PDA
View Full Version : 5.0L (1979-1995) Mustang
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 [257] 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331
  1. What do you guys run in the 1/8th?
  2. slicks question
  3. spark plugs
  4. i'm stupid...
  5. car wont start
  6. just clicks when trying to start...help!!!
  7. just clicks when trying to start...help!!!
  8. car sits low in rear?
  9. systemax II intake
  10. question about mufflers
  11. what is the torque spec for a tranny pan (sn95)?
  12. Took it back to the shop and...
  13. Need Tranny HELP ASAP
  14. bought an 89 lx the other day...
  15. IS IT WORTH IT?
  16. MOVED: sneaky pete nitrous
  17. MOVED: stroked and supercharged
  18. 95 GT fuel pump relay
  19. couple problems
  20. what all is needed
  21. a wheel question, sorta
  22. 1986 GT Conv struts
  23. Quick Clutch Question
  24. CAM question
  25. Which Intake should I use?
  26. 5.0 magazine claim
  27. Timing+ Backfiring
  28. 4180 Fuel Leak
  29. Blower Box Install
  30. which gears
  31. Ignition questions
  32. vert question
  33. My Clutch is Fuked
  34. throttle body question
  35. 90-93 tilt column
  36. 5 Lug Wheels
  37. Cobra burps
  38. SERIOUS PROBLEM PLEASE HELP
  39. Short shifter install, Questions
  40. Shaved antenna
  41. New Cam In 306 Video Inside
  42. cold start problem
  43. Help me choose wheels PLEASE
  44. Irratic idle
  45. exhaust prob
  46. Is this practical?
  47. can wheels be narrowed?
  48. setup questions
  49. My door locks dont engage, just keep turning
  50. 351 winsor heads on 302
  51. cooling
  52. 75mm Throttle body question
  53. belt rubs w/ fms delete
  54. Cobra brakes on a 94GT, pro's and con's?
  55. Rockin teh 10holes.
  56. how fast is my car?
  57. fuel regulater adjustment help
  58. my 5.0 needs major help
  59. Pic whorin' my 2 GT's....
  60. 94 convertible motor
  61. Chirping
  62. will i have enough space?
  63. Lightning Engine Swap
  64. Vacuum line question
  65. Radiator
  66. Rear Gears....which one!?!
  67. Carb Swap - Someone check my parts list please.
  68. Ford paint codes?
  69. '85 GT ignition problems?
  70. Underdrive Pulleys...?
  71. Pulley kits, good or bad
  72. MOVED: 1994 5.0L -- SUPERCHARGERS
  73. PLEASE HELP! NO KEYS!
  74. gt vs. lx
  75. Will Lincoln LSC rear end fit in fox body stang?? please help
  76. FRPP or Eibach drag springs ride height?
  77. Decode your Vin#
  78. 93 GT Convertable..leather 21,000k value??
  79. Check Engine/Computer Q
  80. Rearend Upgrade/Rebuild
  81. Body part name Help
  82. Somewhat of a door leak
  83. what is my compression???
  84. wheel studs
  85. Dyno results in!!!!
  86. Ignition Lightning
  87. I can't believe this, Please help
  88. 3:73 Labor time?
  89. ABC lip?
  90. turn signals not working
  91. TAKING OUT DASH. HELP PLEASE! 89 GT CONVT.
  92. Okay my car sucks
  93. fuel leak question. bbk regulator
  94. Timing?!?!
  95. Clunking Under ENGINE???
  96. 19lb injectors from expolere
  97. 88 gt bucks and carry's on
  98. 94-95 5.0 guys
  99. 87-93 Cobra grille
  100. Head Gasket ?????????
  101. 89 5.0 pricing
  102. Where is timing spout?
  103. Had a photo shot....
  104. MOVED: best polish, wax, etc
  105. Painting questions
  106. Just ordered some goodies from autogeek.net!!!
  107. How much horsepower pickup?
  108. Body molding=$$$$$$$$$$
  109. Do smoked lights= cop drama?
  110. Pony wheels without the center caps: can they look good?
  111. Lug nut ?
  112. Quick Weld Poll
  113. ? About 94-95 5.0 headers
  114. Carb swappage finally finished
  115. would my block be safe?
  116. building other 302..
  117. ebay short throw?
