View Full Version : 5.0L (1979-1995) Mustang
- Loud Tick.....Lifter?
- Pipes for sale
- Canadian Custom Fiberglass
- 3.73 gear
- 89 cobra?
- K&N filter vs.
- Off road pipe without MIL Eliminator
- Air Bag Light
- 5SPD swap, wiring question
- 5.0 mods need help please!
- pushrods
- Are bigger SparkPlug Wires better
- Front adjustable coilovers....anyone have them?
- help with strokers
- Best cold air intake?
- MOVED: Gear Calculator Websites
- Front crank seal
- Pro Shifter
- what could be wrong?
- A3M1 ECU .. interchangable?
- 5.0 swap, how will it effect resale?
- Need help on, Disk,Calipers and brakes
- 2 grand to Spend....
- tailpipes
- moving seat back
- brakes need help
- question about engine stalling
- Timing advance
- How to patch a hole on a convertible roof
- Should I buy???
- Heater Core Hekp!!
- tire wear
- Front sway bar bushing gone
- Heads and blower!
- [Deleted]
- [Deleted]
- Computer Programing
- Which 5.0 to use?
- Headers
- 94 Mustang 5.0 pics needed.
- in need
- GT Tire Sizes Needed
- How to Blow
- Mass Air Conversion
- Carb Tuning
- Duraspark 2
- 460 in a fox
- EFI to CARB
- For you 4 cyl. to V8 swap guys
- Roller Rockers - Pushrods
- i had an accident....
- The "GMKILLER331" build up.
- High idle
- 2 subs + amp in box NICE!!!
- 1991 GT actual weight?
- aod from other ford
- My new GT-Oil pressure...o
- Auto to Standard Swap
- problem! HeLP!
- Coolant drainage
- DRAG TIRES
- headers questions....
- GT vs Lightning....
- rings
- Ignition?, Starter?, help
- transmissions
- 90 lx gears
- What Next?
- what gears are stock in 95 GT
- Idleing
- blocks
- Exhaust??!!
- stang vs. trans am part 2
- Any Clutch Suggestions?
- hood
- Vacume leak
- Valve pitting
- High idle problem
- Need Input
- harmonic balancer wobble
- need hi-beams
- The project has started
- how many of u also have Jeeps?
- 347 Stroker / Crate Motor
- got a part swap queston
- YOUR 5.0 PICS!!!!!
- BEST timing
- Help to Launch....
- Crate Motor
- Different, but still random id
- Loose circiut
- Cam specs and rr - heads.
- clutch
- ATTENTION!Ford gurus and
- sick of problems.
- need to replace d/s header
- 4 cyl to v8 rotor swap
- Do theese bearing look bad to
- 95 GTA undercarraige clunking
- Stearing
- Power draining
- speedo
- Best manual - Chiltons vs
- Help fast please.
- wont start 94 gt,please h
- how do i change the distributo
- door hinge help.
- Random Idle
- tachometer green wire
- Exhaust fitting
- mass air conv. cleaning u
- msd distributor
- gtp
- aod tranny questions
- oil pressure
- Throttle Linkage...HELP
- headers
- Motor Knowledge-Clicking :(
- Speaker Sizes
- please help me
- sticky gas pedal
- EMISSIONS LEGAL FORD CAMS
- shift kit
- exhaust
- Block FAQ
- how many t-5s have you broke?
- my new 1990 5.0 LX - need an o
- well did my msd 6al ruin my ca
- Just orderd my 3.55s tod
- Header Gasket
- Lane Automotive
- 302 blocks from summit
- how much horse power!
- what to do next
- 93 GT Idles high
- ADS Super Chip
- Stock MAF size?
- That sucks!
- WHAT?
- GT-40 y303 heads- not the x303
- Stupid Question
- Air pump...GET OUT!
- funny noise from weld rims
- 3.55 or 3.73s
- Rim Question??
- how much
- injectors
- car wont start
- Vacume Dis. Tree
- 1994 302 rebuild
- Throttle Delay?
- Engine Swap
- 95 GTS upgrade... HELP
- 190k motor can I work it?
- eliminating power steering
- need info!
- Engine potential Vs. good Gad
- Water Pump Problems???
- Need advice
- engine block swap
- my 302
- BFGs???
- screen names
- twisted wedge heads
- Starting from Scratch....
- HEADS FOR SALE?
- oil pressure
- HEY- OBSOL3TE.351W -PICS.
- Shocks / struts
- best heads for a DAILY driver
- NITTOS?
- problem with 93 5.0
- SUGGESTIONS???????
- Upper plenum gasket...
- Keyless Entry
- Short belt
- Hard, Hard Ride...
- Which is better?
- Engine Mods
- 79 Volvo with a modded mustang
- what bulbs do i need?
- Gas milege responses?
- mods and gas mileage
- GT to Cobra
- ecm
- chip or dyno tune?
- whats bad about the 94&95
- rear axle swap, 95 to be put &
- Tremec Break-In
- 5.0 Resto.com
- 5.0 to a 4.6
- Differance between...
- Engine
- Traction
- 1999 COBRA HP
- Pricing out rebuild
- cold air intake
- Wireing Harness(help)
- help with mods for new stang o
- tires
- smog pump
- Fuel Pressure
- which do u use
- 3.55s or 3.73s
- widest tires?
- the 95 compared to foxbody
- Totalled my Car
- What tools Needed??
- The Mustang 5.0 Engine
- engine rebuild
- How fast in 1st
- t-5 to c4 switch
- Squeaking noice
- Vacume Leak.
- 4 or 5 lug
- 1986 SVO
- hard on car
- Fly cut
- books or manuals
- Next mods??
- Power Lock Switch
- NEW
- New Thermo Houseing
- Roller Rockers
- Door moldings
- Fuel pump
- Quater window moldings
- Tbody spacer
- What should i do??
- AC pump and belt
- Thermo LEAKING!!!
- SN95 TURBO SYSTEM
- RollCage??
- stock 302 blocks
- Sell me a strut tower brace !
- How much will my insurance be?
- answers for the 5.8 swap into
- MOVED: GEARS
- 351W swap
- Stock cam
- New engine cost
- 1995 Door Panel
- D I Y ?
- any helpful planning?
- squecking
- Rear End questions
- engine break in
- Oil and spark plugs/wires
