View Full Version : 4.6 (Modular) Mustang
  1. BBK 78mm TB/Plenum Combo
  2. Oil spray
  3. Caster and Camber plates needed?
  4. Lights Pulsating
  5. If you were to swap trannies?
  6. Car is running rich?
  7. TEKSID 2V BUILD ADVICE-TECH INFO?
  8. Saleen Supercharger?
  9. Mach Stereo System Questions
  10. intake
  11. Looking for EGR Delete Kit
  12. Mustang GT Auto Tranny Power Handling???
  13. 03-04 cobra bumper
  14. Need help not sure what to do performance wise with P.I swap!
  15. supercharger question
  16. BUILDING A tEKSID 2v na-SUGGESTIONS-UNKNOWN FACTS
  17. saleen parts
  18. fuel pump problems!
  19. Vortech Oil Return Help
  20. CEL code
  21. 31 splines = new axle shafts?
  22. Street/strip suspension
  23. Weird Ticking Noise.
  24. Axle Hop!
  25. diff question
  26. what do u do when...
  27. What tranny?
  28. how to remove tweeter on Mach460
  29. front lower control arms
  30. Turbo Question.
  31. Please help me!! Re: Engine compression
  32. HOW TO: INTERCEPTOR Motor Swap Into 99-04 GT
  33. Changing brake fluid: how to/which one to get?
  34. Hey Im new to the Forums
  35. Replacing the rearview mirror, few ?'s
  36. best drop height?
  37. What wire is this??
  38. 01 GT won't idle unless gas pedal is pushed
  39. White face guages install
  40. New paint on the 2000 GT
  41. replacing speakers in 96GT w/ Mach460
  42. What's up with the big spoilers?
  43. Sound when opening the door
  44. Question about paint color....
  45. o/r midpipes????????
  46. Steeda UDP install...
  47. ABS question
  48. HP Diff between O/R Pipes and Catted
  49. which mid pipes would fit LTs?
  50. shift light
  51. looking at blower cams...
  52. motor swap
  53. What differential to go with?
  54. Cams or LT headers?
  55. Ball Joints....DIY Project????
  56. So I wake up in the morning to go to work and...
  57. Drop springs and shocks...?
  58. need help ASAP
  59. TIRE SIZE
  60. Upgrading brakes on my '03 GT
  61. Underdrive Pully Kit?
  62. Not your run-of the mill exhaust ?
  63. p0171 running lean
  64. another problem.gauge cluster help
  65. Using Bassani Test Pipes on an SLP X?
  66. Possible Gains After Dyno Tune
  67. Different size pipes question
  68. Help! Weird "miss" at low rpm's in 3rd and 4th only??
  69. Cams
  70. PI head question
  71. Mail order tunes
  72. Weird Problem?
  73. Where are the places to lift the 4.6L out of a 1999 mustang gt?
  74. Electronic Transmission Diagnostic?
  75. 300 rwhp hp unported heads?
  76. Filling Spoiler Holes
  77. 99 GT turning into a Cobra clone..
  78. my codes...help
  79. Optima Battery on an 03gt
  80. posi help?
  81. Smelling Gas and......
  82. idle rpms too high
  83. How do you do a compression test? Search brought up no answers....
  84. How do I make my fan to always be on
  85. Do I need a rear girdle?
  86. few questions
  87. caps for P.I. cams?
  88. Well spent insurance money
  89. q's about 17x8 wheels/tire combos and suspension q's
  90. service engine soon...
  91. upstream 02 sensors problem
  92. Urethane Bushings
  93. 5th Gear Rattle - Shifter?
  94. Relays????
  95. I'm painting my car this weekend, I need to know the grit of the sandpaper to use?
  96. please identify the front rim size in this pic
  97. Something broke Help
  98. bigger injectors..what size?
  99. cylinder running with the injector not plugged in?
  100. Fuel Injectors?
  101. Erratic MAF signal
  102. Will this catback fit my car?
  103. Where can i buy these Jonx? (valvetrain components)
  104. Mid Pipe and Clearence Issues
  105. Dyno Tune
  106. Question on tires
  107. How to make a bracket for the shaker scoop???
  108. cam install
  109. What Springs will drop me more
  110. Anyone know where to get a m90 s/c kit?
  111. which mustang should i get
  112. What do you think?
  113. Hey, what happened to that "rebuild Thread"
  114. Introductions are in order...
  115. Transmissions
  116. P.I question..port and polish?
  117. rear-end problem?
  118. HEAD GASKET THICKNESS
  119. New Car
  120. RPM Trick?!?
  121. Right after an oil change
  122. Vert Mustang window clearance problem..
  123. will it fit...?
