PDA
View Full Version : Classic Mustangs (Tech)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 [163] 164 165 166 167 168 169 170 171 172
  1. firing order for 68 mustang
  2. rear window problems in coupe 67
  3. Overhaulin, TV show
  4. Woodward/Mustang Alley Pictures
  5. Insuring a restored '65 as a daily driver?
  6. Close race for the ROM
  7. posi rear swap?
  8. 65' Temp gauge problem....
  9. TAGS GOT HERE! GOD BLESS NJ DMV!!
  10. Need help w/replacing dash bezels and knobs
  11. 1968 mustang timing
  12. Need a a distributor gear and lower pulley for a 5.0 swap
  13. Driver side Rear view mirror
  14. inline 6 to v8 swap
  15. Steering
  16. 65, 66 Tailight question -- felt gasket
  17. head lights problem
  18. FMX vs C6
  19. Disc brakes for '69 ?
  20. technical (maybe more trivial?) question
  21. inline 6 to v8
  22. Should steering components be painted after cleaning?
  23. engine + trans removal and soda blast ?'s
  24. Wiring woes
  25. 67 390 question
  26. Piston rings For 302 V8?
  27. rebuilding a 289
  28. question about rear pinion seal
  29. Ignition key cylinder removal on a 65? (My latest *WHOOPS*)
  30. Picked up great stuff on ebay!
  31. Key for a 68 mustang covertible
  32. fuel discussion
  33. 5.0L HO swap
  34. Glove Box Mounted CD Player
  35. We have a winner for August Classic Mustang
  36. Over Heating / Transmission Fluid Leak
  37. A little help..
  38. 73 Mach One Issues
  39. new to the site
  40. exaust for 66 stang v8
  41. Helped clean out a barn, found some 140 mph mustang speedometers.
  42. torque converter recommendation
  43. air cleaner snorkel thingey
  44. Manual Top converted to power
  45. what trany do I have?
  46. ac refrigerant refilling
  47. courtesy light problems
  48. need some advice quickly
  49. Need hood suggestions
  50. Trans shift lever rubs...
  51. Prothane, Polyurethane, Thermoplastic, rubber
  52. Is my car really overheating?
  53. Rain Gutter Rust Advice
  54. engine decode on 67
  55. 67 fastback rear end
  56. Classic Mustang Reliability
  57. Changing Speedometer Gear
  58. Questions about Wheels.
  59. Mustang Memories - Pictures!
  60. Converting to discs
  61. Anyone care if I start a thread b/t a few people?
  62. torque converter mishap
  63. What year "new" mustang would you rather have?
  64. 66 CONVERTIBLE ON EBAY! VERY NICE
  65. Aluminum Radiator
  66. Rear springs?
  67. Ride of the Month for the site... Classics rule
  68. Seat / Upholstery Question
  69. 3.50 or 3.89:1 on 302?
  70. Leaking Cowl
  71. STEERING......HELP!!!!!!
  72. Brake drum problems
  73. 393 stroker help wont rev past 5800
  74. Shifter Plate
  75. Who's got the fastest car with what mods?
  76. New upholstery questions
  77. 1968 302 starting problem
  78. Chrome Maintenance
  79. transmission input shaft
  80. found web site dedicated to K codes
  81. '68 Coupe production info
  82. Air cleaner and valve covers for A code
  83. help with a 64 restoration
  84. 1968 Running Great
  85. VERY nice convertable on ebay
  86. A few pics for my friends in classics.
  87. winter is around the corner...
  88. 67' tilt steering...
  89. Need a heads up from some experience
  90. is a 4 valve 289 a A code or K?
  91. I soooo sorry!
  92. HELP! Intake Manifold 66 289 engine
  93. Where to find 1967 Mustang fastback manuels and books?
  94. Mustangs Woodward Dream Cruise
  95. Ignition or Carburetor
  96. Tubular Suspension????
  97. 66 Fastback disc brake HELP!
  98. It's finally here......
  99. Electric fan CFM
  100. C code to A code?
  101. ADIOS!
  102. Hardened Valve Seats
  103. Is my alternator's amperage too high for my regulator?
  104. HELP: Im putting in a edelbrock performer manifold and 4bbl carb for a 289
  105. Rust
  106. 1967 Shelby Mustang GT500
  107. brakes delema
  108. Pick a number!!!!
  109. No Longer Have Ignition Key
  110. 64.5 update, and new everday driver
  111. Top Question
  112. '66: Fuel gauge not working...
  113. '66: Speedometer not accurate...
  114. expert advice...
  115. 73 Mach1 needs 15 or 16 inch tires
  116. 1966 Mustang Fastback, 514 cubic inch engine?
