PDA
View Full Version : 5.0L (1979-1995) Mustang
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 [221] 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331
  1. i have extra wiring
  2. Standalone fuel management on a 5.0?
  3. WHAT DO I DO!?!?!?!?!?!
  4. decent deal
  5. Smog pump elimination, can it be done
  6. track night
  7. Anyone Else have a LM-1 Wideband
  8. Idle...
  9. o my god
  10. NEED HELP PLZ !!!SURGE PROBLEM!!!
  11. Idle/accelerating problem
  12. two hoses??
  13. O2 Sensors
  14. a/c causes idle issues and voltage drop
  15. B303 CAM HELP PLEASE
  16. Wheel help pleaseeeeee
  17. block bolt!!
  18. .
  19. Control Arm question??
  20. Hard Clutch
  21. Running at the strip with a bad throwout bearing?
  22. How does the center console come out on a 91?
  23. Pros/Cons of Bumped Timing...
  24. a sad day
  25. help finding a shifter
  26. Where to purchase convertible top?
  27. how about this 5 lug conversion?
  28. 5.0 help
  29. AIR ADJUSTER
  30. jegs traction bars/rear upper control arm mounts
  31. Smog pump
  32. Squeeling noise...
  33. Code 85, and 41
  34. Which Wiring Harnesses?
  35. Best cam to use?
  36. Shorty headers
  37. IDLING PROBLEMS!!
  38. marangoni tires
  39. Why I love my 5.0
  40. pics maybe
  41. HAHA BIG PICS AT LAST
  42. test post
  43. new part
  44. 86 mustang 4cl w/ 92 Mark 8 drivetrain???
  45. way to calculate mph?
  46. posting pics
  47. hoses
  48. finally got pics
  49. Post a pic for me
  50. Post a pic for me
  51. Engine Oil Leak! please help desperate
  52. tockico springs?
  53. wanna loose some weight :P
  54. talk me into a 5.0
  55. edelbrock performer rpm
  56. car quitting every so often!!!!
  57. help with afr 185's
  58. Tranny options?
  59. how much hp?
  60. can someone run a carfax for me please
  61. Cant fill Gas tank
  62. NEW PARTS TODAY!!!!!!!!!!
  63. 88 5.0 wont turn over
  64. need to ask a question for my burnt friend...
  65. Pulled over again!
  66. anyone done the efi to carb thing
  67. engine light
  68. finally on the road again.
  69. Engine light
  70. anybody looking?
  71. Can I remove this thing in my fender?
  72. Build advise, plz take a look
  73. Bad smell!!
  74. v6 hp
  75. Now that I am single again
  76. mass air flow size
  77. Good deal or not
  78. My Alternator
  79. THE NOTCH IS ALIVE!!
  80. where can i get.....
  81. converter,shift kit,cooler and alum d/s are in
  82. STUPID FUEL LINES
  83. Do these cars ever stop breaking?
  84. wiring help
  85. Exhaust problems
  86. new pics
  87. HIGH IDLE!
  88. MAF Conversion
  89. MM fuel pump?
  90. Stock header broke...dammit!
  91. Suspension...
  92. I am an IDIOT!!!!
  93. right timing
  94. Bad News
  95. Dynomax vs. Magnaflow
  96. Best way to spend $2,000
  97. Windsor Heads.
  98. What would you pay at a shop...
  99. clutch cable
  100. Trickflow heads
  101. 84 mustang gt fuse box location?
  102. its seen better days!
  103. california,sacramento
  104. 19 Ilb injectors
  105. Stupid Suspension Question
  106. nitrous plugs
  107. TreasureTroopers.Com
  108. fuel pump lockring
  109. cars starts but shuts off when its cold unless i hold pedal
  110. Spark plug boots
  111. Carb AFR 165's
  112. 1993 mustang help
  113. burn outs?
  114. Still Unclear
  115. Colorado emissions
  116. what the hell is happening here
  117. Easy Burnout?
  118. Dynotune should be done today.
  119. wat to do with my 5.0?
  120. wat to do with my 5.0?
  121. wat to do with my 5.0?
