PDA
View Full Version : 5.0L (1979-1995) Mustang
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 [105] 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331
  1. how would your car feel..
  2. Ignition Problems
  3. intake question and porting question
  4. negative battery cable
  5. gt40 cast iron heads
  6. how bad is no mufflers
  7. C/C Plates
  8. Shifter Paddle Kit for Automatic
  9. 94-04 pedal swap
  10. I got new Codes today.. Whats the fix?
  11. Mustang Turbo
  12. 5 lug conversion
  13. possible driveshaft problem
  14. what's going on?
  15. solid trans mount or poly?
  16. Idle probs
  17. BBK o/r x pipe wont match up to BBK long tubes?
  18. Bassani cat back
  19. Do I need larger injectors?
  20. Need some help 95->88?
  21. Can't find valve covers for my motor!!
  22. Gotta big shimmy...
  23. Fixing rusty Floor pans?
  24. 5.0 1990 (7 up) shimmy at 65
  25. Valve seals - oops!
  26. Water pump problem?
  27. Stumped on these codes
  28. all i have is 1st gear...
  29. 351w heads??
  30. steering issue
  31. Headlight trouble please help!!
  32. E fans - Are they worth it?
  33. how to tell what size injectors are
  34. Transmission Problems.
  35. are these worth it
  36. power steering pump queston
  37. I want to take out the backseats
  38. Factory 351w Alum heads
  39. 2.5 exhaust
  40. NEW DOOR??
  41. t5 inspection, going to sell
  42. Clutch advice
  43. Suspension
  44. not sure what to do
  45. Will Aluminum fix this?
  46. subframes
  47. gear question
  48. any feedback on a procharger p600b
  49. 3 angle valve job worth it?
  50. Rear/Wheel/Axle Question
  51. Oil pressure gauge all the way at bottom at idle?
  52. 347 stroker question
  53. Push Rod Length
  54. Question on pulleys...........
  55. finally getting an 8.8 rear
  56. MOVED: Pictures of my Stang 92 vibrant red convertible
  57. shifting issues
  58. crank/machining help
  59. How do you take the windsheild trim off a foxbody
  60. How do you take them friggin electrical clips apart?
  61. T-56 Questions
  62. Supercharger? or Turbocharger?
  63. No Idle
  64. Why Won't it Run?
  65. TRX Wheels
  66. Need some Mustang perspective...
  67. MOVED: Craigslist 302- worth it?
  68. Fuel System (Dual or Single Feed ?)
  69. Idle is getting worse
  70. Suspension advice
  71. Air Bypass Valve???
  72. 83 5.0 exhaust help
  73. Clutch and Engine Temp Questions
  74. Need Help on what cam??? LOST
  75. Repair Floorboard???
  76. which size draglites???
  77. what does this part do?
  78. Electric fan switch
  79. 94-95 GT MC quesiton...5-lug swap ?
  80. Rearend noises.... Help
  81. Mustang Flooding Itself
  82. Aluminum driveshaft install
  83. Rings for a 347
  84. Long tube headers
  85. quick h/c/i question
  86. Idle problem
  87. MOVED: Newbie Bastard with Pics...
  88. She blows but I don't get any
  89. Firing Order
  90. Rack Limiters/Control arm rubbing
  91. timing marks off??? possibility
  92. c4 flexplate question
  93. Heres what Im thinking.....
  94. how to choose a cam
  95. Supercharger
  96. What would cause my car to smoke?
  97. electric fan hookup
  98. chance to buy 2 blocks.... need help.
  99. 4 Wheel Disc
  100. MOVED: Battery Relocation, Fans
  101. T-5
  102. cams.......
  103. Intake Manifold Differences
  104. Starter i think?
  105. someone has to know the answer!
  106. QA1, Strange or Lakewood
  107. Any body know what this part is? Pic included
  108. Need New Engine
  109. Motor Opinions!!!
  110. 5.0L won't start...
  111. Rocker Noise
  112. 93 cobra heads need help
  113. Rear Main seal on a 94 Cobra
  114. Harmonic Balancer Center (crankshaft) Bolt size????
  115. Radiator help :/
  116. Wrong 02 sensor, help!!!
  117. I have A Big Leak, and its about to rain again
  118. brake calipers
  119. PLEASE HELP!!! 2 DAYS LEFT
  120. DIY tranny swap help
  121. MOVED: 94gt vs vr6
  122. MOVED: bullit wheels/fox
  123. AOD Trans???
  124. clutch may be goin out? knocking sounds?
