- clearances
- Will It hurt my car?
- sorry to post this
- MOVED: Supercharger
- need a new stang
- what kit?
- car keeps dying
- 5.0 Engine Dress-up
- Funny question....sort of!
- fuel lines and tank
- 87 Mass air conversion
- IAC question
- rim choice? help
- Is 10-40 recommended in these motors?
- Where can you buy a stock new 302 or reman'd engine?
- Tranny went kablow.
- Bumpin timing
- Intake & Ponies
- what do you guys think of this engine?
- How do my old plugs look?
- what would i need here???
- Weight difference?
- Dulled headlights
- 89 LX convt 5.0 dead AC
- startup, maybe not
- Transmission Question
- HELP ASAP
- plug gapping
- CJ Pony Parts
- PLEASE HELP I HAVE A BIG PROBLEM
- E303 help ?
- Where has all the chips gone?
- manifold swap...help!!!
- 86-88 GT Fuel Pressure Regulator Location?
- oil?
- Factory Freak?
- MOVED: 351
- first time at the track... results and opinions
- Clutch Question
- 90 Fox.
- Noise
- Fiberglass, paint, cracks
- Help...
- Throttle Body
- question about flywheel
- Ticking under the hood...any ideas on a source?
- cobra kit
- Question about intake leak
- surging idle
- grinding noise in cluster
- 1993 Mustang GT Convertable
- MAF housing recomendations
- oem clutch cable
- cheapest route to a 13 second car?
- Need opinions
- So I installed a new AOD today, and now the car wont crank/turn over
- A/C not working
- 13 seconds on stock 5.0 motor?
- checked out a 93
- 87-93 wtf!
- 3:73s or 4:10s?
- Wont stop trying to start
- hooker and holly
- ford racing 5 lug rotors?
- New headlights off of ebay... Missing rubber seal???
- SLP Loudmouth II?
- Popped my T-5
- MOVED: I saw the most riced out mustang today!
- MOVED: California
- windsor heads
- What gears do I have??
- whew! was just the smog pump
- MOVED: camera phone pic
- idle?
- GOT MY CAR BACK!!!!
- do you need a double hump crossmember?
- Wheels and Tires... Need Help!!!
- 351m/400 block
- spark plugs
- Looking into a 89 LX 5.0, HELP!
- I'm So Pissed! Trans Install
- Regular or synthetic...?
- Buying a 302 Block
- drive shaft bolts seized?
- HELP! QUICK!
- Question About Idle.. Please help
- 91 conv. rear 1/4 window
- doors?
- BEST SOUNDING EXHAUST EVER
- !!! How can I tell which year my AOD is from?
- Fuel pressure
- mark v8 electric fan ?
- plug off
- Next mod
- 1985 Mustang 5.0 GT
- Selling and buying wheels... help
- Idle Not Fixed
- shocks
- White Face Gauges
- fuel line problem
- Driving W/O Power Steering
- I don't get it?
- Bored wanting to mod
- 16.1 quarter miles!
- Got the 5.0
- Manual swap HELP!!!!
- ok to run eng. for a sec with no belt?
- Video ques..
- cervini hood bolts
- 5- link question
- 4 lug slotted rotors
- will this work
- Header Bolt Question
- DAMN PO PO'S!!!!!!!!!! CHP's!!!!!!!!
- Simple Spark Plug Question
- installing exhaust
- PLEASE HELP FLYWHEEL/TORQUE CONVERTER BOLT REMOVAL
- chrome exhaust tips
- cobra 2000 R rims
- Fuel Pump problem
- Goin crazy.....
- Oil Problems
- Coolant/TB bypass
- Intake ques...
- exhaust problem
- pulleys
- Saleen Replica's
- spider gears
- 97.....mountianeer?
- WIN A SET OF FOG LIGHT BULBS NOW!
- water pump
- Exhaust is on
- Comparison
- cowl induction
- Twisted Wedge Heads
- Starter??
- How Much $$$
- Distributor
- little things for more performance.
- Stroker Questions???????????
- HELP ON REMOVING A PANEL!!
- bran new cervinis hood for 100 bux
- What do you think this car will do in a 1/4?
- tranny convert/turbo questions
- power window help
- Radiator Overflow
- can runs 195 in traffic, headers too hot???
- Mufflers
- "Casper" ...
- black deep dish bullits on a fox?
- why
- hood ?? whitch one...
- e bay
- My intake install tonight...
- GT-40 intake install
- Engine managment
- How hard are you guys launching?
- Where can I buy gears?
- Clunking nooise???
- Tires Screeching on Turns...?
- lets talk about cams
- What octane are you running on?
- pinging.....wtf
- Blower and Block questions
- torque boxes
- engine swap
- Broken Headlight Switch & Rattly Hatch
- fuel gauge
- loud exhaust
- restoring 91 lx do you know?
- best tranny for about 1100 bucks
- What h/c/i to pass emissions?
- ...from '4.10 gears post'...hmmmm !!!
- Steeda radiator...
- codes?
- carpet
- Checking codes
- insurence?
- Any one done this???
- Need to Kill Switch my cars
- Alternator ques.....
- front sway bar??
- 17x10 bullitts?
- whats with the junkyards!!
- 1990 with the CHIRP !!
- NEED HELP PLZ
- pcv valve
- Overdrive pullies,Underdrive.....?
- Front rotors/brake question
- Inspection Test FAILED!?!?
- another MAF question...
- What cam to put in?
- Oil Leak
- gears/speedo/tires question
- Need Help Air/Fuel Meter.
- 5.0mustang&superfords zine.... what a joke
- Overhaul on a 1990 LX
- Motorsport Cams
- syncro's?
- Water guage....
- door handle rivet size??
- Guage cluster?
- just got 93 cobra spoiler
- fuel pump
- water/methanol
- exhaust cut-out's
- 4:10 GEARS INSTALLED QUESTION
- Stalling problem
- New Forum Sponsor Tunable Induction 5.0 UUH Systems
- Anybody here running a Trick-Flow topend kit N/A ?
- MOVED: Bad night
- how much boost with stock motor?
- Who's Running GT 40P Heads?
- is it possible yes but who wants a laugh
- MOVED: of topic.... but oh well.
- My stock block turbo 5.0 goes 6.90's.
- MOVED: Someone school me on superchargers!!!
- Exhaust fitment
- need help
- bullets on foxes?
- timing on a 302 ho with a carb
- 2000 v6 needs new powerplant!
- transmissions?
- vale train noise??
- $600 for a new clutch at Aamco?
- Starting probs....
- AC question?
- Lowest Gas Prices
- Trans. updrade for SC?
- tranny question =)
- Saleen Spoiler?
- What rims?
- Roller rockers...
- My GT has been DE-Gratered, what do you like the most?
- 5.0 swap
- Changing my clutch, need advice
- h/c/i ques.....
- Timing ques....
- BEST subframe connectors
- Springs?
- MOVED: s/c question
- MOVED: price for a 351c block
- double clutch or granny shift
- which gears
- gauge mount
- fuel pump questiona
- i need info on a 351m/400
- Is this safe
- pissed confused
- basic mods+nitrous=gear?
