PDA
View Full Version : 5.0L (1979-1995) Mustang
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 [244] 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331
  1. Bad day
  2. vacuum leak?
  3. mustang totalled
  4. Turn signal relay?
  5. tailpipe size prob
  6. a/c recharge kit
  7. disconnecting factory tach
  8. radiator cap flew off
  9. need help finding a certain notch...
  10. RAIN! help with leak
  11. cleaning egr and such?
  12. gas mileage bad.. any possibilities?
  13. Is it ok to.....
  14. Dash swap pics
  15. Where to buy Paint?
  16. where can you find out production numbers on different fox's?
  17. When was the last four lug fox made
  18. Ford Racing Aluminum Radiator
  19. Need a 5.0 expert!
  20. Towing an '86 Convertible
  21. CALL ME CRAZY BUT.........
  22. Bump Steer kit -- Please help
  23. whats your exhaust?
  24. I have the Drum 5 lug conversion on my 90 GT
  25. Max Box manifold
  26. what is the overall best intake manifold?
  27. difference between fenderwell and regular intake...
  28. turn signal issues
  29. Overheating again
  30. Whats this worth?
  31. 5.0 cloan hook up???
  32. wheels
  33. Crashed 1995 Mustang GT won't start
  34. What should come first?
  35. any one got a mustang for sale
  36. 88 to 86 Steering column?
  37. 351 for my 95 GT?
  38. Steel cowl hood?????
  39. Road and Track Box
  40. Speedo Problems! Help me guys
  41. Radiator? Good or bad deal?
  42. 5.0 mustangs restoring ( are they easy ? )
  43. How is a 331 made?
  44. A popping or a spark sound??? 94 Mustang
  45. High RPM Breakup after Mods
  46. Speedo gear.
  47. 4.9L??
  48. New pics of my new ride :)
  49. $1,200 What to BUY?????
  50. Nissan Powered GT500?!? MotherF*ckers!
  51. just advanced timing
  52. mounting questions
  53. Timing pointer missing?
  54. bitter sweet (pics)
  55. Installed gauges *pics*
  56. Mustang Police Car Question.
  57. Went to the track
  58. harmonic balancer?
  59. interval relay or w/e?
  60. quick pic question
  61. Smog pump question
  62. Tach Help..
  63. Rear brakes clicking/knocking
  64. welp, no more mustang for a while
  65. running rough
  66. fuel pump shutoff?
  67. 351 Parts Cars...
  68. restoring
  69. anyone close to cumberland maryland???
  70. Clear Headlights from K2 Motor?
  71. typhoon/edelbrock rpm performer intake question
  72. Transmission?
  73. Anybode at Englishtown today?
  74. boost gauge?
  75. SEAFOAM QUESTION HELP ASAP PLZ
  76. MOVED: 351 swap
  77. Heads....
  78. Porting......
  79. best rear gears?
  80. exhaust questions for my a 5.0
  81. New headlight pics
  82. Need some advice on my next mods
  83. Cobra Brakes
  84. HELP ON BACKSPACING
  85. Oil pump shaft installation? Please Help
  86. Hi, 93 Cobra wheel question...
  87. How to put smog pump back on?
  88. I need a Mustang Sherlock Holmes!
  89. my car is pissing me off help me please
  90. autometer tach
  91. ****.
  92. Gear question..
  93. Turns over, but doesn't start???
  94. Reversed Intake Manifold CRAZY
  95. What mods to get a stock 5.0 into the 13s?
  96. Loose Pilot Shaft
  97. This Sucks
  98. Hood pins
  99. paxton NOVI-2000
  100. Fuel pressure
  101. need help.....
  102. AOD to 5 speed question
  103. I decided AFR 165s, help!
  104. koeo codes
  105. Might buy a 4cyc n Make a 5.0
  106. im stumped
  107. whuts causes backfire
  108. BBK cold air
  109. Need Help!!!!
  110. USED HEADS, GT40, ALUMINUM, ETC
  111. Help for a NewB
  112. Gauge Pod on the A Post
  113. 305/35 on 18x10?
  114. engine help??
  115. paint ques....
  116. need new brake rotors
  117. loud exhaust
  118. arp bolts with windage tray and girdle
  119. Tubular k-member
  120. Carb or EFI?
  121. Lakewood Struts
  122. Can't Hook Up...
  123. How would you get your stock 5.0 to 300 hp?
  124. buying a 5.0..questions
  125. Horsepower tv......
  126. Fuel issue w/ my 89
  127. quick plz?? clean cats?
