PDA
View Full Version : 5.0L (1979-1995) Mustang
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 [228] 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331
  1. Confused about Cobra Intake
  2. Power Steering Pump Help!
  3. Rims and Tires question
  4. at what point would my transmission give out
  5. help me out guys
  6. mounting 87 dash in 86
  7. Burping the cooling sys
  8. MOTORTOPIA
  9. Can't Keep the Doors open!
  10. Block
  11. 18x9 and 18x10 on a fox
  12. AM I HATED?
  13. Coilovers???
  14. carb question
  15. 1.6 Rockers
  16. check out this bad TT 85
  17. Radiator options
  18. Snap, Crackle, POP....
  19. 85 Mustang GT/Just hearing some opinions
  20. MOVED: 95 GT..G35
  21. heater core
  22. 70 mm throttle body and intake manifold
  23. Forgive me my five-O bretheren...
  24. I need a cup holder!
  25. Here's a good question for ya
  26. 95 cobra pics
  27. 5.0 vs 98 TA
  28. Engine Starts second turn of the key????
  29. Powerdyne came in.....
  30. starter
  31. Dyno sheet
  32. 86 GT 5 speed Vs. 99 dakota 5.9r/t?
  33. MOVED: Nitrous Oxide!?
  34. SPEEDOMETER GEAR
  35. ball joint problems!! HELP!
  36. they took my car...
  37. basic carb tuning?
  38. First cylinder head finally off .... What do u think? (UPDATE-#4)
  39. disopointed with torque converter!
  40. Water pump...
  41. up grading
  42. How Much Head is too Much HEAD?
  43. Well, I finally got a 5.0
  44. fuses
  45. A/C question
  46. TSI Ignition Module Question
  47. Intake Air temp sensor?
  48. ? about installimg a c-4
  49. NEED HELP ASAP!!!!!!!!! PLEASE...
  50. Some AOD problems
  51. Da Coupe is taking shape
  52. Question on Cats!>!?!?!?!?!
  53. EGR Cap
  54. court took my license today
  55. headers
  56. new paint on my 5.0
  57. ...
  58. 2 Friends racing TONIGHT!!!!!!!!
  59. Clutch Problem??
  60. new door handle
  61. guages?
  62. Who has these control arms?????
  63. valvebody?
  64. 5.0 clutch problems
  65. New Fuel Pump Replacment...
  66. Big thanks to SAS trucking....f@gs
  67. BIG cans of NOS powerdrink
  68. wow, 1 good thing came from F&F
  69. Godspeed torqbox
  70. challenge and fun for everyone- you guys look at this
  71. Auto trans fluid flush
  72. remember coolant in the intake....???
  73. ryan...onyx cobra
  74. What would you do?
  75. Trans Fluid in a 5 Speed
  76. Painting Manifold
  77. Is it just my car?
  78. Engine bogs down 3500-4500 rpm
  79. SN-95 hood
  80. Electrical problem
  81. drawing!// check it out
  82. i need a good launch?
  83. 40 Series
  84. aod to t5 on a budget?
  85. Removing headlight???
  86. weight of a stock 93 5.0?
  87. Question for a friend, (pricing: better control/brakes)
  88. My 'Stang vs. Cousins 'Maro
  89. Who all in here is on the bottle?
  90. 94 gt vert questions
  91. Possible set up, anyone have it?
  92. Computer chip swap
  93. 89 Speed Density Car - Info Appreciated!
  94. Solid trans and motor mounts?
  95. The Great Debate. FOX or 03/04 Cobra
  96. Carfax please?
  97. 5R55S to 5.0L Fox
  98. New pics of my sn95
  99. couple quick ?'s
  100. ****
  101. How fast can you go??
  102. AC vents
  103. heads
  104. Ok who wants to hear?(updated with vid's)
  105. tranny?
  106. Hard to start and pops/backfires
  107. 1985 Mustang GT add-ons
  108. VOTING IN THE ROTM
  109. turbo
  110. Engines dies on deceleration and idle
  111. CAR NOT STARTING
  112. BBK SSI assymbled finally
  113. trick flow setup
  114. no ac, or smog pump. belt size?
