View Full Version : 4.6L V8 Specific General Discussion
  1. few power adder support questions
  2. Fuddle 3400 stall TC
  3. Eibach Pro-kit worst directions ever!!!
  4. Dead battery at 2800 miles??
  5. Bad GT500 fuel pump wiring harness
  6. Black Wheels Cant find......
  7. steeda vs. jlt cai
  8. KB Boost A Pump, the control knob?
  9. Is this an aftermarket intake?
  10. Hurst short throw
  11. Spark Plug Removal Successful; Champions Installed
  12. C&L "trueflow racer"? Or a JLT Cai?
  13. 2nd and 3rd gear shifting trouble on 2008 GT
  14. ROUSH delivers up to 700-hp with new supercharger for Mustang GT
  15. Drive Shaft Install - PLEASE HELP
  16. SLP high flow X pipe and Spyder Shaft being installed
  17. procharger p-1sc
  18. Help something is wrong with my car!!
  19. CAI question
  20. Misc advice needed
  21. Will this MAC Prochamber midpipe let me install longtube headers?
  22. RPM Shifting ?
  23. Tune for BBK CAI
  24. Question on Non IC vortech install.
  25. Injector ?
  26. O/R X-pipe installed, have a few comments/questions.
  27. MOVED: Question for Michigan guys
  28. O/R H Pipe
  29. 92 on 93 tune?
  30. Fan switch
  31. Whats the point in shifting with an automatic??
  32. Whipple advice and help PLEASE
  33. Whipple Update
  34. Shaker System
  35. GT mastercylinder ports
  36. Hurst shifters?UDP?
  37. CAN ANYONE POST MODULAR DEPOT'S #?
  38. Which power upgrade?
  39. tachometer
  40. 4 more years of my life.
  41. Mac Headers
  42. Removing Intake Manifold
  43. gains expected from x pipe and high flow cats
  44. Immediate Help!
  45. Synthetic Oil Question
  46. Can someone describe exhaust trumpeting?
  47. Bit the bullet - Long Distance near the PSL
  48. who's better for manual trans...doug or brent?
  49. JBA vs BBK shorts
  50. where to purchase a SPYDER SHAFT
  51. Failed inspection
  52. Exhaust ? (not about best/what to buy.)
  53. What is the must do?
  54. Build new or modify stock?
  55. exhaust sounds
  56. Wideband bung install
  57. Shifting problem fixed!
  58. Two Large White Boxes Delivered
  59. Nitrous setup walkthrough please
  60. rear end thud?
  61. Need a better battery!
  62. newbie ? about service issues????
  63. 2007 Mustang GT auto Transmission
  64. Muffler Delete...straight Pipe
  65. whipple
  66. MIL eliminators and inspection?
  67. I need helf to install defi VSD
  68. Mama's Pony got new shoes
  69. supercharger plans
  70. cams and/or heads prices and advantages?
  71. Just installed Pypes off road X
  72. PI Torque Converter and Related Questions
  73. stupid newb question...delete plates?
  74. HT0 plugs for boost,what gap?
  75. anyone doing a filter relocation kit?oil cooler?
  76. Are all Tunes created equal??
  77. Gains?
  78. Is there a favorite supercharger out there?
  79. 3v with internal modifications
  80. 05 Vert w/ SC
  81. 100 octane
  82. BETTER INPUT SHAFT???
  83. Normal idle?
  84. GT radiator fan?
  85. Weird RPM Problem With Clutch In - Help?
  86. MT 305/35/18 Drag Radials- Now Available
  87. NITROUS SETUP
  88. NEW: Zone 5 MDM Mega Drivers IN STOCK
  89. Question for those with K&N FIPK intake 05 Mustang GT
  90. 05-09 GT Triple Pump Fuel Systems IN STOCK!!
  91. ATTN: Lowered MF'ers
  92. Diablo Predator question
  93. Mustang on wet roads
  94. UPDATE: dealer FIXES excessive heat on legs
  95. SCT XCAL2 changing gear ratio back to factory tune
  96. Should I or Shouldn't I
  97. NSR Cams vs LT vs Gears
  98. Who's runnin' 12 psi and up on stock internals?
  99. FRPP blocks Questions
  100. 262 bucks for shipping?
  101. 08 whipple
  102. Any aftermarket auto shifters?
  103. MOVED: Head/Fog Light Bulbs
  104. MF'er I got a code already: P0191
  105. Procharger guys look here
  106. Exhaust questions - what to buy (MAC ABs installed!)
  107. few questions about 1st time at track tonight
  108. P/P heads vs. new heads
  109. A few questions about nitrous before I pull the trigger.
  110. In a Quandry. . . .
  111. CAI Is it worth it?
  112. NEW@LETHAL PERFORMANCE: S197 Level 1 Fuel Upgrade Kit
  113. nexy mod
  114. Got some money to spend.
  115. Saleen SC plus upgrade installed w/ Dyno vid.
  116. squeeking noise from r/r brake area
  117. BBR stage 2?
  118. Anyone running a Hogan's manifold?
  119. Curious…..has any one tried
  120. Question about vortech S/Cer
  121. PO340 & PO344 CEL Codes
  122. my friends mustang
  123. engine sputtering at track
  124. Nitrous Question ?
  125. UPDATE: dealer fixes excessive heat on legs
  126. 2008 GT Engine Bay Issue
  127. Just installed MGW
  128. Help! Rear brake problem
  129. catch can set up for boosted engines?
