PDA
View Full Version : 5.0L (1979-1995) Mustang
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 [147] 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331
  1. How does this sound???
  2. what can i take off?
  3. CAI causing lean?
  4. good mods
  5. 95 5.0 vs. intrepid
  6. Vacuum problems...
  7. Fault codes what do they really mean
  8. need help from wiring gods
  9. Squeaking from rear while driving
  10. HELP - Spark plugs for supercharger - colder
  11. is there a differnce in between MAF sensors & years
  12. forged pistons?
  13. Gas
  14. Stutter under 2k rpm
  15. changing all fluid
  16. tremec TKO
  17. few wiring questions.
  18. Florida50 gauges
  19. Tail pipe issue
  20. how much hp
  21. Starts, but no go.
  22. can anyone tell me about explorer heads
  23. getting ready to install these need advice
  24. AOD loud/hard downshift
  25. P/s to manual
  26. Quick Question!!!!!
  27. exhaust clip
  28. probably a simple questions?
  29. 1 day started up fine, stalled, now SHAKES
  30. full h/c/i swap
  31. Intake hoses...
  32. starter problems
  33. Questions about a 8.8 rearend
  34. bbk long tube problem
  35. Mustang + snow = bad... but
  36. CA smog?
  37. Where to spray methanol
  38. MAC Upper and Lower Control Arms
  39. Good used mustang place.
  40. insurance
  41. 351 carb swap
  42. How to run Own stereo wires?
  43. 86 5.0 today *pics*
  44. convert from efi to carb
  45. 90 GT with Sunroof is it from Ford?
  46. Fuel Pressure
  47. AOD Trans won't shift
  48. Weld Wheels
  49. Power Loss At 60 MPH!!! Help
  50. Is my Alternator going out?
  51. exhaust pipes
  52. wiring issues???
  53. Deal or No Deal?
  54. what does this wire do?
  55. Richmond Dragracing!!!!
  56. whats a "M" code mustang? i think i have one
  57. trick flow
  58. Will these heads work on stock bottom end?
  59. Backfiring in the intake manifold
  60. What type of gaskets to get?
  61. 65MM TB to 75MM TB
  62. Smoked a 300zx twin turbo today!!!
  63. Whats the best way...
  64. TRIAX OR PRO 5.0 SHIFTER
  65. Let me know what ya think of the paint im goin with
  66. bearings
  67. new to forum
  68. Stock HP on a 94 gt
  69. Shifter rattle
  70. Looking for 2 things...
  71. almost got the tranny out today
  72. rearend swap. 7.5 to 8.8 ?'s
  73. Fuel pressure
  74. my progress so far on project 4eye5.0
  75. Which injectors...
  76. simple question: Intakes
  77. CARB VS FUEL INJECTED
  78. never done a water pump while the motor was still in car, any tips?
  79. Wiring Issues... HELP!!!!!
  80. oil additives
  81. How much of a gain
  82. help help on carb application
  83. Any ideas
  84. breather question
  85. Header paint ?
  86. how much hp does stock 302 have
  87. Went car shopping today, need advice
  88. ??? look @t
  89. I'm losing my mind...
  90. Wipers
  91. Ebay Mustang
  92. What Size EGR?
  93. Bad injector?
  94. stock heads
  95. Drag Springs worth it???
  96. D1 pro charger and high temp problem
  97. T5 trans
  98. Looking for a song please help
  99. junkyard transmissions
  100. NMRA SUPER BOWL!
  101. mustang vs. 240sx
  102. idle problem
  103. Fuel Pump
  104. clutch fork
  105. fidanza?
  106. car alarm
  107. fixing head light need help restoring to 4 eyes, pics
  108. Safe CR on 94 pump gas?
  109. carb help
  110. Gear Question....
  111. where to start
  112. what heads do 94-95 v8's have?
  113. suspension problems
  114. Intake
  115. serpentine problems
  116. Are these considered PBR Calipers?
  117. more carb trouble
  118. what does this wire go to, see pic below
  119. Pics of my H/C/I build
  120. Pulling the motor.
  121. Clearence
  122. Battery problems!!!
  123. Oversized Rotors For 93 5.0?
  124. quick ACT question
  125. Hooking up stock tach on a 351 carb motor?
  126. The beast lives again!! Woot!!
  127. Gauge Cluster
  128. timing and off road hpipe
  129. changing plugs(N00BEST QUESTION OF EM ALL)
  130. I made a PCV Catch Can out of PVC!
  131. Just got the car dyno'd last night. *PICS*
  132. 1.7 RRs question?
