PDA
View Full Version : 5.0L General Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 [59] 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76
  1. Too Good of a deal?
  2. Harwood Hood Fitment
  3. 82 and 84 front bumper
  4. does this track time sound reasonable?
  5. finally got to run the car on a track last night
  6. 10 hole tire sizes
  7. bolt on myths destroyed
  8. Finished complete smog delete....
  9. 99/01 Cobra or Fox?
  10. Where is the CE light in the dash?
  11. track times
  12. First time mustang owner
  13. when doing my headliner
  14. What is this piece I'm looking at?
  15. Too many options....
  16. My 95 - Good bad or ugly???
  17. Summit build, 95 gt
  18. exhaust question
  19. what color should i paint the engine bay?
  20. SN95 front conversion/brake lines
  21. mustang might have to go?
  22. heater core
  23. GAS STATION OVERFLOW!!!
  24. HOW MUCH???
  25. 351W Twin Turbo build
  26. Oh well
  27. i need a new carpet help me find a good one
  28. MOVED: Anyone wanna run a carfax for me?
  29. new mustang owner!!!
  30. got a couple of questions
  31. Got one for the guru's
  32. question on exhaust again..
  33. replacing clutch assy in the driveway
  34. Vert Question
  35. Interior paint
  36. 87 lincoln tc motor in 92 lx
  37. ONLY use Ford factory heater core.
  38. Sites for blocks..
  39. what will i run?
  40. Help me choose a color!
  41. Getting the most out of a tank of gas
  42. So I gave up on the 4.30's
  43. h pipes or x pipes which sounds best
  44. Help me fix my stang.
  45. stock mustang or supercharged mustang that needs work?
  46. Got a rim question
  47. block spliting
  48. suggestions of conversion of AOD to T5
  49. white face gauges done, pics!!
  50. sounds ok
  51. Dyno Numbers
  52. clutch help
  53. 351 GT-40 Heads on a 94 Mustang.
  54. how bad is it for our cars?
  55. exhaust question
  56. i wish i had the money to buy this
  57. summit racing tech SUCKS!
  58. intake:)
  59. are these intakes any good ? pics
  60. bumper cover
  61. Winter projects...
  62. low rpm limit for shifting/driving???
  63. clutch cable
  64. wondering?
  65. how can i get my power steering pump pulley off without using a pulley puller?
  66. reverse hood hinge
  67. need your oil knowledge
  68. Ashtray on fox...
  69. GT-40 heads
  70. if you had the money........
  71. Gas mileage?
  72. headlights
  73. Fiberglass front clip
  74. O/R H vs. Catted H
  75. Picked up a notch...Finally...
  76. UPR k members any experience with them?
  77. T-5 ?'s
  78. Engine Repair; Tap/knock @ start or accel..
  79. HELP WITH CONVERTIBLE TOP!!
  80. Iraq weather report
  81. Talk to me about paint please.
  82. Anyone have a Harwood Hood on SN95?
  83. 1991 mustang gt
  84. 94 cobra Q
  85. Need some trouble shooting idea's
  86. SN95 starter on a Fox body.
  87. Bumper tape on two-tones?
  88. Need An answer to this one
  89. 302 ID...
  90. good price for these heads?
  91. lentech AOD? How good?
  92. tie rods?
  93. installing gauge pod
  94. good racing cat back?
  95. Driveshaft Safety Loop
  96. pic of my gps install
  97. Shock Replacement
  98. MOVED: vs. supra?
  99. HVAC Controls Question
  100. SOS!!!
  101. intake manifold
  102. Anyone ever have problems with D&D Motorsports K-member & A-arms? Street use
  103. which heads
  104. Why do I not see very many 5.0's w/HEI dizzy's?
  105. I Passed!!!
  106. 85 Gt seat belts....
  107. Best Price For Polished Tyhphoon Intake???
  108. Quick seat question
  109. It has begun...
  110. long tubes+AOD
  111. Cobra or auto GT?
  112. MOVED: Eastern NC!?
  113. Vacume Hoses
  114. you guys with dumps help me
  115. Different smog ?
  116. Windsor Dart JR Heads
  117. wire harness
  118. Weird question
  119. Ok had the car 2 weeks now...PICS
  120. deleting the pcv system
  121. Chicane Sport Battery Relocation
  122. need distributor help
  123. eliminating smog stuff
  124. Girlfriends/Wives and 5.0s
  125. 306 to 331 347???
