PDA
View Full Version : 5.0L (1979-1995) Mustang
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 [210] 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331
  1. swap
  2. Car wont start when its hot.
  3. What should my Fuel Pressure be???
  4. Belts?
  5. Max lift before piston/valve issues ?
  6. Are window motor bushings the same on fox and SN-95s?
  7. BBK FUEL PRESSURE REGUALTOR
  8. QUICK suspension question
  9. Rest repair...body men, this is for you!
  10. 94 GT 306 BUILD ENG OVER HEATING NEED HELP!!!
  11. Exhaust
  12. At what point is a cylinder ridge going to cause problems
  13. bbk cai
  14. starter solenoid
  15. /24lbs injectors???
  16. 28 Spline vs 31 spline?
  17. battle boxs?
  18. Standard questions, but I can't decide... blow it, stroke it, or 351
  19. Control arms, Tubular vs Stamped
  20. Sick 95 5.0
  21. 2 electrical questions regarding gauge install
  22. Aftermarket Blocks
  23. Replacement Air Filter - Powerdyne Supercharger BD-11A
  24. spring decision?
  25. need modified MAF?
  26. a video of me and my car!!
  27. steering issue
  28. Aluminum Door panels
  29. How do I remove the door panel?
  30. Volt regulator wheres it located 89 gt?
  31. will it hurt?
  32. Fuel pump Questions????
  33. idle problems
  34. high idle 1st start
  35. Armrests... where to buy?
  36. converted to MAF
  37. Suttering/idle problem
  38. Wow, Now that was a big job...
  39. fender quest.
  40. maaco paint jobs
  41. pinion shim question
  42. what a night
  43. power door locks
  44. Long tubes
  45. anyone running the FMS "C" springs???
  46. kinda stupid question i guess (don't post here PRO50SC..lol)
  47. Adjusting New Headlight Kit
  48. Intake
  49. Cobra vs Trick Flow
  50. looking for 5.0 fox body
  51. starter solenoid
  52. What kind of springs do you guys recommend???
  53. HP Question
  54. just ordered my new hood today!
  55. track tech question
  56. can i beat it...
  57. Another "I finally got to the track!" thread
  58. lets give up some good web sites
  59. Awsome track results
  60. Suspension kit...
  61. I'M GETTING THIS!!!
  62. I picked up my car today
  63. More progress....PICS
  64. Convertible
  65. pcm swap problems
  66. any ideas guys?
  67. Questions about Autometer gauge install.
  68. New Dyno Numbers...
  69. Videos put mustangs down
  70. belt
  71. ITS TIME!!
  72. thought it was a ignition problem
  73. does any one
  74. pulled some codes for detonation problem
  75. How does this motor look as a candidate for a 351W swap?
  76. ok 2 questions ignitions an valve
  77. short block
  78. tapping noise under acceleration, bad header gasket?
  79. Steering wheel/Horn assy replacement
  80. racing seats
  81. TKO trannies
  82. 70mm throttle body, does anyone have one?
  83. trying to ID headers and rear '90 GT VERT
  84. aod to c4
  85. licence plate bracket
  86. Has anyone ever bought the shims and indexed their spark plugs?
  87. alarm and door locks
  88. paint in a week
  89. whats going on
  90. turnin over.
  91. what does foamy coolant in the radiator mean?
  92. easy mods
  93. Went to the track last night...
  94. Hey 7UP
  95. can you use bronco2 axles?
  96. 4942cc, why do they call it 5.0 then?
  97. Please read if you have 5 lug and rear discs..
  98. not a good deal
  99. help removing bumper
  100. telling a 4cylinder bellhousing from a v8?
  101. Need help with compression test
  102. In regards to idle surge and idle hanging
  103. track results=kahboom!!
  104. maf or speed density?
  105. iridium spark plugs
  106. Damn Car won't start
  107. Is this necessary?
  108. 5.0 foxbody
  109. will this work?
  110. tapping noise
  111. gt 40 intake
  112. Engine techs-big question
  113. car running RICH Help
  114. my car died on me!
  115. pro5.0shifter offered for $30 what do you think the catch is?
  116. Need help with engine mod choices?
  117. Thinking of parting out my car
  118. Are my Underdrive pullies suppose to be this big of a pain
  119. Ignition help please!!
  120. Jimmie cone, mt. airy MD tomorrow night..
  121. Back from the Track!
  122. What are your mods and list?
  123. Question
  124. can't figure out this VIBRATION
  125. SCT tune questions
  126. Flywheel
  127. fried wires?
  128. what do i have to do to make this fit?
