PDA
View Full Version : 5.0L (1979-1995) Mustang
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 [195] 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331
  1. mass air conversion problems.
  2. tranee cooler
  3. heres some gears for you 5.0 guys and a pretty low price
  4. engine,tranny,gear combination questions (help)
  5. wow guess the gears could not handle the fun!!
  6. cobra rims
  7. Lentech Valve Bodies
  8. intermitant starting
  9. Console question
  10. 289 mods
  11. Radiator
  12. what heads should i get???
  13. nitrous question??
  14. Door's question
  15. another seafoam thread
  16. street heat or track heat??
  17. 302 block question?
  18. Best manual to buy?
  19. dr. gas x pipes
  20. sunroof replacement
  21. should i juice on an Aod
  22. FINAL Taurus electric fan Q's
  23. De-Carbonizing
  24. 5.0 "H.O." ??? what is ho?
  25. underdrive pullies, throttle body
  26. sigh...
  27. speedo cable
  28. What does it run?
  29. TFS Stage 1 vs E303
  30. 28 spline axels
  31. Forum dudes...I got a sagging rearend
  32. This timing chain and gearset... will it work???
  33. Aftermarket Fox exhaust opinions
  34. ported heads
  35. man this sucks
  36. new and dont know what to do...
  37. Will the 302 block hold 600whp on upgraded internals?
  38. Ported GT40s or Aluminum???
  39. Removing engine/dissasembly?
  40. 1988 5.0 rear lid vs 1990 5.0 lid
  41. Roller Rocker Question
  42. slp loudmouth mufflers ???
  43. Overheating problem
  44. IRS swap
  45. Front main seal
  46. Need help with my 5.0
  47. UPR CLUTCH QUADRANT/FIREWALL ADJUSTER
  48. Whos running a typhoon intake?
  49. how to install a clutch
  50. 95gt smog pump done correctly?
  51. clutch pedal
  52. front coil over
  53. gt-40 intake questions
  54. valve cover clearance
  55. Ave cost to put a 600 horse engine in a 98
  56. c'om guys..vote for the ROTM
  57. Will these fit?
  58. Mustang GT350
  59. rear arm bushings
  60. all mechanics! #2cyl no compression*Pics updated*
  61. $10 well spent?
  62. simple oil pan question
  63. Oil level sender seal?
  64. Engine is finally dead. Suggestions for new build?
  65. speedomer and rpm question
  66. Tough Question For The Pro's...
  67. My speedo only goes to 85mph, wut can I do? Plus another guage question.
  68. WHAT TO DO 4 MID 13S ?????
  69. are 89 LX's the least available stangs?
  70. Is PRO MIA now that he's a MOD?
  71. 1.6 to 1.7 Roller Rockers
  72. 1990 LX 5.0 stock wheels?
  73. 89 convertible questions
  74. sea foam
  75. Seat Belt question
  76. Heads
  77. anyone know anything about 289s?
  78. loudmouth mufflers
  79. millage?
  80. Custom plate idea's
  81. need someone to go out and look under hood
  82. More Cylinder head info then you ever need!
  83. intermittent surging idle
  84. Hows This COMBO?
  85. 1980 2.3 to 5.0 swap
  86. Timing and 8.8:1 compression
  87. idles anywere from 1500-3000 rpm
  88. my new winter beater
  89. horse power?
  90. 4" cowl hood
  91. Picture Request...
  92. Insulation in shift box??
  93. Rare color???
  94. couple timing questions
  95. header gaskets...
  96. Turbo 5.0 rx7 project
  97. convert me
  98. What gears do i have?
  99. steering
  100. Spoiler question
  101. Was there a factory 5lug fox?
  102. 5.0 Fairmont Plans
  103. please give a warm welcome...
  104. Wanna put gears in my car..
  105. to do or not to do
  106. EEC-IV
  107. Injector o-ring size?
  108. cams
  109. A minivan is a sure sign that someone has given up.
  110. Quadshocks
  111. I need firing order for my 94' GT
  112. Buying a stang
  113. Budget super charger
  114. shift kit
  115. ok guys.... sbc distributor in a 302??
  116. sorry guys
  117. f u c k i n school
  118. pics of weld draglites 15x8
  119. what primary size recommend
  120. a/c delete and pulley kit?