  128. mustang has major issues help
  129. Sold my car....gonna miss it : (
  130. My 331 seems to have lost power!
  131. Nation Wide Directory
  132. My car won't start guys =( =( =(
  133. MODS....
  134. What is your fastest ET ever?
  135. Dumb ques...
  136. Probably a silly question but...
  137. Junkyard Turbo Setups
  138. carb swap wires not matching up with fletchers
  139. 5.0 Story Tellers
  140. spark plug Q.
  141. Heads.....
  142. diff gears for autos and 5-spd
  143. lx question
  144. anyone seen UPR adjustable clutch cables???
  145. Timing My 347 right now NEED help
  146. Mass Air Flow Sensor
  147. Crate or no crate?
  148. Cat system Cheap from Ford
  149. Gas Pedal
  150. AOD and gears.
  151. Best aftermarket shifter for T-5
  152. motor oil
  153. carb sticker
  154. tip?
  155. water (or something) dripping
  156. check this out
  157. top end
  158. difference between 2.95 vs. 3.35 trans grear set?
  159. help decide on rims?
  160. hows this motor combo look
  161. Need help....cam..etc
  162. overheating...
  163. Won't start
  164. Heads ???
  165. cobra brake conversion
  166. Anybody have GT-40p heads??
  167. quick question
  168. Shifting !!
  169. I Think My T-5 Is Going
  170. How do you break a 5.0?
  171. kandy paint? pics
  172. Tint
  173. i have to better 13.0
  174. What the hell is going on with my car?
  175. tranny cooler pics?
  176. CLOSE THREAD.
  177. ? On Sub-Frame Connectors?
  178. Installing a new clutch
  179. GT 40x heads....what is your opinion
  180. EGR Blockoff???
  181. GT Ground Effects
  182. Tailgaters SUCK
  183. stock rebuild price opinion
  184. Question about 347
  185. How long have you owned your 5.0?
  186. "Driving hard" and "normal use"
  187. alotta ?'s from a newbie
  188. making a purchase
  189. wanted 87-93 5.0 wanted
  190. Fuel cell/Battery placement
  191. Motor Mounts/Slip up during Conversion
  192. Where can i get a Crank Scraper for 302
  193. interior stuff
  194. custom ground cam
  195. Mechanic surprized me
  196. window trouble
  197. Electric Fan ? What is normal operating Temp?
  198. Diesel?Weird? Maybe. Yes, weird
  199. Intake manifold question
  200. rear main seal?
  201. AOD t-bar gets hot
  202. quick 5.0 4 eye value question.
  203. cam on stock heads.
  204. How does this combo sound/numbers?
  205. High HP Daily Drivers?
  206. Gettin ready for the car show!!!
  207. Steering pump leaking
  208. What Fuel Pump Should I Get?
  209. Bank for the Buck?
  210. Engine shine?
  211. wheel spacing chart
  212. My Vacume reading good or bad?
  213. EXHAUST.
  214. look @ this 302-363 wow!!!
  215. milage no longer registering
  216. Best Engine Oil Gunk Cleaner?
  217. Overheating/Leaking
  218. junkyard turbos
  219. removing emissions pump
  220. TKO 600 or ford Spec T-56
  221. Sideways?
  222. tryin to make the body look better
  223. is this a good deal
  224. is this too big
  225. Upper and Lower intake question
  226. drop in oil pressure
  227. mac exhaust
  228. anyone have 18 inch bullits on their fox's??
  229. Need help, dont know what to call it though
  230. How much a SN95 Vert weighs???
  231. what should i buy next?
  232. Ground Fx Brackets
  233. 70mm Tb and Poweraid Spacer Diameter?
  234. good deal or no????
  235. 87 posi read end Q?
  236. throttle body specs
  237. NEED HELP QUICK!
  238. Another How much hp thread
  239. AOD POS Need suggestions
  240. Intake Q ???
  241. eletric fans
  242. what kind of gas mileage gain
  243. how practical?
  244. who has the best of "bad things happened"?
  245. ::help me with exterior looks poll!::
  246. edelbrock valve covers question?
  247. Which is faster??
  248. Acceleration Hesitation
  249. Help with a cam anyone?
  250. what size clutch
