PDA
View Full Version : Classic Mustangs (Tech)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 [105] 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172
  1. A/C price
  2. Power steering
  3. shipping companies?
  4. suspension upgrade
  5. 67/68 trunk hinge question
  6. Photo Shop Anyone?
  7. Overfilling an Automatic Transmission - what's the worst that could happen?
  8. Stupid Question....
  9. Ok to mix synthetic brake fluid with regular?
  10. Ford 289 Header Bolt Size?
  11. Engine Question
  12. Distributor, First start question
  13. Gutted
  14. 1966 GT powersteering removal
  15. Mustang Legroom
  16. Engine temp tonight
  17. Gt?
  18. maaaaaaaaan, i want these 2 stangs
  19. camshaft question
  20. inner door
  21. cutting a hole in the hood yes or no?
  22. What can a Carb Spacer do for You?
  23. whats best for my 302
  24. 3 point seatbelts
  25. 289 Crank Specs
  26. 1967 Mustang horns
  27. Alternator belt squeel
  28. One wire alternators?
  29. 68 Tail light issue
  30. Sound System for Convertible
  31. Wat would you do if you had $700?
  32. Which Plug Wires?
  33. Rear Quarter Panel to be repaired
  34. High Beam Light
  35. 1968 mustang tach....
  36. compression ratio's
  37. To clone or not to clone...
  38. Would you fix this or replace this?
  39. AOD Converter diameter and Stall speed
  40. Windshield Removal Process?
  41. Speed demon 750 Carb on a 428 Cobrajet??
  42. reverse light problems
  43. Corral lights up
  44. my new delima
  45. torque converter question
  46. Rotor pics?
  47. PLEASE HELP! ASAP! 1967 Carb question
  48. Shorter Steering Column?
  49. What A Newb - Temp Gauge Install
  50. another stupid question by me
  51. 65vs68 Engine Set ups!!!
  52. 72 302 power recovery
  53. Power Bleeders????
  54. Fastback in popular culture?
  55. Possible
  56. CJ PP
  57. Mighty Demon 750 Carb, Treasure or Trash?
  58. Finally working on the 68 fastback 427 again!
  59. how much could i get
  60. Explain my spring to me....
  61. New distributor any Idea's
  62. fuel pump ?
  63. manual steering conversion
  64. How much to offer?
  65. 69-70 Air Conditioner Question
  66. Value of a 65'
  67. Power steering fluid or f type tranny fluid?
  68. 1970 Coupe Availability
  69. ac activated idle adjustment (solenoid) for 260 V-8?
  70. Good Year Eagle ST
  71. Purchase Stock Engine
  72. E-Brake Problems
  73. Production number by paint color
  74. Classic Mustang For Charity
  75. How old for a classic?
  76. 1965 and 1966
  77. carbon fiber or fiberglass?..
  78. 1969 dash pad removal
  79. what is this
  80. What changes are necessary to switch to an 87-93 302 roller block??
  81. battery still dying!!!!
  82. Put the Red Stripes on the Mach 1
  83. my engine is almost done.. possible problems
  84. 5.0 efi swap question
  85. 1966 Coupe, is this a factory A/C unit?
  86. Drum to disk upgrade kit question
  87. 351 W
  88. Parts are in!!!!!!
  89. Lowering
  90. rotor and cap distributor part number V8 289, 2V 1968
  91. Hey guys, need to find a good welder
  92. New heads should I bore them .030?
  93. Could a guy put together an "Overhaulin'-type" event for a noble cause?
  94. Speedo is off on 1968
  95. Parts is parts
  96. My Ride, New to Forums
  97. upholstery dye/paint
  98. fuse box layout
  99. Water Wetter vs. Purple ice
  100. Steering And Braking Problems!
  101. Timing gear question
  102. 65 engine questions..
  103. 65' VIN report help and your opinion
  104. Power Steering Fluid
  105. pieces of nylon/plastic in pick up screen
  106. New Vinyl Roof
  107. OH SNAP! $2500 Vert!
  108. 5.0/302 vs 5.8/351w
  109. Input regarding rear main seal replacement
  110. Horsepower for a 1965 289?
  111. power steering issues
  112. 65 console mounting brackets
  113. Ground Effects
  114. 1966 Mustang Coupe and a poor college kid...
  115. FS: 1969 Mustang Coupe
  116. Smoke coming from one side of 67 Dual Exhaust
  117. Other forums......Suck!
  118. Got my DL!!
  119. Car wont start, something electrical...
  120. How Old Are You Compared to Your Car? POLL
  121. Wild stang spotted
  122. Putting on Holley Heat Shiel with My 4 Hole Spacer
  123. Chemical Stripping
  124. New backfire
  125. wrecked '66 fastback
  126. found idiot wiring!!!!!
