- more question about whats wrong with the car.... i just got done with the h/c/i
- head question
- 65mm BBK TB smog legal?
- WTF Fuel pump...
- will it leak?
- can i do this?
- coolant smoke
- HELP Please!
- crease in C pillar?
- hci question need help please
- explorer block...
- Car will not start
- proform/blackmagic electric fan
- flexplate problem
- fuse?
- ac and smog delete?? how much horse does it free up??
- Everything Mustang from 80-95 *UPDATED*
- Ignition Problem
- gas gauge question
- Cam dowel pin
- Change from frpp F cam?
- Pics for spring install?
- 90 GT Exhuast Question
- couple of motor questions
- ac hose removal
- Supercharger/Fuel Pressure/Tune help
- Felpro 1262 WTF!
- Where does this wire connect?
- going from 15 to 16 in wheels
- afs wheels
- Fuel Pressure Regulation
- how hard is it to convert the fox body front ends?
- high hydrocarbons
- power wire question
- Rear disk brake issues.
- temp guage
- sputtering
- Destroyed an SS blew some gaskets
- Procharger
- gear install complete kinda...*COMPLETE!!*
- What brand of Turbo
- What kind of Ignition coil is recommended?
- IAC Replacement... anything else
- front control arm squeak
- Oil pan and RTV
- Facial Reconstruction
- Damn, left my nitrous bottle open
- hp to the flywheel
- started car tonite wondering whats up
- engine or trans-NEED HELP
- Speedo drive gear chewed up!
- NON-H.O. 5.0 TIMING PLEASE?
- 95 cobra 347
- ran KOEO and KOER test HELP!!...
- 100000 mile maintenance
- 1980 5.0l Mustang engine question
- TKO 600 or AstroPerformance A-5 Gear Kit??
- low oil sensor thread size?
- any1 using edelbrock exhaust-5646
- ported stock heads or gt40p
- Will they fit?
- gas guage
- engine rebuild ?
- i think i found my short
- Maximum Motorsports K-Member Kits
- What should i do first?
- THE BIG ONES
- novi 2000? or s-trim?
- fiberglass hoods on a four eye
- H-pipe or x-pipe?
- Lowered Fox + full exhaust; will it work?
- Nitrous System...Which one?
- Good deal or not
- help with drag car
- oil pump help
- AOD Torque Converter Question
- best way to spend $1000
- 86-93 vs 94-95?
- 86-93 vs 94-95?
- Hard to keep steady pace.
- No 02s in my midpipe
- duals on a fox
- slp loudmouths
- 1.7 roller rockers and TFS 1 Cam
- STARTING PROBLEMS PLEASE HELP!!! VERY IMPORTANT!!!!
- HCI Pictures.
- Anyone have pics of this hood on a fox?
- BOLT SIZE
- Emmisions legal cam?
- think i found my problem... right??
- fuel lines
- different mass air sensor
- idle hunting
- serious engine problems
- one more question cam?
- redone rear suspension keep swaybar on?
- casting numbers on roller blocks
- gettin ready to start the car up... FIRST TIME IN 2.75 months
- shifter for 5.0 foxbody
- Fuse box diagram
- 5.0 in 96
- daily driver
- cosmetic ?
- loss of power and bad gas milage
- 95 GT Lowering Springs
- MOVED: Pictures of Nice Looking 5.0's
- H-Pipe
- ANYONE HAVE PROBLEMS WITH 331 LUBRICATION
- ECM and Wiring Harness for 351 swapped Mustang
- 351 windsor and 351 clevland
- 94 5.0 AC PROBLEMS
- Air in cabin
- TF Track Heat compared to CNC ported Track Heat
- Biggest SBF i have ever built.
- Track Heat's, 1.7RR& E303
- list of ECMS?
- Breaks
- few quick qestions!
- suspension
- ISKY piston notching tool
- t.b. size for explorer intake??
- Will Mach 1 seats fit 94 gt vert ?
