PDA
View Full Version : 5.0L (1979-1995) Mustang
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 [145] 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331
  1. shaker hood on sn95
  2. 1987 mustang
  3. How fast is this 331ci stang?? My friends camaro ss is setup to race it.
  4. quick question
  5. how much oil
  6. oil change recomandations?
  7. What trans do I have?
  8. Cobra Vs Explorer intakes
  9. 86 Headrest
  10. aod transmission
  11. yes or no to these?
  12. RACK AND PINION NO#S
  13. alternator problem
  14. Carfax needed asap please
  15. Drag wheels and tires
  16. some pics of the stang
  17. gt40p's vs stock
  18. POPING BACKFIRE
  19. possible buy!!
  20. Fuel Pump brand...which to buy?
  21. Is any body going to this
  22. Engine running rough question?
  23. looky what i got!
  24. Dumb
  25. NEW PICS
  26. went to the track.
  27. Orange County, CA guys, CHECK THIS OUT!!!
  28. uneven launch
  29. installing cam have ???s
  30. Degreasing a 5.0
  31. parts supplier for 87-93 seats?
  32. Ford Racing Handling Kit
  33. map or baf sensor
  34. GOT MY CAR DYNO YESTERDAY
  35. TFSH intake help
  36. Just Got Back From the Track, GREAT TIMES
  37. dumb question
  38. good spark plugs
  39. 302 vs 351 Water pumps
  40. Running BOSCH PLATINUM #4
  41. water pump
  42. HO or not?
  43. goin carb
  44. 89 vette vs my 95 gt ?
  45. Convertible pump, or motor problems.
  46. Question
  47. car is running like crap
  48. torque converter
  49. Good plug and proper gap for fuel inj 347 stroker?
  50. Narrow band air/fuel gauge worth it or garbage?
  51. Help! no spark no fuel???
  52. Im not sure what to do
  53. Nice weather... been spit shinin' the pig. *PICS*
  54. exhaust
  55. autocross
  56. trak lok
  57. Tires
  58. Idle air control
  59. good deal?
  60. Upper Control Arm Bushing...DAMN!!
  61. About to buy an SN 95 GT Things to check?
  62. Good plug wires
  63. Piston rings or Valve guides?
  64. {resolved it} not stang but maybe can learn something that will help the stang in the future.
  65. seat problem
  66. b303 hp
  67. Plugs & Gaps question
  68. Need gasket size help......
  69. Lets make a beast
  70. New Bumper cover
  71. car wont fire
  72. Cats and fuel smell question....
  73. Body Question
  74. Need Answer ASAP!
  75. Pro Topline aluminum heads
  76. Question
  77. timing question
  78. What cams are people running with sd?
  79. Finally some pics of my cars
  80. WE HAVE IGNITION!!!
  81. HELP Stalling issues STUCK IN A PARKING LOT
  82. leaning out a 351
  83. ???
  84. fiberglass hoods
  85. back spacing
  86. HELP
  87. Holley fuel pressure regulator and what i should get to replace it.
  88. louvers
  89. Hello, i have some questions
  90. MAC shorties on GT40P heads?
  91. clutch
  92. cut exhuast off beofre second cat?
  93. paint update....
  94. no emissions laws if car is 20+ ?
  95. 1988 5.0 Head Question
  96. open headers!
  97. Possible electrical issues...need suggestions
  98. throw out bearing/ clutch fork
  99. blew my motor *** even more vids
  100. Need Help brake ?'s
  101. junk yard tranny question
  102. A/C and smog Removal Help!!!
  103. Steel vs. Aluminum Underdrive Pulleys...
  104. Average track times?
  105. i need help really really bad
  106. attention tweecer owner! error message?
  107. Mid Micigan Motorplex anyone?? Test and Tune?
  108. Rear End gear Oil
  109. header exhaust gaskets
  110. hi-flow cats comparison
  111. stand alone engine management
  112. RIM AND TIRE HELP PLEASE
  113. rear seat delete?
  114. Spline Count?
  115. dropping PSI
  116. Different Idle sound
  117. stock fuel rails
  118. Painting the Engine Well...
  119. how to get injectors out
  120. drag radials
  121. changing oil pump
  122. 5.0 hp?