  129. Mac exhaust
  130. Ripped a Nissan SE-R....
  131. Anyone know about APC gauges?
  132. My car is done!!!
  133. Tweecer RT and the ECU
  134. Next mod
  135. My compilation!!!! Videos work now!!!
  136. Water Pump replacement difficulty
  137. Help car not running right
  138. people please some help on gear's
  139. Engine purchase help needed
  140. computer help
  141. is she worth the money?
  142. thanking about going back 2 honda
  143. some more help
  144. Shift Point
  145. [found it]'90 GT looked in book and on car can't find fuel filter. help!!!!!
  146. Is this worth the price?
  147. 31 spline axle's
  148. cooling bug
  149. finally solved it!!!!!!!!!!!!!!!
  150. Springs
  151. Hey my friend is looking for a 5.0
  152. results from races today
  153. 86 GT hatchback question
  154. Help With alternater pully
  155. CAR JERKS/TWISTS UNDER HIGH SPEED SHIFTING
  156. bumpsteer kit vs. offset rack bushings
  157. THOSE WHO USE STRANGE SHOCKS OR ABOUT TO
  158. new age dash in a fox body
  159. Pedestal rocker question...
  160. What would YOU do? Heads OR stroker?
  161. Cloggeed Oil Pump
  162. Rim Size in an '86 GT
  163. For the project Which MOTOR? Need some advise.
  164. About to install Pypes Violator's...
  165. help
  166. Burned chip?
  167. How did I beat a modified 98 mustang with my stock?
  168. people!!!!!!!!!!!!!!!!!!!!!!!!!
  169. rebuild time
  170. Hello...
  171. oil guage
  172. 89 LX sedan... time to get r dun
  173. Engine mounts!
  174. bug in my HCI setup
  175. New Motor going in... have several break-in questions...
  176. Rocker Question
  177. trying out posting pics
  178. Trouble with Equal length headers clearing the steering shaft?????
  179. flow tube for sale cheap
  180. my exhaust
  181. Proform rockers ? any advice
  182. custom converter increases efficiency of AOD transmission resulting in h.p. and tq. gains???
  183. heads question
  184. Ok. Where do I install the nozzle?
  185. Tire size question
  186. Pedestal mount rockers...
  187. [2 problems solved]HOW DO YOU GET THE FUEL LINES OFF FILTER?????
  188. hp rant
  189. injectors
  190. Cold Air Intake
  191. Might have bought an 88GT. Good deal??
  192. shock and struts
  193. anybody watch that new pinks episode?
  194. main girdle and oil pan?
  195. how will this end up
  196. came accross this on E-bay
  197. Good deal or no???
  198. lifters/rocker arms
  199. Progress........Fnally PIC
  200. timing?
  201. battery
  202. work involved in fitting 15x 10's
  203. new pics of my stang
  204. un f'in believable!
  205. HA HA my 5.0 is no longer my DD! Suspension here we come Ideas?
  206. NO OIL
  207. Rear End Pop noise.. whats the problem?
  208. horsepower
  209. twisted frame?
  210. Let's try this again. Favorite driving music?
  211. What would you do?
  212. new tail lights seem bad
  213. So, what's your favorite driving music?
  214. about to race...
  215. help about weatherstripping
  216. Strange shocks and struts
  217. Dad's 1/4 mile ET
  218. is there a direct disc boltin for fox?
  219. My car won't start again
  220. help please everyone i am stuck badly tried everything
  221. What's the difference(s) between a A9L and a A9M ECMs ??
  222. What would this run?
  223. help estimating hp/torque & 1/4 et
  224. Wheels for the stang
  225. brakes
  226. Intake clearance on valve covers??
  227. Not starting ?
  228. strut question
  229. Rear interior quarters???
  230. saggy
  231. THE BEAST IS ALMOST COMPLETE, Partailly Finished
  232. jojo just got some new parts
  233. coolant loss. evaporation?
  234. beehive/conical valve springs
  235. Throttle body question
  236. GT40p's and Long tubes??
  237. got my twisted wedge heads now what???
  238. why did you decide to go with a 5.0?
  239. Best Place In Firewall To Run Wire
  240. very simple h/c/i question
  241. some wierd sound coming from the passenger side??
  242. dart block 302
  243. Heat shield on SN95...
  244. What is the Difference? Help guys.
  245. just got back from the dyno
  246. 2 questions!!!
  247. Added a 1985 GT Vert To The Stable - PICS ADDED!
  248. Sunroof question?
  249. How to figure out lift ?
  250. looking at new rims...question?