  121. actual tech question
  122. drag launch spring pics
  123. removing ac
  124. MY 85 GT
  125. heads question
  126. is it worth it
  127. runs bad, but only in the rain??
  128. New rear
  129. Subframe connectors
  130. 3" cobra r hood
  131. what set up for all motor???
  132. Very Noob-like question
  133. with full exhaust intake n chip what hp??
  134. speedometer gauge
  135. cant remember
  136. MGW
  137. what header on automatic 92 gt
  138. Standard vs. Full Length Subframes?
  139. popping out of 2nd
  140. which exhaust
  141. guess whats on the way
  142. Brake dust...
  143. 460 in a FOX
  144. A few parts for sale
  145. line lock
  146. mufflers
  147. Wanting to carb an 88', have a distributor question.
  148. transmissions
  149. cam question??
  150. Need clutch help quick!!
  151. rear upper arms front bushing question
  152. 84 GT 350
  153. Okay flywheel to use with a King Cobra Clutch?
  154. Sickest street driven sn95 i have ever seen.
  155. TECH
  156. cruise control not working
  157. 165 psi compression...couple questions.
  158. 5.0 GUITAR - CHECK IT OUT
  159. Front tires slowing me down?
  160. starter solenoid
  161. Well I did the Seafoam thing
  162. Progress with Pics *FIXED*
  163. Quick Question.
  164. OK guys, need some help!!!
  165. cleaning question
  166. Suspension Mods
  167. Buying Heads, Pushrod length?
  168. conv't question
  169. 475+ hp dyno on 357W :) :revised
  170. Power estimate before and after
  171. somebody make sure im right?
  172. HOW DO U....
  173. low coolant
  174. PURRRRRRRRRRRRRDY
  175. That's it, I'm leaving the forum too!
  176. upper and lower intake
  177. ? about switching to carb
  178. If I was looking for a project...
  179. spindles
  180. How is speedo off??
  181. injector Question
  182. Thinkin ahead.....Suspension....??
  183. rims for 87
  184. P.I. vs non P.I.
  185. 86 mustang running bad
  186. i'm leaving the forum..
  187. my 5.0 Feels weak... Just purchased.
  188. front strut questions...
  189. deal on not
  190. whats my motor worth?
  191. XXX Stamped Block?
  192. Stock Z06 10.85 ET
  193. Another post on oil burning...
  194. Engine Swaps
  195. on the cover of the new 5.0 magazine...
  196. my sleeper..
  197. this nerd at my school
  198. You guys are going to HAAATE me..
  199. Any pros or cons to this gasket set?
  200. fender sizes??? new pic
  201. SN95 Respect
  202. '79-'82 taillights
  203. SPORT LINES!!!
  204. 1.6/1.7 offset crain roller rockers??
  205. Stay away from Superior Radiator of MI. Ebay name DISSRAD
  206. '85 2.3 clutch fork
  207. Trading wheels??
  208. compression calculator?
  209. Smog sticker
  210. The new Boss 302 block is back!
  211. Lost my brain-quick ? please
  212. weight of 5.0L vs 5.8L?
  213. 408 stroker
  214. Check out this deal!!
  215. 400 HP?
  216. Tremec Transmission
  217. Stock red line ?
  218. Weight of a notch?
  219. Quick but Important Question
  220. Speedo Reading
  221. TPS Bad?
  222. hp with this combo
  223. Cobra or not?
  224. Find the missing 200hp!
  225. My search for GT40 heads...JACKPOT
  226. Heads, Cam, Exhaust...thats it!
  227. once again! bought some more stuff for my stang!
  228. Ranger Transmission
  229. I NEED HELP!
  230. how easy?
  231. 95 vs TL..95 vs a Mustang
  232. High Idle
  233. Weatherstripping
  234. ok nominations for 5.0 a-hole of the month
  235. 75-300 shot needed
  236. cold fusion nitrous kit (help please!)
  237. Black rims on white car
  238. HP increase
  239. GT-40 heads
  240. transmission
  241. Door Locks
  242. Decisions...decisions. Chance for another 5.0
  243. Door speakers
  244. Trick Flow Intake Install on 95 GT?
  245. Cam question
  246. Timing cover/waterpump bolt tightening sequence
  247. These are the rims for me !!!
  248. hookin up
  249. steering wheel..
  250. Cold Air Intake?
