
- argh, must not cry...
- Does the 68 yrs have....
- Need help on finding a new carb
- speed/tranny question??
- Soda Blasting
- Virginia Classic Mustang
- Installed my MSD 6A yesterday
- master cylinder conversion
- Battery Apron
- Some progress and a color
- Putting my 9" rear on next weekend
- I know this should be in "off topic" but HAPPY EASTER boys!!
- were does it go
- good then bad day
- rear end spools
- Please help on intake manifold
- How do I make an old engine run?
- what are the most common rust areas in a mustang
- Mustangs Plus special offer on suspension
- Clutch peddle sticking out too far
- Help wanted - Looking for mustang dealer
- Busted torque converter stud
- Best aftermarket C4
- 65 fastback fan diameter
- Steering Shaft
- Build your own - save $$$
- Free Granada Swap installation guide
- Glaze Filler Stuff
- explorer rear disc brakes?
- tires
- Maintaining the block?
- Will not turn over?
- 67-8 fastback deck lid molding clips?
- rear disc brake swap
- tranny
- no numbers on balancer
- Fuel Bowl threads stripped
- Ways to protect my investment?...
- WATER LEAK
- CAN YOU GUYS HELP WITH ME GETTING A NEW DOOR TAG
- Ball Joints - Help, Advice, Doing something wrong?
- what color?
- rear ends
- Rear End Fluid
- Where do you get your sheet metal?
- Horn Help PLZ
- 65 fastbak
- rewiring????
- Cylinder head torque spec for a 200
- 4 lug to 5 lug swap
- starter noise
- Restoration Guides
- Question about overheating and blocks.
- twisted frame end
- Exhaust system ?
- Ignition Coil Wiring
- Cruise-O-Matic
- 65 fastback Fan diameter
- windshield installation
- Traction Bars
- Rainbow Products A/C and heating...?
- Crank pulley
- Trunk Pressure Valve
- Did this for Soaring
- Valve retainers
- THE SUN IS OUT!
- ut oh trany
- swap bezel/gauges
- cant anyone help with my 66?
- 67 fastback sale
- 1966 fastback Frame rails
- Quater Panel differences?
- carb spacer does it matter?
- Anyone live is Cedar Park Texas that can go slap those boys at Mustang Project for me?
- Tightening Question
- simple gear oil question
- Pertronix
- speedometer gear question..
- A BRAND NEW '70 Convertible????
- Intake manifold instal and valve adjusting ?
- fuel gauge
- 66 coupe orig color and other stuff
- how can you tell a 64 1/2 from a 65
- can you guys please help me decode this vin
- mufflers
- Radiator size question
- New owner needs help
- Comes home tomorrow!
- engine wont start
- New Here! Need rear spring help
- smoke from dipstick
- Brake Locking Up
- Batteries
- what to name her
- Do you use sealant on a rubber gasket?
- If it's not a head gasket, then what!??
- Mustangs Unlimited
- So I'm preping for Por-15... question.
- Removing old Parts
- signs of coolant around base of distributor???
- First time on the freeway in the "new" 66
- Sagging Doors
- Tail Light wiring
- 1967 6-cylinder book
- Gimme any advice before I dig in
- So the wife caught me today...
- Engine and Carburator Tag decoding
- 66 Convertible being raffled
- 66 Hubcaps
- new shelby razor wheels
- which heater hose goes where?