  117. transmission problems
  118. Finally got some time
  119. "New" member with presentation post
  120. Trans swap FMX to C4 in a 70 Mach 1 351C
  121. Desprite Cry for Help
  122. 67 mustang questions...
  123. Brake Stutter
  124. re-charging a/c problem
  125. 67 289 to 351c swap?
  126. Who owned my stang before me?
  127. 1968 coupe project car
  128. Got a blown head gasket
  129. What engine do I have?
  130. Old School Rumble
  131. electric fan questions
  132. Connecting a 66 mustang radio
  133. WHY OH WHY?????????
  134. 1965 Rear seat belts
  135. ALT Breaking Belts
  136. transmission loud noise & drop
  137. 1966 grille on a 1965
  138. transmission won't go in gear
  139. Head Unit/ Alt Question
  140. Temp Sending unit test?
  141. Custom console
  142. Coolant temperature question
  143. COME VOTE
  144. Vacuum Problem
  145. Thinking about a Mustang project car
  146. engine acting a little funny
  147. '72 Mach 1: Good or Bad buy
  148. 1967 VIN location on engine
  149. What else should I do?
  150. Where do I get floor mats?
  151. Voting Time for August
  152. 67 mustang high country special emblem
  153. mustang 1969 engine trouble, help plzzz
  154. Front window in 65 fastback
  155. 69 fastback stalls in any gear... HELP
  156. full exhaust
  157. 67 ride height?
  158. 67 289 to 351w swap
  159. how to change to manual
  160. rear end
  161. How do you post picture with post?
  162. Shelbys in Indonesia???
  163. K&N filter
  164. Do I need an Alt???
  165. '66, headlights blinking
  166. 67 mustang pwr str return hose
  167. Galaxie Nationals, August 13th Dearborn, Mich
  168. Dilema
  169. Distributor question
  170. Headliner torn at seam
  171. What's first?
  172. Question..... How far do you go?
  173. Nickel Plated Tri-Y Headers
  174. A question about 1 chamber mufflers.
  175. just out of curiousity....
  176. Electronic ignition HELP!
  177. Best Engine year?
  178. NEW CONTEST
  179. Please help change the course of my life...
  180. Best Stang & Why. Your oponion needed!
  181. What Exactly Defines A Cobra Jet?
  182. MIS ROCKS!!! - You missed it!!!! - Is anyone taking their classic to the Aug 6 car show at MIS?
  183. Overlay kit for console
  184. "Old School 91 hatchback"
  185. Covertible Well Liner
  186. cool valve covers & oil pan
  187. 66 Interior colors?
  188. color of parts ?
  189. Flywheel Removal
  190. new guy with a 69 MACH 1
  191. Locking Gas Cap
  192. Newbie Ppster (Again): Advice on door weatherstripping
  193. I seriously want to kill my mustang........
  194. I think my clutch went out...
  195. Mustang Suspension
  196. A 460 In A Mustang?
  197. Starter motor bolts?
  198. power booster or manual brakes??
  199. How to make sure it's a REAL Shelby
  200. What fits??
  201. Go or No Go?
  202. Help on Frame Rails
  203. Your opinion on this one ->
  204. underdrive pulleys
  205. V8 symbol
  206. Engine choices?
  207. disk conversion help [please]
  208. forgot how to set timing ;(
  209. Engine mounts??
  210. 289 vs 302
  211. Firebird vs. Stang
  212. New Pics of My '65
  213. off topic but hey, we love the guy sooooo
  214. Trunk lid HELP!!!
  215. car stalls off the line
  216. Air cleaner height
  217. 6 cyl - 8 conversion
  218. F5 Interior Trim Code = White w/Red Appointments?????
  219. new guy with fan question
  220. paint
  221. Color Help?
  222. WIN!!!!!!!!!!!!!!!!!
  223. frame, floorpans, and torque boxes
  224. cougar-mustang interchangeable
  225. Need Help Again!!
  226. Good deal or not?
  227. 65 Mustang Emblems
  228. head gasket blown
  229. small air cleaner?
  230. body work,metal>? fiberglass>?
  231. a/c help please
  232. transmission rebuild advice
  233. Bought a Ford Truck to haul Mustang Parts
  234. Engine Problems!!!
  235. Sound proofing
  236. [question] 69 shaker hoods
  237. How do you replace window felt?
  238. question about 68 coupe
  239. Differential Cover
  240. Floor pan welding
  241. Suspension question for '70 Mach 1
  242. Horn Doesn't Work?
  243. 289 Running Hot.. Please HELP......
  244. My first Mustang Mystery
  245. best oil for high mileage
  246. 65 Basic Question
  247. Performance/Tune up ???? Before-After
  248. transmission part
  249. Suspension kit
  250. holy crap ,got some seriuos power
