View Full Version : 5.0 Mustang
  1. 347 EFI
  2. she wont start
  3. advice
  4. no spark no idea
  5. cutting springs
  6. diagianose me new 89gt
  7. Door Lock Wiring / Actuater Problems
  8. running rough...cant get it perfect
  9. 87 5.0 into 95 Gt
  10. clicking noise after oil change!
  11. NEED HELP!
  12. 351 windsor or cleveland?
  13. popping noise, hesitation, maybe backfiring?
  14. Erratic idle with heat on
  15. I seem to not be getting fuel to my injectors and also maybe a vacuum leak
  16. Which Junkyard Rearend????
  17. Diode trio/ code 31 and 84
  18. sn95 motor in 88 fox?
  19. 293 cam??
  20. starting to wonder....
  21. planning a rebuild.
  22. Dropped valve? Help
  23. lifter placement
  24. reposted 95 e303
  25. 82glx low oil pressure(guy says it aint high as it should be)
  26. Crackling noise when i get it
  27. gt40 heads an intake
  28. MSD pro billet distributer
  29. rpms cut out at 3500....have codes
  30. starter help!!!!
  31. Removing A/C and Smog. Converting to electric fan.
  32. need help with built 5.0
  33. size of threads on the rear brake lines.
  34. What else do i need to check?
  35. 87 GT - Need Help
  36. Buzzing is killin me
  37. Power seat switch failure?
  38. need help finding input shaft bearing
  39. How to check the TPS
  40. Idle Fluctuation
  41. Lowering rear, change pinion angle?
  42. popping coming from front end
  43. help me with my blower motor
  44. Turn signals NOT working!
  45. brakes lock up easy
  46. stuck starter
  47. vacum
  48. need advice on a/f ratio
  49. REAR MAIN PROBLEMS!!!!
  50. Adjustable crane cam rocker arm problems
  51. Rocker Arm Ratio
  52. engine still pinging after seafoam
  53. charger on a car
  54. Rough cold idle(+ some other problems)
  55. distributor question before I start car
  56. help with 94 5.0 carb swap
  57. Engine Swap
  58. 95 e303
  59. Taurus Electric Fan
  60. 88 lx 02 sensor
  61. Coolant system pressure problem?????
  62. Need help low flow to egr valve or a broken vacuum line.
  63. oil leak
  64. Help Identify if Traction Lok or not....pics
  65. Timing cover replacement
  66. Need Rebuild Advice
  67. Voltage Regualtor issues
  68. what do i need for a 5spd swap -87 5.0gt
  69. Clutch Help!!
  70. Tranny swap
  71. need some info on a build
  72. Parking lights don't work...Help?
  73. Harmonic Balancer Wobble?
  74. problem with ignition key cylinder
  75. heat wont go throught vents
  76. possible header/exhaust leak
  77. Radiator Core support
  78. Idle problems and running rich
  79. 347 in 94 GT
  80. help, whats the threaded hole in the iron gt40 head for?
  81. mass conversion question
  82. Problem with keeping battery charged.
  83. pistons
  84. help
  85. 5/8 head plug for EGR not working
  86. Timing is off!!!!
  87. quick simple question
  88. Power Steering pump woes
  89. what fitting to use on schrader valve? trying to check fuel pressure
  90. running hot new engine
  91. Left Bank Lean, Low Idle, Need Help!
  92. gears
  93. UPR Battery Box Install Questions?
  94. '89 GT Was Running Great - Suddenly Dead (No Crank)
  95. More 5.0 intake questions
  96. smog pump eliminator
  97. O2 eliminators (90)
  98. Idle Surge Issue After Head Gaskets
  99. A few questions (Wiring, starting)
  100. Anyone ever put a late 5.0 dash in late 80's 5.0
  101. saleen wing repairable?
  102. a couple rebuild questions
  103. head noise?
  104. Decking a block question
  105. Trick flow
  106. Adjusting Idle / vaccum line.
  107. B-Cam in a Carb 5.0?
  108. 8.8 rear end rebuild advice
  109. flywheel loose
  110. what can a hyper piston handle?
  111. Clutch pilot bearing
  112. tubular k member question?
  113. Megasquirt vs. twEECer
  114. car dies
  115. no fuel pressure
  116. my 89 mustang gt running ROUGH help pls
  117. help to deny the blow by!
  118. 2.3 liter 5 speed to 5.0 liter V8 can 5 speed tranny work?
