PDA
View Full Version : 5.0L (1979-1995) Mustang
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 [307] 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331
  1. stroker questions
  2. Long Tube vs Equal Length
  3. Question about turbo's and low RPM's.
  4. Turbo Manifolds ONLY.
  5. what should my RPMs be?
  6. Trying to Come Up with a Plan
  7. searching for mustang
  8. Track Updates
  9. NEED some help deciding!
  10. braided brake lines.
  11. Exhaust Recommendations
  12. Isaac's rebuild questions
  13. Surging/Dying--Rich?
  14. rpms f**ed up
  15. couple engine questions.....
  16. track tonight!!
  17. HATCHBACKS SUCK!
  18. ROLLOR ROCKERS
  19. Engine built for Turbo vs Engine built for N/A
  20. Electric Fan runs nice.
  21. What plugs to use?
  22. Firing Problem?
  23. Fuels!!!!!!!!!
  24. Time Conversion Chart
  25. water pump problem...
  26. I have no front sway bar...
  27. Mass air problems
  28. Intake Tube Quest.
  29. Pushrods
  30. Oil Question
  31. 2000 rpm idle
  32. What servo does my C-4 have?
  33. ignition timing marks (last time i swear!)
  34. U/D crank + 140 amp alt. + MrkVIII fan = ???
  35. trans. problems?
  36. 95 cobra build up
  37. squeeky belt
  38. second gear problems
  39. again...
  40. 91 LX 50 Ford Keyless Entry/Alarm Question
  41. bad news
  42. building a new 5.0
  43. new block vs. getting old one machined
  44. Torque specs
  45. weird wheel hop
  46. stockpile of parts
  47. new hair drier
  48. EGR deleta
  49. can a 88-93 mustang GT beat a 03 cobra?
  50. 3.73's and RPM
  51. Turbo kits for 5.0 BEST one???
  52. Tranny shift kit
  53. new motor
  54. Which Water Pump?
  55. Which Oil Pan?
  56. battery question
  57. ebay racing seats
  58. SHIFT KNOB THREAD SIZE
  59. corrolation between...
  60. Beautiful- check this out!
  61. hibernate and stand by
  62. is this a good intake
  63. Carb
  64. Knocking '69 5.0 302 V8
  65. price of a 92 gt
  66. 5.0 A/C question
  67. advancing timing, water pump in way!!
  68. easy k&n filter upgrade?
  69. 5 lug in rear, 4 lug in front?
  70. What shifter knobs are you using?
  71. bad news :(
  72. What do YOU run?
  73. Fuel Pump Stopping
  74. have you seen this?
  75. Shock??
  76. LITTLE SIDE SHOCKS 8.8 REAR
  77. 3.55's or 3.73
  78. Idling problem
  79. Planned build
  80. Sweet Deal...
  81. Weird Revv........
  82. First Ever Track Times...Thoughts
  83. should i use rtv gasket on my upper to lower intake and TB with gaskets?
  84. stock 93 cobra throttle body.. is it 65mm
  85. Short shifter....?
  86. aftermarket bbk tach
  87. belt size?
  88. Engine swap question.
  89. lower control arm issues
  90. Speedometer on crack?
  91. delta flow vs super delta flow?
  92. Alternator options
  93. Spark plugs % spark plug wires
  94. CAR'S BACK TO NORMAL..THANKS TO YOU GUY'S
  95. excessive crankshaft endplay
  96. Back from the track
  97. Delta Flows
  98. 94 rear end under 79
  99. Apex S-afc on a mustang?
  100. Trans problem
  101. Help me choose exhaust system
  102. new guy with v8 ranger
  103. Help with Horn please
  104. Trouble shooting.Need Roundman.
  105. Very very strange belt size...
  106. Where can I purchase Blower sleeves?
  107. notihng big just baught a new car
  108. AFR 185 piston/valve clearance issue?
  109. 8.8 rear end ?'s
  110. posi
  111. Are They Ford Racing Gears?
  112. I'm thinking of buying a TwEECer.
  113. Possible rocker problem
  114. Idle Problem
  115. Need a good nitrous cam!
  116. bypassing factory wiring
  117. 94GT Alum Heads and Cam..WHAT TO BUY
  118. 94-04 mustang/gt parts for sale
  119. 94 gt for sale
  120. What is this cam??? Please help
  121. Quick Question
  122. computer piggybacks/pms?
