- Frozen Door Handles
- Check engine light?
- GT40P head swap / q's
- reset base idle question
- Heater core question
- speedometer gear question.
- 85Gt Intake
- Smog pump bypass
- Two questions (possibly more..)
- Speed density - 87 GT...MYSTERY PARTS!!
- Driver and Passenger seats
- Oily Spark Plug
- headlight switch
- 87 5.0 horsepower question.
- Trans Swap
- Advanced Timing and Gas
- Quick question
- Dizzy Cracked? Should I worry??
- little question....
- Fog lights
- MAF sensor question.
- 3:73 gears question
- throw out bearing
- 5th gear probs and tranny rattle
- Fuel lines and pressure regulator
- Question for SN-95 owners
- help! ticking noise from stud mount roller rockers?
- Suspected noise, WTF
- need an answer now!!
- can worn rear end cause a vibration?
- Misfiring
- Megasquirt and Fast Idle Valve
- MOVED: ==> Every Automotive Calculator You Will Ever Need!!!
- Tie Rod Interchangability
- problems with transmission or clutch
- clutch petal vibration/noise
- speedo issues
- Broken wire connector, need help
- Crane hi-6 problem
- jet chip or hypertech
- 80mm maf question???
- just wanted to know
- advice wanted (repainting my foxbody gt)
- Air Filter.
- 3ag alternator - which one??
- Lifters
- Throttle body
- Fill me in on these turbos...?
- taking out the axle
- Need some advice
- 86 valve clearance
- Alternator Issues?? Bad wires?
- poss. msd 6a bad or tfi?
- Just started smelling gas!
- Ignition for EFI to Carb conversion
- CLUTCH PEDAL WIRING????
- TRICKFLOW TRACK HEAT AND STOCK MOTOR???
- Electronic fan temp controller kit\ Worth it?
- Big question...kinda
- Frustrated with explorer intake
- Intermittent miss in rev's
- some advice
- 95 cobra rear in a fox body
- Spool, c-clip questions
- no spark but car is turning over
- sn95 ?
- rear end question
- No power to cigaret outlet
- fanless
- Subframe Install Question
- MOVED: H/C/I on a stock block and telling actual mileage on car
- MOVED: Tire Size
- Cobra intake install
- MOVED: 285 on a 10inch rim??
- MOVED: How is this exhaust? Does anyone have it?
- MOVED: vortech question
- MOVED: Does anyone know where to find these???
- will this fit (transmission)
- MOVED: SWITCHES!!! lots of them
- brake warning light switch in proportional valve leaking
- MAF Conversion on 86 - Which VSS wires to splice?
- Ideas for refreshing up my new 5.0
- MOVED: You Are NOT Going To Believe This!!
- advantage using an h-pipe
- Wow. What's wrong.
- rear end idenfication
- must i adjust timing with nos
- Do all of the cowls on the fox bodies rust?
- Bumpsteer
- WIRES EVERYWHERE!!!
- door pin and bushings help!
- MOVED: what yall think?
- I NEED HELP ?
- MOVED: Why?
- MOVED: Cold Air Intake and filter $20 Technical Conversion
- double whamy of a question =(
- header heat tape
- MAF meter
- brake pedal still isn't firm..
- Speedo Gear
- 87-93 GT outter tie rod bolt size ??
- UPR front suspension help???
- Catalyctic Converter Shield
- are they gt40 or gt40p?
- need to find a carborator
- crank pulley
- help
- help
- Mt et tires
- 30lb Injectors Without Tune
- 75TB to 70MAF tube
- dccontrol.com?
- Torque Specs for 1.6 Pedestal Rockers
- Electrical Issues
- wierd noise....help
- Engine NOT heating up - any ideas???
- Trick Flow Twisted Wedge Heads
- Stupid question
- camshaft?
- fuel pump suggestion
- stock rear end
- 91 LX Will not start
- MOVED: HP guesstamit
- transmission ?
