- how would I know if my fastback had factor air
- RPM Heads- FINISHED
- oil pan
- This is my son..Last night
- i won a carsponsorship!
- i lost my wheel (now with pics!)
- Real Wood Steering Wheel
- Global west Stage 2 Suspension kit
- is this a good deal?
- 289 Head/Cam Help
- 1972 Mach 1 Question
- 1967 Convertible Good Buy?
- 1969 Dash Clock Question
- 1966 Upholstery TMI vs Distinctive Industries
- craigslist Score! new seats!
- Haha Hey guys check this out
- Engine Build Help... My first build!!!
- picking up motor from shop today
- Selling my 66, need suggestions on upgrades
- 67 p/s pressure hose
- 65 convertible?
- is this a good buy?
- GT Fog Light Kits
- Fastback project for sale
- got more curious about my engine (decoding)
- gauges
- help with vin# question......
- Need 2 Ford Mustang 1964 - 1969
- Your Song & Your Car
- motor help
- Batterie is not charged
- Selling my 69 Mach 1 Spoiler
- 68 Aftermarket Metal
- bleeding P/S pump
- 390 motor mounts / repair or replace ?
- Are saddle interiors relatively rare? (67-68)
- 289 block
- thanks to JamesW- help with mini starter
- Getting a new ride! Thanks to . . .
- 302
- 68 Horn doesn't work
- Mustang 4Sale
- piston/cylinder size 289 block
- Question for the MIG welders.
- more tranny q's
- power steering backet for headers
- 1968 302
- Workshop Manual CD
- 1970 key cylinder removal
- WOW! The price of classic cars has gone up big time
- Brakes....HELP!
- Speaker & Location Selection
- trying to safen up my ride...need advise
- Did 1970 Mustangs all have collapsible steering columns
- IM GONNA BUY AND SELL!
- tech question
- New Issue - HELP
- 4.6 swap - motor mount questions
- Another question for you guys that have done the T-5 swap?
- Just found out my motor is a '64. Good or bad for my application?
- 04 Cobra drivetrain into 67 Mustang Fastback
- How many amps do headlights draw?
- PCV question
- Lightest stock flywheel.
- New Member New Project 64 w/picz
- Engine Parts
- motor craft 1100 carb issues
- Wire a PA Alt on a 67
- one wire alternator
- where to purchase a mini starter
- thermo
- Rear Window Removal?
- mini starter problems
- 69 351 Windsor Vaccum diagrams
- Removed CA Emmision, Help!
- what size tires came on a 66?
- Power Steering Vs. Rack and Pinion
- Leaf spring question?
- Ignition switch
- Cobra valve covers
- Headlights on '67 convertible
- the stang got saved
- 289 by chance
- T-5 transmission from '95 GT
- Pushrods- Help please
- 1965 - Good buy?
- rear disc questions.
- 1966 Mustang Horn
- Shelby Drop complete!
- Transmission Q's
- MSD didn't fix it, I'm barkin' up the wrong tree...
- engine rebuildto
- T-5 transmission lubricant.
- my 65 pics
- Drum to Disc - 14" Rims don't fit.
- Quick question on front disc brake upgrade....
- MOVED: RACE?!?!
- my new rear end
- Brake System light turned on.....
- electrical re-wire question
- guage ?'s
- New Tranny?
- rad is losing water but no visible leak. what's wrong?
- help changing 2bbl to 4 bbl carb 73 mustang
- two questions??
- need help removing the colum
- Do I dare tear into the motor deeper???
- Rarest Mustang Here
- I think I damaged my motor??
- 66 mustang
- Installing Roller Rockers- Need Some Help
- Reliability of your Mustangs
- DTC and gear aligmnent
- some quick help please
- first car show
- 67 mustang UPDATED linkage to new edel 600CFM carb needed.
- wheel fitment 66 mustang
- Fuel Gauge Problems 69 Must
- Quarter Window Help
- steering box
- For the 72-73 guys
- names/screen names
- Have you seen this stang?
