PDA
View Full Version : 5.0L (1979-1995) Mustang
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 [255] 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331
  1. Need Help Bad
  2. injector size
  3. another fox
  4. Ground effects
  5. track times..
  6. exhaust tips
  7. Reliability/Durability
  8. changing cylinder heads
  9. vibration
  10. Transmission ?
  11. possible or not?
  12. Sound Barrier / Insulation
  13. Painting 91 LX which Color (with pictures)??
  14. Does Autozone really...
  15. Weld Racing Rims
  16. 10-pin connectors?
  17. fuel pressure
  18. Dire need of Help
  19. gt 40 intake manifold
  20. what engine to go with?
  21. 96 gt brake kit on a 95 gt
  22. street radials?
  23. rear end
  24. Has anyone changed their weather stripping?
  25. Vacuum routing
  26. how much for head work
  27. 92 GT Paint..
  28. Starting Problems?!?!
  29. should i have it balanced?
  30. Doing a little thinking...
  31. intake maniflod
  32. Wierd Cable?
  33. Painting Car which color
  34. help on a rear end problem
  35. spark plugs equal ruff idle and just ruff all together
  36. 5.0L swap
  37. overheating
  38. fuel issue....
  39. frequent drop in oil pressure.
  40. Not Chilton or Haynes
  41. What u guys think...
  42. best fuel pressure and idle problem
  43. 24lbs or 30lbs injectors?
  44. New Fuel Pump...
  45. Sea Green? Is that right?
  46. F 303 cam question.
  47. Upper/lower control arms
  48. Top End Kit?
  49. bogart rims
  50. Fly cutting piston question
  51. 302HO price???
  52. fuel lines *fast response*
  53. HELP!!! on the price of my cobra...
  54. Battery????
  55. AOD-E acting funny
  56. springs for heads
  57. starter
  58. my fan looks like it wiggles
  59. Whats your guys opinions on....
  60. Cooling Fan
  61. Oil ques....
  62. Mystery oil leak
  63. Solid Cam vs. Hydraulic Cam
  64. Noisy Roller rockers
  65. Oil Pressure
  66. how could i get around 400 to 450 horse power with a 302
  67. Gears
  68. Sticky tach
  69. could my combo be capable of 12's?
  70. Wipers get stuck on Low
  71. caster camber plates
  72. Opinion on belt idea
  73. New Engine, Both seals leak
  74. looking for more......
  75. MOVED: boost queston
  76. Tires
  77. Hopefully getting an 89 notch tomorrow got some questions.
  78. PISTONS; PLEASE HELP!!
  79. Springs
  80. 86 5.0 w/t-tops
  81. cant find this part anywhere...
  82. torque converter?
  83. 5.0 help
  84. What will a cylinder balance test tell me?
  85. gas prices
  86. intake and rocker Qs
  87. Pics of the car.
  88. Power Steering Issue
  89. 70 Throttle Body Spacer?
  90. Heads question
  91. Broken Shifter
  92. Gear question...
  93. Motor Decision
  94. tryin to decide if i'm gonna buy this 5.0.. please help
  95. Carb Conversion: What Edelbrock Intake to buy?
  96. whats the displacement of a 5.0 bored .40 over
  97. Hey I'm pretty lucky
  98. Just ordered tires....
  99. I think my pony needs some oats... hungry
  100. H-Pipe
  101. newer explorer injectors?
  102. windows
  103. Need a good place for 86gt weather stripping and parts
  104. will I need a new chip w/ engine rebuild/upgrade
  105. Steeda Camshaft...
  106. Hello, im new with questions.
  107. Transmission Prices?
  108. bullitt ons sn95
  109. World Heads
  110. Starter Probs...
  111. Negative battery cable?
  112. Vinyl Dye OR Spray?
  113. What spark plug wires ......
  114. Will it work?
  115. ROTM contest in full swing
  116. Does my '95 Cobra have...
  117. sunroof
  118. Clutch question....
  119. Chugging problem
  120. Belt
  121. Looking for
  122. 306 Shortblock
  123. ROUGH IDLE
  124. explorer manifold
  125. anyone ever heard of
  126. Sorry Guy's
  127. Heatercore going out
  128. Adjustable Fuel Regulator ?s
  129. Roller Rockers
  130. Getting ready to steam clean my motor...
  131. foglights
  132. weared noise
  133. MOVED: PROMBLEM
  134. Seats?
  135. Blown Head Gasket
  136. what trans/clutch do you have?
