PDA
View Full Version : 5.0L (1979-1995) Mustang
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 [212] 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331
  1. Stock Curb Weight??
  2. couple questins, i think
  3. Turkey Run?
  4. Removing smog pump...
  5. Question bout Intrax lowering springs?
  6. Need good advice, I'm starting a new project.
  7. internal rattle 95gt aode
  8. Please help with rim pictures!!!!
  9. fastest mustang
  10. 1991 mustang gt dyno numbers???
  11. What Does It Take To Keep Up With This???
  12. anti theft concerns/ideas '90 GT vert
  13. speedometer broken after gears.
  14. need help with valve cover.
  15. anyone got long tubes with a aod
  16. Finally Got to the track this year/engine
  17. Sportsman block
  18. ARE AFR HEADS##1
  19. To those with SN95 front spindle conversion: Use SN95 ball joints?
  20. Ross, SRP or JE.
  21. Coolant blockage
  22. GT 40P
  23. What length are stock fox-body studs...
  24. Charging problems
  25. Felxalite fan
  26. Calling All Suspension Gurus!!
  27. Low Coolant!!!!!
  28. SRT-4 OWNED
  29. Noise while turning
  30. BRONCO MISSES BAD WHEN FLOORING IT
  31. carb or fuel injection
  32. got the trickflow in
  33. MAF size vs. factors?
  34. Putting 4.10 gears in my Auto 95GT...
  35. possibly buying a 95 5.0
  36. lowering spings?
  37. help
  38. eagle rods
  39. would you trust these
  40. rev limiter
  41. Weight differents in cars?
  42. dry or wet???????
  43. G force tranny questions
  44. 95 GT VSS?TECHNICAL Q'S
  45. SC, or 347, or both...
  46. Car Jerking
  47. maf
  48. what will i run?
  49. canfield heads
  50. Doing the rear!
  51. Play In Wheel...
  52. 4 Eye pulled on me today...
  53. LOOK HERE Everyone Do The Intake Procedures!
  54. fuel pump not turning off
  55. How To Install Headers?
  56. another 351 assymbly issue
  57. 88 mustang... is it worth it?
  58. TFS install, LESS power than before!
  59. Think i will tell a difference?
  60. need sum horspower...
  61. LX Coupe 88 5.0 needs some help
  62. Lets say i do Shrotie Headers, o/r H, & catback. How do i keep the CEL off?
  63. stock rods
  64. TF street intake vs track heat intake
  65. CHP Dynotech Engines
  66. 4.6 vs 5.0
  67. Cam, Heads, Intake, Computer -- GT-F150
  68. What do you guys think of this turbo kit?
  69. Check out the Mustang In the "For Sale" section
  70. Exhaust system help
  71. My 0-60 times, timed today...
  72. MAF/ samle tubes.
  73. What's your brake pad of choice?
  74. 93 gears
  75. painting brakes
  76. ceramic coated vs jet hot ceramic coated
  77. stock injector size?
  78. port/polish quest.
  79. ford mufflers?
  80. u/l control arms
  81. Installed new shifter last night
  82. 3:73 gears, I have 2 questions...sorta
  83. intake coming together
  84. For those with Draglites welds
  85. fuel filter
  86. how to install a new Power Steering Shaft Assembly?
  87. what kind if ignition systen in 87 5.0?
  88. Saleen Coupe
  89. More 'rebuild' questions please!
  90. 94 GT rear end ratio
  91. underdrive pulleys
  92. Stock Motor, Freshened, Supercharger?
  93. Car dying please help!!!
  94. How much would it cost in labor?
  95. bad to drive?
  96. whats a good mach with afr heads????????
  97. gas mileage/speedometer question
  98. help with engine upgrade need
  99. Gotta do what ya gotta do
  100. autometer question?
  101. tire suggestion?
  102. silly question
  103. thumper of orange park
  104. Fuel injectors
  105. GOIN WITH JAY ALLEN NOW
  106. Tranny PROBLEM
  107. need som help !
  108. drill hole in the butterfly will it help idle problems??
  109. Emissions question
  110. 5.o EFI or 5.8 carb in a 1987 lx?
  111. s-trim 1/4, Hp estimates.
  112. regular gas prices?