- No comprssion in one cylinder
- Dash lights stopped working?
- New to the 5.0 & Hav sum ?'s
- How do i???
- Edelbrock Performer RPM II
- 42lb injectors to BIG for a 347?
- Help on blown thermal fuse
- does anyone know?
- Balancer/Cam Removal
- new ride with problems! help!
- what do you think of this idea
- 347 support
- need help with cam!
- 5.0 H.O. OR NON H.O.? HELP PLZ
- I didn't know quite where to put this...
- cleveland heads??
- ebay cai
- explorer heads
- Couple fan questions
- idle problem
- idle problem
- 1995 GT and questions
- 300 h.p. is it possible?
- Speed Density to Mass Air
- 1986 Mustang GT finally done-before and after
- advice on an intake manafold
- anyone running eibach sportlines i need some advice??
- sway bar on or off
- Does this part exsist?
- Exhaust help
- Valve Float.. SH*T
- how to get power steering pulley bak on
- loping idle
- tocan you?
- vortech supercharger
- first thing to replace when over heating?
- A new block.
- wiring diagrams
- AFR 185cc heads
- Power Steering pump?
- new tach.. wires...
- wtf
- removing factory alarm
- post pics of your suspension setups!
- Ready for AEM tune - then boost.........
- R&R intake questions
- wtf happend
- torque specs for valve cover bolts
- ? about hci/rebuilding
- timing
- t-56 installation speedometer cable
- 86 5.0 w/ ford racing pulleys...water pump?
- yyy on my block?
- Need help! over heating problem
- Stupid CAi question of the day... tune needed?
- idle problem
- suspension
- cant get front control arm bolts off!!!!
- guy on forums who does tranny's!?
- Will a 87-93 water pump fit 95 5.0
- Best way to remove rivets?
- radiator fan options
- 0 comprssion in one cylinder
- ah **** what did i do?
- Replacing the cam adds 55hp?
- Synchros Or Could It Be Something Else?
- trans prob (only one gear)
- IS MY COMPUTER JUNK???
- quick qustion!
- Will 30 HP make a difference on the street?
- AC Delete??
- who should i have build my 331?
- subframe ?'s again
- stock 5.0 block with main support system and valley girdle support
- blown fuses HELP!!!
- Vaccum lines
- Gear swap then need new carrier
- vibrations, help plz
- AOD to Tremec Tranny
- swaybar?
- 4cyl Hatch conversion. What can I get rid of?
- lopey cam
- 03+ Cobra Supercharger?
- converting from Gen-V to Gen-IV
- 5.0 Swap Questions
- new MAF help, computer reset?
- new car?
- whats next
- Lean!!! UPDATED
- 5-lug
- car stalls when in gear
- Hesitates when cold.....help.
- trying to pull codes?
- seafoam whats it do exactly list comments and answers plz
- Anyone with aluminum heads
- Drivetrain questions..
- Fellas, help me with my quadrant issues
- Odometer does not work 1994 5.0
- Stereo wire colours
- Anyone running Holley heads?
- distributor for carb?
- T-Rex Wiring
- pcv change?
- want newer seats....where to go?
- car shorting out
- Throwout Bearing....
- WindshieldWiper fuild in gas tank?
- Exhaust Installation
- Just did seafoam and i cant get car out of Park!
- What is the Best street clutch?
- how much do i need to gap my spark plugs
- P heads and Nitrous, which plugs
- Installing gears in a 8.8 rear. NEED Help
- need help with electrical...
- pistons
- found my idling and stalling problem..i think!
- roller rockers and flat tappet cam?
- Weird thing happened after adding Seafoam.
- valve clearances with eldabrocks
- Replacing the Clutch Pedal Assembly
- Hanging Idle. surging rpms at idle.
- Heads or S/C
- Water / Meth injection - Anybody running the Mr. Freeze kit
- removing trans from motor?
- Power window, one touch down module
- engine feels too hot
- I want 400 horsepower
- exhaust leak help