  130. Couple of **simple** question
  131. tranny
  132. retorque on headers?
  133. yo yo yo ,i need some gauges!
  134. Best Blower Cam?
  135. MOVED: Painting costs
  136. Where can I get a block?
  137. lower control arms
  138. stock tire size for 18 x 9 bullits
  139. Where do I start?
  140. A/F Problem.
  141. WHO HAS A KENNE BELL 2.6 SUPERCHARGER?
  142. Did Ford Change Valve Covers Between 05-08??
  143. Picked up my car from ST Motorsports and
  144. Axle Back Options
  145. 87 Tune
  146. Engine problem Supercharged 4.6
  147. SLP or PYPES
  148. J&M PRODUCTS Now Available at Lethal Performance!!
  149. Engine shuts down, when coasting at 60 mph?
  150. Will These Fit?
  151. Lubrication/Grease Points
  152. Mcleod Slave cylinder
  153. Please help me troubleshoot a P2196 code
  154. slim line fans
  155. exhaust flanges
  156. Rattle at 5000+ RPM :\
  157. Do you have a Saleen SeriesVI?
  158. Saleen SC'er/ Cervini/Ronaele mustang install problem
  159. Hot Rod Cams Ordered
  160. Advice
  161. shorty headers
  162. Tensioner Support Plate
  163. fuel pump LPH for various pumps?
  164. Cam Swap Info
  165. TR-3650 Synchro lag
  166. CEL 10psi Fuel pressure
  167. Roll Bars?
  168. F/I - Belt shredding & tensioner bending issues
  169. Pypes Mid muffler Advice
  170. Boost gauge.
  171. Supercharging and Tune
  172. Axle back challange?
  173. BBK CAI and Tune Questions
  174. Manufacturer of the '08 Bullitt Shifter?
  175. Re-tune for a new exhaust?
  176. Pypes Violator Axle-back
  177. axle backs?
  178. Procharger ?
  179. rear end fluid
  180. exhaust question
  181. Fuel pump - factory tune?
  182. Wierd track experience... any similarities?
  183. Mexico Oil Question?
  184. Nitrous with MSD?
  185. any one know I.D. of radiator hoses on the GT?
  186. Just purchased 08 Gt Need some hp help
  187. CEL p0300 - how to clear the code or fix?
  188. 93 tune dumb question?
  189. Lower 1/4 Mile ET: Bolt Ons
  190. Best price for Procharger race valve
  191. I FINALLY GOT ANOTHER CAR!!!
  192. How come FORD didnt give us a 91 tune?
  193. Those w/ gt500 fuel system
  194. Axlebacks for Adults
  195. Dyno need help
  196. Finally Dyno'd The Paxton
  197. Cold Air Intake
  198. Explict's Whipple Install Thread.
  199. mustang power
  200. Cost for FI
  201. problem with Whipple install
  202. Transmission Woes. Open for suggestions.
  203. what fuel pump will support 500hp?
  204. Please Explain Bama Perf/Torque Tune Differences
  205. Noob with 4.6L performance questions
  206. FRPP CNC heads anyone?
  207. Need Help 1/4 mile
  208. Dealership Oil Change?
  209. O/R midpipes, how much do they really help?
  210. What are YOU putting down and whats your best 1/4 mile time?
  211. JBA S197 Longtube Header Blowout!
  212. pypes!~ axel backs review...
  213. Oils
  214. 4.6 Liter Billet Fuel Rail Adapter
  215. Major help
  216. Anyone have experience with Smith Performance?
  217. Where can I find one of these...
  218. where to next? good power #'s?
  219. Axlebacks uneven
  220. Flowmaster Super 44 on 2008 GT? Mistake?
  221. Needed Custom Tune source for SuperChips FlashPaq
  222. Cam Questions for the v8
  223. Automatic Brenspeed Users
  224. What Spark Plugs
  225. OR/H with stock mufflers input and sound clips please
  226. How much are these worth?
  227. For those of you that self installed Magnaflow, Corsa axle backs.
  228. How High an Octane Rating is Good?
  229. I may have a problem on my hands! Exhaust HEELP!
  230. MOVED: Nitto 305/35/20 Tire Life ?
  231. Turbo Kit for my 06
  232. MSD Launch Controllers
  233. MOVED: Porter Cable 7424, yes or no?
  234. New tune after adding o/r pipe?
  235. tech question
  236. How loud do you think this setup would be?
  237. 3.2 or smaller pulley users - need your input.
  238. Are rear end girdles worth it?
  239. Called Whipple about my belt issue
  240. Loudmouth or Boom Tubes??
  241. Throttle Body Bypass
  242. Installation Costs? How much did you pay...
  243. Will long tube headers have good ground clearance
  244. Quick Question
  245. New Tune - Strange Problems (AFR all screwy)
  246. Need Help with these codes?
  247. GUYS WITH BUILT MOTORS/FI ENTER
  248. Why am I so down on power??
  249. GT/CS;320HP??
  250. S197
