PDA
View Full Version : Classic Mustangs (Tech)
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 [170] 171 172
  1. '68 main underdash wiring harness
  2. Idle speed way too high
  3. stroker kit for 351W
  4. Good Buy or Dumb Move?
  5. Roll cage for a '66 coupe
  6. Question about brakes and suspension on a 66'
  7. radio wiring
  8. instrument bezel...
  9. 351 in a 66 coupe with original 289?
  10. Rack and pinion steering
  11. EFI 5.0 In A '67
  12. MAC headers
  13. 72 mach 1 dash, interior lights not working
  14. Old Front End Parts
  15. 67 351 Windsor Burning Oil
  16. Power brake mod?
  17. 65-68 200cu 3spd reliable as daily driver?
  18. alternator placement 71 302
  19. Color of the engine compartment
  20. ALT Light-65 mustang
  21. anyone ever put a flaming river steering box in a 6cyl?
  22. rear end accident fire block plate? Any know where i can get one?
  23. Blinker Problems
  24. 65 Fastback at the local track
  25. Headers
  26. 65 Water Pump Confusion
  27. 65 Coupe front drum brakes.
  28. 429 Thunder Jet => 1967 Fastback
  29. 74 stang worth
  30. Best Synthetic Oil to use?
  31. Heater Hoses
  32. What weight Oil? What octane level fuel?
  33. i-6 to v8 switch
  34. 1971 Ford Mustang Landau
  35. trade for 12 second GT?
  36. vin # ?
  37. 67 fastback value
  38. voltage regulator?
  39. Synthetic oil
  40. Spring Cleanin' Of Sorts
  41. Help with power brake booster seal
  42. converting column shift to floor?
  43. what carb and intake should go on a 289 66 coupe
  44. 67 mustang buying help
  45. 67 mustang fastback sheet metal
  46. '65 Kenwood Tape/Radio CD Changer Addition?
  47. shocks on 66 mustang 289
  48. what year is this mustang? {pic}
  49. 240ci I6
  50. MSD Ignition System?
  51. Mustang Color
  52. crappy intake combo?
  53. My boyfriend and I are restoring a '69 Mach one...
  54. accelerator pump question
  55. transmission question
  56. help C4 broken tonight
  57. What does YD mean?
  58. Buying my first Mustang 1966
  59. 68 ignition problem
  60. Bigger tires
  61. fuel cell for 67 coupe
  62. Desperate for help - 302 rocker arm nut problems
  63. 2 different heads!
  64. Fastback vents
  65. Bigger Gas Tank
  66. What is a 289 2+2??
  67. Fuel milage.....
  68. redline
  69. Good Place for Financing
  70. What next?
  71. check this out...
  72. Location of dataplates (door end & where)
  73. driver side door lock won't work on 66 coupe
  74. resto purchase
  75. noise under 1967 Mustang
  76. its gone...
  77. Remote mirror
  78. Speakers in door
  79. Sylvania Xenarc HID kit
  80. carb, intake, and cam help
  81. Need the advice of folks who know these cars
  82. Front seats, what should i do?
  83. New car project (PICS)
  84. Brake Questions?
  85. the curse?
  86. New Guy needs help :)
  87. 289 question
  88. AOD in a 65
  89. tranny swap
  90. question about heads
  91. Hello, '67 that doesn't start...
  92. Bellhousing needed or Part # cross over
  93. Fuel Tank Install
  94. 641/2 puking water out of radiator.
  95. simple question, simple answer?
  96. Holley question
  97. Quick Question...
  98. new to all this
  99. Collectable Mustangs
  100. 65 coupe wheel wells
  101. screech
  102. need help with a '65 fastback
  103. Shoulder belts for '67 mustang
  104. 1966 Mustang GT Fastback Help
  105. if you need old parts pm.me
  106. 8" posi questions
  107. 68 turn over slow when warmed up
  108. Tranny swap
  109. Basic help for new guy...
  110. Center consile
  111. 73 grande mustang
  112. Package Tray
  113. wheel info??
  114. rear end for 66'
  115. heater hose through carb spacer ??? Why?
  116. headers w/ c-6
  117. Online Parts Retailers?
  118. 67-68 convertible
  119. what do i need to put big tires on
  120. How do I determine if a rear is a posi?
  121. 6-cylinder driveshaft same as 8-cylinder?
