PDA
View Full Version : 5.0L (1979-1995) Mustang
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 [232] 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331
  1. Belt length for 5.0 with bigger pullies
  2. idles rough, little power, skips - misses
  3. LT1 question
  4. Finally some pics
  5. stroker
  6. Typhoon...
  7. GT-40p headers?
  8. Headers
  9. t-5 Conversion PITA
  10. Long tube headers or short??
  11. best gear ratio
  12. coil over vs shocks/struts
  13. exhuast tone
  14. 1988 Dash guages only half work
  15. exhaust
  16. Rear Axel
  17. nice deal on e-bay 4 a set of head
  18. what size injectors
  19. component location cruise control 92, 5.0
  20. What are some loud mufflers?
  21. which weighs less
  22. Anyone know
  23. Engine Prices how much did everyone else invest?
  24. 351 swap
  25. Trying to post a pic--hope it works!
  26. NEED ELECTRICAL HELP
  27. Hoods
  28. throttle body ques...
  29. stock fuel lines
  30. Belt touches
  31. FUN FORD WEEKEND! whos going?
  32. Is it true...?
  33. how many hp?
  34. gear installation cost?
  35. Newbie: mustang build-up?????
  36. Cobra SVO 700 Hood 2.5 Inch Rise
  37. Voltage dips at idle.
  38. Some actual pix of my 89
  39. retorque
  40. Wobbly Tire
  41. anyone have a pic of a fox coupe with cobra/gt kit?
  42. I want a 4-cylinder...
  43. 96 to 91 rear shocks
  44. Picture of my 1987 GT, what mods???
  45. Will my car throw a code?
  46. is this possible?
  47. what ford vehicles came with gt40's stock?
  48. Rear susp.
  49. MOVED: lancer raliart
  50. Whats with the fog lights...
  51. Fiberglass Hood Companies
  52. Whats needed for gears?
  53. Around the Area? Masion Dixon Dragway!
  54. Im looking to buy some converters
  55. Ride Of The Month
  56. Some pics of my black stallion...
  57. idle
  58. it's 5.0 month !!!
  59. Cervini's Ram Air Kit
  60. mass air meter
  61. Advance timing on 94 5.0
  62. BFG Traction T/A
  63. Radiator options
  64. Dyno next week
  65. talk me into an AOD plz
  66. autozone??
  67. 3.73 gear stock in 4beater automatic?
  68. what kind of wheels for 87 GT???
  69. Oil Change Instructions
  70. Engine swap....And now problems. HELP!!!
  71. will roush rims fit my 5.0?
  72. Crap- whining/grinding noise coming from rear
  73. Another exhaust clip
  74. Aftercooler
  75. Smog removal. Please Help
  76. Some pics from the trip I took today!
  77. general info
  78. Oil Pump
  79. MuthaF@#kin' Fuel Line Ruptured! PICS
  80. i drew this notch it sucks but its still a 5.0
  81. lowering
  82. Rear Quad shock removal
  83. tranny questions???
  84. Can I tell you what I hate?
  85. save on gear install
  86. Car running lil hot....
  87. clutch cable
  88. What belt size to use with vortech and A/C delete??
  89. help with shocks
  90. takeing trans out
  91. Motor Mounts
  92. PROBLEM with electronics
  93. any non-street legal i/h/c kits?
  94. Photo of my 1991Gt
  95. What is the best intake manifold
  96. AIR BAG LIGHT
  97. pros & cons to having a spool?????
  98. Need help with problem
  99. Pic's of My 93 notch
  100. Gas Mileage
  101. HORSEPOWER GAIN
  102. Horrible Horrible Situation Please Help!
  103. Noisy rear
  104. torque box reinforcement plates
  105. Photoshoot of my 93'
  106. Rear Springs...
  107. need your opinion fellas!!
  108. Should I do this?
  109. Donor car list for 351W
  110. Proform electric fan....
  111. starter/flywheel problem
  112. 2 great rides.
  113. Converting to MAF
  114. I got my Baby back!!!
  115. ?????'85 Mustang GT BOSS?????
  116. Stroker Recomendation
  117. running but not right
  118. Poping sound on d exhaust
  119. gears?