  133. Cobra Grill
  134. injectors on stock motor
  135. What Clutch Should I Get?!?
  136. pilot bearing??????????
  137. Need Help w/crankshaft on 5.0
  138. whats the difference (5.0)&(5.0ho)?
  139. Raced a 93vert last nite
  140. AODE
  141. Hiding a Monster in a Shoebox
  142. pro comp head problems
  143. Someone please give me tips on cam install
  144. Blew A Big Water leak
  145. h/c/i
  146. 5.0 motor almost complete
  147. what other cars have the same alt as my 86 gt?
  148. cam?
  149. Progress so far
  150. Injector size questions
  151. Where did it go? Help!
  152. ? on Bracket on 8.8
  153. So what's my problem?
  154. Differential cover problem help.
  155. Completed Speed Density Cam Swap
  156. GT40 intake question
  157. Production Block 347 Stroker
  158. are the water pumps 87-93 94-95 5.0 different
  159. Someone posted a link to a harmonic balancer...
  160. Upper Intake off, have a few questions..
  161. clutch cable will not go on
  162. Oil pressure?
  163. Where are all the vins on fox bodies???
  164. No START HELP
  165. New mustang!! mods
  166. 408 Stroker Build
  167. MAF for 42lb injectors?
  168. am i the only retard to put thier trans crossmember in upside down?
  169. what would it take mustang to keep up with a supercar
  170. 01explorer rear in 95gt?
  171. oppinions, torque box kit, any good??
  172. fox body problems
  173. wiper switch wiring diagram
  174. Son of a Bitch!
  175. HELP!!!!!! Intake problems
  176. procharger/methanol/compression ratio
  177. 331 STROC\KER BLOCK
  178. Help me with these pushrods
  179. Do I really need this?
  180. voltage regulator
  181. What Intake is this?
  182. MAP Sensor on 94-95 Models
  183. good setup
  184. Drag Radials?
  185. 300 hp
  186. Methanol injection questions
  187. how do u enable factory audible alarm?
  188. Quick cruise control question
  189. Unscrewing ford thermactor plugs!?
  190. new and heads
  191. 93 cobra
  192. What should my car be running?
  193. lifters
  194. which route to take
  195. Swiss Cheesein it. yee haw!!
  196. might have found my new mustang
  197. Anybody every installed these??!!
  198. I NEED HELP ASAP!!!!
  199. Have to get new plates
  200. I always thought it was faster....
  201. Drag Radials
  202. TPS trouble????
  203. carb to efi
  204. idle and accel
  205. torque boxes
  206. Shifters?
  207. gt4op intake any better than what i have now ?
  208. Cant Keep 91 Mustang Started
  209. Power steering problems.
  210. Fog Light Opinions Needed
  211. comparison
  212. PRO-5.0
  213. disappointment at the track today!!
  214. seafoam
  215. 2nd Gear??
  216. Silicone on Gaskets??
  217. clutch won't engage
  218. Battery Problem.
  219. 79 Fuel tank
  220. 5.0
  221. tranny help needed
  222. MMMMM stroker pics
  223. console ???..
  224. fan question
  225. Rebuilding a T5, how hard is it?
  226. pressure for 275/40 nittos at track?
  227. Rockers hitting valve cover
  228. Data aquisition
  229. Ford racing vs Eibach
  230. underdrive pulleys question
  231. Couple of Local Badass Foxs PART II - MORE PICS!!!!
  232. Stroker Camshaft ???
  233. fuel pressure
  234. Polished wheel help
  235. GT40Ps and stock cam vs. b303.
  236. Window tint
  237. bbk clutch cable for SN-95
  238. major problem please help
  239. GT40 Upgrading, lets get the info right.
  240. Throwout Bearing
  241. Going to start parting it out...
  242. 5.0 rebuild
  243. rear air bags
  244. speedometer gear
  245. Bout to start swapping everything
  246. UPR quadrant (cheap)-any good ?
  247. 6G alternator upgrade
  248. hah new color in a few months
  249. Sandblasting Chrome wheels?
  250. Trans Swap Question