  119. head Gaskets
  120. dipstick
  121. Turn signals dont work, please read
  122. Throttle locking up?
  123. will a t56 bolt up to a 302
  124. Rear Disc Brake conversion problems HELP!!!
  125. 5.0 Build Questions
  126. fouled plugs
  127. front 17X9 wheels and coilover clearance
  128. Where did the torque go on my 331?
  129. 88 5.0 gt wont run till it warms up?
  130. high idle problem
  131. egr back of heads
  132. wind rushing noise with cold air intake
  133. swapping mt into auto 95 5.0
  134. Starting problem
  135. running a little warm I think
  136. changing fluid in power steering?
  137. fuel injector not fitting snug into fuel rail
  138. 5.0 Questions
  139. big boys of the 5.0s need expertise
  140. Start up taking to many cranks
  141. 87 stand want to hide engine compartment wiring
  142. Heater core through glove box?
  143. Pig rich after emissions delete
  144. temperture gauge not working
  145. '93 gt fog light delete?
  146. It starts but wont stay running!
  147. cam question??
  148. running lean and pinging...help
  149. Exhaust pipe closeness to fuel tank
  150. GT40 Tubular Paired with what lower?
  151. Speedo gear install?
  152. 61 mile to the tank WTF
  153. New speedo gear install?
  154. 5.0L Question????
  155. alternator problems
  156. 347 Build help.
  157. oil cooler
  158. Oil pressure guage problems
  159. ignition situation
  160. 5.0 to 2.3?!
  161. fuel pump issues
  162. will maximum motorsports coil overs lower my car?
  163. 94 Mustang Rebuild
  164. Howling noise?
  165. 302 to 351
  166. Squeking noises!!!
  167. 5.0 down! loss of power need help
  168. Body kit installation
  169. egr connection
  170. Can't get my dizzy back in?
  171. idle problems
  172. 88 5.0 no maf?
  173. Oil Pump Shaft on the outside of the dist. eyebolt
  174. 95 Convertible Top Problems
  175. Cost cutting engine building
  176. d00e heads
  177. car turns off after i start it
  178. installing a cobra degas bottle
  179. Stalling Out Problem
  180. Did i make a mistake?
  181. i've got an odd cutting out problem...
  182. cold starts and laying down under pressure
  183. 5.0 starting problems, i need help bad
  184. Throttle Body problems. NEED HELP ASAP!!!
  185. Transmission harness wires cut!
  186. 5.0 Build up questions
  187. Steeda #19 Cam & 1.7 Roller Rockers
  188. 5 Lug Conversion
  189. Questions 86 GT
  190. Heater does not work well
  191. Starting issues
  192. front rotors
  193. 1990 mustang cold starying
  194. convertible rear view mirror
  195. install questions
  196. Coolant loss need help
  197. High Idle after making run?
  198. Tilt converion
  199. Dash Removal
  200. 1994 convertible mustang 5.0 parts
  201. 86gt rough idle and missfire
  202. Chip to tune 93 Cobra MAF, or aftermarket MAF???
  203. hurst shifter problem
  204. 1989 mustang map question
  205. swap from a straight 6 to a v8 302 any info
  206. rock hard hoses
  207. driveshaft or rear end?
  208. need help exhaust ?
  209. 1966 mustang to 5.0L project any suggestions
  210. spark plugs have oil on the threads
  211. question about solenoid wire on starter
  212. still runs bad! Help!!!
  213. rebuilding 302 with 289 heads couple ??
  214. power steering
  215. Mark VIII fan mod question
  216. ATTENTION NEW MEMBERS!! READ!!!
  217. gt40 intake spacer ?
  218. fox body headers/ sn95 car
  219. best cam for stock bottom end SD setup
  220. 03 GT Brake upgrade
  221. jack point
  222. how do i check fuel pressure?
  223. What year doors will fit a 1986 Mustang GT?
  224. Nitrous plugs
  225. Fuel Pressure ?'s
  226. stock 5.0 cam specs
  227. Will 2.02 valves clear the pistons?
  228. Crappy AOD Tranny's
  229. 80MM COBRA MAF HOUSING
  230. clutch cable problems
  231. upper control arm bushing not seated?
  232. my morning from hell
  233. Flickering check engine light
  234. Location of headlight relay
  235. car shuts off while driving
  236. F/R manual steering rack
  237. temp gauge not working
  238. Compression ratio help
  239. Alphabet cams
  240. need some help
  241. turn signal issues
  242. gutted resinators
  243. Got somethin weird goin on with my 87 GT
  244. Just finished the swap...
  245. fuel pump doesn't prime
  246. Headlight problems
  247. DomeLight wiring
  248. 70mm BBK throttle body spring stiff
  249. prob:hesitation/surge at 2500-3000rpm
  250. noisy clatter coming from intake manifold area?