- Quick question on trickflow head install
- Its always something
- glowing headers along with over heating
- slight problem with heater
- spyder gears "8.8"
- Need A Horsepower Estimate
- where do these wires go
- Spec Stage 2 Clutch Break in
- ANY SPARK KNOCK SINCE COLD WEATHER?
- Starter Hanging up
- wiring harness
- MOVED: Where did you mount your digital ign box?
- Trick Flow Pushrod length
- re-ring engine kits at autozone.....
- 87 steering problem
- TKO VS T56
- Anyone looking for better 19# injectors...
- question about a9l vs a9p with auto
- 357w Head confusion! Need Input
- DO MMS STRUT BRACE CLEAR TRICKFLOW INTAKES?
- Forged 347 stroker
- Power Steering Cooler
- car won't start please help
- MOVED: Check out THIS gear drive setup
- SN95 Valve Cover Q?
- Lifter hold down torque
- '87 AOD shifter
- Engine just sitting....what to do?
- 87 Mustang Trouble
- best pullies?
- 91 Mustang Start Problem
- Neutral Saftey Switch
- Rebuild gearbox or Get a new one?
- Back fire?? **UPDATED w/ Sound Clip**
- Blowproof bellhousing ?
- vibration
- turn signals not working...
- burning oil
- catch me riding darkly..
- MOVED: Finally got me a C4 i've been searching for.
- MOVED: I am very impressed.
- MOVED: k member kit
- Steeda UDP Install
- Replacing inner tie rods
- Is a camshaft really worth it?
- ODB1 Or ODB2?
- What size rear end is in my 95 Stang GT
- Explorer Mustang 5.0 xover questions
- Cam???
- Aeromotive VS Glenns Performance fuel system?
- Black magic Electric fan need some help
- Help with Axle code M
- 'm Rear Control Arms
- Does anyone know what this is?
- 7.5 or 8.8
- exhaust cut outs
- 85 mustang rear end
- Installing headlights
- any reason i shouldn get solid motor+tran mounts a
- 1992 power seat
- MOVED: GT seats vs LX seats 90 Notch
- 1989 Mustang H/O won't idle HELP
- mega squirt lovers
- Thermactor Air Bypass and Air Diverter Solenoid....
- Checking Piston to Valve Clearance
- cam specs please
- front struts is making a hole in my hood.
- Turbo Fox
- Guages Under Stereo
- school me on installing a cam...
- what would you recommend?
- how to run a koer/koeo test ?
- 91 LX 5.0 Emissions
- Headers from Ebay
- anyone running a mallory distributor?
- Suspension Questions
- 5 lug swap!
- 06 Front Struts and Knuckles to a 1985 Fox
- cig lighter
- what oil to use, whats a normal oil pressure
- 306? nitrous?
- gas smeelll
- electric fan relay
- idle.. still lost
- B cam VS. Steeda #18
- rear end calculation
- B&M Shifter
- aod trans brake
- Turn signal gizmo
- Tranny Question!
- pypes violators vs. flowmaster 40's on a 5.0
- Didn't bench bleed new M/C, problem???
- MOVED: inheritance
- MOVED: Quick question?
- MOVED: Why Do You Have Your Stang?
- Newbie to hot rodding looking for advice.
- cam for 5.0
- MOVED: Rim Question & Pic request
- Quick question about heads
- E cam and 1.7 RR
- Leaking water inside the car
- Help me decide-cylinder heads
- pully for the belt tensioner
- MOVED: wanna look good
- suspension
- SIDE WINDOWS
- wiring harness through firewall?
- bout lost my car
- 1988 mustang engine help.
- losin my mind
- Instrument Clusters
- MOVED: combo, what do you think, suggestions?
- MOVED: looking to purchase 86-93 mustang
- Gotta Problem
- Tranny Crossmember
- What do I need?
- NOS
- 1987 GT dash gauges messed up!!? Tach, fuel gauge.
- running rich
- Insane Wheel hop.!! plz help
- New Rockers Don't Fit...
- engine swap info needed
- Dead Battery after 2 days
- FOX body rear trailing arms
- Question about clutches?
- SINGING REAR END
