PDA
View Full Version : 5.0L (1979-1995) Mustang
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 [123] 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331
  1. Worth it or not???
  2. stuck clutch
  3. overhauling my suspension...Woohoo!!
  4. 4 Cyl Springs
  5. Royal Purple which one to use
  6. bigger injectors with this combo?
  7. GT40 P HEADS
  8. Fog light assembly question
  9. Driveability Problem
  10. Engine Vibration and High Idle
  11. pypes exhaust install
  12. quad shocks
  13. gauge cluster for 1994 gt
  14. How to find a Vacum leak??
  15. why does my battery keep dying?
  16. What is wrong with my car?!?! (video included)
  17. Long Tube Headers Help
  18. Mass Air meter and CAI HELP
  19. Anti-Rattle shims?
  20. fuel question
  21. Water temp and oil pressure gauge
  22. t-5 to c-4 swap
  23. Nitrous B.S.
  24. Megasquirt question
  25. HELP 86 STANG WON'T RUN
  26. New alternator, still no charging
  27. Big problems need some serious help brake booster!!!!!
  28. GRANATELLI MAF
  29. Trick Flow Track Heat Package and Emissions
  30. Spinning Tires first 75ft
  31. This ever happen to you...
  32. 1500 rpm whistle from intake.
  33. issues..
  34. port matching
  35. Need engine help in West Atlanta
  36. can i port/hog out anything on upper intake?
  37. what will a 5.0 do with larger injectors only?
  38. lowering..?
  39. rpm gauge whent crazy..?
  40. 12 second car
  41. motor mounts
  42. I'm Stumped and Need Help/Advice
  43. Wiring Issue
  44. exhaust done
  45. new front rims poll
  46. headers?
  47. MAC cat-back not fitting right
  48. 5-speed troubles
  49. Drivetrain build...
  50. What causes this?
  51. strange noise??
  52. what speedo gear do i need???
  53. threaded plugs
  54. Hole in my water pump!??!!?!
  55. carpet question
  56. BUILDING A NEW TOP HALF OF MOTOR
  57. V6-V8 Swap
  58. help!
  59. motor?
  60. radar detector?
  61. 92 mustang convertible top leak water?
  62. Stalling
  63. car wont hardly run????
  64. Is anyone Running this same combo? 94' cobra
  65. What can be done about this??
  66. AC and Smog pump eliminate ?'s
  67. electric fan?
  68. what you guys think of set-up??
  69. 460 swap
  70. fuel pump ??? what do i need??
  71. aod transmission/ motor questions
  72. difficulty level pro 5.0 install
  73. fuel pump
  74. 4cyl t5 and 4:10 gears?
  75. Finally Installed!
  76. Potentially looking at getting a fox body, coming from DSM's...
  77. Help with guage question ???
  78. auto trans question
  79. AOD tranny
  80. exhuast help
  81. fuel pump
  82. Angcobra 5.0 Block Broke?
  83. override transmission
  84. running rich question
  85. spark rattle???? this is weired
  86. O2 sensors
  87. Convertible top..??
  88. Rear End QuesTion..??
  89. Exhaust Question
  90. C-6 trans question
  91. Intake manifold?
  92. GT40 INTAKE OR TRICKFLOW
  93. gasket help!
  94. exhaust project going well
  95. Rear seat removal
  96. The never ending Head thread
  97. ignition question for dummy's
  98. Fuel pressure setting
  99. line lock?
  100. oil pump change while engine in car
  101. 4cyl springs ???
  102. prochamber or upr x w/cats
  103. got my motormounts, now how do I put them on? with pics
  104. where can i get a chp kit or a scat 306 kit
  105. clutch cable installation problems.. *QUICK HELP*
  106. Fuel pump location
  107. a little belt info
  108. Cooling problems, it's never ending with this car! Need help asap
  109. auto 302-stick351 carbed?
  110. Your thoughts
  111. quick gasket question
  112. Getting Ready For Inspection. Quick Questions!
  113. Ok, I really need help with this..
  114. knock problem
  115. Help me identify my weird rev squeal please???
  116. VALVE NOISE? OH NO
  117. new dyno numbers Update
  118. stock timing?
  119. Starter grinding
  120. repainting my taillight housing. what paint
  121. Lifters
  122. New Starter and Silenoid - Still hangin up
  123. HCI Finished - Car doesn't want to idle stalling out*Updated Pg2*
  124. Fuel pressure/ PCV ?
  125. what tire pressure to run?
