PDA
View Full Version : 5.0L (1979-1995) Mustang
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 [242] 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331
  1. where can i find trick flow heads
  2. 110 Octaine
  3. Motormount replacement difficulty?
  4. H, X, Pro Chamber Pipes
  5. sea foam
  6. Radiator Help Please
  7. Broke my glove box :(
  8. Off to the Junkyard....quick question!!
  9. Production #'s
  10. Horn Location?
  11. Why do auto parts sites say i have a AOD-E in my 93 GT ?
  12. running hott and acting sluggest
  13. New exhaust system
  14. A quick question...
  15. fuel pressure for spray
  16. Headlights...
  17. Anyone with a SN95 and roller rockers?
  18. replacing thermostat
  19. will it work?
  20. Hood pins
  21. Trouble when going around a right curve
  22. Performance Alignment
  23. switching engine with a 87 thunderbird any suggestions?
  24. Springs on a 95?
  25. Question on MAS electronics
  26. shifters
  27. Headers Question
  28. back seat remove
  29. Throttle body question
  30. im sure this is a dumb question
  31. Production Figures of 1991 Mustang Gt ?
  32. steel hood
  33. So what could it be
  34. blue heater hoses really needed?
  35. Your Shifter Preference?
  36. 1st post, seeing if yall have had same problems
  37. rebuilding
  38. Tailpipe hanger broke
  39. starter problems
  40. Compatibility
  41. 5.0 6spd?
  42. Heads: Edelbrock Victor??
  43. how does higher timing..
  44. Getting more performance
  45. Octane levels
  46. comp cams
  47. Blower problems, Please Help!
  48. Lentech Automatics
  49. AFR 165cc or 185cc
  50. Now Bad News plz help
  51. speed
  52. Mass Airflow Question
  53. APC seats install
  54. 95 5.0 mustang gt hp
  55. Coolant in the oil
  56. Tach Problem....
  57. v8 swap complete :-)
  58. Putting new Halo Headlights on my 94 mustang. Wiring question...
  59. overheating then runs fine
  60. Fawk! I what a crappy day...Sour Milk and Belt Dressing!
  61. Stiff Clutch
  62. WHERE DID YOU GUYS HOOK UP MECHANICAL OIL PRESS AND WATER TEMP GUAGES UP?
  63. new pictures 86 GT convertible
  64. rear gear install
  65. About to buy new headlights, Quick question!
  66. belt size
  67. heads question
  68. What valve covers do I need???????
  69. What valve covers do I need???????
  70. Rearend build
  71. mass air question
  72. Water pump & Timing cover ?
  73. might not be soo bad
  74. Which headers
  75. FMPP Cams-->
  76. do u know about these rims?
  77. Cant close hatch...dont know whats broke.
  78. My first exhaust clip
  79. EMERGENCY!
  80. Door Hinges-->OEM??
  81. 6-71 8-71 blower
  82. May Be Buying NOS... Today? (JUST BOUGHT IT)
  83. GT & HO
  84. 87 vert back seat removal
  85. Stupid Post.
  86. Motor rebuild
  87. whats the diff in a non (ho) block & a ho block
  88. Wut u think bout dis 5.0
  89. 18 inch bullits on a blue lx how you guys think it will look and if there would be any problums???
  90. carfax
  91. x-pipe
  92. Will a 95 T5 fit my 92?
  93. Another Problem...Fed Up!
  94. 5.0 power
  95. ...
  96. Might just be wishful thinking
  97. Got a new pony
  98. looking for a cam
  99. Replaced Convertible Top on 90 LX
  100. might be geting another pony!
  101. valuable rear end/speedo info
  102. Tranny problems
  103. What Spark Plugs?
  104. Choosing brakes.. Need help!
  105. Shaking while braking
  106. SVO front rotors
  107. whats is better?
  108. wats up with my ignition?
  109. Brakes staying locked up after take off
  110. Plug wire set & brakes
  111. used 95gt vortech supercharger-a few Q's
  112. fan help
  113. need some help!
  114. Anyone not running a front sway?
  115. A little Geo Prisim goes a long way......
  116. anyone read this book?
  117. brake question
  118. Timing Cover? help pls!
  119. what should i do?
  120. a/c doesnt work
  121. ok i give up no luck, help?
  122. HELP!!! are consoles different
  123. differences between 5.0 notch and GT hatch, ratios, strength etc. ?