  125. air intake
  126. Blinker Wiring Question
  127. whats wrong with my 5.0!!!?!?
  128. roller rockers????
  129. Hurst Short Throw Shifter?
  130. tranny rebuild Q
  131. MOVED: selling parts need help on price descsion
  132. Changing Struts?
  133. heating controls
  134. heater core
  135. small block rebiuld
  136. Will a 2006 mustang radiator fit in a 89 GT?
  137. MAF and injector size
  138. My bell housing is cracked
  139. MOVED: what heads and intake for 351windor?
  140. new motor... problems...
  141. Gears, transmissions, etc...
  142. rear end mounts
  143. locating dowels?
  144. carb help
  145. seat track torn apart...
  146. MOVED: Made some progress tonight... Updated with more pictures!
  147. explorer questions
  148. All Spec Clutches - 10 % off!
  149. MOVED: WTB 8.8 or 9"
  150. How to determine gear ratios
  151. MOVED: 1991 5.0 V8 Brakes
  152. MAJOR PROBLEM
  153. Rear 3-point seat belts in an 89 hatch
  154. Torque box reinforcements
  155. Cruise control module
  156. unknown problem
  157. Speedometer problems
  158. What compression?
  159. Shifter moves in gear
  160. roller rocker and head
  161. autolites
  162. Can aggresive shifting send a T5 to it's grave?
  163. oil pump
  164. MOVED: New Dyno Numbers
  165. EFI swap
  166. brown intake runners
  167. I.R.S. in a 5.0???
  168. porting mistake
  169. EEC and Vacuum Advance??
  170. Stalling and bucking... the problems never end
  171. C4 Tranny Fluid requirement?
  172. tough cobra question
  173. what all do i need to do a cam swap?
  174. Pro Systems Carbs.
  175. sleeved blocks
  176. Torque Converter?
  177. tutorial on installing heads?
  178. What size rockers?
  179. CHP SSP Mustangs
  180. Touble with Tranny
  181. Powerdyne Supercharger Kit
  182. What does the tuner mean when he will chip my car?
  183. MOVED: Finally got some new seats
  184. fuel return line clip question
  185. radiator question
  186. AC delete question
  187. Distributor Placement
  188. Anyone have a write for speed density to MASS
  189. AFR? or TrickFlow?
  190. changing spark plugs
  191. need help
  192. oil pressure help
  193. Head Bolt Torque
  194. where is the ICM at on a 87 5.0 5-spd?
  195. corvette heads on a 5.0 = 450 hp?
  196. Head Gasket Compatibility
  197. Low Coolant Sensor
  198. heads ?
  199. what gears
  200. Tire size on pony rims
  201. Pony learned a new trick!
  202. stuck on steel head's or aluminum?
  203. Quick MAF Quesition
  204. cobra motor
  205. Slack in front end of a 1991 LX
  206. Passing Emissions Hpipe w/No cats on 91 LX
  207. no power to fuel pump sn95
  208. i need to get it back together
  209. SPOUT circuit open
  210. IAC
  211. MOVED: recieved my fuel pump today
  212. Good Explorer Intake???
  213. HEADS...HEADS....AND MORE HEADS!!!!
  214. about stock rockers, pic included
  215. Are these good?
  216. Cleaning up engine bay
  217. Starting problem when warm
  218. Replacing Water Pump and now leading to many more things!!!
  219. question about a hatch...
  220. 1989 mustang lx fuel pressure
  221. 4cyl K member in a v8 swap
  222. new tubular gt40 intake
  223. poping out of first
  224. MOVED: got the drag springs in
  225. ring and pinion help
  226. Crazy SOUND!!
  227. koeo code 67???
  228. 5.0 Nitrous Motor Write Up????
  229. anyone that has taken off the intake manifold
  230. 4 cyl T5 vs 8 cyl T5
  231. so what do you guys think?
  232. 95 5.0 battery relocation ?
  233. Frustration
  234. GT-40 Intake ?
  235. stock timing chain...
  236. Convertible rear view mirror courtesy lights
  237. clearance problems
  238. My 5.0 has black smoke and burns my eyes
  239. 99 GT wheels on my 93 fox
  240. simple electrical question
  241. timing issue
  242. Where is the ECT sensor and TPS sensor located?
  243. MOVED: 89 GT Convertible...What's it worth?
  244. MOVED: 5.0 headers only first run
  245. Gears
  246. Jumping Spedo
  247. taking my heads to the machine shop
  248. 94 302 cobra normal opp temp? and random shut off problem
  249. How Do I fix Door Sag?
  250. How do I clear the check engine Light?