- fiber glass hood/gauges
- No turning back
- 1965 Coupe Question
- not a classic but...
- Replacing front marker lights on 1970 coupe
- How do I tell what gears I have?
- Leaking Transmission seal
- Single to Dual Master cylinder
- Heater core
- Need advice info for buying oil cooler for a 200 6 popper
- dust cover / inspection plate
- Front caliper pistons
- Kickdown cable pic's
- c4 or c6
- Cowl Plug
- Carb linkage
- Greatest Movie Car Chases
- Rack and pinion
- Flywheel Dust shield ??
- Hoping the classic guys could help
- Paint for interior? What to use.
- The coolest Mustang ever made
- Might need engine rebuilt
- my night with a 428 cobra jet
- 63 mustang?
- Can a 302 hang with a 351?
- 65 pics
- Just Got Front and Rear Suspension For My New 64 1/2
- Roller Cams; what's the deal?
- steering wheel issues
- I'd like to know what you guys think
- A danger near a ford short blocks when armed with a set of spanners!!!
- Radio Help
- Aftermarket Shaker on a 67 - 68
- Always Check your lug nuts after break work(a lesson hard learned)
- 4 lugwheels
- so i'm replacing the water pump
- Putting headers on, Starter is in way!
- '67 vs. '68 disc brakes, stopping ability?
- 1970 mustang, cassette or 8 track?
- Carburetor tag numbers-what do these mean?
- Got in a wreck with the stang and it may be Totaled
- Anyone need windows? *link*
- HP
- Ford crate motor question
- shock tower repairs help needed!!!
- Lean best idle??
- Distributor?
- Pictures of Dash with AC in 1970
- Cam and Stock Carb (is it possible)
- priming questions
- looking to trade
- Interior myself?
- Roosters & Wagons
- floor panel
- new export brace fitting problems
- Are these a good buy?
- Granada brake users?
- 302 question !
- Discs for the 67...
- 66 Sandblasted
- 500 error message
- those with Performer RPM heads- HELP
- Mustang Fastback Side Vent Drain Hose
- Newer custom front end on a 70,, weird
- 351c in 66 stang...
- maybe..
- I found another granada
- Accelerator Rod
- Headmen headers vs. other brands
- Coupe to Convertible
- In or around San Diego,, Body/Paint Contact info
- freeze plug sealant?
- Front disc or power brakes??
- HELP with 1st Mustang!!! (WITH PICS)
- Neutral Safety Switch
- Interior Paint Fiberglass/Plastic/Metal
- Brake Booster Suggestion
- looking for a pic of shelby accident in CA
- rear end power hold
- Rust, and lots of it...
- 4-Speed Question
- How should I do this...
- Cold cranking amps?
- stroker kit
- Subframe connectors and Hey!
- 302 for $75
- Need help figuring out what to pay for 1st mustang....
- 1969 For sale...is it worth it?
- new guage cluster
- Decoding
- rebuilt 289
- Dropping Car off for Paint tomorrow!!!
- Recommended primer for upper cowl?
- Need a '67 GT500 for a photoshoot in SoCal
- come on ebay pls stop!!!!!
- making your own
- Billet Lower Grille
- Cut Springs to Lower Front End?
- 64 1/2 Modified w/Alternator, Need new Wiring Harnessess
- 1969 Fastback Interior Panels???? Need Help
- Engine Help-many questions
- adding AOD to I6 what needs to be done?
- dash lights
- leaf springs
- Axle Spline ?
- 351C
- Wheel and tires sizes for my 73 cert
- Newbie saying hello
- faded seat covers
- Started the Teardown- Bring on the power!
- mini starter on a 67
- Bouncy Ride
- shoulder belt on a 68 convertible (in the shop manual)
- I won't ask for r & p opinions, but...
- '67 Mustang, Apraisal advice** good deal?
- So, it's raining a bit over here.
- some new shoes~!!
- Leak??
- rust repair
- speaker questions.
- Help with Interior & Floor Restoration
- check this craigslist ad
- 66' vent window hardware
- Some final questions.
- I6-V8 swap pics