  113. Guys, What should i do with this stang???
  114. Water in Headlights
  115. 460 swap questions
  116. BRAND NEW RE-BUILT 306 FOR SALE
  117. Question about dizzy's
  118. rear oil seal
  119. Explorer Heads
  120. WEIGHT REDUCTION ??
  121. heating question
  122. Are '84 GT's with t-tops really that rare?
  123. Battlebox
  124. Engine prep for supercharger
  125. FINALLY GOT SOME PICS WHAT DO YOU THINK?
  126. 88 gt serios upgrade question
  127. AOD Tranny question
  128. did my lifters collapse?
  129. Can Someone pls help a noob out..
  130. Stock H-Pipe....
  131. H/C/I or Novi 1000 w/ 8" crank pulley?
  132. Fuel Sender Problems
  133. cant find this noise
  134. need help with intake
  135. Vibration Problems...Any suggestions???
  136. question
  137. Tomorrow, finally!!!
  138. roller rockers??
  139. Shifters
  140. how to be faster 0-60
  141. ROTM
  142. speedo swap???
  143. heads
  144. rear end and other stuff
  145. catted h pipe?
  146. Stock h pipe with cats /95 gt
  147. CODE 113 WHAT IS THIS????
  148. explorer heads
  149. need help with my intake
  150. HARD STARTS NEED SOME HELP
  151. lil smoke show
  152. steeda parts?
  153. vavle lifters
  154. 5.0 Power?
  155. Exhaust Questions...Help
  156. blow by
  157. Help with Rims
  158. Wow I'm pissed
  159. Brake Help
  160. harmonic balancer
  161. suggestions and commetnt
  162. Help with headers....
  163. anyone know what this connector is for?
  164. rearend gears
  165. GT to LX
  166. a/m door lock pins
  167. How do you fund your 5.0?
  168. Posessed Dizzy
  169. Fuel Pressure Regulator Suggestions
  170. What springs to use with TFS 1???
  171. NEW MOTOR TIME WIT PICS
  172. suspension upgrades
  173. plug wires
  174. VIC ON AUCTION BLOCK 2 PAY FOR 5.O GT
  175. clutch slip?
  176. motor suggestions
  177. cold air int
  178. Is it like this with y'all?
  179. is a coil worth it?
  180. Messed up tranny question
  181. 94 and 95 headers...
  182. lifter question
  183. electric fan wiring help
  184. List some of your favorite mod, parts, performance websites for the 5.0
  185. i got my pics
  186. gear's
  187. Power Steering Question?
  188. carb pcv !!!!!
  189. slp or flow
  190. 95 5.0 HEADERS AND CAM
  191. Is he serious!!!! guy wants to race
  192. EGR question.
  193. Question bout exhaust.
  194. line loc?
  195. I want to upgrade the suspension
  196. hey ppl check out my burn out clip!!
  197. RING GAP ANYONE!!!!! ????? STANDARD BORE?
  198. Surgeon at work (pics)
  199. oil pan removal?
  200. 1.6 or 1.7 rockers ? Now i'm confused
  201. 95 gt gone to crap..help
  202. Staring reassembly tomorrow !
  203. hood again...
  204. MT ET street radials or BFG's?
  205. oil pump drive shaft fell into oil pan now what?
  206. Broken Hood latch
  207. t-5
  208. 347 stroker on sn95
  209. Car show time !!!!!
  210. i thought id share this
  211. buy an unlocked nokia n93,n73 at $240usd,sidekick 3 at $190u
  212. electrical prob please help
  213. 140 seedo fit???
  214. help
  215. power locks and window ques...
  216. timing
  217. Blow By W/Paxton SC Need Help
  218. black ford emblem
  219. 1.7 Roller Rockers
  220. Distributor Trouble
  221. New Paint Finally
  222. Suspension
  223. Suggestions on best clutch cable/linkage?
  224. I have an 87 5.0 GT...
  225. MOVED: 351w
  226. axle bearings?
  227. again
  228. 351 heads on 302 block?
  229. AOD ?'s
  230. Powder coating or High heat paint ?
  231. just checking
  232. In addition to...
  233. Got my P headers today....
  234. brake question
  235. Holley FPR
  236. How big of a fuel pump to go?
  237. speedo 140
  238. Why is it impossible to find parts?
  239. 36lb or 42lb Injectors
  240. engine
  241. quick question
  242. Door Pins
  243. Well, I drive a Honda now.
  244. AUto trans on a 351W
  245. 85GTvert or 89GT hatch 4 racing?
  246. 88 5.0 just dies when driving
  247. 85-86 Weight
  248. Synthetic Oil?
  249. Question about TPS.
  250. street rims
