PDA
View Full Version : 5.0L (1979-1995) Mustang
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 [303] 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331
  1. yes i broke a valve spring
  2. clicking
  3. where to buy 5.0 91 LX Gauge cluster?
  4. Tranmission suggestions...
  5. New 88 GT w/T-Tops!!!
  6. Fuel Pressure
  7. Limited Edition 5.0?!?
  8. Newbie Here. Few Q's Too
  9. Subframes
  10. part throttle hesitation
  11. CHeck Engine
  12. GT40 P Heads
  13. Question??????
  14. 96 cobra engine
  15. what the hell does the compression numbers mean?
  16. what the hell do all these different gear numbers mean?
  17. HOW DO YOU CLEAN OUT WATER IN HEADLIGHTS?
  18. '94 V6-302 swap
  19. speedo gear swap out problem
  20. HEADLIGHTS REMOVAL!!
  21. Spark plug wire setup and sparkplug setup help!!!
  22. Hey Roundman- I have Q's!!
  23. 95 cobra fuel pump
  24. smog pump eliminator
  25. how about them guages?
  26. Tune up question.
  27. quick ? about fuel pressure- need advice ASAP !!
  28. what is this?
  29. fuel pressure gauge
  30. Best spark plugs for edelbrock heads
  31. Radiator Leak...
  32. igntion and battery problem
  33. fuel pressure
  34. Sorry, another "how much HP" thread
  35. speedo recalibration
  36. What the F*ck...stupid missing problem...
  37. connecting rod bearings
  38. New Project, whats ur opinions???????(long)
  39. Overheating
  40. Just got 4.10 gears for my b-day!!
  41. x-pipe problem...
  42. What to clean the heads with?
  43. changing my wires and distributor
  44. blown head gasket???
  45. Mustang Idle Problem Fix
  46. whats your gas mileage?
  47. tps ???? i cant figure it out
  48. hey guys, my burnout too
  49. Power steering brackets
  50. need the lower part of my center console
  51. i want a cold air intake, any suggestions?
  52. is it bad to relocate a battery in the back of a hatch?
  53. anyone know about idle problems?
  54. 86 fox worth 1000 dollars??
  55. running rich
  56. Looking for some advice/help
  57. Subframes are in!!111one
  58. 1/4 window question again.
  59. Intake Question?
  60. how many Quart's of oil...
  61. Manual trans rebuild prices
  62. Stock Airbox with K+N filter vs. K+N cone filter
  63. Is this a good price for Head Installation?
  64. License Plate
  65. Engine Swap
  66. Lets see those engine compartments
  67. being a ford....wont start
  68. HOW TO REMOVE 1/4 WINDOWS???
  69. building a mustang
  70. Pics of your Cars
  71. what do u guyz think of this....?
  72. anyone using ajustable shoks??tokiko??
  73. 6A ignition box
  74. BATTERY DEAD AGAIN!!!!
  75. intakes and stock hood
  76. got a new daily driver
  77. Ever been screwed by someone on eBay? Check this out....
  78. Any NYC members?
  79. intake
  80. How many DIY head porters out here?
  81. I called up moroso in west palm beach...
  82. which speedo to get
  83. First step in waking up a 351W??????
  84. UPR x-pipe & CAI
  85. Fuel pickup question
  86. compression test...
  87. trick flow engine kit help
  88. shift lever
  89. WHY R MY SPARK PLUG WIRES BURNING OUT????
  90. X-pipe question
  91. need front clip?
  92. My New Custom QA1 Coil Overs
  93. Na 5.0 power, how much?
  94. cb radios
  95. cluch packs
  96. so i was thinking....
  97. T-5 gears in trans
  98. Heads
  99. got a deal on gears... need info!
  100. my new exhaust.... let me no what u think
  101. gears ?
  102. speed density
  103. DOES anybody know.......???
  104. changing out heads
  105. Does anyone have rear disks on their Fox?
  106. 94 gt modification
  107. Transmission pulley?
  108. brakes, little to big
  109. finally got some pics
  110. installing longer wheel studs
  111. UPPer intake quesiton
  112. Whats the combustion chamber size on a stock E7TE head?
  113. 5.0 HO build
  114. Straight Piping
  115. LOL thats static!
  116. DiscountTireDirect = ****ing Morons
  117. New times - thoughts
  118. Variable lifters?
  119. Tired of breaking down...
  120. Why so scared of the big blocks?
  121. Pulley modifcation, whats the REAL amount of hp gained?
  122. F cam questions.
  123. rebuilt engine?
