View Full Version : 5.0L General Discussion
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53
  1. Tinting tail lights
  2. RIP 302
  3. 84 Carb problem
  4. Smog removal
  5. front springs for foxbody
  6. Gear and dyno question
  7. 1990 5.0 LX
  8. TPS question
  9. Having issues! 94 gt roller w/87 5.0 mtr and trans project
  10. The "Fox Body Lean"
  11. Possible exhaust issues
  12. 5.0 computer
  13. New pics
  14. Is this guy serious?
  15. Going to longtubes
  16. fog lights
  17. new water pump
  18. Painted Pony's
  19. so i was bored
  20. I found whats causing my problem
  21. Body work
  22. 5 lug swap on an 85 gt
  23. Quick Ques..California A9P
  24. Chassis Ground Wires
  25. Distributer Manipulation?
  26. bellhousing from a 302 to a 351
  27. problem found....
  28. Rear end problems
  29. Anybody have pics of....
  30. 02's LT's and OR Hpipe
  31. 12 hours down 12 to go
  32. Picture's of the 'Vert after a good wheel polish, and Wax
  33. T-5 shifter handle and Tremec interchangable?
  34. Question about an old build thread
  35. Question: ASC McLaren Mustang
  36. Heater tube assembly removal
  37. 5.0 Lower intake install/removal question
  38. purple Ice?
  39. what other AOD trans will work in a 88 mustang Lx 5.0
  40. WHO CAN FIT 275/45/17s
  41. Need your opinion (suspension)
  42. Tremec TKO 5 speed clutch questions.
  43. Looking for a fan.
  44. Code Reader
  45. I got stopped !!!
  46. Wiring information, finding dimmer for tach
  47. used 331 stroker price?
  48. 2 questions one thread...
  49. Let's Get To Know Our Fellow 5.0 Owners
  50. Newbie needs some advice.....
  51. Qustion
  52. Fuel pump code/questions/is he full of it
  53. MSD Superconductors
  54. Baseline Dyno Run
  55. I need advisers and friends
  56. OK, here's a good one for you guys...
  57. stock cobra struts
  58. 50resto's got coupe 1/4's
  59. watkins glen hpde
  60. random vacume hose?
  61. free turbo!
  62. possible bad MAF... crap
  63. New here
  64. got a hot date....
  65. just checkin in
  66. Plugs
  67. Lack of Power
  68. Look what the big brown douchebag kicked to my door!
  69. LOL! interesting day today
  70. Bullits on 91 notch?
  71. nature sucks
  72. exhaust questions
  73. carb to injected
  74. Picked up the 89 coupe. Pics/vid inside
  75. Q: fox interior swap?
  76. Some insurance ?s
  77. Nip/Tuck
  78. Pics/vid of my 83GT Vert
  79. I found some gt40s
  80. good deal on an 88 GT 5.0l??
  81. Good Deal?
  82. caster/camber plates
  83. What makes cams different?
  84. anybody put a 4.6 liter - 3v
  85. What intake and carb?
  86. 4 cyl to 302???
  87. 1995 t-45 conversion
  88. some 5.0 questions
  89. long tube questions
  90. code 66?
  91. Which parts do you recommend?
  92. Cleaned up the mustang and got some pics
  93. Frame for dash
  94. stang wont stay alive
  95. foxbody to buy or not to buy
  96. Finally got it running
  97. Gave her a wash today
  98. can a sensor be bad and not throw a code?
  99. should i buy this 5.0
  100. HELP! Convertible 1/4 Window Parts
  101. oil leak
  102. panhard bar or watts link and tq arm?
  103. NO Start
  104. Help-New Engine Choice
  105. How much are these wheels worth if I sell them? Pics
  106. Fuel pump problem.....
  107. How much is a good set of GT40 heads worth?
  108. how much possible power out of the 302 N/A?
  109. If you drive a Blue 4-eye vert in Michigan.
  110. setting timing
  111. Replacing bushings?
  112. still runs like crap...
  113. Out of Ideas... Need Help Bad!
  114. the new shelby's ain't as quick as I thought they were
  115. chp stands for???
  116. Removing CD Player
  117. new intakes
  118. 331 vs 347
  119. Had a few questions for the pros
  120. UPDATE: Project Joker
  121. what are these? (pics)
  122. Front springs?
  123. Solenoid
  124. wierd start when hot?