  137. 91' alternator fire. Changed to 3G. Bad Idle
  138. How long do they last, and your opinion please :D
  139. Pot of Gold PCV
  140. caster camber ?
  141. vert will not convert
  142. Big Braking Systems for SN95
  143. Mustang Week
  144. O boy, I need some pros...
  145. 370ci out of a 302?
  146. MOVED: nitrous question
  147. MOVED: Lets talk turbos
  148. What aftermarket intake manifolds fit under stock hood?
  149. venom 400/ chip
  150. Anyone know where I can get these inserts?
  151. MOVED: spray or not
  152. All stock..should I get 4.10 or 4.30?
  153. Why do I have to wait 1 sec. to shift?
  154. new guy
  155. GO TMY NEW RIMS TONIGHT!
  156. 87 Fog light switch help
  157. Mystery Relay HELP..what is it for
  158. bad idle
  159. Headlights and bumper on a fox
  160. Summit cam shafts
  161. suspension set up what do you guys think?
  162. Engine rebuild??
  163. am i going to have problems?
  164. C&L TRUE FLOW PIPE FITMENT!
  165. guess what, I have yet another question!!!
  166. Hatch Foxbody pcitures
  167. Convertible window leaks
  168. Harmonic Balance Question
  169. Hot restart stall issue
  170. Throttle jumps at first start...
  171. CAM&HEADS?
  172. high idle over 1500 rpm tranny grind
  173. whats a really good distributor, spark plug wires an spark plugs?
  174. Anybody in the NEW YORK Tristate area
  175. Fuel pressure
  176. gas mileage
  177. heads/crossover pipe
  178. MOVED: swapping a 351 into a 96 gt
  179. What is the best brand of synthetic oil to use in a 91 lx?
  180. Primetime? Or not?
  181. stock torque convertor
  182. need opinion
  183. Mustang Forums Project Mustang Name Poll
  184. Will this hood work?
  185. New Belt
  186. Engine sitting too low
  187. 87 STNG SHOULD I SELL/ IF SO HOW MUCH
  188. Hows it look?
  189. Engine removal
  190. New Cobra R hood came in today...
  191. my car cuts out like a miss when i turn sharp!
  192. BELT SIZE
  193. Cooloing Problems
  194. TB size
  195. MOVED: hmmm...
  196. 89 BLACK INTERIOR. VINYL HELP PLEASE. HOW TO VINYL DOOR CARPET??
  197. front coilover problem.
  198. Brake stands are harder than I though
  199. I think I found the motor of choice
  200. vacuum line diagram
  201. 1990 Mustang GT Speedometer
  202. I told them!! **** D&D!
  203. very dumb question
  204. using Tweecer, hard?
  205. synthetic oil problem??!!
  206. My Throttle Body!!
  207. my summer project.
  208. spark plug gap
  209. Adjusting Timing
  210. HP paranoia
  211. trouble getting in reverse and first
  212. Do I need to change oil when replacing my oil level sensor?
  213. bottom end go out?
  214. got some more new parts in!!!!!!
  215. Deleting EGR
  216. MOVED: Getting ready to buy
  217. What to do with my '95 GT
  218. Anybody have these??
  219. How do I work my oil filler cap?
  220. Intake Install
  221. MOVED: pinks - chevy in a fox ?
  222. Cant find..
  223. 91 Notch for $3k, should I jump?
  224. so what's the deal w/ hypertech programmer??
  225. Planning ahead
  226. Duraspark ignition box
  227. Main Support and Oilpan/pump Troubles
  228. chips
  229. I BOUGHT IT
  230. No EGR gasket?
  231. belt
  232. Does anyone know why...
  233. first gear
  234. Car runs horible when its cold
  235. 92 Convertiable Needs new top
  236. Spool or locker?
  237. Looking for videos.
  238. My shifter says "TR-3650" on it, I have a 93LX5.0?
  239. New TRAC LOK??? Do I need it?
  240. I think they sent me the wrong Carrier!!!! HELP PLEASE
  241. Procomp HEI dist?
  242. Anyone got P's ? what header ?
  243. Exhaust question not a newbie question
  244. rear end rebuild kits
  245. TPS HELP FAST!!!
  246. just hit a wall...literally
  247. car show in fla?
  248. What fluid to use in a t-5 tranny?
  249. Constant ticking
  250. stealth, airgap, holley, w/ gt40P?
