PDA
View Full Version : 5.0L (1979-1995) Mustang
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 [294] 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331
  1. Electric water pump and P/S delete questions
  2. What's a good performance chip
  3. Still vibrating, frustrated
  4. A/C Fan Slows down as RPMs increase
  5. Overheat,no water loss.
  6. ticking noise from under the car!!!
  7. aod or aode help
  8. head casting #'s
  9. Can't go into 2nd Gear
  10. how much
  11. 89 need a pcv baffle
  12. 94 shifter questions
  13. Anniversary Mustang
  14. Headers + H pipe
  15. help me out
  16. pistons vrs heads
  17. AOD to Manual
  18. Motor Upgrade?
  19. car is acting stupid
  20. ignition question
  21. Shift kit Question
  22. Driveline issues(frt u-joint)
  23. The Most hp while staying emsissions legal...
  24. Need help with brake light switch!!!!!
  25. why AFR'S?
  26. Tips on starter mods
  27. Air Bag Warning Light
  28. gas gauge problems
  29. Needs to be fixed
  30. 95 rearend in an 89?
  31. Timing to 14 degrees?
  32. 5th set of header gaskets goin on tonight
  33. edelbrock intake
  34. I NEED MY FELLOW 5.0'S BUDS HELP
  35. 93 Coba parts
  36. removing intake silencer?
  37. Trick Flow twisted wedge tech ?
  38. Taking off Harm. Balancer
  39. 373 Gears - Cobra
  40. Running problems
  41. my goals
  42. suspention problem
  43. cutting of the stock springs
  44. Have a couple of questions, need help.
  45. MAF For 87 Stang...
  46. Creaking sound in first gear
  47. battery backwards
  48. Swapping bottom ends question....
  49. 88 5.0 vs 94
  50. Coilovers question
  51. 4 lug bullit or torq thrust II
  52. Side Exhaust or Not
  53. 89 mustang oil problem
  54. 5.0 in a 94 v6
  55. Pro-m question
  56. H Pipe
  57. water pump leaking?
  58. transmission problem.... speedo cable
  59. Supercharger for 5.0
  60. cam timing help
  61. 1/4 mile Times?
  62. Is this a good deal or not?
  63. engine does not run right
  64. speedo gear hell
  65. temp guage
  66. tranny or U-joint making noise?
  67. 351W into '96 stang
  68. aluminum driveshafts
  69. Car running hot
  70. A9L In auto
  71. poly motor mounts
  72. wraping headers
  73. Few things need replacement, which is the CHEAPEST route
  74. temp
  75. EVR ohms
  76. EEC dif between A9L and A9P??
  77. Long deals on plug wires
  78. Flows are gone
  79. Took back my Auburn Posi today...
  80. Mustang Vs Firebird
  81. gaskets
  82. Harmonic Balancer
  83. B&M Trickshift
  84. Another 5.0 engine...
  85. my 88 5.0 at the street drags
  86. Ignition Coil
  87. Anyone Running Direct Port Nitrous??
  88. My friends 87...
  89. Misfire??? Problem Running... PLEASE HELP!!!
  90. Control arms and drag shock Q's???
  91. made an custom CAI
  92. My 88 GT vs My 89 GT
  93. 89 Stang Engine Removal
  94. Speedometer and Gears
  95. SUSPENSION Question
  96. Skip and loss of power problem!!
  97. flaming river?
  98. changing upper and lower intake
  99. Roll Cage for 94 Convertable
  100. rear control arms?
  101. windshield wiper switch
  102. Mustang progress pix
  103. Rear left brake drum smoking
  104. Muffler Comparsion Chart
  105. explorer high torque camshaft
  106. Holley 750cfm Carb question...
  107. Engine Map(Location of Parts)
  108. Engine swap ? from 95 to a 93
  109. POWER LOSS...please help me out!
  110. i love my edelbrock intake!
  111. quick exhaust question
  112. American Thunder vs. 40 series
  113. which heads to use
  114. Keyless Entry on my 5.0
  115. is mass air flow worth it.
  116. Need 93 GT Vaccum Diagram!!!
  117. Best place online to get 8.8 clutch pack?
  118. Favorite FOX!
  119. First time at the track
  120. Changing Headers or Not
  121. AOD Aggravation
  122. American Thunder package
  123. Questions about BBK shorties install?
  124. whos doing twin turbos
  125. 89 Convertible Problems
  126. Who's using Summit fiberglass seats?
  127. mass air sensor
  128. where can i get one?
