PDA
View Full Version : Classic Mustangs (Tech)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 [137] 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172
  2. Automatic transmission?
  3. temp. guage
  4. PS to MS intall help (lubrication)
  5. Autolite 4v Jetting question
  6. Open holes in underbody?
  7. 66 Flasher switch
  8. What's the market like for a 67' FB?
  9. need advice
  10. Some 1967 Questions
  11. U-Joint
  12. which transmission?
  13. brake problem
  14. rear disc brakes
  15. The engine tranny is in!
  16. 302 Engine 67?
  17. block strength
  18. Brake light wont turn off!!
  19. transmission swap question
  20. gauge options?
  21. Fe?
  22. steering ?
  23. 69 351 Elecrical Questions
  24. C4 Transmission Fluid
  25. restomod66.. please!
  26. Is this bad? (intake manifold)
  27. Clutch Question
  28. 66' window linkage problem
  29. running rich
  30. what would my car sound like if.....
  31. Which proportioning valve?
  32. 66 Convertible - Engine Fire
  33. Concours or concourse?
  34. '66 replacement parts
  35. Brake Swap Comments
  36. New carpet
  37. Original 65 Grille assembly..what's it worth?
  38. LOOKIT what I just won on Ebay!!!
  39. ford tooling vs. aftermarket
  40. First start of day is hard. Rest are easy
  41. proper rotella-t weight for 289
  42. what price
  43. pics of my motor...
  44. 1977 Granada
  45. What is the HP of a 1966 A code?
  46. 302 stock cylinder heads
  47. what is this?
  48. I6 Question
  49. 3 point belts, in a 65
  50. basic questions
  51. BB Coil Springs too stiff for a small block?
  52. Cost to replace front frame rails?
  53. Power Steering Fluid Out Fill Tube
  54. Bolt Spacing for 69 Wheels
  55. Export Brace Performance
  56. Vent/Heater blower quit
  57. 68 Mustang Wiring
  58. is this a 289 or 30
  59. Total Control Products
  60. how to bring chrome back to life?
  61. Interior question
  62. rear valance question
  63. Alternator regulator on '68 289
  64. taillight
  65. !969 Mustang Project...Need Input
  66. Removing rear shocks?
  67. alternator relocation
  68. I Made It !!
  69. He Heee! 425hp/425tq 351C is on the Dyno, pics & video!
  70. Sorry Soaring
  71. Best Way to Clean and Paint Dash?
  72. Intake Manifold question
  73. Heater Blower Motor
  74. Can a valve job cure smoke from the breather?
  75. Just ordered my new Edelbrock 650 AVS
  76. step by step i6 to v8
  77. 66 - Painting/Restoring Interior Metal
  78. C-4 Transmission not shifting in drive
  79. AOD???
  80. PVC breather?
  81. 65 AT kickdown bellcrank picture
  82. Is this a decent price?
  83. panhard bars
  84. Brakes for a 65
  85. PowerSteering Question
  86. dane cook
  87. new splash guard pics
  88. 351 oil pressure
  89. Transmission problems?
  90. going to a pointless ignition...any suggestions?
  91. turn signal flasher switch
  92. couple of new pics of my '65 resto mod GT
  93. FMX Tranny Dip Stick
  94. License plate thread
  95. Rear Valance/Dual Exhaust Question
  96. Brighter Lights on 1970
  97. cali emissions?
  98. timming once again
  99. Mustangs made in Amsterdam
  100. rebuild advice
  101. Got my Stang back.
  102. oil
  103. vacuum source for 67, 200 engine
  104. Ignition replacement
  105. BB Coil Spring Rate (lbs.) ok for sm blk?
  106. Intake manifold Question
  107. Spitting Mustang
  108. New to the forum...
  109. leaking gear oil from driveshaft?
  110. What size carb would you run on it?
  111. 360 Engine
  112. Rare Hood?
  113. convert to throttle cable?
  114. 1968 Mustang
  115. Aftermarket Air-conditioning?
  116. GT350 Question
  117. Was it worth it?
  118. whats the diffrence in codes made by mustangs?
  119. 65 efi Q
  120. Paxton Supercharger
  121. Subframe Connectors ?
  122. Can't find a new gear selector
  123. Here's my new Stang......
  124. Built my workbench.
  125. lucas products - synthetic or straight 10-40?
  126. 66 door handle
  127. Change Export Brace - How Hard?
  128. Voltage Regulator
  129. WHAT DOES A 'CANTON' WINDAGE TRAY DO
  130. HOW WOULD 'YOU' ATTACH A SCOOP TO YOUR HOOD
  131. Pomona Classic Car show ( august 27th ) W/pics
  132. Project Update as I go
  133. "Fun" day.