  118. MOVED: CD player installation
  119. Typhoon intake
  120. What should I do w/ my money?
  121. Some helpful tips would be awesome.
  122. K&N on BBK CAI...
  123. will deep dish rims fit
  124. I NEED TO FING WELD DRAG LITES.. PLS HELP
  125. installing tach
  126. my gt just stalls
  127. Good artcl. on power gains fr. head swap
  128. Axle seals already??
  129. headliner
  130. Headers and H-pipe.
  131. 86cobravs.88cobra
  132. best 5.0 shifter
  133. MOVED: 90 LX Notch VS 99 GT...who wins?
  134. control arms
  135. help getting new rings
  136. What should I look for?
  137. quick ?
  138. For thoes wondering about tire size
  139. Need help w/ build motor?
  140. Pricing , price, labor charge for work and parts
  141. Lets see every color but black sn-95's
  142. MOVED: 185s heads too much head for 351
  143. fms a/c delete install
  144. gt-40 heads y303
  145. Intake Manifold
  146. LX to GT
  147. Is this a good price?
  148. New gears are howling.
  149. Heads Question
  150. Installing new gauge faces on '89 5.0
  151. speedo gear
  152. MOVED: heres one for yuh
  153. Guage people.....w/ pods.
  154. Radiator prollems
  155. Post pics of Sick Black SN95s
  156. 94 mustang stock fuel pump flow?
  157. Re-locate battery
  158. Question about cam..... not chocie but info.
  159. 1988 Mustang Headlight lens installation
  160. Custom cam or tfs1 ?
  161. Computer question
  162. World Products - Windsor Jr. heads
  163. Rear ends
  164. Busted clutch adjuster??
  165. replace evaporator with heater core?
  166. Need Help
  167. What Cam?
  168. Steeda aero spoiler.
  169. WIRE HIDING HELP!!
  170. SLP exhaust clips...view only password now included!!
  171. installing flowmasters
  172. High volume fuel filters
  173. Mustang videos/sound clips online?
  174. smog pump?
  175. 88mustang
  176. which cam to use???
  177. anyone heard of this?
  178. Cobra R wheels on 88 vert question??
  179. Engine swap help/ set up?
  180. MOVED: Shocked...?
  181. Mass Air Meter
  182. lets see all the 5.0 motors
  183. 1/4 window seals
  184. coverting to maf
  185. 1988 stang
  186. MOVED: kenne bell supercharger
  187. STOCK 89 Gt times?
  188. carb/ intake
  189. FUEL LINE BROKE ON WAY TO CLASS THIS MORNING
  190. Do o2 sensors...
  191. Should I replace my IAC?
  192. Question about codes.
  193. factory timing
  194. AFTRE-MARKET SUB-FRAME CONNECTERS
  195. top end!
  196. Autobound top end?
  197. Where to find upper windshield trim?
  198. booster/master cylinder removal
  199. Welds on a 94
  200. pro 5.0
  201. Headers?
  202. MOVED: Brand turbo????
  203. MOVED: Cough! Spring in the Mid-Atlantic Cough!
  204. another EGR q
  205. Erratic Fuel Guage?
  206. Stall Converters?
  207. MOVED: ford 351 changeout ???
  208. MOVED: who is spraying?
  209. at my wits end....
  210. egr help
  211. Flippin Headlights wont shut off!@%$#@@
  212. Need a Little help for my fox
  213. GT-40 302
  214. Molding
  215. couple q's
  216. left and right rear spring different height?
  217. Replace fuel pump on my 95 GT
  218. Mods
  219. Engine Problem-need some help..plz!!
  220. What Should I Do!?!?!?!
  221. Venom chip?
  222. New Cam, new Lifters?
  223. for all the mustang techs
  224. My Turbo Stang...
  225. Mac exhaust sound and video
  226. Future (very near) Engine build
  227. GT to LX body Help
  228. just installed my CAI
  229. MANUAL RACK AND PINION
  230. '94 GT Conv. -- Best Mods?
  231. Electric waterpump
  232. Plugs and wires?
  233. just got rpm II!!!
  234. TwEECer
  235. throttle position sensor
  236. 3.73's, holy c**p!!!!
  237. headlight conversion
  238. Idle problems
  239. Pic request please.
  240. want to paint my wheels black.
  241. Will I chirp....
  242. body kit on fox coupes ...
  243. more stuttering problems
  244. SVT is no more
  245. Will 93 5.0 parts work on 95 5.0 parts
  246. fuel filter
  247. Setup
  248. what do you think about this hurst shifter?
  249. Say Cheese!
  250. Cost of AOD transmission Rebuild?