  123. Problems after new build
  124. boss's 89 GT so sick
  125. popping come from under the hood
  126. Cross Over H Pipes ? Yes No?
  127. spark plug wire protection
  128. I think I found my alternator..
  129. Help I am Changing the Steering wheel !
  130. 27 inch tall slicks fit?
  131. drive shaft loop anyone???
  132. seat upgrade
  133. mid pipe for aod/5 speed
  134. Harmonic Balancer Removal
  135. RWHP??
  136. firewall adjuster
  137. Buying A New Clutch, King Cobra Any Good?
  138. STARTER SOLONOID
  139. What should I buy??
  140. Help me with my shopping spree
  141. Got me some MT's today
  142. Found my problem>>Blown head gasket..
  143. side stripes
  144. Injectors and TB's
  145. hehe guess what i got to work on
  146. 5.0 fun
  147. Looking for new rims?
  148. Stupid question on motor rebuilding.
  149. Carb Tune
  150. Pony runs rough when warm.
  151. new top and frame
  152. Delphi injector: Are they Ford?
  153. will 4cyl tranny work on V8
  154. head/intake swap requirements?
  155. Brake lines
  156. Weird fuel pressure change because of new pump?
  157. no brake lights!!!
  158. Harmonic Balancer Question
  159. help with tranny
  160. Custom car insurance
  161. centerforce dual friction
  162. s/c on a stock 95
  163. what to pay for a 351?
  164. Jack Stands
  165. Ball Joints
  166. Vacuum...
  167. Heres My Baby! Pics and Vids
  168. newbie needs help
  169. anyone try the "super tech" full synthetic they sell at wal mart?
  170. intake manifold gasket issues
  171. can I talk this down?
  172. difference in heads?
  173. MAF i can't find a definite answer
  174. Water Pump ?
  175. I NEED HELP!!! Won't start and i dont know why
  176. Another Clutch Question
  177. ring things on the bottom on your heads
  178. 88 GT hatch rattles
  179. Gauges Gone Wild
  180. Installing/Degreeing cam
  181. tensioner
  182. routing my belt
  183. Clutch Slipping? (New one?)
  184. Tailshaft bushing...
  185. How to change my clutch
  186. 2 bolt to 4 bolt conversion NEED ALL EXPERTS HERE
  187. fuel pump
  188. About how much hp am I pushing to the wheels and to the flywheel?
  189. curious
  190. good day
  191. should i get it
  192. Quick Question!
  193. Oil Breather?
  194. intakes
  195. New Air filter and PCV Valve - Free (pickup or ship)
  196. Exhaust fitment question
  197. Rear seats
  198. How to get 400rwhp with a 331 all motor
  199. Will an E-cam fit a 1986 stock 5.0?
  200. Factory Racing 5.0
  201. where to get Guages and pic request
  202. X pipe
  203. ?turbo
  204. brake pads ratteling in caliper?
  205. Turbo thread
  206. Trick Flow Brand Gaskets?
  207. Systems????????????
  208. *FINALLY*
  209. stupid question
  210. stock w/turbo
  211. Fuel Pressure Regulator Help
  212. should i go borrow $4K for this?
  213. Most Reliable
  214. clutch qaudrant button
  215. injector size question
  216. timing help
  217. Tracking issues
  218. Need to get an idea of what this thing is puttin down...
  219. seats
  220. valve covers question
  221. Wow
  222. Cobra R Tremec, worth the money?
  223. EGR spacer
  224. Not a bad steal...
  225. ford racing f303 F cam question
  226. vibration problem solved!
  227. 88 GT Hood/Headlight & Tranny ?'s
  228. Header Install Before or after Heads??
  229. 89 5.0 basic upgrades?
  230. Pick what I blow my money on
  231. Cold air for Fox 5.0
  232. X Brace
  233. Underdrive pulley help for a 94 5.0
  234. COIL OVER KITS
  235. QUICK question: driveshaft
  236. Will these work without sn95 spindles?
  237. 40 series 1 Chamber mufflers for S/C car?
  238. will O/R H or X bolt to stock headers???
  239. Torque wrenches
  240. New TrAck Times?
  241. T-top holder
  242. nubee w/ intake questions
  243. Stock shifter?
  244. 331 balancer and flywheel
  245. 1993 Mustang LX 5.0 vs. 1979 Camaro Z28
  246. exhaust clip
  247. Stupid Question...
  248. Noise
  249. misfire fixed, question about ideal
  250. What plugs should I get