  124. REAR DISK BRAKE KIT TIPS
  125. H-PIPE
  126. anyone have any shops in the cbus ohio area???
  127. Competition enginering
  128. Has anyone use a .....
  129. Whats causing it to miss?
  130. Block
  131. looking for an H.O 5.0 engine
  132. Mufflers Which ones
  133. 1.7 Adjustments!
  134. MSD Distributor ?
  135. EFI vs. CARBURATED
  136. modification begins!
  137. C4/C6 Conversion
  138. 6spd vs 5spd Tremec
  139. egr valve
  140. Awesome news!!!
  141. performance question
  142. 96 explorer engine????
  143. steeda aerospoiler vs saleen spoiler?
  144. Castrol Synthetic or Castrol GTX for 91 stang
  145. 86 mustang vrs 86 ford econoline
  146. I want my cam to sound like this----(video)
  147. relocating battery
  148. bumping the timing?
  149. What kind of springs do you recommend?
  150. question about my slicks and stall speed
  151. Lots of questions about the 89-93 motors.
  152. Electric Fan
  153. My cars value?
  154. my first stang
  155. MSD electrical stuff...
  156. Remanufactured Motor
  157. Gauges.
  158. The IAC....
  159. Supposed to help you pass smog? (oil i think)from wal-mart..
  160. 87 5.0 FUEL PUMP RELAY LOCATION?
  161. Stock Heads
  162. step by step guide...lifters
  163. Mass Air vs. Speed Density?
  164. MASS AIR? or NO?
  165. DYNO #'S!!!!
  166. AFR w/what else
  167. Dipstick Length
  168. Identifying heads
  169. Pony Rims for Sale AnyBody?
  170. A '91 GT 5.0/302 Block bored 0.030" over equals: ?
  171. Mexican Blocks
  172. Need Help....
  173. nitrous question for a 95 GT
  174. cluch petal
  175. IAC question
  176. rebuild questions and reccomendations
  177. Is the problem a clutch cable???
  178. Ford Motorsport Springs B or C?
  179. w00t!! got all my 5-lug parts.....
  180. throttle sticks when engaged!!! help
  181. Shifting problems
  182. omg....
  183. 429 in a fox body
  184. saleen wing or cobra wing
  185. MSD Plug Wires (95 GT)???
  186. Horsepower
  187. Short Throw Shifters?
  188. was bored.. photoshopped
  189. heating driveshaft bolts
  190. Tranny build!
  191. Rev Limiter?
  192. drag racing question
  193. highbeams HELP!!
  194. Long Tubes or Equal Lenghts
  195. My Big Thread of Questions for My V8 Conversion...
  196. help!!!!!! another header ?
  197. Gears and intake
  198. rebuild yes or no
  199. ..turbo in my future?
  200. HELP!!!!!
  201. TransGo or Baumann
  202. VECI
  203. Ackward 5.0 modding question...
  204. Fuel injection upgrade, when is it needed on a 5.0?
  205. mac exhaust
  206. headers
  207. what injectors to go with my new combo?
  208. 5.0 beast
  209. Broken valve spring?
  210. 75-80 drag way
  211. Exhaust Rich
  212. AFR vs ..?
  213. Bassani
  214. Timing?
  215. GA strip
  216. STOCK NUMBERS 1/4 MILE 1986 GT VERT?
  217. What fuel pressure?
  218. rocker arms vs. the Shifter
  219. removing rear quater glass
  220. BBK SSI Intake
  221. lifter fixer stuff...
  222. 351W project
  223. Heads
  224. I have a ? about 5.0 engines
  225. Injector conversions?
  226. OIL PAN and Dipstick
  227. Oil pressure at idle
  228. FENDER MOLDING WHERE TO FIND?
  229. 1989 lacking high end.
  230. Bumper problems
  231. gas octane...??????
  232. What to Look For???
  233. HELP!!!! Won't Start
  234. TPS setting
  235. Getting Ready To Put Together!!!
  236. Lost Bolt, Need Help!!!!!!
  237. good sites
  238. TB question
  239. 05 pics and quick vid (off topic)
  240. 3 Chamber Dumps
  241. Weird Grooves in Lower Intake...
  242. Rebuild Question
  243. Head Gaskets
  244. Optima Battery
  245. missing from 700rpm to 1000rpm.....
  246. dip stick
  247. How long will the 5 liter engine last?
  248. rebuilt motor
  249. temperature guage
  250. Intake problem
