PDA
View Full Version : 5.0L (1979-1995) Mustang
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 [180] 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331
  1. just a quick question
  2. Timing??
  3. Black
  4. i've tried everything and my turn signals still dont work...
  5. Eliminated AC, SMOG PUMP, &Tensioner!
  6. Fuel pump issues
  7. HELP: Idle Problem
  8. Mass Air Sensor question
  9. Not Charging? (Need Help)
  10. Hooked suspension
  11. Cold air vs. ram air
  12. how to get90+ steering wheel on 87
  13. Question
  14. 85 gt exhaust
  15. fox vs 07 gt
  16. 94 mustange intake leak common???
  17. Think its worth 8k???
  18. supin up a truck opinions pls
  19. 5.0 starter
  20. What this worth?
  21. Guys who owned fox and SN95 pls reply
  22. block
  23. how to remove stock fuel rail
  24. 331 turbo 15psi vs. 427alum.
  25. After rebuild from 331 short block, car won't crank
  26. problems with pison ring compressor
  27. Help with identifing the heads on my 302
  28. Trick Flow or ecam Wich is better?
  29. No cluster lights
  30. Clutch...
  31. engine ideas
  32. Fox Body Sunroof Hinge Holders
  33. what do you think?
  34. VIBRATION FINALLY FIXED!!!!! THIS IS HOW I FIXED IT!!!!
  35. how a stall converter works?
  36. 408 supercharged
  37. 5-Speed to AOD swap
  38. New with '93 GT conv.
  39. question for anyone
  40. What should I order in another week or two?
  41. Noise on cold start up
  42. crap
  43. wavy paint = former collision?
  44. i am buyin a camaro
  45. removing the front seal?
  46. big decision
  47. Check out my new headlights!
  48. TwEECer Update should be Released SOON!!!
  49. cobra r hood problems...
  50. New smog pump LOUD!!!
  51. For Sale
  52. AOD Shifter Removal
  53. How much does the fox 5.0 weigh?
  54. just took a couple hundred pounds off my car....(pics inside)
  55. how do i remove the ignition lock?
  56. Pics Of Really Sick LX
  57. throttle Body install
  58. supercharger
  59. Lookin for a trans...
  60. I Took the stang for a Ride today......
  61. few more motor questions
  62. OK so I just got done cleaning the car in and out
  63. aeromotive fuel tank
  64. Where is a good place to power my shift indicator light from?
  65. h-pipe problem/help
  66. T-5 Removal
  67. New Era Performance can now Flowtest your injectors!
  68. 93 5.0 Mustang Turn Signals Not Working
  69. No start condition, 95 gt 5.0
  70. cant get key out of ignition!!! help
  71. mil eliminators
  72. why the heck
  73. pinging
  74. yellow/brown puddle
  75. HAVE TO SELL NEED ADVICE
  76. power steering pump question
  77. Electrical problem
  78. timing set at 4 degrees?!!?
  79. Clutch Pack Shims
  80. GT40 crate motor for my 84 gt
  81. Jet Chip
  82. thought i should pass this on
  83. turn signals not working
  84. Who has welded their torque boxes
  85. Auto to 5 speed swap
  86. 1995 351w specs
  87. k-member
  88. Power Windows
  89. hoist the engine
  90. I'm back....I DONT WANT TO HAVE TO SELL CAR BUT possible clutch/ leg problem -any ideas??
  91. heads
  92. Underdrive pulleys???
  93. paint example?
  94. problem at track tonight, need help
  95. help A.S.A.P ?
  96. quick thought of mustang
  97. Anyone ever done a brake proportioning valve for there Stang?
  98. my air bag light
  99. Intake spacer plate ?
  100. Radio harness
  101. my first fox need some help!!!!!!
  102. will it fit?!?!?!?
  103. Twin Turbo LS1 Volvo 740 Wagon!
  104. saleen
  105. Front Brake caliper bushings?
  106. Radiator and Cooling Fan
  107. problem
  108. 1986 mustang front bumper clip interchangable with an 88?
  109. tranny
  110. Anyone?
  111. K member
  112. shorty headers yes or no
  113. Oil pressure
  114. Newbie here...need engine mod help please
  115. 91 door
  116. Adjustable Control arms?
  117. 86 5.0 HO Please help
  118. Anybody dealt w/ fox power mirror problems?
  119. oil pressure
  120. lifting front wheels
  121. 347 H/C/I Set-Up ?