  134. stripping paint
  135. AM Radio, speakers configuration possible
  136. Electronic Rustproofing system, anyone knows about that?
  137. vinyl top replacement
  138. The engine is painted and tranny mounted, ready to go in!
  139. Coys Wheels
  140. Has anyone used dallas mustang?
  141. I want to get a classic mustang and make it drift like the one in that movie
  142. IS chrome making a comeback on new cars?
  143. Any Pontiac People Here?
  144. pinging!?
  145. Outer tie Rod Problem 'downunder'
  146. where did all the....
  147. Free White Face Gauge Overlays
  148. Room to pull
  149. Shock question
  150. part removal before paint
  151. 16x7 ss cragers on 69 mustang
  152. What Sould I start with!?!?!?
  153. showing my a$$
  154. MUSTANG script in stripe pic.
  155. Glove box idea?
  156. woooo!!!
  157. Trouble Timing Engine
  158. Wheel Cylinder/Backing Plate Bolts
  159. 65 suspension and brakes
  160. Dumbest Mustang Question Thread
  161. steering wheel/steering
  162. How to determine engine on 71 grande?
  163. bullitt wheels on an old stang
  164. Framerails... ?'s
  165. Another Project
  166. My bodyshop quote?
  167. MustangsUnlimited selling Mopar stuff?
  168. Engine number
  169. Installing Door Lock Knobs
  170. How much does my mustang weigh
  171. Header installation question
  172. ATF in Power Steering ?
  173. Water Pump Bolts (where do brakets go, bolt lengths?)
  174. Finished fabricating my ram air
  175. mustang 2 wheels
  176. Picked up my new engine
  177. 60's stang impractical for daily driver?
  178. This is what I call a car
  179. rocker panel mouldings
  180. 1966 Headlight Adjustment Procedure??
  181. 1966 Mustang Shift Knob
  182. Brake lights #@%&!!!!!!
  183. Are they pulling my chain?
  184. rear end gear
  185. steering wheel motion
  186. early or late production?
  187. Hedmann Headers
  188. 69 mustnag fastback
  189. my 302 hits 4000 rpms at 75...
  190. REPLACING OVERFLOW TANK <----NEED HELP---
  191. determining gears
  192. Hurricane
  193. motor dissasemply
  194. 351W vs. 351C vs 351M/400...how can you tell which is which?
  195. old gas in gas tank
  196. What Wheels?
  197. '60s Mustangs
  198. 1967 mustang - front end lowering
  199. X code Mustang on ebay?
  200. i got it
  201. Replacing Package tray.
  202. timming help!
  203. REMOVING P/S VALVE FROM PITMAN ARM
  204. Distributor Recurving
  205. Water Temp sensor location
  206. a 460ci into a 67 - 69 fast back??
  207. Fuel Gauge Resistance?
  208. 66 rearend id..how?
  209. Front Tire Size?
  210. rephrase - Mustang II suspension and steering into a 65? I got this off the net...
  211. take a good look "WOW"
  212. WTF is this thing?
  213. Painted Dash
  214. Rear Valance Pics
  215. classictube.com
  216. 67 frame rails
  217. Back to original radio
  218. Tires Balanced
  219. Removing Speedo Needle
  220. wrong sheet metal
  221. greasing ball joints, control arms, etc.....
  222. AutoMeter Tach Issues
  223. 289 2v stock carb adjust
  224. 66 Mustang Fuel Gauge ??
  225. Pertronix vs. Mallory Unilite
  226. sitcky pedal
  227. made in tailand
  228. mustang fastback conversion?
  229. engine schematic
  230. MOVED: Full Tilt Street Rods - Mustang II crossmember
  231. Need Tire/Wheel advice
  232. How Rare????????????
  233. Keep emblems?
  234. Scam Alert Please Read
  235. 66 fastback A/C
  236. '66 Clutch chatter
  237. GT stripe on!!
  238. Severe Tire hopping!
  239. Or mustang II front end into a 65
  240. 74 stang shock towers into a 65?
  241. 74 stang rack and pinion into a 65?
  242. Leaping forward to 2009
  243. 351 into a 65 Convertible...is it safe?
  244. Oh.. it's me again..
  245. 68 - 289 - Shakes in Drive / Reverse
  246. 302 into a 66 coupe?
  247. door sag
  248. Lax Vegas Mca National Show
  249. 66 Mustang Interchangeability
  250. Replacing a 302 with a 351
