- Have I hurt my engine or taken some of its life????
- 2001 transmission question
- reliable gears?
- What is it going to take??
- How to make MIL's
- Has any body here raced a F-150 HD?
- diablosport question
- Steeda pulleys installed!!!!
- 2-Bolt vs 4-Bolt Mains
- Vortech or Paxon?
- 96 GT, the first of the 4.6's
- Looking for magazine features
- Need help i have a weird sound coming from the inside
- Which Caster/Camber Plates ?
- superchargers?
- new ignition
- where can i buy a GT emblem.
- the fuel thing
- Bumpsteer kit???
- P&P my TB/Plenum...reuse the gaskets?
- Good price for gears/install/xcal 2/tune?
- Wich spark plug
- CODE KEY FOR 1999 GT.
- "Locking" lug nut set?
- installing overlays problem
- gauges...is this corect
- Flywheel Torque Spec's ??? HELP !!!
- performance chips
- PCM Reprogrammed? what is this?
- Nitrous
- what's your 1/4 time?
- what do you guys/girls think about this
- what brand control arms?
- Lowering Kit
- lower control arms
- Bassani or Loud Mouth??
- 01GT 03 Cobra rearend swap
- thought for air setup
- 4:10's top out??
- predator tune and nitrous
- Lowering
- nitrous with compression
- I GIT THE COBRA!!!
- Peeling steering wheel
- 3.1" s/c pulley on vortech w/o aftercooler??
- Quick question Electrical
- How much leather in leather seats?
- Idle all messed up!!
- Warranty on TB and Plenium
- TB Plenium combo?
- Need Help!!!!
- Exhuast vid
- Heads/Cams
- Ahhh Leak
- 75mm TB???
- cant find it anywhere...
- pullies
- Dying out!
- heads?
- runnin rich
- Another newb ?
- 97 4.6 GT Spark plug ?
- Superchip power gains??
- 96-98 GT owners
- 1997 Mustang Cobra
- BBK Thottle body/Elbow
- Two-Piece Tonneau Cover Install
- WTF? Cars stalling
- trusty nitrous system???
- Instally gears need help
- injector Q...
- rims
- clickity in exhaust
- Exhaust Choice?
- strut tower brace and front windshield?
- New with some questions
- the fix
- SCT Chip
- the cobra, im buying (if passes)
- Buying a 2000 GT!! Few Questions
- Installed BBK Throttle Body
- 00 Gt, problems...?
- were can i buy metal grille
- Mobil 10W-30
- few questions
- Suspension Noise??? PLEASE Help!!
- gear grinding! =(
- Difference between performance chips and programmer
- I finally installed my C&L plenum and 75mm tb
- PI head swap and exhaust
- Online Parts Store
- Lifter ticking
- Which spoilers are functional
- Mil eliminators
- clutch smell.
- Intake has extra hole?
- how do i disable the alarm?
- 4.6 pi intake Vs 5.4 from a F-250
- First dyno results on new combo
- Mach 1 Chin
- mach one lip
- just had O/R h-pipe installed
- good question here
- V-8 Question
- 373's on highway used car?
- Keyless Entry Question
- first purchase
- Took my rear end out yesterday!!
- HELP ME!! PLEASE
- car just shut off while driving...yay
- Whats better??
- Satellite antenna placement...?
- I'll take broken tranny mount for 300 please.
- Looking for opinions on next mod
- squealing under the hood
- Tranny Mount?
- ABS light
- Aluminum Driveshaft
- HELP!!! Installing BBK Caster/Camber Plates on 98 GT
- 3:73 vs. 4:10 gears
- need a quick easy mod to help 1/4 time
- C&L Plenum, 75mm T-body Are In!!!
- shelby cobra
- axle swap
- Clutch Issues
- Would full exhaust get me 300 rwhp?
- Drivetrain loss in stock 1998 Cobra?
- How do gears make you loose power?
- Need Part # badly!!
- A Tire Question
- feedback please
- What faster?????
- STEEDA PULLEYS..
- Dumb question.
- Huge Problem!!Need Help!NO SPARK!
- My imagination or.. 2002 GT engine..inside
- control arms
- gears
- ignition
- launch tips
- DENSACHARGER(tunable induction) question
- next best mod
- hp rating @ flywheel or rearwheels?
- How to tell if car is earlier or later 2001
- springs??
- Need help
- GOT A VERY SERIOUS PROBLEM
- wtf
- Msd ignition
- where is the engine coolant plug.
- Roush shift "handle"...
- Can someone tell me how tails spit fire?
- Just orderd my new Falken tires!
- Wow Dealers are a Rip!
- What's the clicking I hear? Please help
- Spark Plug Gap
- Easy question? Need answer!
- need to lower car 1.5"s?
- gears?
- fuel line clog
- Rear Gears?
- spark advance using the Diablosport
- c/c plates and subframe connectors...
- 01 GT run W/LS1??
- superchip
- good Mustang shop around JAX
- MSD Ignition??
- Mustang Shops In Ohio
- spec stage 1 clutch
- h-pipe noise
- axles
- Cobra Headlights
- Smooth idle return
- FR500 intake manifold
- head porting
- Longtube tuning
- PI Q's
- anyone else w/ 99 cobra
- thermostat leaking
- cat back question
- anymore bolt ons?
- "Flapping" noise
- Plasma Booster- Multi-fire Ignition
- Cracked Intake Manifold...
- New plenum/tb installed....a few ?'s
- 99+ auto speed-cal?
- 1st Mod for my Cobra?
- Window Tinting
- Whats needed?
- What mods to do next?
- Question about headlights
- Plans
- Mustang Shops in missouri/ Eastern Kansas
- Steeda Underdrive Pulleys
- CHK ENGINE LIGHT/NO CODE
- Honeycomb Tail inserts
- upgrade fuel system w/ 8psi?
- Backfiring?
- 18x10.5 Needs IRS Modification?
- deep dish bullitts
- Starting Problem
- Tornado fuel saver?
- getting ready to install my headers!
- Hood clearance
- Mach ! IRS or Solid axle
- best off road x for 98 cobra?
- 200 amp alternator
- Few quick questions
- About to buy
- Shifter
- mac 70mm throttle body
- mac verses steeda cai
- Spring Isolators, Which ones can I leave out?
- What is the Rear end in the 01 Automatic GT!!!!
- Swap question
- MAF and Injectors
- Whats next?!!?
- Mods to get
- Hey anyone know how to get access to 2000+ salvaged mustangs?
- frpp throttle body
- fed up with my 98GT
- Diablo Chip
- car died on 4th gear.
- MOVED: Eibach springs FS or FT
- Polished Throttle Bodie
- Saleen S81 3-piece wing
- 00-04GT S/C Only?
- car sort of jerking in a moderate to high rpm
- intercooler
- intercooler
- Eibach Pro Kit Rear Pinion Snubber?
- Air pump removal "97 Cobra
- can you crack a header?
- RPM Outlet Question...
- Kenny Brown seller?
- Bullitt Cluster swap...
- SLP Loudmouth
- belt squeel
- Rear end whine from gear change
- not needed but will i see any gains?
- 01 cobra
- Bit confused about horsepower (99 GT)...
- Predator Tuner Question
- dyno numbers
- Is this a good idea?
- stock 97 svt mustang supercharged?
- procharger
- Weird Problem
- intake question
- What do you guys think...