  126. Stock splash gaurds on an LX (removal?)
  127. dss ?? to buy or not to buy
  128. any auto guys run this shifter?
  129. fried clutch?
  130. Besides the battery, where else can I hook up the horn for B+?
  131. exhaust decesions..
  132. Distributor from a 351? Also, camshaft?
  133. is there a diagram for this?
  134. Alternator pulley diameter.
  135. MOVED: cj pony parts car show??
  136. Throttle Body EGR Spacer
  137. Tranny???
  138. 1990 Mustang trans question
  139. centerforce clutch opinons
  140. alternator issues
  141. Neil Erickson Midwest Induction GT40p
  142. stubborn speedo cable
  143. air conditioning removal
  144. 5.0 88 VERT TO 93 NOTCH TECH HELP
  145. factory tach
  146. fuel starvation ????
  147. Will '87 up taillights work on an '85??
  148. weighed my car today
  149. Ongoing issues, car keeps dying
  150. New Clutch
  151. Question on offroad x or h pipe?
  152. quick clutch question??
  153. cleaning injectors
  154. MAF Question
  155. Would this cause my massive loss of power?
  156. rocker arm?
  157. NEED HELP!!!
  158. Small cap HEI dizzy
  159. still got issues
  160. Digital Dash - Fast & Furious style - UPDATE
  161. Where do they go?????
  162. over heating
  163. Does Anyone Know???
  164. puffin
  165. what is this thing?
  166. quick clutch question
  167. New N/A 331 dyno plot inside
  168. 93 gt rear disc brakes
  169. What to do next?
  170. rear end rebuild
  171. Looking for a smoother ride
  172. 4 lug rims
  173. Cars getting hot, no overflow?
  174. MAF Meter question and timing
  175. Weld draglite question
  176. Changing Dash lights to colored LEDs
  177. Tuning Your 5.0l
  178. What Torque converter?
  179. help with completing h/c/i
  180. CARB. ISSUE
  181. Max. Rear Tire Size
  182. Need help with wiring
  183. Installation Kit Required?
  184. Terminator Radiator In Fox
  185. Brake Calipers, 93 rear disc caliper piston!
  186. 75 amp bosch relay
  187. 351w Flywheel Question
  188. hesitates only with a/c on
  189. Throttle response is a bit laggy...
  190. ECU problems
  191. 94 timing
  192. huge miss until 3000 rpm
  193. Does this seem right? Temp question
  194. Nitrous problem fixed!
  195. MOVED: Salvage 89 gt 5 speed
  196. no compression
  197. painting my 88 lx hatch?
  198. k member help!!!
  199. 347 stroker question?
  200. carb ideas for a 400m...
  201. clutch adjustment???
  202. HIGH volume oil pump question
  203. Heads/cam/intake
  204. 1993 5.0 Detonation after 3000 rpm
  205. rocker arm fell off
  206. idling problems
  207. lacking oil pressure
  208. pinion shaft retainer bolt?
  209. i need colder plugs what which do i need
  210. 400m into a 86 lx hatch
  211. Front Struts
  212. Stupid Question on 50 shifters
  213. Cobra grill insert
  214. Acceleration problems..
  215. When it rains it pours
  216. rich/lean issue
  217. 5 lug questions...
  218. clutch quadrent
  219. 95 mustang cobra Q
  220. manual steering rack
  221. any1 know if a '96 cobra exhaust fits a fox?
  222. White saleens in 4 lug?
  223. Anyone running gear drive? Any sound clips?
  224. Clean hatch?
  225. Help w/part #
  226. what are these
  227. SN95 Suspension Upgrades
  228. which would look better
  229. neutral safety switch need help
  230. quick dumb easy question.
  231. Starting to build up my 93 LX
  232. what could cause this
  233. removal of E-brake
  234. 5 lug aftermarket axles
  235. Front Oil Leak
  236. 86 mustang inexpensive performance mods
  237. Water temperature
  238. loss of power after h pipe???
  239. What rear end is it?
  240. anyone running a 7.5?
  241. I'm down to BBK or Cobra Intake....
  242. Bracket for rear speakers
  243. BBK equal length headers
  244. Heater tubes can they be removed?
  245. help!!!!
  246. rims???engine?
  247. Turn Signal Problem! HELP!
  248. tuning fuel pressure regulator
  249. $650...what suspension should i buy
  250. How much vacuum should I pull at idle?