  125. new and need some input
  126. sway bar removal/what ive been up to
  127. Project: Anti-Stereotypical
  128. Motor is Locked After Build?
  129. Just picked up a 5.0.......
  130. going to look at this fox tommorow
  131. Long journey close to over(pics inside)
  132. what to buy first?
  133. 1990 mustang
  134. Emblem Removel Help
  135. What should the fuel pressure be?
  136. What will it run?
  137. carb question
  138. New Pics
  139. What spring rate?
  140. new to forums hi everyone tryin to do 88 5.0 build had some questions
  141. Air Tube
  142. Would this would be worth it for a 1988 5.0?
  143. how many miles on your aluminum heads?
  144. 1992 5.0 mustang 66k miles ( Who's Car)
  145. Look at this junk Summit sent me
  146. My new project
  147. Whats with all this tubing and stuff in the engine bay?!
  148. foxbody in the snow
  149. Fire It Up!!!
  150. got a 302 and my input shaft is too small
  151. a few things ive done recently...pics
  152. Well im new and i have the newbie questions
  153. Looking At a 92 lx
  154. 94 gt line lock help!!! w/ pics
  155. Over heating 86 GT
  156. It sucks not having 2nd gear
  157. how much Hp and Tq gain from a blower running 7-8psi
  158. 1988 Mustang GT Convertible - I would like to know EVERYTHING about this car!
  159. question about smog pump delete.
  160. Headlight switch replacement
  161. Pulled codes and...
  162. Nitrous guys
  163. fuel level sending unit
  164. Finally! and a whine?
  165. I need turbo help
  166. Clearence issues
  167. strange engineering
  168. tire clearance
  169. 1992 T5 trans.
  170. Miss on cold start
  171. Anyone know where i can get this part?
  172. Tall dude in a 'Stang
  173. Alternator ?
  174. Sister hit my car - Body work?
  175. New carpet install
  176. How much should I ask for my shortblock?
  177. Dyno Vid
  178. 5.0 question for a classic
  179. HEADS HAVE ARRIVED!!!
  180. Clutch Selection!! HELP!
  181. trouble finding 4-eyes?
  182. AutoX Tips?
  183. Recomended valve springs for a B303
  184. 94 Gt issue
  185. dash lights out
  186. mustang hit by drunk driver question
  187. bad squeak but what is it?
  188. the stang now w out ac compressor pictures
  189. need some help with trickflow
  190. Timing?
  191. unique problem
  192. gas mileage with bolt-ons
  193. Cash to spend, where to spend it!?!? Need Advice
  194. question on a 302
  195. finally came off
  196. Wideband AND quadrant
  197. New TPS. NEW problem help
  198. Will this create a parasitic draw?
  199. Solid motor mounts
  200. How to Remove doors?
  201. my car still pings
  202. Question about brake lights.
  203. Need some help
  204. Vibrant Red ES for 93 Cobra
  205. Got a qustion
  206. Looking to buy my first 5.0 Stang
  207. Replace/Fix Pannels or ?
  208. Rebuild time
  209. Hood flew open!
  210. Redneck Converter Issues
  211. A/C- Heater control panel problem!!!!
  212. new pics
  213. Before and After with BBK Springs????
  214. Made some progress today
  215. Which water pump?
  216. New hood, questions on prep?
  217. shift cables??? CONFUSED
  218. Pad or cover??
  219. power steering pump deletion?
  220. Renting Air Compressors?
  221. Dust Shield/covers?
  222. Starting my swap
  223. easy wire tuck without all the work
  224. in diffrence in aod's
  225. Running alcohol to pass the sniffer?
  226. FR 500 17x8"
  227. Anyone put these on a fox ?
  228. fuel system
  229. Where can I find new crossover tubes?
  230. Looking to buy a 94 GT convertible
  231. Coolant leak help
  232. Coolant tubes
  233. To Those Who Remember My Fox
  234. Guess what I saw
  235. Restoring CHP #E408395
  236. 89 GT Ground effects
  237. So I went from a 5.0 to an LS1 camaro, recently something crazier!
  238. axle problem
  239. My 1987 Mustang Build
  240. What year did they start the 140mph cluster?
  241. convertible
  242. Help me decide on next project
  243. OPTIMA battery
  244. Bay Area engine builders
  245. give me some ideas
  246. Sold my car...
  247. Help with Pricing
  248. Font End Shake
  249. Finally installed HIDs
  250. OMG...I finally succumbed to the 'Stang