  120. changing my clutch
  121. Which one...?
  122. Trunk Question
  123. Need a carfax PLEASE
  124. passing the techs at the track
  125. Tech Fluids/Capacity Info --->
  126. shift kit install
  127. finally solved the backfiring :)
  128. Alignment
  129. Transgo Question Regarding Valve Body
  130. I want to know everything
  131. I want to learn about heads.
  132. good fuel system
  133. N E one have a old parts car? Or Spare Gt hatch?
  134. Which springs
  135. k-member brace bolt size
  136. idle problem
  137. New problem
  138. door weather strip ?
  139. Coil Springs Snapped GRRR DAMN!!
  140. installing new springs
  141. G TEch computer need help!
  142. dumb questio
  143. Rough ride
  144. IM READY TO CRY!
  145. Alternator from 97 5.0 Mountaineer
  146. wat shuld i do 2 my 86???
  147. Can u guys beat a 350Z?
  148. Wont Turn Over
  149. Got a question for you 5.0 People.
  150. manual steering
  151. Problem: Rough Idle + other error codes
  152. Aluminum/carbon fiber driveshaft gains?
  153. coil over conversion?
  154. lunching
  155. Sorry guys
  156. quicky
  157. pics
  158. MOVED: 351W Donor List ??
  159. MOVED: 2007 Mustang Production in Progress 605 HP !,Youve Been Owned
  160. Cobra upper and GT40p lower
  161. edge racing converter
  162. 3 Gauge Pillar For vert...
  163. engine noise
  164. Best Wheel Combo?
  165. king cobra
  166. Are projector headlights worth it?
  167. game
  168. CARB OR EFI
  169. seatbelts
  170. Thinking about drag springs...
  171. Speedo Cable
  172. Sold the 5.0
  173. MOVED: Nitrous wet vs. dry?
  174. haha
  175. springs
  176. another oil pressure problem
  177. tranny dieing?
  178. how bad is it
  179. Spark Plugs
  180. cheap drag radial
  181. radiator fan question
  182. headers have my mind spinning
  183. another dumb question o' the day
  184. Quick ET Boost?
  185. MOVED: 408 stroked 351w--heads and compression
  186. New Cobra Rims!
  187. 14 inch Draglites?
  188. Some new parts installed (pics)
  189. WHAT INJECTORS AND ROCKERS 2 USE
  190. auburn diff junk?
  191. MOVED: 351W EFI
  192. trac-lock
  193. changing Fuel Filter??
  194. Used a Friend's G-TECH Meter...
  195. Is it normal for tires to not break loose from a stop?
  196. Did i lose some power?
  197. Loud Clunking Noise....?
  198. Cleaned up Engine Bay....
  199. CARB TO EFI
  200. shift kit??
  201. hmp tv
  202. Dyno Results
  203. cranking but not starting pt.2
  204. centrifugal supercharger
  205. will these fit?
  206. hey
  207. e-brake
  208. Brake Upgrade (fitment Q)
  209. Taurus electric fan...for mustang
  210. starter getting too hot?
  211. 3 questions
  212. BBK induction and chrome wheels...
  213. goin with the streetheat trickflow
  214. Got a Clutch question
  215. what causes this code
  216. 16 inch rims...
  217. What returns the shifter to center position?
  218. Cranking, but not starting
  219. Where should I get my Gears in stalled in the MA area?
  220. does anyone have the 5.0 Haynes Manual?
  221. pull block out
  222. MOVED: 5.0 vs ta ws6
  223. Helpp
  224. 2nd Gear Going...
  225. H/C/I Combo
  226. Water pump ques...
  227. Pro's and Con's of Stroking
  228. uhuh may be a traitor
  229. Calling Balljoint Experts..
  230. Whine! Whine! Whine!
  231. A351 1.6 roller rocks. need help.
  232. Harmonic Balancer..NOob question
  233. Transmission Drum - Stamped Steel or Cast
  234. interior colors?
  235. Need Help...
  236. Clutch acting weird
  237. MOVED: 95 5.0 vs 94 Z28
  238. Cam Help!!
  239. weld drag lites or prostars
  240. Drive shaft!!
  241. choppy idling- how to fix?
  242. stock 89 head combustion chamber
  243. MOVED: 351w help
  244. MOVED: NEED HELP WITH TURBO
  245. Rear Wheel HP
  246. Finally hit 14's
  247. Changing a starter ..? need help :/
  248. fox body chin spoilers?
  249. 40 series flows dumped
  250. shift timeing
