- Manual Fan Switch?
- Vibration in pedals
- O2 sensor in aftermarket exhust
- 5.0L into a 99 V6????
- Rev Limiter/Power
- Intake Setup
- 4 BBL Intake?
- not lifters thank god, i think lol
- mph gauge
- rear bearing
- shift kit question, please help
- Very inexpensive CAI
- Dynamic Racing Products
- Adjusted timing
- Jackin up my car
- Coolant temp valve
- What headers for Gt40-p heads??
- timing clockwise or counter?
- 306?
- best place to get a rebuilt T-5
- Aluminum Flywheel
- Everything needed to put in a 331 stroker
- The Right Fuel Pressure?????
- Your opinions please?
- Sending Unit Question
- power steering pump switchout
- Push rods keep bending
- Losing Oil Pressure
- New pistons
- E-Brake Line
- Clutch cable adjustable?
- HELP... Head gasket or not?
- New Brakes
- transmission fluid
- new stang?
- Timing Advance....How Much?
- timing help?
- What are the best head gaskets?
- how rare is this?
- More Spark???
- New Clutch
- Fuel Pressure Help????
- Head job (problems)
- jist got my stang......
- 86 Mustang GT Nose replacement
- ODB I codes
- Bolt on carbed 5.0- how much power?
- CAI and MAF
- 94 cobra info
- Exhaust sound went downnnnnnnn
- FMS AC delete install
- AC system gas removal
- Stock tranny
- Slack in the throttle cable?
- Comp. Codes
- Good heads for 88 GT?
- 351w dart block
- GT vs GTS
- Underdrive Pulley Installtion
- Extra clearance for lift
- will a 86 to 93 h pipe fit on my 94?
- Motor Oil...
- AOD shifting into overdrive...
- Roller rockers,lifters etc, plz give advice?
- AOD Kickdown Linkage?
- 5.0 to 351 TFI distributor conversion?
- 87-93 Door Moldings Problem
- Motor cutting out
- high mileage 5.0 coupe
- Will my 5.0 keep up with an IROCZ?
- Changed injectors out in Parking lot
- New Chip
- Whats a better motor?
- h-pipe question
- Leaking rear main seal
- rebuild kit...
- Tires wobbleing
- What next?
- AOD question
- What usually breaks first?
- dual throttle body,ya
- Belt idler pulley??????
- GMkiller got a question for ya???
- nitrous questions
- No Bottom End
- Automatic Stalled
- EGR valve not operating
- Will it Fit?!
- fuel pump stays on after car is shut off
- Cam Identification
- Sending Unit Install????
- bouncy bouncy speedometer
- dead battery problems
- smogging
- Transmission oil, how often do you change it?
- First modification and strong 5.0
- Castrol 20w-50+Lucas
- Got most of my parts! now for Questions
- notchback v. gt
- Is this a 28 oz flywheel?
- Can anyone help with turn signals?
- 85 t-5 tranny?
- Lifter......
- Shifting problem?
- What kind of plugs?
- Plug gap
- Twin Turbos?
- VACUUM LINE
- Under Drive Pulleys
- Holley Systemax on an 88 gt
- Water Pump broke
- Smog Pump Removal Directions.
- Injector help
- Newer H pipe, older fox
- Cant Decide
- H-pipe install
- collapsed lifter :( need suggestions please?
- Oil change question
- [Deleted]
- hard to climb past 85ish MPH
- very rough idol?
- ford racing 373? what others?
- Power Window Wiring Harness
- Going to synthetic... maybe...
- car shuting off............
- ok, poll... which exhaust sizes are better for my motor?
- need help with headlights plz!!!
- Better cam?
- Roller Rockers
- DOES ANYONE HAVE A 1976-77 V8 OIL PAN?
- What's a wrecked 90 GT worth?
- ruff shake
- Help please.. muffler shop trying to screw me ? 2" 2.25" for 380 horsepower ,I thought 2.5.........
- 373
- buying used motor
- lightest mustang
- Ok muffler GURUS i need advice!
- [Deleted]
- THERMOSTAT
- Lifter Noise
- [Deleted]
- Pulleys.
- ball joints???
- tranny?
- 1/4 times
- 5.0 problems
- Rear Disc Swap
- Plug gap?
- Opened up the rearend today.
- 80mm MAF not cooperating at all, help
- engine/trans problem?
- Cost for a new gear?
- What's that noise?
- should i change oil weight????
- mobil 1 vs. valvoline
- New Seats
- Removing Air Pump
- rearend?
- Fuel line question ???
- How much HP to run mid 11's???
- VACUUM HOSE
- Redline
- new engine
- what does the weight of the oil.....
- i dont get emails
- My T-5 comes out of second when im driving
- Gas Mileage
- dual exhaust
- roller lifters
- Launching a AOD car.
- what oil weight??
- Which heads for my application
- Timing RPM
- Smog Pump Removal
- Steeda firewall cable adjuster question
- my first 180
- Tranny problems !
- How much hp stock axles can handle?
- HOW MUCH????
- Professional Products
- Tranny Cooler
- Actual horse power?
- Speakers
- F'ed up my car!!!
- Can Stock Gt-40p heads handle Egrind
- Which sounds better ?
- 17inch Bullet rims
- cooling fan question
- Broke my @#$@#$@# heater core!
- longtubes
- help with brakes
- Ignition or h/i/c
- how many?
- Trick Flow or Dart
- MY 250 H/P JETS ARE IN.
- O2 and MAF Sensors
- supercharger?
- AOD to T-5 swap
- 5.0 vert top
- How are these heads?
- Engine Rebuild
- aod to t5
- 351 clevland heads on 302
- Crane 1.7 rockers
- What Size Belt??? Adding Pulley?
- Idler Tension Pulley
- will these Tbird parts interchange
- clutch cable
- How much can 19lb injectors handle?
- Help Please!!!!
- Max Hp for stock maf and injectors
- NEED BETTER PERFORMANCE
- AC delete
- ATTENTION OLDSCHOOL GEARHEADS!
- X303 Camshaft
- Cam and valve clearance help
- what to look for on a used vortech
- Pro 5.0 Shifter question
- BBK headers
- URGENT : wiring diagram 90-92 hazard switch
- Idling question
- Spark plug info
- 351 conversion worth the time/money?
- Emissions, Yuk!!!!
- smog bypass belt size (not a question...back on track)
- Code scanner
- Do you have to take out the seat to change a Quadrant?
- New clutch problem
- Upper and lower radiator hoses
- Building Bottom End
- 5.0 FUEL RAIL
- change wires or coil?
- THREAD SIZE
- 83 stang gt, 88 lx 5.0 Help!
- wireing diagrams?
- Looking for tech manual
- nos bottle warmer install how to
- best spark plugs and wires??
- 88 5.0 GT Exhaust
- Car running like hell
- Talk to me about aluminum flywheels
- Timing marks.
- oil pump drive shaft
- DISTRIBUTOR MODULE
- Pulleys question
- need help tunning my stang!!!
- nice mods w/rebuid q?s
- Which intake is the best for an '88 5.0?
- howl from rear
- Recalibration Speedo?
