- Wrong color yeller
- In Dash Stereo Mounting
- C4 Tranny question
- Fuzzy Dice???
- Engine swap finished... Now what??
- What happend to the post up top??
- Front Disk Brake Conversion
- 68 Engine/tranny swap
- Can't get my '70 started... no spark.
- not a mustang, but check it out
- 66 C code Coupe Horns
- Body dimensions
- Went by T&L Engines last week
- Alternator for a 65 289 coupe
- window install
- c4 gearbox help!!
- Looking to sell my Mustang, what would be a good starting figure?
- Rounding up all my parts
- the metal, people need some help
- It Does Live and was Well Worth it.... Oh Yeah!!!
- It LIVES, and it is bad ass!
- Another use of a 289
- emblems and other stuff
- Brake fluid leak
- fan question
- 66 Radio recomendations
- 302 4bbl... which one?
- Early vs. Late fastback seat hardware
- Fastback door trim sealer
- Installing a new Spedometer cable...
- Some things just make you want to cry...
- New project anyone? She runs for 500 bux.
- question on a 351C
- Starter solenoid help for a 67 GTA...
- Another Mustang parts place.
- Is it just me ?
- 1973 air conditioning compressor?
- Pulstar Plugs
- rear axle seal/integral carrier
- Help!!! clutch pedal/bracket
- help with my '72 351C
- Help with intake install 2b to 4b conversion 351c
- rear seats on a 69 mach 1
- How much have you paid, and what could you get?
- HISTORY QUESTION
- What would you do
- intake manifold
- i need help with a decode
- My movie car
- Introduction - photos included
- brakes finaly
- 66 trunk lock install? (i feel like an idiot)
- How much power is reasonably possible
- Light Recommendations
- Question For the NC area classic owners
- Spark plug wire help!!!
- Northern Virginia Mechanics
- 1965-66 vs 1967-68 Engine Compartment Size?
- MU car show tomorrow in Lawrenceville, GA
- Back on the Road
- 70 mach 1
- Anybody looking for an FE Motor this looks like a dandy!!
- Making a GT350 .. How do you do it?
- mmm question
- I had to press the Fastback back into daily driver duty
- swaping out flex fan
- Sway bar
- Bench Seat Issues
- Changing oil
- Strange Noise?????
- Buying the whole seat?
- Suspension Mods for Aftermarket Wheels
- Strange Rubber piece
- BIG PROBLEM WITH #'s???
- 69 coupe alignment
- numbers matching?
- New doors hung
- 351c Timing
- New 67 Hood
- new to old
- popular crate engines
- Steering Wheel
- 4100 carb, spacer and intake?
- SHOULD I CHANGE MY GAS TANK
- Another Tire Question
- Will the 69 C4 trans fit a 66 mustang?
- New to the classic car thing, what should i expect for a fastback?
- Coolant leaks everywhere
- What color?
- clutch fan verses stock flex fan
- gas tank issues
- Fan Shroud issues
- 67 fastback 289>300hp
- 71 Mustang Instrument panel lights
- C4 Shift Kit
- Looking for Utah Shops
- 13" Wheels
- cheap 66 fastback indiana
- Car Dolly/Drive shaft
- Nice Paintjob....
- engine dying on 67 mustang
- Cowl - I think I'm in good shape?
- Production #'s??
- Front running lights
- Interior Wood Panels
- blinker question
- Styled Steel Wheel - what color?
- What type of exhaust system!!
- Spring perch
- MOVED: WTB 4100 Autolite and intake
- Door lock issue
- Parts on and ready to run!!!
- Ralph sold the farm.
- Emblem Removal
- Guess the name of that car contest.
- Parts came from Jim
- Almost took my eyebrows clean off!
- Wheels?
- Jumpy Speedometer
- pas window regulator
- Prices?
- New 68 owner
- 70 coupe floor pan
- seat belts
- A/C Compressor
- CABLE CLUTCH
- 9" rear end
- better cooling fan
- Gauge issue clarification
- What should I do?
- Here is that car with the doors that many thought was fake!!!
- What clutch for a '65 stock rebuild?
- frame rail extension rust
- what kinda tranny to get?
- Rear axle leak??? (WITH PICS)
- 1967 Valve Body Number
- 3-pt. Seat Belt Supplier
- Greetings from a new user with questions
- instrument bezel replacement
- caliper paint for intirior?
- Convert 1971 Grande to Mach 1 - Is it possible??
- ++++need help++crooked 302!!!!++++
- overheating??
- turn signal doesn't work all the time
- 1969 Roadrunner vs 1968 Fastback
- anyone ever use lead to fix bodywork?
- OMG, had to share this pic
- BEWARE LA MUSTANG
- Stupid fender question.
- Heartbroken...:(
- What does Glen (Soaring) do in retirement
- 289 pistons
- 65 Mustang project update
- 1970 Transmissions
- Shelby hood
- 1966 2.3 Turbo Mustang
- sent out to get media blasted
- 69 mustang gauges
- WEIRD CLUTCH ISSUES
- What color Black?
- If i get these heads(link in post), what exhaust?
- 1968 Shelby console repos??
- 302 Build opinions
- 68' coupe rear bumper removal?
- PONY MEET 7/22/07 - KENT NARROWS, MD
- Drive shaft installation question
- Seats aren't the right year?
- careful with who does your body work
- Appraisal?
- where to get good floor pans
- 351 and gt40 heads
- Adding emergency flasher to '65
- Code ?
- 70 pics
- Cold air intake on 68?
- Anyone have a couple of 289 stock pistons?
- 1968 mustang motor mounts for 302
- Engine Identification Tag (ID) question
- 72 convertable.... is there any major things to look for!
- Control Valve Question?
- 302 or 351
- 351W
- Need info on buying '65
- max temp.
- Hood Pins
- where would the engine numbers be?
- Slower on new server
- Inaugural drive...
- treatment of bare metal parts
- Audio System help
- Fox Body?
- Grab a Trak susp. questions
- Will it fit?
- 4100 carb & stock intake?
- Golden Hack Award Nominee
- Ticking Time Bomb???
- Wiring
- Trunk Lock question
- first show
- 69 engine bay restore and detail
- Total timing on a 302 ?
- What temp should i run my mild 302 at?
- Looking into a 65-69 Mustang
- axle seal leak
- Howto buy an old mustang
- sticker or no stickers
- Corral lights up
- best engine/radiator flush
- Custom throttle linkage complete
- Won't start when hot
- Window problems.
- Set me straight on H and I beam rods
- Figured it out!!
- Electric Fuel Pump
- MOVED: 1965 Mustang For Sale !!!
- Anyone intersted see classic forsale
- '67 Coupe Alignment Specs
- Vacuum leak?
- Car Show
- Site Problems
- How do I find out what size carb I have?
- Brand new '66 mustang owner.
- door glass swap
- Update to my 65 (alot of pics)
- new here (pics)
- Final shot
- what Holley do I have???
- Painting and Patching...
- Differential advice?
- Juke Box on the Cheap
- Rear valance is off
- How to get the rocker panel chrome off question.
- seat tracks
- MIG Welder?
- bullit rims on 65' fastback?
- Breather smoke
- Night driving
- Tail panel splash shield?
- New shoes for my horse - Pix
- Exhaust or Valve cover leak?
- E-Brake Handle Retrofit
- 289 Head Tightening sequence
- M code Coupes
- Upgrading drum brakes to disc brakes $?
- Engine help please!
- Who Needs Door Handles????
- -Door Pannel
- starter question
- any tips on header install?
- Question: What do the vacuum ports on my carb. go to?