  122. 1967 mustang 6-cyl to 8-cyl conversion
  123. 1967 1968 disk brake conversion
  124. 1968 fornt door pillar repair
  125. 1967 front frame rail repair/replacement
  126. 67-68 hubcaps
  127. window? need advise
  128. value of a 66 coupe
  129. Gt Side stripes on a 67 mustang
  130. Body Kit
  131. MOVED: URGENT!!!!!
  132. bellhousings
  133. is the 302 a good motor or not
  134. 1965 questions
  135. 70 fastback headers
  136. Speakers
  137. 1970 Boss wheels
  138. I need help/advice...
  139. 66 Mustang 200 Exhaust Manifold Question
  140. 1964 1/2 SHAKER Pics
  141. Color engine compartment
  142. 225/50/15
  143. 1966 200cid timing
  144. 1966 Coupe resto questions
  145. suspension upgrades for '67
  146. which headers to use with 351W in '67 fastback?
  147. 6Cyl genius needed (or someone with a camera)
  148. In desparate need of 1 6cyl part
  149. '67 manifold question
  150. Seat platforms
  151. v-8 spindles for 66'
  152. Brakes on a 67
  153. Convertible cylinders and lines replacement 1970 Mustang Convertible
  154. decoding head casting #'s
  155. headliner in 66 coupe
  156. problems with new brakes on mustang 289
  157. trouble with straight 6
  158. 68 stang brake swap
  159. Help a rookie in need, puhlease.
  160. Need Sanity Check
  161. oil leak on my 1964 stang
  162. HELP!!! problems starting mustang
  163. Paint Job
  164. Removing Vinyl Top
  165. 427sohc
  166. holley 4bbl 600cfm carb
  167. holley 4v carb on 289 cou
  168. Wat do u think of the Grandes
  169. Instrument Lights wont wo
  170. Door Help
  171. Interior
  172. 1969 Buyers Guide, Digest, etc
  173. What’s it worth?
  174. best suspension...Ohlins
  175. Not a stang, 1969 Ford Rancher
  176. What to Do?
  177. Tranny Swap
  178. Interior Question
  179. Rear end
  180. here you go!!GT 500KR PIC..
  181. blower for my 289
  182. 66 stang instrument volt regul
  183. Need parts for a Mach 1
  184. a quick question
  185. Questions from Newbie
  186. torque requirements
  187. auto-standard swap
  188. big block power
  189. convert auto to stick
  190. Stiffing a Chassis & Suspe
  191. 71 fastback 351c
  192. C4 torque converter inter
  193. Tranny’s for 351w
  194. Wiring
  195. Tall Driver Question
  196. new gears-now speedo says 0-60
  197. Deciding engine
  198. Super Snake
  199. need headlight parts for 69 Mu
  200. Difference 289 - 302
  201. outside mirror
  202. Total Control Shock tower
  203. ’65 Fastback
  204. Engines
  205. center console on 19
  206. Why does everyone want to
  207. 351C, 351M/400M engine mounts
  208. Need 69 conv. deck moldin
  209. Need 69 deluxe seatback butt&#
  210. Running Hot
  211. carb and ignition questi&
  212. Boss 429 Front Rotors
  213. Restoration Question
  214. Rack and pinion
  215. Rear End
  216. Export brace
  217. New to all of this...
  218. 67 / 68 Fastback Engine Possib
  219. rims for my 66 stang
  220. Weather Stripping
  221. Looking for 69 Shelby
  222. I’m buying a 1969 Mach 1.
  223. Supercharging my 1968 mustang
  224. install NOS on a 67
  225. 1969-70 FASTBACK PACKAGE TRAY
  226. engine updating
  227. 1965 mustang 6 cylinder identi
  228. Eng., Trans.,brakes UPDATING I
  229. 66 Stang Help
  230. Gas Cap Question?
  231. 6 spd in a 68 Behind a 428???
  232. 71-73 Mustang steering box swa
  233. MY FASTBACK IS FOR SALE
  234. 1965 Mustang
  235. What color should i paint my 6
  236. 1969 Mustang true Mach 1
  237. v-6 brakes compared to v-8
  238. What does every one do fo
  239. Brakes...more front than
  240. best sound deadener
  241. My 1969 Mustang, maybe selling
  242. 1969 Mach 1
  243. Gas Gauge 68
  244. spindles?
  245. 66 Coupe to Conv
  246. need more horsepower
  247. ’70 disc brake setup for
  248. rechroming
  249. C4 tranny locked up.
  250. 66 Coupe 4 sale. Real cheap.
