- Windshield leak
- oil pan fit?
- crate sitting
- 89 mustang
- Got the tail lamp harness installed
- jacking up the car
- american pony parts
- Ever wonder if your really saving by buying "the kit"??
- Rear shackle emlinators?
- Question for the San Diego guys.
- Great News
- I've got a new motor to add to the "collection"
- TORQUE CONVERTER BOLTS
- Rust Bullet -vs- POR 15. Experiences please.
- Turn signal cam
- car runs smoother
- Hello,
- Wheel spacers/adapters?
- Got my wires
- Why would my brakes be "loose" at first?
- external oil line 351c ??
- cloudy white on oil dipstick
- unique guage locations???
- 67 Clutch Pedal Assembly
- HP set-ups
- k i got one pic of my mustangs!!!
- Asked that guy the costs for the paint job on my '65.
- What kind of gas do you use in your classic mustang?
- getting ready for the Mustang Roundup in steamboat!!!
- My engine wants to run?
- Fast and furious tokyo drift
- right front signal lite does not work all others do...tips on fixing it?
- Salvage Title?
- What to do with old carb?
- Power window conversion?
- Young kid with a new Mustang vs a classic
- Finally, my PS Pump arrives!
- Trunk - before and after
- Ethanol OK?
- Show and tell!
- WHAT NEXT
- IM SICK OF OLD CARS
- t-5 conv...
- Need help starting car
- Help me fix my leaks!
- change...
- Which pipes
- Pic of engine finished, but rough idle...
- Need Help
- Front coil lowering question
- I think i found my solution!
- My Car on HRPT
- where to find sheetmetal
- 5 bolt bell housing & 260 Engine(64.5)
- Miles per gallon - how much?
- gear drive
- What a mess of wires.
- Lowering front end question?
- Ford autolite 4100 4 barrel carburetor value?
- 1/4 mile time for modded 66' doesnt sound right
- 1965 6cyl Carburetor trouble
- I'm so proud of my self
- Fender removal?
- aftermarket gauges
- 2 Row or 4 Row???
- Want to keep factory tach.
- Acid dipping....
- Another project finished. Rust in trunk
- vinyl top or hardtop?
- frame rails and torque boxes help!
- 68 coupe??
- Restoring 1964 mustang in Atlanta
- Should we modernize our classic?
- rust hole under the rear quarter trim panel
- West Michigan Mustang Show
- Cross Section Books?
- how many were made
- Compatability Concerns
- How do you guys know...???
- 1968 Pony Center Console??
- 69 MUSTANG DELUXE SEAT COVERS, CRISP AND CLEAN...
- v6 to v8
- electrical?
- Plug Wires?
- Quarter Panel Extentions - Bad Fit....
- Are all year pony emblems the same?
- Front Disc Conversion
- New fuel pump... Not starting
- Another project today
- trac-loc & rear end questions 101
- 3 DAy old Rebuilt Tranny Knocking
- New pics with the new grill
- wrong master cylinder
- 1965 Production #'s by exterior color?
- it gets worse!
- chosing a piston ring
- I want some flames
- How much will turndowns do?
- RADIATORS...
- Home made 67 R type valance. Whatcha think?
- Mustang II discs on a 1966
- versailles spindles
- clarece
- eleanor
- Need help with 67 steering wheel
- OK.... Problem, i need some help!!!
- I gotta know, auto shop class in school or not?
- Steering, Power to Manual
- best parts place?
- Windsheild Trim Removal?
- C4 to 4 Speed $$$$ ????
- oil ring update
- Realigning my bumper question.
- info on c6 trans
- 289 inline 6
- birthday stuff
- sorry for the double post
- Carb specs?
- Altantor / Regulater 66 would you up grade ?
- Valve lash on a 200 I6?
- rain leaking in my 66
- removing/installing lock cyl's
- side emblems
- Need front hubs
- Power steering pump pulley
- oil ring
- My 67 Mustang "Mystique"
- extra 351c2v parts
- Lift ponts?
- Wheel spacers to fit disc brakes?
- How good of a deal was it?
- Codeing your car Need help!
- Help with 69 mustang seat removal!
- Good to Go.
- My 66...work in progress (Pics)
- 68 coupe floor pans
- I NEED HELP
- Intake Threaded Hole Totally Screwed
- pic's finialy
- well your not going to believe this garbage!
- Question about Transmission Coolers
- I am planning to buy this '65 mustang....
- Finished my new grill!!!!
- car on rotisserie pic - best rust protection?
- trany lines
- Right rear flasher not working.
- wheels and tires help
- Original Magnums & 67 coupe
- Help "transmission
- Seeking solid 64-66 'vert chassis
- three gauge cluster - how to install?
- 68 Hood Mounted Turn Signal Problems
- Clutch Rad Fan.How should it work?
- The more I think about it. I think I wanna change the color
- sorry guys. but yet another one
- Aluminum radiator
- front disc prob
- 67 rear end or rear brake problems
- Drip Rail Replacement...or removal?
- Rear Axle Problems
- installing new front bumper
- good price
- 66 project car
- sheetmetal ordered
- dipstick broke dipstick
- a few questions
- car keeps running
- i cant make this sound go away
- Largest length muffler that can be stuffed under a 65
- rear disc brakes
- So here is my dilemma...
- need info in a hurry 351c crank
- need some # crunches!
- Stupid plug wire ?
- Wont idle
- fans
- Installing floor pans. Support question, all or some?
- pics of my 67 vert.
- KYB's are now installed
- pics of shelby drop
- X-PIPE...
- wheel size help...
- car shutters
- Changing Oil Type
- interior paint colors
- tire size for 65
- Vinyl Top, Do you have one and what do you think?
- 'Sprint' Questions
- autozone gt-40 heads...
- New Purchase: 65 Coupe
- headers for a 289
- power
- Cruising Gears
- 68 electrical problem
- my 69 is here!
- First ride
- A Hole In The Water Neck....
- RING JOB ON 289
- My 66 is overheating
- Need help with hoses
- oil pressure
- Got my gas adjusts
- charging ?'s
- my 66 mustang
- Gauges & Constance Voltage Regulator
- car trouble
- what looks better, ON or OFF?...
- what type of grease?
- cylinder heads - opinion
- Alarm installed
- Disk Brakes for 65-66
- 1968 mustang/cougar brakes. . .
- headers
- whats up fellas???
- Proud owners of a '67 Mustang
- 1965 Mustang GT coupe needs restored - $3500
- 66 front end wiring harness
- 1968 Coupe Quarter Extentions....
- 66 door creaks ?
- later model mustang seats in a 69
- 1965 fastback weatherstripping install prices $$$
- 1965 Mustang Interior Question
- Is your classic mustang an everyday car?
- strut tower braces
- Look at this car
- front end alignments
- How much rust encapsulator?
- Overhaulin redoing old Mustang Tonight
- finally, i take her home tomarrow.
- prepping a rearend? (sandblasting tips?)
- 69, Best way Through Firewall
- Vinyl Top/Paint Combos
- Whats the prime year for a Mustang?
- My car is now Rangoon red!
- where can I get a 1965 fastback eleanor replica hood?
- Protecting welds?
- rare 67 taillight panel question......
- 69 Mach resto progress pic
- grill
- 65 Rearend swap
- stock351c2v
- glasspacks
- racing or street
- is this a good welder?
- KYB Gas Adjust shocks
- Will this work!?
- SUSPENSION...
- MOVED: Trick my Rides
- 1972 351W balancer/flexplate
- 1968 in pieces