  122. intake + carb question
  123. HEELP no one knows whats the deal
  124. 02 sensors
  125. quick, simple head question
  126. Explorer heads and intake question!
  127. WHAT CAM CAN I USE WITHOUT SMASHING MY VALVES??
  128. Please Help! floorpan issues.
  129. 275 /60 /15?
  130. To expose my ignorance... Balancer
  131. ranger axle question
  132. Rim/tire ques...
  133. silver springs mustang show
  134. How Much Louder?
  135. Need some advice!!!!
  136. Taking off air pump
  137. Suspension
  138. Changing LX rear bumper to GT
  139. question about durability of AODs with shift kits...
  140. 140 cluster
  141. Found the Short!!!
  142. Make our own 5.0 car club on Motortopia???
  143. One Week Today
  144. Pauls Automotive, Cincy Ohio
  145. s/c set up
  146. T5 to Aod swap
  147. please help me with these actuators...
  148. thought everyone would get a kick out of this
  149. Can't figure out what next- need help!
  150. whar supercharger should i get
  151. New to the forum & got a big problem, gear heads check it.
  152. What am I worth?
  153. Upper and lower intake manifolds?
  154. gauge install lighting
  155. Just ordered some more stuff for the stang!
  156. Wires? HELP ME OUT!!
  157. hid question
  158. Quick Question guys.
  159. trickflow h/c/i without maf?
  160. speed density question...heads
  161. Limited slip?
  162. Spring Compressor
  163. windsor jr heads
  164. Can Somebody help me out
  165. 3:73 gears
  166. egr spacer
  167. Speedometer Gear
  168. putting in to speedo cluster...
  169. Uneven??
  170. gunna get these rims what do you think?
  171. What brand O2's are ya'll running??
  172. spyder 2 intake???
  173. dealers list
  174. UPDATE!!! FUNNY THREAD! Got a citation in my front door today!
  175. How much $ have you spent??
  176. 351w rev to 6500?
  177. Rain getting in
  178. Heads for 347 Stroker
  179. Aftermarket Seats
  180. post your set-ups
  181. O'kay heads for carb?
  182. Need help 03-04 cobra sc on a 5.0
  183. Seat rail extenders...
  184. 140 amp alt question
  185. 6cyl need help bc no v6 owners have a brain!
  186. Cupholders...
  187. Stock cam lift?
  188. question about afr 165s...
  189. clear headlights!
  190. Bad choice ??? how can i fix it
  191. flowtech headers
  192. 89 foxbody mods
  193. Bleed
  194. just got an email from pinks
  195. flat tap it vs. roller cam?
  196. Power lock clarification--- Newbie
  197. new paint?
  198. No Speedo/Temp/Gas
  199. ram air
  200. '77 351 windsor
  201. strenght of a 95 gt
  202. turbo
  203. Pics of my car before the year 2000
  204. BALANCE QUESTION!!! HELP!!!!
  205. So I've got some money...
  206. GAS LEAK HELP!!
  207. need help finding a part...
  208. Gears?
  209. yo adder
  210. what to buy for a better ride???
  211. WANTED
  212. cat question
  213. Pro's and Con's 5.0 Cobra?
  214. Teal Stang Mystery
  215. Porting Heads Is it worth the time?
  216. How much horse power is lost going from 10W-30 to 10W-40?
  217. T5 trans question how much it can handel
  218. Serpentine belt problem
  219. would this one work
  220. Anyone using Baumann???
  221. whats up got a ideal does any one know if itll work
  222. weight on bottom of rearend
  223. Car almost keeps dieing need help
  224. Tired of the Stang
  225. t-5 rebuild
  226. Check this out ....
  227. Underdrive pulley help!!!!!!!
  228. clutch theory
  229. difference in distributors?
  230. Do I need Adjustable Clutch Quadrant/Firewall
  231. What Would You Pay??
  232. who installs your exhaust?
  233. Point of a cowl?
  234. Removing 5" Tach Needle
  235. 87-93 side window louvers? where to get them
  236. I found a 351
  237. Just painted my wheels watcha think
  238. What kind of bodykit or something to make a hatchback lx not boring
  239. whats it worth to you?
  240. rear end diagram
  241. a cam question
  242. VENOM CONTROL MOD
  243. What do these do?
  244. My 351w
  245. Annoying Squeek from Trans!
  246. 5.0 HO or 5.0
  247. Thinking about buying a 1982 GT
  248. WTF is this?
  249. New pixs guys got some of my xmas presents
  250. 31 spline axle upgrade