  124. Wheel and tire question
  125. JLT Products
  126. Upgrades
  127. Pics of charcoal interiors???
  128. To become a N/A 12 sec stang .....
  129. Strut Tower Brace
  130. P0161 - OS Heater Sensor Malf and Tuners Questions
  131. Headers question
  132. Service engine soon, related to pulley??
  133. Replace Headliner?
  134. Clear up a NHRA Roll bar rule for me.
  135. 2007 saleen motor in sn95
  136. Engine efficiency
  137. 1999 Stang 3.8 to a 4.6 swap
  138. heads and cams swap
  139. Home MAde turbo 96-04 mustangs
  140. Transmission bobber thing.
  141. Lots of Questions??? auto to 5 speed.
  142. stalling - bogging
  143. Possible Big Problem
  144. big brakes or not?
  145. hitech cams
  146. STILL WON'T START
  147. 98 Head Unit swap, seperate cd player removal.
  148. high mileage GT
  149. GEARS, AXLES and LSD
  150. starting problems
  151. 4v swap tune
  152. Procharger D1-SC Questions
  153. 4 Dead Cylinders
  154. Engine alignment?
  155. 1996 mustang gt questions
  156. Multiple power adders??
  157. dropping the entire rear end
  158. Mystery part in front of engine compartment 4.6 vert.
  159. NGK TR55 OR TR55IX
  160. Issues with clutch cable kit
  161. EGR delete
  162. borla, will it fit
  163. change tune
  164. Throttle Body, yes or no?
  165. need feedback on tires NEXEN N3000 ZR-4
  166. Before and after the Dyno tune.
  167. mods! help
  168. Info on 2000-04 GTS
  169. 4.6 crate engine and transmissions-cheap!
  170. squeaky steering
  171. MMR feedback, reviews...
  172. Side Scoop Removal and Install
  173. C & L intake kit
  174. Interior paint, new autometer 3g pillar
  175. spark plugs
  176. Finally decided to purchase the SCT PRP
  177. 2002 T-3650 Transmission Noise
  178. 2 Questions...
  179. Cobra bumper conversion
  180. Need advice on next mod.
  181. how much should i sell these for, need an answer QUICK
  182. HELP! trouble removing my t-45 from my 99 gt
  183. gears/speedometer/tach
  184. how bout these cams?
  185. Running Rough in Cold Weather
  186. strange rear shock
  187. Removing Sway Bar ?
  188. Dumb tire question
  189. Small Block Ford In a New Edge
  190. Help from anyone with aftermarket catback
  191. Cigarette lighter doesn't work..
  192. FT shocks on 96GT Conv, how hard to change?
  193. Engine braking at high speeds
  194. how to identify pi heads/intake
  195. What kind do I have?
  196. 5 speed short throw shifters
  197. How to..
  198. Left Blinker problem
  199. 2001 power window driver stuck down
  200. reliabilty and streetabilty
  201. Anyone got qa1 k-member pics?
  202. Chattering with clutch depressed?
  203. Need Pictures
  204. Help! car keeps dying after tb and plenum install.
  205. truth about throttle body spacers?
  206. never buy accell coil packs!!!!!!!!!!!!
  207. Deleting my AC compressor
  208. hi flow cats
  209. What's Rebuilt Engine
  210. Stainless Steel Systems Exhaust
  211. from an 04' to a 97'
  212. knocking clutch or tranny? *with vid
  213. 300rwhp N/A 2V?
  214. Y2K Cobras
  215. Need new plugs!
  216. 4.6 Stroker
  217. 2003 GT tunee up
  218. Aftermarket coolant tanks.
  219. Throttle Body & Plenum Combo??
  220. mact lt's which x pipe?
  221. T45 broke, what is broke?
  222. Can this work?
  223. 4V guys, got a question
  224. quadrant
  225. lowering springs
  226. Diablo Sport Tuner
  227. Is this a ripoff?
  228. Clutch Cable shat
  229. ***I SEARCHED*** ;), please help. Misfire issue in cylinder two!
  230. Can this work?
  231. Vibrating Pattering sound ?????
  232. Racemaster Drag Radials
  233. exhaust help what to do
  234. getting mac lt and catback but who has catted h pipe
  235. exhaust,help!
  236. Tranny issue?
  237. Cobra Swap
  238. ENGINE QUESTION
  239. Motor swap question?
  240. S/C application ?
  241. Fuel Pump Questions for 2004GT
  242. LUCAS gear oil
  243. does the 4.6 in a mustang same as crown vic?
  244. need help! Mustang shaking and bad noises coming.
  245. problem found (i think) need help
  246. Need first start help
  247. rebuild/sensors question
  248. Too much fuel? ECU gone bad?
  249. Steering Rack Bushings
  250. O/R exhaust question