  122. UPDATE GOT MY S/C
  123. Try new things and need some information
  124. Underdrives pulleys and stock belt?
  125. Measurment for an air cleaner?
  126. HELP WITH New Diff On The rear end
  127. Which xpipe to buy? Need help!
  128. Holy ****, he dropped his prices again!!!
  129. HP question for this setup?
  130. Stock production motor with TRW pistons?
  131. Interior Fix
  132. What would you pay
  133. I NEED ALL NEW EXHAUST
  134. stroking question
  135. need opinion on rear shocks
  136. what heads will and wont bolt up to the headers.
  137. So its my birthday!
  138. My white 89 has idleing probs
  139. Anyone from WA?
  140. New to forums/Transmission question
  141. 90 GT Vert, side skirt what years will fit!
  142. Idle Issue?
  143. no one knows about idling probs huh?
  144. Afr 165 heads
  145. Idle hunting up and down then dies
  146. attention nj,ny,pa
  147. To all you cam guys...
  148. hp estimation for 408 with 10 psi supercharger
  149. Who has World cast heads?
  150. 94 gt vert sputtering resolved.
  151. help with gears
  152. Wheel Studs
  153. Damn Windows
  154. Ignition Switch
  155. completely lost
  156. what can you bore and stroke a 351w out to
  157. crazy beeping!
  158. EGR
  159. Connecticut?
  160. help!!!!
  161. pushrod length
  162. Temp Problem..T-Stat?
  163. fuel pressure ?
  164. Dash lights
  165. q for those who have installed trick flow kit
  166. Your Opinion on Hypertech Chip for 91 5.0
  167. anyone running ARF 185's?????
  168. 95 Ho Engine Q
  169. 5.0L Rebuild ???
  170. Question for the 5.0 owners!
  171. 5.0 alternator wires?
  172. 95 year end production
  173. Chicago Area
  174. Stranded Again!
  175. How often are you supposed to clean your TB?
  176. fuses?
  177. RPMS
  178. EEC Relay
  179. 373's
  180. Car throwin lotsa codes. need pro-help
  181. Trickflow stage1 and gt40P heads?
  182. TrickFlow top-end kits!!!
  183. When I raced my buddy yesterday...
  184. question for fox owners?
  185. 17inch chrome air cleaner cover???
  186. GETTING VERY FRUSTRATED!!
  187. Intake Options
  188. Head/Cam Job, question...
  189. HELP...Running Rich or Burning Oil
  190. Tranny????
  191. last night
  192. Quad Shocks and new suspension
  193. Explorer intake help!
  194. Installing a mass air conversion
  195. B303 cam help
  196. New to the forum. Just saying Hi
  197. help please
  198. performance YEAR
  199. Convertible Weatherstripping
  200. wtf is goin on?!?!
  201. Wallmart for an oil change? What oil works best
  202. Retard vid....if it works
  203. smog removal
  204. How do you Id a header?
  205. Roller Rockers question
  206. Steering Help Please!
  207. ignition switch?
  208. 302 blocks
  209. THINKING ABOUT SELLING RPMI INTAKE.?
  210. Good Deal?
  211. coolant temp sensor
  212. NEED HELP ASAP....STARTING
  213. MY FRONT TIRES ARE SO DRY ROTTED!..NEED NEW TIRES.
  214. nitrous installed
  215. speed density info
  216. Sanding quarter window molding?
  217. San Diego Meet and Greet
  218. Anybody ever use one of those light batteries?
  219. Battery light wtf?!
  220. Suspension/Sub-Frame?
  221. Cam or no cam???Audio clip/slideshow
  222. Distributor
  223. f-cam in aod
  224. 90' GT Vert Good deal?
  225. Dipstick
  226. what happened to the....
  227. installing torque boxes is a PITA!!
  228. Will it fit??
  229. Anyone Running a Manual Steering Rack?
  230. Less BS More TRUTH!!!
  231. PARTS FOR 1995 GT
  232. a-pillar suggestions
  233. Best Gas Mileage Fox?
  234. Stronger blocks?
  235. double clutching
  236. Trans for 347 stroker?
  237. weird problem on 89 lx
  238. are these any good checkem out!!
  239. gonna get deleted, but i need one simple answer
  240. My race night.
  241. tire question
  242. TPS or Fuel prseeure Regulator?? WTF
  243. My freinds 5.0 in trouble?
  244. noobie questions
  245. STEERING WHEEL ADAPTER
  246. fuel pressure?
  247. Injector issues. Leak? costin me $$
  248. LITTLE HELP
  249. Throttle Body for SN-95
  250. UPDATE** Civic vs. my car