  123. N20 Question
  124. What should I do?
  125. replacing alternator
  126. help please!!!
  127. Top end vibrations are drastic.
  128. how hard is it to....
  129. Summit SFI Balancer ???
  130. UPS man bears gifts!!
  131. how much would you pay
  132. Rear end gear installation
  133. Are the optima batterys worth the money
  134. 92 Black GT
  135. Probably going to the track..need advice
  136. Virgin 5.0
  137. Atempted to RIP ME OFF!!!!!!!
  138. 88-93 ? or 94 or 95?
  139. NEED HELP W/ 92 PATROL UNIT
  140. NEED HELP W/ 92 PATROL UNIT
  141. Help with PERF. Parts
  142. Do you live in California?
  143. Window Tints
  144. 1/4 mile times
  145. PCM
  146. Here's a guy who love his Pony Car
  147. insurance
  148. B-303 vs. E-303...vs. SMOG?
  149. nasty yellow headlights
  150. mass airflow on 87's??
  151. BBK Air Intake, not manifold
  152. is there supposed to be a gasket here?
  153. WHICH REAR EATON OR DETROIT LOCKER
  154. freaking tach
  155. New rotors
  156. Help Cheating Emission Testing
  157. cam ??
  158. help with additions
  159. What size Injectors Do I use ?
  160. THUNDERBIRD or mustang
  161. price of a 1992
  162. how mcuh should i be looking to spend?
  163. Best Intake and Carbs
  164. price of a 87 ford mustang lx
  165. Will 275/40-17's Nitto DRs fit on the rear...
  166. U.K Member Needs Help '66 OR '73?
  167. Heater Core Bypass
  168. Gas mileage...
  169. Trade 5.0 for 351w?
  170. REAR SEAT DELETE
  171. Intake Opinions
  172. racing parts
  173. Which is the best year?
  174. will this do anything for me?
  175. clutch problems
  176. .032 big difference for cam profile??
  177. rear end setup
  178. is there a cheap way to get rid of rev limiter
  179. No rev limiter...
  180. BBK 70mm throttle body
  181. 65mm tb enough?
  182. power steering?
  183. Header bolts
  184. Roller Rockers
  185. More Horsepower
  186. Pulleys??
  187. overheating problem.......maybe??
  188. 70mm TB good w/ 73mm MAF?
  189. Trick Flow Heads
  190. Is there a fix for this design flaw in 87-93 mustangs?
  191. is it really worth it?
  192. Games/models of 5.0 Mustangs??
  193. Performance and Suspension?
  194. Porting
  195. Borg Warner O2 sensors compare to Bosch?
  196. Shortage Issues! Please help!!
  197. 8.8 rearend help
  198. cooling fan
  199. Unsure of what to do
  200. I Need Opinions....
  201. Clutch Question
  202. Clearance ?'s
  203. best intake recommended for a 91 GT HB
  204. Emissions
  205. Engine Bulidup
  206. GEARS
  207. Oil
  208. deq??? in wash. wahh?
  209. How long do street slicks last?
  210. belt size for excluding ac and air pump??
  211. Engine turns, no start!
  212. DR Qs
  213. real quick timing question
  214. Who makes the best X Pipe that will fit long tubes?
  215. Overheating
  216. how much power out of this 347 combo?
  217. 3.55's or 4.10's
  218. for those with Kenne Bell
  219. wheel size affecting launch?
  220. adj. clutch quadrant?
  221. new guys car second try
  222. looking to buy 5.0
  223. New guy, heres my car
  224. initial timing
  225. What should my car Idle at?
  226. anyone know where I can
  227. anyone know where I can
  228. ignition problem, need help!!!
  229. 91 5.0...Fair price???
  230. Trans bezel, metal ring or not
  231. sealing head and intake bolts
  232. Rear Gears!!
  233. Kumo tires
  234. Im Disapointed...
  235. Good Deal
  236. fuel pressure dropping... need your help
  237. nitto ?
  238. car stalls when stopping or turning fast
  239. a Question about rebuild on engine
  240. stock clutch cable w/ headers?
  241. Dbeck's Mega Bite and Upper Results.
  242. AOD time slips
  243. basic engine rebuild
  244. Oxygen sensors
  245. Long Tube Headers
  246. Fly wheel for a budget
  247. Max power on stock tranny?
  248. Where to go from here
  249. who gets the best mileage
  250. alignment with new springs