  124. 4.10's??
  125. sputtering
  126. ticking noise
  127. What is the best year Mustang made after 1980?
  128. Anyone have this?
  129. Timeslips
  130. 88-93 hatchback
  131. what do you think about these torque box reinforcements?
  132. low budget performance
  133. 5.0 Question
  134. HELP!!!automatic consoles and manual
  135. Safety Question
  136. 5.0 swap into a 99
  137. 4.10 gears and stall converters
  138. So I have $800 to spend at Summit... couple questions so help me out!!!
  139. anybody else ever had this thought ?
  140. Some clutch talk
  141. Steeda Tri Axe Shifter
  142. what size tires to get
  143. Tech question
  144. Check out this combo!!
  145. Stock AMP
  146. fox body vert dash wiring questions
  147. aod to c4
  148. aod to c4
  149. 1/8 to 1/4 guesses
  150. aod to c4
  151. Truck EFI
  152. quick oppinion
  153. Well it happened...
  154. WELL I FIGURED OUT MY IDLE PROBLEM.NOW WHAT?
  155. Fuel Pump
  156. Wont Start!! HELP!!!
  157. tach
  158. 5 lug conversion
  159. 1994 Mustang GT Add Horsepower
  160. Supercharger
  161. GT40P question...
  162. suspenstion setup ?
  163. Think i found an engine?
  164. aod 'beefing up" plans
  165. Coolant Leak
  166. Need a new radiator!!!
  167. Hoods?
  168. fuel rails
  169. Compression ratio help
  170. About to buy seafoam.
  171. 85 merc capri 5.0
  172. 1st Gear/Reverse Grinding
  173. What years
  174. 140MPH cluster swap
  175. good swap victim?
  176. Best way to clean a.......
  177. Pics of the stuff I installed yesterday
  178. MOVED: 351Cleveland Swap into Fox Mustang, Whats involved?
  179. Valve Covers and Heater Core
  180. Should car be loaded to install Sub frames?
  181. 6al question
  182. still won't start...
  183. fuel psi level.....
  184. Air Bag Module
  185. could i please a a carfax?
  186. EBC Green Stuff VS Hawk pads
  187. 5.0 problemss
  188. Headers
  189. Quetion for tech heads out there
  190. My new 5.0 LX Notch
  191. Rear control arms
  192. Control arms
  193. Clutch way to stiff
  194. New Clutch
  195. Flywheel question
  196. Fully loaded 1995 GT vs. a GTS. How much difference between the 2?
  197. starting/ timing problem
  198. Damn car
  199. Horrible Noise
  200. Crazy Sound
  201. AOD Transmission trashed? Couple questions...
  202. First 1/4 mile run!
  203. 50,000K motor for 50 bucks>>>
  204. Can anyone help me out with a carfax?
  205. PICS of new rims on car.
  206. Im having Hood issues
  207. Everything is in....
  208. Loud Clicking Noise
  209. any ideas?
  210. did I do good or not?
  211. Found some stuff, you guys think this is a good deal?
  212. street machine rebuild
  213. Axle Questions
  214. Gotta love the 5.0
  215. Whoa!!
  216. how long would this take on average???
  217. Tires?
  218. An actually new question to you guys...
  219. Finally done and a smooth idle!
  220. ??Code 31: EVP or PFE Circuit below minimum voltage??
  221. tranny swap
  222. fuse box
  223. Airbag Replacement
  224. how does this happen?
  225. slp exhaust help
  226. exhaust leak
  227. Ash tray
  228. cops got me!
  229. how rare is my color combo?
  230. 94-95 belt routing
  231. How many get abused by their women...
  232. Disturbance in the Force...
  233. Just got my first 5.0
  234. fuel pump ?
  235. 95 cobra v 95 cobra svt
  236. wheels and tires.....
  237. She's In A Coma
  238. MOVED: Zex nitrous kit...
  239. carb vs efi
  240. Torque specs for oil drain plugs?
  241. clueless and need some opinions
  242. Front strut replacement
  243. cobra vs gt!
  244. so i tried the..
  245. Fox Notches ... Ugly or Beautiful
  246. What Is This Part Called??
  247. 5.0l Rebuild/Engine Manual
  248. Today's the day 6/10/06
  249. does this sound right?
  250. New Pullies. Need help
