- quick q
- No Spark and No Fuel Pressure
- Found my Donor car
- computer
- my car is ****ed
- tires
- Carbed 95GT questions
- 2 different questions.
- What should i do with this?!
- charging issues
- H-pipe question
- newb question...
- motor mounts
- Will f303 cam work with 1.7 r.r.??
- machining the block...
- car sits a little high in the front after 5 lug swap?
- Cam choice help
- Power increase with GT40p's?
- thinking about going to carb.
- maf problems
- Anyway to tell if I have stock gears or not?
- A/F Ratio
- How do you get away with an o/r mid pipe?
- Professional products balancer
- I know nothing about suspension
- Temp
- Long tubes on a 94 mustang
- 1994 cobra computer
- Cam
- electrical problem cant figure it out help!!!
- MOVED: What to do, what to do...
- ride start an AOD??
- runnin a lil hot help
- What do you guys think??
- Crazy mid-range top end with CEL on...
- where the o2 sensors start at?
- Caster Camber Plates
- overheating.. new waterpump?
- 5.0 differences??
- how to correctly purge a coolant system
- I used friends gtech and ran 15.9 at 94mph
- AOD Shifting Hard
- header gasket problems
- 3 questions
- clutch, oil leak
- GTS Missing
- Gas Gauge
- Tranny Issue!!!
- Stalling Issue!!!!
- hows my setup?
- big block
- GT-40 Head Install Question/Future Issue???
- drag rad. tire press.???
- and boom goes the water pump
- My guesstimation on power turn.
- AODE Tranny
- important question please help!
- camshaft help
- FYI...FUEL PUMPS
- fuel pump??
- differnce in Spyder intake and spyder 2 intake???
- big block vs small block
- CAMSHAFT?
- 1.7 RR's
- shorty header issues
- ECM and Wiring Harness
- MOVED: 351w NOOB Questions!
- elictrical problem
- MAF on an 87
- what strut tower brace fits the best
- contemplating on a happier note
- Cobra Axles Help
- ud pulleys
- Driveshaft bolts
- low oil light
- Where can I get a cheap rear seat delete?
- School project: sensor locations
- Anything wrong with this short throw shifter or one similar to it?
- Brake line help what am i doing wrong?
- LM 1's or LM 2's
- Stage 8 Locking Header Bolts???
- 1987 Mustang GT T-Top 5.0
- small amount of smoke coming out of oil dip stick?
- electric choke
- High Idle?
- breaking up after 2500 rpms...
- eh, contemplating...
- Engine Shake
- what do i need for c4 install?? help
- How do you remove idler pulley?
- Motor blocks 5.0-5.8
- Damn fuel line pooped off
- MAF differences???
- timing
- um wtf backfire?!?
- check engine light ?
- Maf questions
- what heads for best performance?
- GT to LX
- Full Exhaust (Headers midpipe Catback)
- Missfire?
- size of factory 95gt Maf
- Great Resource for Wiring Diagrams...
- flowtech vs. bbk headers
- 1994 Mustang 3.8L to 5.0L
- compression ratio question
- Got back from track with M/T's
- a/c ASE
- Vacuum Identification Clarification
- Diablo Chip......Opinions please??
- AFR HEADS 185cc..opinion
- SMOG PUMP ELIMINATOR
- Weld Draglites
- Wiring for a 1983 alternator.
- trick flow intake???
- Why is this grey spungy material coming out of my vents?
- need some rebuild advice
- Stock gears 1988 LX 5.0 ??
- underdrives and waterpump
- What is this called? I think it went bad!
- Clutch Cable Stretched
- Airpipe! Please READ!!
- Timing and mid pipe
- 91 four banger tranny?
- better flowing heads?
- Hey look at this!
- E Brake Install
- WTF! Now it's poppng!
- Dizzy gear and timing....
- waves a white flag...
- Brake Pressure Metering Valve
- alternator ??
- CFI to EFI?
- Fel Pro Gasket Number
- exhaust
- what kind of alternator should i get
- Testing for radiator leak
- pigtail placement on rear springs??
- new mufflers
- good deal on headers and midpipe???
- Clutch problem!?
- Pro comp heads???
- 331/347 question
- Got a 95 mustang 5.0
- rpm 2 intake
- Suspension
- headlights dont work right
- Southside machine control arm issues
- Voltage Regulator
- starting question
- MAJOR LAG????????
- Transmission
- Injector Problem
- 94 Mustang
- got her dyno'd at school
- Block Filling
- New throttle body
- Damn it, I fix something and something else breaks
- Did I make wrong choice?
- 2.3 to 5.0
- My AOD
- charcoal cannister
- 347 buildup
- Roll control on '90 GT
- which intake, injector, maf to use???
- heads question and A/C delete
- rocker adjustment
- Random CE light...
- Batterrry......BA TA REY Question
- Dash replacement?
- seem reasonable?
- EEC?
- nitrous purge questions
- tig welding tranny
- transmission fluid question
- Rubber things in heads?
- LT header battle: BBK vs. MAC
- Help FINDING A/C O RINGS FOR ALL THE LINES
- what kind of hp?
- need help on heads i got wtf are they lol
- 165 AFR's or 6 lb vortex
- what spark plugs
- Tremec poppin out of reverse
- HCI difficulty meter...
- Engine bay is gettin really hot!!
- .......i dont even know what to put
- 1.7 with B cam
- pulled codes
- Question about at the track
- What roller rockers you got?
- cooling down
- Felpro question
- Problem with my fuel gauge?
- wheel torque spec
- lugging at 1500-2500rpm
- SINGLE SILICONE HOSE
- 5.0 explorer block
- Jacking the motor....
- Distributor Gear?
- Yet another problem
- 2 different length ebrake cables, wtf?
- what else could be a 12 volt positive source?
- Fuel odour after putting in gas??
- No o2 sensors
- o2 sensors
- Front Seal leak...
- More Newb Questions
- Going to Dyno Friday-Prediction
- My 95 Mustang GT is squeaking from the engine, what could it be?
- Fog light Bracket?
- What to Do
- 93 foxbody CCRM fit in my 95 gt?
- cam
- Rear Quarter Window Remedy?
- WHAT SUSPENSION I NEED FOR 400 HP
- why not the ebay twin turbo kit?
- How much for a used H pipe?
- SS Braided Hose
- Coolant from Hell!!......help
- Car dies if I take my foot off the gas - WTF?
- check oil light
- any suggestions?
- Advice, something seems off...
- belt size for 1986 smog 5.0
- $3500 budget for motor what to build??
- Coolant leak
- Walbro GT40 260 lph in tank pumps???
- Auto tranny down shifting by itselft??
- Hurst Short Throw
- Trouble with the stang
- working out bugs
- hitting low 12s all motor who and how?
- Oh yea.
- Whats the average MPG?
- Fuel pressure gauge question
- M/T's gods gift to mustangs
- Reproduction wiring harnesses ?
- What size optima for '91?
- winter parts finally added :)
- need brake caliper bolts!?
- Finished Project 65
- heater core
- The answer to end SOME noob questions
- 5.0 question
- tranny problems
- fuel filter
- 331 STROCKER
- Putting in my New cam, Reinstalling motor.. Need help please
- OMG SomeONE PLEASE HELP ME PLEASE
- trans swap tutorial
