- wiring
- CA Emissions Question
- No Cats, No o2
- Cam shopping...
- Throttle Body & Plenum Combo $100 diffrence
- C pillars
- just making sure
- 1997 convertible cobra for $9400?
- HorsePower Gains
- Stage 1 Clutch vs. Stage 2
- 70mm to 75mm
- Idle\Throttle problems after disconnecting the battery, helpski please
- injector install & fuel pump
- my stang is ten years old!
- What should stock fuel pressure be?
- 12 seconds?
- LT Headers
- need fast answers about headers!!!
- what mods next....
- tranny problem
- what next
- clutch install?
- Where to Now????
- Radiator for Cobra
- 0-60mph times?
- anyone replace their steering wheel before?
- gt vs cobra
- calipers
- Cobra Supercharged?
- center column
- clutch problems (chatter, etc)
- Advise needed please....
- cam seized
- Whats Your Horse Power?
- Programmer for 03GT
- 96 GT what should i do next?
- Suspension/Chin Spoiler Installed **PICS**
- clutch life span?
- slp exhaust install
- shifters
- 4.6 build
- Port and Polish
- Just to share
- cobra head swap on GT. is it possible??
- Nitrous
- cams
- K Member... anyone?
- Does aluminized steel sound diffrent?
- Mach1 Header question
- FINALLY My cobra runs like a cobra should
- question on lowering springs
- nittos?
- NEW AND INTERESTING QUESTION PROMISE
- for 40thanniversaryGT
- borla?
- What Tranny fluid to use with a T-45??
- Need help with battery
- LCA Bolts
- oil galley plugs?? leave the front ones in or what?
- Does anyone know how to remove there PCV valve?
- 99-04 Side Scoop Removal?
- happy new years
- Do iI Have Gears
- Has anybody used Hawk Performance Brake Pads
- 96-04 sohc 2v GT owners!!!
- How too, instructions.
- Difference between new CAMS and PI SWAP
- X or H
- 1996 mustang gt coolant leak
- lower crankshaft pulley
- ordering grill delete, have a question
- black on my wheels
- Shortening the travel distance of clutch pedal
- Tire sizes....again
- cams
- Tire Sizes
- Best intake manifold???
- new parts
- What do you think of these shocks/springs?
- what brand headers
- suspension mods
- What is (opinions WITH facts) the best Clutch?
- Intresting but prolly old news.
- tow hook
- Tranmission problems..
- i need stock cat back take offs...look !
- Wierd engine sound when cold or idling
- New gauges, New rims, tell me wat u think
- INTAKE MANIFOLD LAWSUIT SETTLEMENT QUESTION
- Used Diablosport Predator?
- tires
- Help Please!
- squeakin breaks
- A BIG DIFFERENCE?
- installing headers....
- tire sizes and spring kit..
- ? for people with gears
- Getting traction tips
- brakes
- what other mods could be done for the price?
- whats everyone think?
- How much is dyno testing? Where can u go?
- whats the difference in the crown vic 4.6 and stang?
- when plastic coolant crossover leaks
- Stock Mustang GT Rims!!!! HERE
- Would a Roush front bumper suck?
- h pipe help?
- 3.73's worth it??
- 99+ engine swap
- Wont Start.
- Need help finding a wire coming from the TPS, asap
- A couple small problems
- Yes or No FRPP Mustang Suspenion
- CAI and Plenum question
- Whats everyones Dyno numbers?
- ? for Cobra owners.
- just got back from the dyno
- Questions about MODS-Not in sticky
- H PIPE IS A BITCH!!
- Coolant Leak
- Oxygen simulators
- Speed Tooth Gear
- Front end noise ?
- pictures of my 00 GT (03 cobra clone)
- how many.......?
- Engines
- detroit area
- tune up help
- i think its my brakes
- transmission noise
- One set of Cats
- Is this set-up worth it?
- street racing
- Most amazing story ever (and Funniest)
- have a feeling people are gonna jump on me for this but...
- Anybody have a clue how much machine work costs?
- MGW= awesome
- 2002 gt
- front bumper
- ebay parts
- fuse digarm for a 2001 gt?
- Entertainment for the ride
- Spring Isolators?
- how can i increase throttle reponse
- long tubes on an automatic
- different breed of stangs
- ?on hp and times.
- Pictures of the Wrecked saleen DIAL UP USERS BEWARE!!!
- Power Loss Above 3500 RPM
- OK what next
- what seats to buy?
- interior light problem
- Gauges
- Shorty vs Longtubes
- gutting my cats?
- another 03 cobra question
- South Carolina
- Question about Eaton s/c
- Hood pole?
- Bassani headers - complete system
- 2001 OEM Keyless Entry
- Strange OBD code behavior - various codes pop up at the same time
- Mid-pipe or Cat-back Dilemma
- TRADE: '03 DSG decklid w/ wing for wingless decklid
- 03-04 cobra guys
- $Rims$
- Check Engine Light
- any photos?
- new motors
- air silencer
- wheels?
- Bank 1 Bank 2 Lean
- 02 sensors
- Lowered car over Christmas
- new looks?
- Which ring and pinion gear set is best?
- question GOT a deal on saleen pullies can I get the older waterpump
- deep dish in back normal in front?
- ? on xpipe
- engine code
- tuner, again
- catalyic converters?
- Cobra going under the knife
- any idea what this OBD2 code means
- 460 Mach Speaker Replacement
- 02 sensors
- o2 sensor question
- CAI questions/comments.
- Summit H-pipe anyone have it?
- Billet Accessories
- WHAT!!!! No vacuum leak?
- UDP Help!
- equal length compared to LT headers
- MEZIERE Electric Water Pump
- Fastest car on the street
- Brake Upgrade
- procharger
- whats better for a 96 gt, used s/c or PI heads ported n polished?
- Damnit, twisted the EGR tube, question?
- best exuast
- 3.8 to 4.6 engine HELP ME PLZ!!
- plastic honeycomb inside hood scoop?
- Re-calibrating my Speedometer
- MOVED: what is up with this ford racing s/c? real or seems to good to be true?
- MOVED: Best Twin Turbo Kit for 96-newer Cobra
- i need some help deciding
- bullitt wheels?
- which ones?
- 35hp for 45$ !!!!
- any pics of these?
- Mac o/r h-pipe
- Head Swap Info needed, yes I know about the sticky but more people will see this
- T.B. & Cold Air HELP?!?!?!?!
- chin spoiler
- got me a 98 stang
- Best mods for the money????
- Anyone running 265 40 17 tires with Eibach Pro-kit ?
- Rear Bearing Replace?
- Code3GT is home!!!!!
- exhaust vs. tuner?
- Tonneau Cover Question
- what you all think bout these?
- new stuff
- Best Mid Pipe!!!!
- 17s vs. 18s?
- Shifters
- REAR LOWER CONTROL ARMS
- K&N help
- SeaFoam is the Koolest!
- 4.6 compared to 5.0
- just took some pics of my ride!!!
- header question
- 2004 Mach 1 for 23k
- Question
- Different sized rims
- Locking Lug Nuts
- Bullit Gas Cap???
- Hardwiring a Radar Detector????
- MOVED: Heres all that girls care about...
- what to get with rear end gears
- T-56 Help!!!!!
- Fuel Pressure guage install
- Need help on roll racing
- What tire pressure do you guys run?
- ideas for roll racing? power adders?
- Second fuel line???
- Transmission help
- desperate spark plug wire help!
- Kenne Bell
- Mach 2 hood