  115. sn-95 dash swap into 1989 gt vert
  116. Please
  117. E303 cam combo question
  118. old oil filter clogged
  119. Different Specifications
  120. Oil Pan With or Without Sensor?
  121. S/C ques..
  122. Trying to find a 89-92 Mustang with just body and frame..
  123. Where to place jack stands in front?
  124. My New Ride
  125. Rear end needs some love!!!
  126. Pics of my enigmatic car!
  127. car wouldnt start today
  128. MOVED: Nitrous pros and cons?
  129. suspension
  130. What to do with $1,200
  131. WELD RIMS
  132. roller rockers and cams
  133. quick question
  134. grinds bad in 2nd gear
  135. How to remove backseat???
  136. Question?
  137. REAR DIF
  138. my car is being a peice please help
  139. Getting rid of PS...what belt do I need?
  140. Computer Question...?
  141. Are External Fuel Pumps Suposed to be loud?
  142. starter problem
  143. bew rims
  144. Here's a friend I think that we'd all like to add
  145. Trans Rebuild Sucks
  146. Installing cylinder heads
  147. Saleen wing
  148. NEED HELP WITH REAR END
  149. Long crank, next day stalling in fourth then no restart.
  150. where do these hoses go?
  151. u joints
  152. New Setup
  153. Victor Jr. intake
  154. Victor Jr. intake
  155. Why 5 lug
  156. Stock Gears Vs. Aftermarket Gears
  157. Check Oil light
  158. stock cam and aftermarket heads?
  159. Pistons backwards!!!!
  160. et question
  161. Weight distribution?
  162. MOVED: 95 5.0 Vs 06 Rsx Type S?
  163. 95 spindle for 5 lug
  164. line lock question
  165. are any stangs here tubbed out
  166. A/C
  167. NEED HELP BOGGING PROBLEM
  168. another cam question
  169. New to Mustangs
  170. 95 cobra what would u pay??
  171. Which catbacks dont have a lot interior sound?
  172. set rockers on factory heads
  173. Labor estimates on installing sfc's + more?
  174. Cross Threaded Heads! UH OH
  175. GLX emblem
  176. Fixing Warped Rims
  177. Stock SN95 beat me tonight...wtf?
  178. Timing Advice
  179. What do you think it is?
  180. Thinking bout buyin...
  181. Got some codes poping up...
  182. which one
  183. Pics Of The New Motor, WOOOHOOO
  184. gauges(a/f)
  185. electrical problem i think
  186. Restoring my interior
  187. summit brand??
  188. speedo wont work?
  189. Who can tell me why my computer won't do an injector test after it puts out the codes?
  190. starter problem!!
  191. mass air , throttle body help
  192. Shot peening
  193. 331 0r 347
  194. Engine quote from DSS..
  195. Converting to capri tail lights
  196. Anyone see how big the brakes are on the Ford 500?
  197. Differnt gt40 intakes
  198. I met the 87-89 ford 5.0L calibrator/tuner
  199. For all those who helped
  200. Oil pan
  201. Which to do first?
  202. power cuts off when i hit a bump
  203. High Oil Pressure Problems
  204. Complete rearend for 1994 GT
  205. new guy here with pics of my 89 gt
  206. Subframes put on today
  207. First track visit
  208. 347 Build Need Help
  209. Value of Gears?
  210. A question about Holley Systemax upper intake.
  211. 92 notchback electrical help...please
  212. suspension
  213. Autometer Speedo
  214. Control arms stuck!!! help please
  215. what do you think?
  216. anyone in maryland rebuild transmissions?
  217. help
  218. Rockers on an '87
  219. Lug pattern for Fox body..?
  220. hook up MSD
  221. THIS is why you have to be CAREFULL on EBAY!!!
  222. New member (With Pics)
  223. 1983 mustang gt
  224. morons
  225. *EDIT* HP/Torque estimates?
  226. Intakes
  227. Winter plans
  228. I test drove the ugliest
  229. Help with parts
  230. i need a new ride
  231. Shifter Installation Help
  232. Mods besides forced induction???
  233. Who had the overheating problem, I cant find the thread.
  234. Anyone heard anything about....
  235. need as many pics of 93 cobra's and saleens
  236. t-5 question
  237. laid down some cash for my new rear
  238. jc whitney coupon for my hommies
  239. Cobra intake manifold...get one?
  240. Constant Control Relay Module
  241. 3000 rpm stall converter
  242. Sticking Idle
  243. Stock 5.0 blown
  244. gears?
  245. Looking for a project car within the next 6 months
  246. 93 wiring question! Answer if you dare!
  247. gt40-X aluminum or afr?
  248. 2 questions about POWAH!!!
  249. mods
  250. Ignition problem, need help!