  127. "self-aligned"
  128. all lights pulsating
  129. RACK AND PINION STEERING
  130. Suggested Shocks
  131. 1966 Rear Question...?
  132. shaking comes and goes on my 65
  133. 66 GUAGES IN A 65
  134. value for a 65
  135. what is my 69 fastback????
  136. Junker Car!
  137. change oil, no oil pressure
  138. Increasing compression ratio on the I6
  139. What would this be worth?
  140. 289 won't start
  141. Front Drums
  142. Lifter Bleed Down???Help me Please!!!
  143. removing thermostat
  144. opinion
  145. Leaf springs
  146. what color is this?
  147. HOLLEY 570 CHOKE/TUNING Q.
  148. Investment in classic mustangs?
  149. new r&p setup
  150. Slow-Slow-Slow
  151. Convince my parents
  152. i used a " Ridge Reamer " today
  153. Need some direction-power steering pump
  154. Dipstick questions
  155. breaking in my motor ?
  156. charging trouble?
  157. Search engine doesn't work for now
  158. Transmission
  159. short headers or no??
  160. Are you guys getting this on here
  161. Rear belts in a '65 fastback
  162. kickdown cable
  163. How old are you compared to your car??
  164. has anyone heard of?
  165. Aluminum V-Belt Pulleys for 69 351W
  166. More horse power 66 289
  167. Exhaust system anymore and then...
  168. 67/68 Bullitt Movie Replicas
  169. Schematics for Seat Belt Installation
  170. no power in gear
  171. Modified Exhaust System
  172. vibration when driven over 30 mph
  173. 69 AC Control Vacuum Switch - Where?
  174. Headers on a 66 straight six
  175. New guy...
  176. Long trip home ......
  177. how many amps is my alternator?
  178. steering wheels
  179. Power Steering house routing - '67
  180. new radiator, still hot?
  181. 17" rimms for a 66 coupe : tires
  182. Just a reminder.
  183. Which Spark plugs work well?
  184. 66 1brll carb part needed!!!!!!
  185. Interior door light?
  186. inner door skins
  187. Where did that wire go?
  188. Identifing Windsor Engine
  189. Bad coil?
  190. Intake manifold question....
  191. rack & pinion
  192. Odometer rollback
  193. Side Marker Question
  194. Carburator Question
  195. Power Meet Sweden 2007 - mixed pictures.
  196. where is the temp sender?
  197. Be Careful Please
  198. out for a cruise
  199. TOOL GUYS?
  200. Northern GA mustang Meet
  201. Converting to 9" Rear end. Need Help!
  202. Source for early 65 289 timing chain cover
  203. blacked out tail light panel..
  204. can anyone tell me what model...
  205. New engine??
  206. Good Car to buy???
  207. pony interior help
  208. door weatherstripping question
  209. Reputable resto shop in OR/WA
  210. 1965 Steel wheels 14" factory ?
  211. Rough Idle and Vibration
  212. Water Leak Help
  213. Couple of pics of my cleaned up block,,
  214. what to do?
  215. what is my 69 fastback???
  216. vacuum leak
  217. Aluminum Block 347?
  218. pillar pads
  219. Newbie w/pics
  220. 67 GTA fog lights
  221. 351w VS 65 I6 Rear End...
  222. tach wiring question
  223. Carb Bowl Deposits What is Causing it?
  224. need help from the 71-73 stang guys!
  225. How Much Am I Going To Spend?
  226. looks like an old but rebuilt 6 and tranny if anyone is looking
  227. Transmission Castings
  228. How many Rearends were there?
  229. 67 A/C Classic Auto Air
  230. best 4 barrel carb and manifold for a 66 289?
  231. rear end question
  232. Electronic Navigation Systems
  233. timing / idle?
  234. Fuel pump eccentric problem
  235. rear seat question
  236. paint color in trunk compartment
  237. Safe Rev Point - 289?
  238. Gauge Replacement
  239. Shoulder Belts for '65
  240. Wheel stud size and other problem
  241. seats out of 70s ranchero?
  242. ballast resistor
  243. does this sound familiar to anyone..?
  244. Top End Cutout Problem
  245. WHat the heck did I do wrong with my air cleaner????
  246. 351C Timing Cover Gaskets
  247. RH headlight Dim
  248. Taking apart 67 rear quarter louvers
  249. real cobra gt
  250. Compression Ratios!!!!!