  126. Three Point Racing Belts
  127. My 14000 mile no option notch
  128. mickey thompson street radial
  129. After Market Automatic Shifter Install ?
  130. Black Chrome Wheels
  131. hood pins someone pick me out a pair on ebay
  132. test pic of engine
  133. Ha!Ha!Ha! check out this use for rhino lining!
  134. Just got done with upr install!!
  135. Dart pro 1 heads?
  136. 5.0 questions. need expert advice
  137. Project only90s new look for GT-lots of photos
  138. Anyone running the Crane HI-6s???
  139. Air compressor ?
  140. Should i get this for my DD?
  141. Looking to get COLD AIR INTAKE
  142. Scat or Eagle
  143. Factory 95 alarm question
  144. Breather hoses
  145. bbk shorties
  146. What tools do I need to change the brakes?
  147. Sweet deal
  148. black moldings
  149. The end all of Top end threads (mine at least)
  150. how much does she weigh
  151. Fog Light Cover
  152. lx vs gt..
  153. kenne bell on a 5.0 fox
  154. What do you think of this 1995 GT? Should I buy it? What would you pay?
  155. Does anyone know the size of the driveshaft flange bolts?
  156. some pictures
  157. Header Question
  158. Parts Came!!
  159. 85 & 86 mustang parts
  160. Finally got the time to fix it!
  161. Finaly simple greened her!!
  162. triple white 93 convert
  163. oil pressure sender. need help ASAP
  164. Heat in an 87
  165. which block?
  166. interior screws ?
  167. Ordering New X Pipe Quick Question
  168. to but or not to buy????
  169. Should I buy this 93 notch $400(read post before voting)
  170. 86 Mustang 5.0.. Looking Into Change
  171. Bumper question
  172. Z-spec/ SPec stage 3+/ with NOS
  173. MOVED: ME vs. 07 Wrx?
  174. H/C/I combo ?
  175. wheres the water temp sender?
  176. My master plan
  177. source to buy a built 5.0?
  178. 02 sensors
  179. Should I buy it?
  180. gt hood
  181. 91' gt new motor/tranny/wire hiding projectALRIGHT SHES ALIVE!!!!
  182. Just checking in!
  183. Whats your thoughts on this 92 LX?
  184. taking parts off wrecked car
  185. Help What holds The Rear Seats forward
  186. no more 5.0
  187. What should i go with?
  188. Sad Day for My Stang..Wrecked! Picture.
  189. EGR delete question
  190. 2004 Cobra Color
  191. bullitt wheels on foxbody??
  192. need some torque specs
  193. Because I'm a Picture Whore
  194. What are they worth???
  195. anybody have these headlights?
  196. Trans Finally Died......Suggestions?
  197. Lookie what I did
  198. 94-95 5.0 underdrive pullies
  199. PROJECT FACE LIFT (BEWARE 56K)***FINISHED!!!***
  200. Q Challange fox from school
  201. subframes installed finally !!
  202. will 93 hatch trim fit in an 86
  203. pretty "cool" question!
  204. paint job
  205. suspension and tuneup questions
  206. Heads/Smog
  207. equal or unequal
  208. Headlight wiring...
  209. Dr Gas x pipe
  210. Post up pics of your car before the modding began
  211. M-6250-F303 camshaft
  212. What size Torque Conveter for 3300-3500 Stall
  213. ebay mustang
  214. Newbee with a cam question.
  215. 1000hp "sleeper" stock gas tank arrived
  216. MOVED: Remember Knight Rider?
  217. Junkyarding tomorrow
  218. Which is the better computer?
  219. What is the lifter pre-load set at for a b303 cam?
  220. Failed Inspection
  221. 1987 LX Info
  222. Dual alternaters???
  223. where to get installed?
  224. Who has about 600rwhp?
  225. buying five lug conversion is this everything i need?
  226. Finally back
  227. All California cats...cats or no?
  228. Oklahoma
  229. LX tails
  230. Ash tray lid
  231. If I had the money
  232. 94 cobra first mods
  233. So you say you want new wheels and paint
  234. is this a good battery rear mount kit ?
  235. Cobra rear bumper
  236. aftermarket foxbody fenders
  237. New Engine Picture
  238. D&H auto parts
  239. what paint for edelbrock performer manifold?
  240. long tubes for an AOD
  241. 93 saleen?
  242. 1989-92 Mustang Plans (look good?)
  243. which cam should I get?
  244. Rod bearing locks face cam?
  245. cleaning interior
  246. Are GT-40P's smog legal
  247. Where to find 83 convert seatbelt bezel
  248. Does anybody NOT mod their cars?
  249. Converting to a manual from an automatic?
  250. 1967 v8 vs 1989 v8