  129. Most important header option
  130. bypass heater?
  131. Where did My post Go????
  132. how much can i get for my 93?
  133. cold air/air filter
  134. new rear end
  135. gas gauge problems
  136. AOD giving out?
  137. Shorty, Shorty Equal length, or Long Tubes?
  138. fuse box diagram 84 lx
  139. 88 GT wont start after storage
  140. 95 to 93 engine swap
  141. head swap? Should I attempt to do it myself?
  142. Suggest camshaft...
  143. Timing Cover Install
  144. I got my MM Full Length Sub Connectors Today!!!
  145. Need 347 stroker kit and camshaft suggest a kit!
  146. speed density or MAF computer?
  147. headlight problem
  148. followup...car wont start!!!
  149. Speedometer accuracy
  150. SCT custom chip
  151. TIRE FITMENT
  152. fuse box schematic
  153. pics of what iam doing right now
  154. PYPES Header nightmare
  155. gears?
  156. 96+ 5 lug parts
  157. installing a new guage pod
  158. my car wont start!!!
  159. 94 gt cooling question . . . .
  160. slight grinding noise in gauge cluster
  161. how to bypass msd ignition?
  162. Radiator Question
  163. A question about fuel flow...
  164. Stud Mount & Pedestal, What's the big deal?
  165. 347 Stroker kit
  166. Power Steering Whine
  167. emergency brake light
  168. 3.73 Gears and Speedometer
  169. valvetrain noise..
  170. 3.73's. Worth it?
  171. detonation while at a steady spead?
  172. banging noise in the rear
  173. What are quad shocks I see mentioned here?
  174. Rebuild or new engine?
  175. engine temp question
  176. help! shifter problem!
  177. 5.0 Cobra build questions
  178. cam size
  179. pro-M 75mm mass air
  180. How much do foxbody seat weigh?
  181. Upper and lower intake swap
  182. The water temp sensor is unpluged
  183. Mass Air Q
  184. IAC Question
  185. gt 40? e7?
  186. lincoln town car cam help
  187. tps....
  188. Best ignition system.
  189. low voltage at fuel relay coil
  190. AFR vrs Edelbrock heads
  191. does anybody know where the fuel filter in a 89 mustang is
  192. tuning programs
  193. Will my Rockers clear?
  194. 90 charging system, oil leak, and vibration
  195. 460 fox kit
  196. fuel lines for 347
  197. Head Gasket?
  198. A whine in gear
  199. Check Engine Light!
  200. is it possilbe 351M in a 93 Mustang
  201. still have the vibration!!
  202. 347 stroker project
  203. missing power
  204. 87 turbo coupe rearend
  205. Another Quadrant Question
  206. car wont start
  207. 93 or 94 computer
  208. 1.7 roller rockers or cam?
  209. 87-89 vs. 90-93 Foxes...
  210. cam question
  211. negative batter cable...
  212. Fenders
  213. ignition woes.
  214. ignition woes.
  215. what are some free mods that i could do to my 89stang.
  216. 8.8 REAR
  217. shaking when accelerating!!
  218. 351 swap info in a 1994 gt
  219. AOD Rebuild After Shift Kit Mess...Please Help
  220. 5.0 stalling and hard starting
  221. 351vs.aluminum 302 heads
  222. Upper/lower 5.0 intake manifold from Mercury Mountaineer?
  223. 94-95 Saleen
  224. need help with fuel pressure
  225. how much fuel pressure
  226. front sway bar
  227. doesnt hold fuel pressure
  228. car not performing
  229. Heads Cam Question
  230. Need Help with front suspension
  231. blower motor problems
  232. Clutch problems!
  233. clicking when i drive....
  234. Next Modifications
  235. help with figuring compression ratio
  236. 347 Stroker Oil Problem
  237. 93 cobra MAF?
  238. More Tranny problems...
  239. Looking for info on tublar k-members
  240. ram air
  241. windshield wiper control?engine temp guage
  242. Illegal Parts And Passing Smog
  243. My cage and subs
  244. reverse lights
  245. Custom gauge cluster...
  246. Holley Systemax 2
  247. Help...Can't figure this out(Clutch Problems)
  248. Torque Thrust D's
  249. Detonation in 1 cylinder?
  250. I bent my rod
